Hey
I have some problems retrofitting Cruise Control in my Audi A3 8p.
I have installed the new stalk 8P0 953 513 D.
I then coded first the steering wheel electronics:
1. 16 - Steering Wheel
2. 07 - Coding
3. Changed my coding from 0000012 to 0000042
Since i went from board computer without Cruise Control to now having Cruise Control
Options
0 = no Board Computer, no Cruise Control
1 = Board Computer, no Cruise Control
2 = no Board Computer, Cruise Control
4 = Board Computer, Cruise Control
I then went to code the engine control. My "Coding II" was greyed out, and after some research i found that i should use "Long Coding" for mine instead. cf. http://wiki.ross-tech.com/wiki/index.php/2.0l_TFSI_(AXX/BGB/BPJ/BPY/BWA)#Coding
So i went into the long coding helper, scrolled to bit 6, and checked off "Cruise Control installed"
But my cruise control still doesn't work, and now i have a fault code on 16 - Steering wheel saying Incorrectly Coded
Is it possible that i need to open 16 - Security Acces with a code in 01 - Engine, to acces "Coding II" and then code it as normal by using the password 11463.
Here is my AutoScan before and after the coding (Sorry for possible misspelling, it is translated from Danish to English via Google Translate)
Before
After
2. 07 - Coding
Options
Before
Sunday, May 23, 2021.13: 03: 22: 34728
VCDS - Windows based VAG / VAS emulator - Runs on Windows 10 x64
VCDS version: NEZ 21.3.0.0 HEX-V2 CB: 0.4543.4
Data version: 20210319 DS325.0
www.vcds.dk
Frame number: WAUZZZ8P56A085730 Registration no .: BC62057
Mileage: 225780km Repair order:
Model Type: 8P (1K0)
Search: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 62 72
Frame number: WAUZZZ8P56A085730 Mileage: 225780km
00 Steering Angle Sensor - Status: Ok 0000
01-Motor - Status: Malfunction 0010
03-ABS brakes - Status: Ok 0000
08-Air conditioning - Status: Ok 0000
09-Centralelektr. BCM1 - Status: Malfunction 0010
15-Airbags - Status: Ok 0000
16-Steering Wheel Electronics - Status: Ok 0000
17-Instrument - Status: Ok 0000
19-CAN Gateway - Status: Malfunction 0010
22-4 Wheel Drive - Status: Ok 0000
25-StartSafe - Status: Ok 0000
42-Door Electr. V for - Status: Ok 0000
44-Power Steering - Status: Ok 0000
46-Comfort Electronics - Status: Ok 0000
47-Soundsystem - Status: Ok 0000
52-Door Electr. H for - Status: Ok 0000
55-Light Length Law. - Status: Ok 0000
56-Radio - Status: Can not be contacted 1100
62-Door Electr. V bag - Status: Ok 0000
72-Door Electr. H bag - Status: Ok 0000
Control unit 01: Engine Explanation file:. NEZ \ 06F-907-115-AXX.clb
Control unit no: SW: 8P0 907 115 HW: 8P0 907 115
Component: 2.0l R4 / 4V TFSI 00 0130
Revision: --H01 --- Serial number: AUX7Z0E9FNC066
Coding: 01030003180F0060
Dealer: WSC 06314 000 00000
VCID: 6FBBD9C86B9576F3669-803A
1 error found:
000568 - Charging pressure sensor (G31)
P0238 - 001 - Signal too strong
Freezer frame data:
Error status: 01100001
Error priority: 0
Error rate: 1
Resets: 255
Time indication: 0
Freezer frame data:
RPM: 0 / min
Last: 0.0%
Speed: 0.0 km / h
Temperature: 9.0∞C
Temperature: 11.0∞C
Absolute pressure: 1010.0 mbar
Volt: 11.557 V
Control unit 03: ABS brakes Explanation file: NEZ \ 1K0-907-379-MK60-A.clb
Control unit no: SW: 1K0 907 379 R HW: 1K0 907 379 R
Component: ESP 4MOTION MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 41DF4F700D81B083C0D-8014
No error codes found.
