A3 8p Cruise Control Retrofit
   #21
RasPal
Denmark
C?ID=437325
   #22
vastechnics
C?ID=143747
As far as i know this doesnt. Correct me if im wrong.
i have checked partslink. When you try to order accesoires they give as not that it must be checked if 8P0 module is installed. So i can confirm that the module dont support
   #24
vastechnics
C?ID=143747
8P0 953 549 F. This will work 100%
   #25
RasPal
Denmark
C?ID=437325
I've looked it up, and it looks a little different from mine, mounting wise.
   #26
vastechnics
C?ID=143747
Impossible. Ive looked by your vin in partslink24
   #27
RasPal
Denmark
C?ID=437325
Will my slip-ring and other hardware be compatible with this module?:)
Will i need anything else?
RasPal
Denmark
C?ID=437325
I *think* it's a question asking what the part number is of the slip-ring?
Oh tanks. Can i read this info from VCDS or do i need to disassemble it again to check?
   #32
Trowbridge, UK
If it doesn't appear in an Auto-Scan then you will need to look at it physically, or is the FULL part number shown on the invoice when you purchased it?
   #33
RasPal
Denmark
C?ID=437325
I checked it physically, the part no. On my slipring is 1K0 959 653 D.
   #34
RasPal
Denmark
C?ID=437325
Do anyone know if this will need to be replaced?
   #35
Although I would have expected the factory installed 1K0 953 549 AF module to support CCS I believe @vastechnics is correct regarding the revised part number. PL24 lists 8P0 953 549 F as the direct replacement. Temp screen shot here:
The slip ring part number 1K0 959 653 D should be compatible.
On a side note, I did some digging. The only scans we have with 1K0 953 549 AF coded to 0000042 are from 1Z, 2K, 1T and 1K vehicles. For that reason I suspect this might be one of those cases where certain 8P and 1K part numbers (such as the ECM, stalk and/or SWCM) are not compatible with each other and 1K0 953 549 AF might have been fully compatible with CCS in a non-Audi. For instance, this stalk from a random scan is 1K0 953 513 G (not 8P0 series):
If that's correct it may explain the discrepancy here: http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
RasPal
Denmark
C?ID=437325
Ok thanks!
   #37
RasPal
Denmark
C?ID=437325
Hi again.
I've replaced the module with a 8P0 953 549 F today. But i ran into some problems. I started by doing an AutoScan, which you can see down under as AutoScan 1. But i thought to myself, that's the wrong coding. So i went into [16] an changed the coding from 0012142 to 0000042 But my fault codes didn't disappear, as you see into AutoScan 2. But that's not the only problem now both my Power Steering light and ESP-light is permanently on, and i have no power steering.
I see that i now have a fault code on my [44] - Steering assist. I know that my slip ring is in the same position as when i took the wheel off, because i have taken pictures of the wheel position, and the slip ring has 2 taps, that go into the wheel, therefore i think should be right positioned.
Is the information for the Steering Angle Sensor stored in the Steering Wheel Module, so i need to recalibrate this after changing my Steering Wheel Module?
What have i done wrong? Or what am i missing?
Furthermore my cruise control still doesn't work, but i guess that is because of the Steering Angle sensor fault.
