;SW:5WA-907-530-E HW:5WA-907-530-C --- CAN Gateway
;Component:GW2020 High 752 7075, Coding:0000113D6600000000000100010301377301610902000100030100010001010000000000000000000000000000000000
;EV_GatewMQB2020,004003,EV_GatewMQB2020_VW38.rod
;Thursday,14,January,2021,14:58:50:29555
;VCDS Version: Release 20.12.0 (x64) Data version: 20201125 DS322.1
;VCID: 4ACC97EAEC383E6BED6-801E
Group,Description,Actual
IDE00019,Voltage terminal 30,13.0, V
IDE00322,Status of basic setting,was not yet started,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,15,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,13,
IDE00634,Vehicle electrical system current,23.512, A
IDE00767-ENG18474,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG18475,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG18476,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG18477,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,9,
IDE00767-ENG18512,No. of unscheduled ECU resets-Muc_Reset_Counter,0,
IDE00767-ENG18534,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG18535,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG18536,No. of unscheduled ECU resets-Reason_of_4th_last_reset,2,
IDE00767-ENG18537,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG18538,No. of unscheduled ECU resets-Reason_of_latest_reset,0,
IDE00767-ENG18624,No. of unscheduled ECU resets-Watchdog_Reset_Counter,1,
IDE00773,Terminal 15 status via CAN,On,
IDE01285,Counter of component protection malfunctions,0,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.3, H
IDE01807-MAS00106,History data 21-Year,2021,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,12,
IDE01807-MAS00109,History data 21-Hours,15, H
IDE01807-MAS00110,History data 21-Minutes,54, min
IDE01807-MAS14375,History data 21-Cycle counter,179,
IDE01807-MAS14376,History data 21-ECU 1,00 7C,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.3, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 44,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.3, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 76,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.3, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 7B,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.3, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG28833,History data 21-Bus_ECU_1,Migration data bus,
IDE01807-ENG28836,History data 21-Bus_ECU_2,Hybrid data bus,
IDE01807-ENG28839,History data 21-Bus_ECU_3,Powertrain data bus,
IDE01807-ENG28842,History data 21-Bus_ECU_4,Hybrid data bus,
IDE01807-ENG28845,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16910,History data 22-Migration data bus,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN_Connect,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG124425,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG124426,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG124427,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG124428,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG124429,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.0, H
IDE01810-MAS00106,History data 24-Year,2000,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,0, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,0,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,00 00 00 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Unknown,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Unknown,
IDE01810-MAS14413,History data 24-Alert events in current cycle,0,
IDE01810-MAS20473,History data 24-Alerting message counter,0,
IDE01812-MAS01468,History data 26-Terminal 15,198,
IDE01812-MAS03173,History data 26-Powertrain data bus,2,
IDE01812-MAS03174,History data 26-Comfort data bus,580,
IDE01812-MAS03177,History data 26-Infotainment data bus,6,
IDE01812-MAS03178,History data 26-Suspension data bus,5,
IDE01812-MAS03180,History data 26-Local data bus,21,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,7,
IDE01812-MAS14374,History data 26-Totals,626,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,3,
IDE01812-MAS16910,History data 26-Migration data bus,2,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,424,
IDE01813-MAS03174,History data 27-Comfort data bus,403,
IDE01813-MAS03177,History data 27-Infotainment data bus,414,
IDE01813-MAS03178,History data 27-Suspension data bus,1068,
IDE01813-MAS12185,History data 27-Hybrid data bus,687,
IDE01813-MAS14374,History data 27-Totals,5640,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,1700,
IDE01813-MAS16910,History data 27-Migration data bus,944,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN_Connect,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,6913,
IDE01814-MAS03174,History data 28-Comfort data bus,200,
IDE01814-MAS03177,History data 28-Infotainment data bus,422,
IDE01814-MAS03178,History data 28-Suspension data bus,10,
IDE01814-MAS12185,History data 28-Hybrid data bus,45696,
IDE01814-MAS14374,History data 28-Totals,392,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,10,
IDE01814-MAS16910,History data 28-Migration data bus,56785,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN_Connect,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2021,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,4,
IDE01816-MAS00109,History data 30-Hours,10, H
IDE01816-MAS00110,History data 30-Minutes,17, min
IDE01816-MAS14375,History data 30-Cycle counter,101,
IDE01816-ENG20570,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG20572,History data 30-Bus_2,Infotainment data bus,
IDE01816-ENG20574,History data 30-Bus_3,Migration data bus,
IDE01816-ENG20576,History data 30-Bus_4,Hybrid data bus,
IDE01816-ENG20578,History data 30-Bus_5,Extended data bus,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,2.8, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,1.4, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,1.3, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.4, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.1, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.3, H
IDE01817-MAS00106,History data 31-Year,2021,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,12,
IDE01817-MAS00109,History data 31-Hours,15, H
IDE01817-MAS00110,History data 31-Minutes,54, min
IDE01817-MAS14375,History data 31-Cycle counter,179,
IDE01817-MAS14376,History data 31-ECU 1,00 7C,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.3, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 44,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.3, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 76,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.3, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 7B,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.3, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG28833,History data 31-Bus_ECU_1,Migration data bus,
IDE01817-ENG28836,History data 31-Bus_ECU_2,Hybrid data bus,
IDE01817-ENG28839,History data 31-Bus_ECU_3,Powertrain data bus,