Control unit 08: Air conditioning Explanation file: NEZ \ 8P0-820-043.clb
Control unit no: SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: Climate Vending MachineH17 0200
Revision: 250003 Serial number: 8P0820043H
VCID: 313F1FB0BD21200330D-8064
Control unit 09: Central electr. BCM1 Explanation file:. NEZ \ 8P0-907-279-23-H.lbl
Control unit no: SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002241810
Coding: FD8E4F019014200000000000240064000008FE135A0500
Dealer: WSC 06314 123 08192
VCID: 40D94A74068BB98BCF3-8014
Subsystem 1 - Control Unit No .: 8P1 955 119 B Explanation file: NEZ \ 1KX-955-119.CLB
Component: Wiper AU350 H01 0130
Coding: 00062736
Dealer: WSC 06314
Subsystem 2 - Component: Error Lin-Slave 02
6 error codes found:
00061 - Footroom lamps
012 - Electrical fault in circuit
Freezer frame data:
Error status: 01101100
Error priority: 5
Error rate: 1
Resets: 52
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
01518 - Bulb for left rear light (M16)
Freezer frame data:
Error priority: 2
Error rate: 1
Resets: 52
Mileage: 225788 km
Time indication: 0
Date: 2021.05.23
Time: 12:47:00
Freezer frame data:
To
Volt: 11.35 V
To
To
From
From
From
01519 - Bulb for right rear light (M17)
Freezer frame data:
Error priority: 2
Error rate: 145
Resets: 52
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:44:00
Freezer frame data:
To
Volt: 11.40 V
To
To
From
From
To
01800 - Light switch (E1)
008 - Unrealistic signal
Freezer frame data:
Error status: 01101000
Error priority: 3
Error rate: 28
Resets: 52
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
02071 - Local data bus
004 - No signal / communication
Freezer frame data:
Error status: 01100100
Error priority: 2
Error rate: 1
Resets: 52
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
01520 - Rain and light sensor (G397)
Freezer frame data:
Error priority: 2
Error rate: 254
Resets: 52
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
Control Unit 15: Airbags Explanation file: NEZ \ 8P0-959-655-94.lbl
Control unit no: SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial Number: 00362004KGMU
Coding: 0073622
VCID: 42DD407C0887AB9BD97-8016
Subsystem 1 - Serial number: 6332DRB4023D12ACQ
Subsystem 2 - Serial number: 6342DRB4023C090BL
Subsystem 3 - Serial number: 63528RB400AA62B8R
Subsystem 4 - Serial number: 63628RB400AA6542I
Subsystem 5 - Serial number: 63729RB400BADE27 /
Subsystem 6 - Serial number: 63829RB400BADE26 /
Control unit 16: Steering wheel electronics Explanation file: NEZ \ 1K0-953-549-MY8.lbl
Control unit no: SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Link module 034 0070
Coding: 0000012
VCID: 76B5ECAC14CF473BA5F-8022
Control unit 17: Instrument Explanation file: NEZ \ 8P0-920-xxx-17-MY7.lbl
Control unit no: SW: 8P0 920 930 TX HW: 8P0 920 930 TX
Component: KOMBIINSTR. VDO H80 0430
Revision: D07 Serial Number: 2241GD07000502
Coding: 0005043
Dealer: WSC 00011 888 96745
VCID: 1B63DD18CFADBA537A1-804E
Control Unit 19: CAN Gateway Explanation file:. NEZ \ 1K0-907-530-V1.clb
Control unit no: SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A058CCD
Coding: FD3F0342072102
VCID: 2A0D08DC90F753DBF17-807E
1 error found:
01304 - Radio (R)
Freezer frame data:
Error priority: 2
Error rate: 254
Resets: 52
Mileage: 220513 km
Time indication: 0
Date: 2020.12.19
Time: 11:24:33
Control unit 22: 4-wheel drive Explanation file: NEZ \ 1K0-907-554.lbl
Control unit no .: 1K0 907 554 B
Component: HALDEX 4Motion 0107
Coding: 0000001
Dealer: WSC 00000 000 00000
VCID: 2C010EC49A034DEB03B-8078
Control Unit 25: Immobilizer Explanation file: NEZ \ 1K0-920-xxx-25.clb
Revision: D07 Serial Number: AUX7Z0E9FNC066
Dealer: WSC 31721 133 80545
Control unit 42: Door electr. V for Explanation file: NEZ \ 8P0-959-801-MIN2.lbl
Control unit no .: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000144
Control unit 44: Power steering Explanation file: NEZ \ 1Kx-909-144-G2V2.clb
Control unit no .: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D10BCB8271B1B497-8066
Control unit 46: Comfort electronics Explanation file: NEZ \ 8P0-959-433.lbl
Control unit no .: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505488F016300
VCID: 3E25348C7C7FCF7BBDF-806A
Control unit 47: Sound system Explanation file: NEZ \ 8Px-035-382.lbl
Control unit no: SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674526177563
VCID: 71BFDFB07DA1600370D-8024
Control unit 52: Door electr. H for Explanation file: Redirection error!
