Hello everyone, i have another fun one, audi A6 with the depleted battery fault codes. the shop had replaced the alternator before my inspection. posting the logs, maybe someone can help me out with it? thank you in advance
Tuesday,12,July,2022,16:47:17:50448
VCDS Version: 22.3.1.4 HEX-NET CB: 0.4615.4
VIN: WAUL2AF29KN075353 License Plate: PUURFECT-A6
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 15 16 17 19 22 36 3C 42 44 46 47 52 5F 61 75 81
A5 BB BC C4 CA CC CF D6 D7 DE
VIN: WAUL2AF29KN075353 Mileage: 136704km-84943miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DLZA) Labels: None
Part No SW: 4K0 907 559 A HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0007
Revision: B8H11000 CVN: 2F6F2645
Coding: 0A6500122326010E34286000000400000000000000000000
Shop #: WSC 41459 003 1048576
ASAM Dataset: EV_ECM30TFS0114K0907559A 001007
ROD: EV_ECM30TFS0114K0907559A.rod
VCID: 3326E18B9AF0781702-8066
VINID: 9D195C09158225B7801C50C50C6A38481E
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 M HW: 0HL 927 156 B
Component: 0HL 30TFSINAR H01 0003
Revision: --H01--- Serial number: 0000001112 CVN: E458A77D00000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 373ED59B8E8894373E-8062
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190003000916
Part No SW: 4K0 907 379 Q HW: 4K0 907 379 F
Component: ESP9 Plus H06 0853
CVN: F8A65B53
Coding: 58AA159729A90B9B11A14896208052D2F439881AA894D08812044A4B2F9C11
ROD: EV_ESP9BOSCHCMP_AU58.rod
VCID: 43C6B14BCA50C89792-8016
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 GE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0653
Coding: 07000363C0291CCD070C87081CEF9C2A130B37110406009701010A0019331C01086909024010000000000100000300180002000004010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 77BE159BCE085437FE-8022
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001811140400437
Coding: 7DC727
Serial number: 22348406X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 C HW: 4K1 941 501 C
Component: E1 - LTM H09 0086
Serial number: 14S14.01.1900691091
Subsystem 4 - Part No SW: 4N0 907 410 B HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600368Z003602
Coding: 250000
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE115101823310946
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 E HW: 4K0 947 135 E
Component: Dachmodul H42 0413
Serial number: C00157117
Coding: 0D0104
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135527000060015698
Coding: 0A0700
405507 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[Function limitation due to energy management system]
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:29:13
average_Voltage_terminals: 11.10 V
Outside air temperature sensor-Outside air temperature on CAN: 31.00 °C
interior_temperature: 33.50 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 K HW: 4N0 959 655 K
Component: AirbagVW31 H02 2720
Serial number: 003YUM00XR6Q
Coding: BFCCF0C000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 44C4B257CF5ECFAFAB-8010
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019011026100000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019011402600000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J19000AWH6I0T
Coding: 303134
Subsystem 4 - Part No SW: ----------- HW: 480 000 701 19
Serial number: 357000000008E94C963.
Subsystem 5 - Part No SW: ----------- HW: 480 000 701 19
Serial number: 3580000000094BA0373K
Subsystem 6 - Part No SW: ----------- HW: 480 031 701 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C1C29BD0D03DFS
Subsystem 7 - Part No SW: ----------- HW: 480 031 701 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C18B38A1A0BE4I
Subsystem 8 - Part No SW: ----------- HW: 480 030 401 19
Component: FrontSensor_D 002 0149
Serial number: 355001C18F4398512DAJ
Subsystem 9 - Part No SW: ----------- HW: 480 030 401 19
Component: FrontSensor_P 002 0149
Serial number: 356001C18F4B5AD0CA8
Part No SW: 4N0 907 129 HW: 4N0 907 129
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 6E9030FFB15215FF2D-803A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 890 C HW: 4K0 920 890 C
Component: FBenUSAACC--- H11 0153
Coding: 8BE620C3A888D7050203E1609880080008002000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2E10F0FF71D255FF6D-807A
Part No SW: 4K0 907 468 J HW: 4K0 907 468 C
Component: Gateway H05 0207
Serial number: 1MF03027139101
Coding: 020100050004064054960000005B0132CC3A000710000000097D078E10000000
GVL: F1D13C000000000002DC08008000C800100C0010000000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 3B36C9ABB2A0B057DA-806E
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 741863120019011100C3
131687 - Control Module for Emergency Call and Communications
U1421 00 [008] - No Communication
[Timeout_Node_0x67_DiagAdress_0075_ConBox]
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:29:13
8519683 - Energy Management Active
U140B 00 [008] - -
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.12
Time: 16:38:26
EM_vehicle_state: 02 10
Static current shut-off stage: Deactivation stage 2
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
9502727 - Databus
[BMS_No_Component_Function]
Reset counter: 114
Mileage: 136704 km
Date: 2022.07.12
Time: 16:41:01
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
48V activation restriction-Electrical compressor: not active
16711990 - Ethernet Databus Branch 1
U122C 00 [008] - No Communication
[Ethernet_databus_no_communication_port_1]
Fault Frequency: 31
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:34:59
Ethernet counter checksum error: branch 1: 0
Ethernet counter connection interruptions: branch 1: 162
Address 22: AWD (J492) Labels:* None
Part No SW: 4K0 927 755 HW: 0CJ 927 749 A
Component: C8_DL4_N_SD2H01 0008
Serial number: 18304B0655
