@vastechnics if the informations on this site is correct, my steering wheel module should support CCS.
Im sorry, i don't understand this reply?whatis no op slipring
I *think* it's a question asking what the part number is of the slip-ring?Im sorry, i don't understand this reply?
Oh tanks. Can i read this info from VCDS or do i need to disassemble it again to check?I *think* it's a question asking what the part number is of the slip-ring?
If it doesn't appear in an Auto-Scan then you will need to look at it physically, or is the FULL part number shown on the invoice when you purchased it?Oh tanks. Can i read this info from VCDS or do i need to disassemble it again to check?
Friday,30,July,2021,17:02:57:34728
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WAUZZZ8P56A085730 License Plate: BC62057
Mileage: 229380km-142530mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 62 72
VIN: WAUZZZ8P56A085730 Mileage: 229380km-142530miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 HW: 8P0 907 115
Component: 2.0l R4/4V TFSI G00 0130
Revision: --H01--- Serial number: AUX7Z0E9FNC066
Coding: 01030003180F0160
Shop #: WSC 06314 123 12345
VCID: 6FBBD9C86B9576F3669-803A
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High
Fault Status: 01100001
Mileage: 225788 km
Date: 2021.05.23
Time: 20:18:07
Temperature: 24.0°C
Temperature: 24.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
Component: ESP 4MOTION MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 06314 000 00000
VCID: 41DF4F700D81B083C0D-8014
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH17 0200
Revision: 250003 Serial number: 8P0820043H
VCID: 313F1FB0BD21200330D-8064
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002241810
Coding: FD8E4F019014200000000000240064000008FE135A0500
Shop #: WSC 06314 123 08192
VCID: 40D94A74068BB98BCF3-8014
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Component: Fehler Lin-Slave 02
00061 - Footwell Lights
Fault Status: 01101100
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Fault Status: 00101100
Reset counter: 227
Mileage: 228593 km
Date: 2021.07.17
Time: 15:39:00
Voltage: 11.65 V
Fault Frequency: 155
Reset counter: 220
Mileage: 213493 km
Date: 2020.06.30
Time: 15:44:00
Voltage: 11.40 V
01800 - Light Switch (E1)
Fault Status: 01101000
Fault Frequency: 30
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
02071 - Local Databus
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 00362004KGMU
Coding: 0073622
VCID: 42DD407C0887AB9BD97-8016
Subsystem 1 - Serial number: 6332DRB4023D12ACQ
Subsystem 2 - Serial number: 6342DRB4023C090BL
Subsystem 3 - Serial number: 63528RB400AA62B8R
Subsystem 4 - Serial number: 63628RB400AA6542I
Subsystem 5 - Serial number: 63729RB400BADE27/
Subsystem 6 - Serial number: 63829RB400BADE26/
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H38 0070
Coding: 0012142
01426 - Controls in Steering Wheel (E221)
01304 - Radio
00002 - Transmission Control Unit
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 TX HW: 8P0 920 930 TX
Component: KOMBIINSTR. VDO H80 0430
Revision: D07 Serial number: 2241GD07000502
Coding: 0005043
Shop #: WSC 00011 888 96745
VCID: 1B63DD18CFADBA537A1-804E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A058CCD
Coding: FD3F0342072102
VCID: 2A0D08DC90F753DBF17-807E
01304 - Radio
Reset counter: 194
Mileage: 220513 km
Date: 2020.12.19
Time: 11:24:33
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 B
Component: HALDEX 4Motion 0107
Coding: 0000001
VCID: 2C010EC49A034DEB03B-8078
Revision: D07 Serial number: AUX7Z0E9FNC066
Shop #: WSC 31721 133 80545
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000144
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D10BCB8271B1B497-8066
02546 - Steering Limit Stop
Mileage: 9360 km
Temperature: 19.0°C
Voltage: 11.80 V
Voltage: 11.60 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505488F016300
VCID: 3E25348C7C7FCF7BBDF-806A
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674526177563
VCID: 71BFDFB07DA1600370D-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000144
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Coding: 0000012
VCID: 3D2733807179D463A45-8068
Address 56: Radio
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
Friday,30,July,2021,17:05:08:34728
Mileage: 225788 km
Date: 2021.05.23
Time: 20:18:07
Temperature: 24.0°C
Temperature: 24.0°C
Voltage: 11.938 V
Voltage: 0.000 V
Revision: 00T12001
Coding: 0021122
Coding: 00062736
Shop #: WSC 06314
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Reset counter: 227
Mileage: 228593 km
Date: 2021.07.17
Time: 15:39:00
Voltage: 11.65 V
Reset counter: 220
Mileage: 213493 km
Date: 2020.06.30
Time: 15:44:00
Voltage: 11.40 V
Fault Frequency: 30
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Reset counter: 194
Mileage: 213493 km
Date: 2020.06.30
Time: 15:41:00
Voltage: 11.55 V
Coding: 0073622
Coding: 0000042
01304 - Radio
Coding: 0005043
01304 - Radio
Reset counter: 194
Mileage: 220513 km
Date: 2020.12.19
Time: 11:24:33
Coding: 0000001
Coding: 0000144
Mileage: 9360 km
Temperature: 19.0°C
Voltage: 11.80 V
Voltage: 11.60 V
Coding: 0000144
Coding: 0000012
Address 56: Radio
Coding: 0000144
Coding: 0000144
End----(Elapsed Time: 01:09, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
I think on this car, it's done/stored in the ABS/ESP module, like this:Is the information for the Steering Angle Sensor stored in the Steering Wheel Module, so i need to recalibrate this after changing my Steering Wheel Module?