IDE01817-ENG28842,History data 31-Bus_ECU_4,Hybrid data bus,
IDE01817-ENG28845,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.0, H
IDE01819-MAS00106,History data 33-Year,2000,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,0, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,0,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 00 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Unknown,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2021,
IDE01820-MAS00107,History data 34-Month,1,
IDE01820-MAS00108,History data 34-Day,14,
IDE01820-MAS00109,History data 34-Hours,14, H
IDE01820-MAS00110,History data 34-Minutes,45, min
IDE01820-MAS14375,History data 34-Cycle counter,197,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4A,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,1, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,198,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01831-MAS03159,Generator variant-Manufacturer,Others,
IDE01831-MAS06310,Generator variant-Generator identifier,Unknown (31),
IDE01831-MAS06311,Generator variant-ASIC manufacturer,7,
IDE01831-MAS06312,Generator variant-ASIC variant,31,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.2, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.1, H
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,EF 35 C8 34,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,can be reached,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not attainable,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,can be reached,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,can be reached,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,can be reached,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,can be reached,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not attainable,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not attainable,
IDE01995-ENG16990,Control module protocol information-Ethernet,Yes,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,Malfunction,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,Malfunction,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,Malfunction,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02486,Data logger triggering,not active,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG124125,Readiness for bus sleep mode-Sleep-Bit 0,System_not_ready_to_sleep,
IDE03150-ENG124124,Readiness for bus sleep mode-Sleep-Bit 1,System_ready_to_sleep_or_sleeping,
IDE03150-ENG124123,Readiness for bus sleep mode-Sleep-Bit 2,System_not_ready_to_sleep,
IDE03150-ENG124122,Readiness for bus sleep mode-Sleep-Bit 3,System_not_ready_to_sleep,
IDE03150-ENG124121,Readiness for bus sleep mode-Sleep-Bit 4,System_not_ready_to_sleep,
IDE03150-ENG124120,Readiness for bus sleep mode-Sleep-Bit 5,System_not_ready_to_sleep,
IDE03150-ENG124119,Readiness for bus sleep mode-Sleep-Bit 6,System_ready_to_sleep_or_sleeping,
IDE03150-ENG124118,Readiness for bus sleep mode-Sleep-Bit 7,System_ready_to_sleep_or_sleeping,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 01 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,available.,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG124117,Bus identification-bus_number,TNF 167462,
IDE04343-ENG124116,Bus identification-bus_type,Bus master,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG124962,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG125035,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG124115,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,A0 0A 59 05 B1,
IDE05960-IDE01827,Generator-Specified generator voltage,13.2, V
IDE05960-IDE01828,Generator-Generator DF Signal,9.700, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,On,
IDE05960-IDE01855,Generator-Generator current,27.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,active,
IDE05960-MAS11758,Generator-Identification,No,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,207.0, A
IDE05960-MAS21325,Generator-Ramp time,3, s
IDE06011-ENG118665,Selected driving profile-driving_profile,INDIVIDUAL,
IDE06011-ENG124961,Selected driving profile-link_profile,link_profile_2,
IDE06011-ENG26214,Selected driving profile-Operation_mode,EV,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,552, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,373, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,84, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,324, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07159-MAS01155,Control module switch-off: counter-Control module,250,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,13.2, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,25, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,210, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,12.00,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,51, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,44, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,12 3F 85 9F,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,8.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,0, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,-40, ∞C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, ∞C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE08794,Battery cell analysis,Initialization,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Front windshield heater,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Plugin Hybrid,
IDE09074-MAS08256,Vehicle properties-Max energy content,10550, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),19.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,6.4, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,15.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,35.2, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,530, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,600, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,477, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,8, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,485, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,477, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,8, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,489,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,480,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,9,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometers,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,15.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,15.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,15.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,15.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,15.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,15.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,30.9, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,1525, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,5,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initialization,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No malfunction detected,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,23,