AutoScan 1
Friday,30,July,2021,17:02:57:34728
VIN: WAUZZZ8P56A085730   License Plate: BC62057
Mileage: 229380km-142530mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 62 72
VIN: WAUZZZ8P56A085730   Mileage: 229380km-142530miles
   Part No SW: 8P0 907 115     HW: 8P0 907 115
   Component: 2.0l R4/4V TFSI G00 0130
   Revision: --H01---    Serial number: AUX7Z0E9FNC066
   Coding: 01030003180F0160
   Shop #: WSC 06314 123 12345
   VCID: 6FBBD9C86B9576F3669-803A
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High
                    Fault Status: 01100001
                    Mileage: 225788 km
                    Date: 2021.05.23
                    Time: 20:18:07
                    Temperature: 24.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.938 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 R    HW: 1K0 907 379 R
   Component: ESP 4MOTION MK60    0102
   Revision: 00T12001
   Coding: 0021122
   Shop #: WSC 06314 000 00000
   VCID: 41DF4F700D81B083C0D-8014
   Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
   Component: KlimavollautomatH17 0200
   Revision: 250003      Serial number: 8P0820043H
   VCID: 313F1FB0BD21200330D-8064
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H36 1201
   Revision: 00H36000    Serial number: 00000002241810
   Coding: FD8E4F019014200000000000240064000008FE135A0500
   Shop #: WSC 06314 123 08192
   VCID: 40D94A74068BB98BCF3-8014
   Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Component: Fehler Lin-Slave 02
00061 - Footwell Lights
                    Fault Status: 01101100
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
                    Fault Status: 00101100
                    Reset counter: 227
                    Mileage: 228593 km
                    Date: 2021.07.17
                    Time: 15:39:00
                    Voltage: 11.65 V
                    Fault Frequency: 155
                    Reset counter: 220
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:44:00
                    Voltage: 11.40 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Fault Frequency: 30
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
02071 - Local Databus
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H12 3760
   Revision: 91H12376    Serial number: 00362004KGMU
   Coding: 0073622
   VCID: 42DD407C0887AB9BD97-8016
   Subsystem 1 - Serial number: 6332DRB4023D12ACQ
   Subsystem 2 - Serial number: 6342DRB4023C090BL
   Subsystem 3 - Serial number: 63528RB400AA62B8R
   Subsystem 4 - Serial number: 63628RB400AA6542I
   Subsystem 5 - Serial number: 63729RB400BADE27/
   Subsystem 6 - Serial number: 63829RB400BADE26/
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H38 0070
   Coding: 0012142
01426 - Controls in Steering Wheel (E221)
01304 - Radio
00002 - Transmission Control Unit
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 930 TX    HW: 8P0 920 930 TX
   Component: KOMBIINSTR. VDO H80 0430
   Revision: D07         Serial number: 2241GD07000502
   Coding: 0005043
   Shop #: WSC 00011 888 96745
   VCID: 1B63DD18CFADBA537A1-804E
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A058CCD
   Coding: FD3F0342072102
   VCID: 2A0D08DC90F753DBF17-807E
01304 - Radio
                    Reset counter: 194
                    Mileage: 220513 km
                    Date: 2020.12.19
                    Time: 11:24:33
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 B
   Component: HALDEX 4Motion      0107
   Coding: 0000001
   VCID: 2C010EC49A034DEB03B-8078
   Revision: D07         Serial number: AUX7Z0E9FNC066
   Shop #: WSC 31721 133 80545
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0070
   Coding: 0000144
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D10BCB8271B1B497-8066
02546 - Steering Limit Stop
                    Mileage: 9360 km
                    Temperature: 19.0°C
                    Voltage: 11.80 V
                    Voltage: 11.60 V
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 E
   Component:    KSG          H04 0050
   Coding: 188000186D088505488F016300
   VCID: 3E25348C7C7FCF7BBDF-806A
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382     HW: 8P4 035 382
   Component: AB2 SUBWOOFERBOXH04 0180
   Revision: 00003       Serial number: 30674526177563
   VCID: 71BFDFB07DA1600370D-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0000144
   Part No: 8P0 907 357 F
   Coding: 0000012
   VCID: 3D2733807179D463A45-8068
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0060
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0000144
End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
AutoScan 2
Friday,30,July,2021,17:05:08:34728
                    Mileage: 225788 km
                    Date: 2021.05.23
                    Time: 20:18:07
                    Temperature: 24.0°C
                    Temperature: 24.0°C
                    Voltage: 11.938 V
                    Voltage: 0.000 V
   Revision: 00T12001
   Coding: 0021122
   Coding: 00062736
   Shop #: WSC 06314
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
                    Reset counter: 227
                    Mileage: 228593 km
                    Date: 2021.07.17
                    Time: 15:39:00
                    Voltage: 11.65 V
                    Reset counter: 220
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:44:00
                    Voltage: 11.40 V
                    Fault Frequency: 30
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
                    Reset counter: 194
                    Mileage: 213493 km
                    Date: 2020.06.30
                    Time: 15:41:00
                    Voltage: 11.55 V
   Coding: 0073622
   Coding: 0000042
01304 - Radio
   Coding: 0005043
01304 - Radio
                    Reset counter: 194
                    Mileage: 220513 km
                    Date: 2020.12.19
                    Time: 11:24:33
   Coding: 0000001
   Coding: 0000144
                    Mileage: 9360 km
                    Temperature: 19.0°C
                    Voltage: 11.80 V
                    Voltage: 11.60 V
   Coding: 0000144
   Coding: 0000012
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:09, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
RasPal
Denmark
C?ID=437325
Ok, I'll have to try to do the basic setting again.
   #40
RasPal
Denmark
C?ID=437325
But does anybody know why I got the new fault codes on [16], even after coding it to not having tiptr. Or multifunc.