Control unit no .: 8P0 959 802 H
Coding: 0000144
Control unit 55: Light length rule. Explanation file: NEZ \ 8P0-907-357.lbl
Control unit no .: 8P0 907 357 F
Component: Dynamic LWR H01 0010
Coding: 0000012
VCID: 3D2733807179D463A45-8068
Control unit 56: Radio
Control unit 62: Door electr. V behind Explanation file: NEZ \ 8P4-959-801.lbl
Control unit no .: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000144
Control unit 72: Door electr. H behind Explanation file: NEZ \ 8P4-959-802.lbl
Control unit no .: 8P4 959 802 D
Coding: 0000144
End- (Elapsed time: 01:12, VBat. Start / end: 11.5V / 11.4V. VIgn 11.4V) -
After
Monday, May 24, 2021.19: 05: 09: 34728
www.vcds.dk
Mileage: 225820km Repair order:
Frame number: WAUZZZ8P56A085730 Mileage: 225820km
16-Steering Wheel Electronics - Status: Malfunction 0010
Component: 2.0l R4 / 4V TFSI G00 0130
Coding: 01030003180F0160
Dealer: WSC 06314 123 12345
1 error found:
Freezer frame data:
Error priority: 0
Error rate: 1
Resets: 255
Mileage: 225788 km
Time indication: 0
Date: 2021.05.23
Time: 20:18:07
Freezer frame data:
RPM: 0 / min
Last: 0.0%
Speed: 0.0 km / h
Temperature: 18.0∞C
Temperature: 21.0∞C
Absolute pressure: 1000.0 mbar
Volt: 10.795 V
Revision: 00T12001
Coding: 0021122
Coding: 00062736
Dealer: WSC 06314
Freezer frame data:
Error priority: 5
Error rate: 1
Resets: 53
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
012 - Electrical fault in circuit - Periodic
Freezer frame data:
Error status: 00101100
Error priority: 2
Error rate: 144
Resets: 85
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:44:00
Freezer frame data:
To
Volt: 11.40 V
To
To
From
From
To
Freezer frame data:
Error priority: 3
Error rate: 29
Resets: 53
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
Freezer frame data:
Error priority: 2
Error rate: 1
Resets: 53
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
02195 - Light switch - switches and instruments (E20)
009 - Interruption / Short circuit to ground - Periodic
Freezer frame data:
Error status: 00101001
Error priority: 5
Error rate: 1
Resets: 92
Time indication: 0
Freezer frame data:
From
Volt: 12.20 V
From
To
From
From
From
Freezer frame data:
Error priority: 2
Error rate: 254
Resets: 53
Mileage: 213493 km
Time indication: 0
Date: 2020.06.30
Time: 15:41:00
Freezer frame data:
To
Volt: 11.55 V
To
To
From
From
From
Coding: 0073622
Coding: 0000042
1 error found:
01044 - Control unit incorrectly coded
000 - - - Periodic
Coding: 0005043
1 error found:
01304 - Radio (R)
Freezer frame data:
Wrong status
: 01100100
Error priority: 2
Error rate: 254
Resets: 53
Mileage: 220513 km
Time indication: 0
Date: 2020.12.19
Time: 11:24:33
Coding: 0000001
Coding: 0000144
Coding: 0000144
Coding: 0000012
Coding: 0000144
Coding: 0000144
End ------- (Elapsed time: 01:11, VBat. Start / end: 12.1V / 12.1V) --------