Coding: 110C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 72A8248FA56A311FC9-8026
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000358445766
Coding: 005C1A400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_006.rod
VCID: 79BA13A3F81C424788-802C
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 F HW: 4N0 907 566 A
Component: MRR_HR H12 0266
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651.rod
VCID: 393AD3A3B89C8247C8-806C
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS001 0188
Serial number: YE007RKS08042
Coding: 001FDB0052001480A001A030
VCID: 40CCBE47DB46D38F8F-8014
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: 94002001010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 312AEB8360EC4A0770-8064
Part No SW: 4N0 907 064 CD HW: 4N0 907 064 D
Component: BCM2 MLBevo H14 0163
Coding: 0134000049A000C0650FA0006C01000203034000810026502F0400000B04823F001E0101000011
ASAM Dataset: EV_BCM2CONTIAU651 009009
ROD: EV_BCM2CONTIAU651_009_VW53.rod
VCID: 73A6218BDA703817C2-8026
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000046098245
Subsystem 3 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11384520
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ7D008PYJ
Coding: 0185010000AAAA2FAA0000010000
Shop #: WSC 00022 444 00000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 240412D72F1EEFAF8B-8070
0600 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [008] - Open Circuit
Reset counter: 154
Mileage: 136704 km
Date: 2022.06.30
Time: 14:09:44
Voltage terminal 30: 11.2 V
0605 - Loudspeaker 2 in Double-Subwoofer
B130D 13 [008] - Open Circuit
Reset counter: 154
Mileage: 136704 km
Date: 2022.06.30
Time: 14:09:44
U1400 00 [008] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:18:49
Voltage terminal 30: 7.0 V
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS001 0188
Serial number: YE007RJH09117
Coding: 001FDB005E001480A001A030
VCID: 3FCEBDBBA6B8AC77F6-806A
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 084 D HW: 4K0 035 084 A
Component: MU-H-LNS-US 047 2711
Coding: 0185010200000000C1220002061C00302F0001E403F00804CE
VCID: 271E05DB5E2804B7AE-8072
Subsystem 1 - Part No: V03 959 804 CG
Component: MIB2P_NA_Q419 0416
Multimedia System 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00107111800060388
Compact disc data bank:
Component: Gracenote2 3007
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000250810021
Multimedia System 5:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00110121800080690
Media socket:
Subsystem 6 - Part No SW: 4N0 035 726 A HW: 4N0 035 726
Component: MediaConnectL 014 0133
Serial number: 051900000932004
B11CF 53 [009] - Deactivated
Reset counter: 114
Mileage: 136704 km
Date: 2022.07.11
Time: 13:02:40
Voltage terminal 30: 10.0 V
Satellite radio tuner status-Audio Signal: available.
Satellite radio tuner status-Antenna current: 105 mA
Satellite radio tuner status-Reception quality: good_signal
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 291A03E3483C32C7B8-807C
28709 - HV Battery Pack
P0A7D 00 [047] - State of Charge Low
[Diag_F_SOC_LL1]
Mileage: 136704 km
Date: 2022.07.11
Time: 12:33:22
28710 - HV Battery
P0B29 00 [047] - Complete Discharge
Fault Frequency: 11
Mileage: 136704 km
Date: 2022.07.11
Time: 12:33:22
Part No SW: 4K1 035 283 C HW: 4K1 035 283 B
Component: ConBox H09 0233
Serial number: 005CCA12F120261
Coding: 01C020FE4040800000
ROD: EV_ConBoxAU651_002.rod
VCID: 281C06E753360BCFA7-807C
458759 - Control Module Incorrectly Coded
U1014 00 [008] - -
[ECU_coded_wrong]
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:35:08
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0051
Serial number: 18.349 40284
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AR HW: 4N0 907 107 H
Component: zFAS Var C H09 0295
Coding: 02018600000000000033D60000F00504139D560000000000000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000070180080003000000000000000000080400000F0
ASAM Dataset: EV_ZFASAU516 001006
ROD: EV_ZFASAU516_001.rod
VCID: 0F6E4D7BD6987CF746-805A
2117692 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Databus_Ethernet_missing_PDU]
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:32:15
Ethernet signal quality: no link
282656 - Video Cable for Information Electronics 1
B13B9 01 [008] - Electrical Failure
Reset counter: 154
Mileage: 136704 km
Date: 2022.07.11
Time: 12:32:00
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS003 0188
Serial number: YE007RL518746
Coding: 000FDB0000001480E000A020
VCID: 42C8B44FD54AC19F99-8016
Component: TSG HBFS003 0188
Serial number: YE007RL521275
196738 - Motor for Child Safety Lock
B14FF 29 [009] - Signal Implausible
Reset counter: 114
Mileage: 136704 km
Date: 2022.07.11
Time: 12:32:08
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 663 HW: 4K0 959 663
Component: DCDC_GEN_2 H20 0307
Serial number: DC19026000498
ASAM Dataset: EV_DCDC48VFLEXAU581 004001
ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
VCID: 75A21F93D4042627EC-8020
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Coding: 268040058101
ROD: EV_SunRoofCONTIAU736_009_AU58.rod
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 N HW: 4N0 903 028 N
Component: BSG-HP1-65 H17 0523
Serial number: 20111800020198
Coding: 20000400000000
Shop #: WSC 31414 035 00001
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 3620D89F89826D3F25-8062
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0266
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651.rod
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H05 0031
ROD: EV_LMSLeftHELLAAU58X.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0061
Coding: 800000
VCID: 1F0E1D3B0678CC77D6-804A
End----(Elapsed Time: 01:55, VBatt start/end: 11.3V/11.2V. VIgn 11.2V)-----