IDE11738,Ethernet counter connection interruptions: branch 3,23,
IDE11739,Ethernet counter connection interruptions: branch 4,27,
IDE11740,Ethernet counter connection interruptions: branch 5,13,
IDE11741,Ethernet counter connection interruptions: branch 6,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE11755-MAS14856,IP network: VLANs-VLAN,2,
IDE11756,IP network: counter messages with inadmissible VLANs,43632,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,1847,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,00 36 F8 58 8C 82,
IDE11762-IDE02766,Information break recommendation-Malfunction status,No malfunction,
IDE11762-MAS03095,Information break recommendation-Function status,Initialization,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869-IDE09467,IP network: NDP cache-MAC address,30 B4 B8 66 B3 DD,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE11869-MAS14856,IP network: NDP cache-VLAN,0,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,02 7D FA 00 14 00,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,44 3C 88 06 B5 F0,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,30 B4 B8 66 B3 DD,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,30 B4 B8 23 9D 37,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE03615,Component protection participant status-Variant,KS Slave,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 15,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS16979,Component protection participant status-Prioritisation,Not prioritized,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12133-MAS01896,Freewheel - energy-Free run,45, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,5,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,5,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,2,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,3,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,4,
IDE12238,I network: discarded messages counter,1857,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,84,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,left and right lightly handled,
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG124545,Diagnostic capability of the bus interface-Diag_path Bit 0,Control module/bus interface diagnostics capable,
IDE12806-ENG124546,Diagnostic capability of the bus interface-Diag_path Bit 1,Control module/bus interface not diagnostics capable,
IDE12806-ENG124547,Diagnostic capability of the bus interface-Diag_path Bit 2,Control module/bus interface diagnostics capable,
IDE12806-ENG124548,Diagnostic capability of the bus interface-Diag_path Bit 3,Control module/bus interface diagnostics capable,
IDE12806-ENG124549,Diagnostic capability of the bus interface-Diag_path Bit 4,Control module/bus interface diagnostics capable,
IDE12806-ENG124550,Diagnostic capability of the bus interface-Diag_path Bit 5,Control module/bus interface diagnostics capable,
IDE12806-ENG124551,Diagnostic capability of the bus interface-Diag_path Bit 6,Control module/bus interface not diagnostics capable,
IDE12806-ENG124552,Diagnostic capability of the bus interface-Diag_path Bit 7,Control module/bus interface not diagnostics capable,
IDE12807-ENG124572,Participant authenticity-Ecu_authentication Bit 0,Control module/bus interface authentic,
IDE12807-ENG124573,Participant authenticity-Ecu_authentication Bit 1,Control module/bus interface not authentic,
IDE12807-ENG124574,Participant authenticity-Ecu_authentication Bit 2,Control module/bus interface authentic,
IDE12807-ENG124575,Participant authenticity-Ecu_authentication Bit 3,Control module/bus interface authentic,
IDE12807-ENG124576,Participant authenticity-Ecu_authentication Bit 4,Control module/bus interface authentic,
IDE12807-ENG124577,Participant authenticity-Ecu_authentication Bit 5,Control module/bus interface authentic,
IDE12807-ENG124578,Participant authenticity-Ecu_authentication Bit 6,Control module/bus interface not authentic,
IDE12807-ENG124579,Participant authenticity-Ecu_authentication Bit 7,Control module/bus interface not authentic,
IDE12844-ENG20451,Installation list of the 10 bit node addresses-ECU ID,TNF 167462,
IDE12844-ENG20480,Installation list of the 10 bit node addresses-ECU Name,Data Bus OBD Interface,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 10,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG124632,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,58, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,production,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00000131*2021-01-14-13:46:27*6*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00000125*2021-01-14-12:23:34*6*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00000125*2021-01-14-10:36:04*6*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00000125*2021-01-14-09:55:07*6*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00000125*2021-01-13-23:33:49*6*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCDZMW,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,0, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,32,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,29.9, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.3, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,19.9, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,29.3, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,0, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,2046,
IDE14151-MAS17930,Route-based range calculation-Range from destination,2046,
IDE14151-MAS17931,Route-based range calculation-Route-based range,2046,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,activated,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,0,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,0,
IDE14260-ENG124430,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG124431,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 6F 6E 46 30 A1 C5 60,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
MAS00464-MAS00106,Standard - ambient data 1-Year,2082,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,28,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,29,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,142, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,5,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,70, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine running,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,active,
MAS12666-MAS01170,SubSystemNodeAddress of sub bus participant-Subsystem designation,Generator,
MAS12666-ENG39149,SubSystemNodeAddress of sub bus participant-SubSystem Node Address,00 1D,
MAS12668-ENG39150,Actual installation of sub-bus users-SubSystem present Bit 0,not attainable,
MAS12668-ENG45633,Actual installation of sub-bus users-SubSystem present Bit 1,can be reached,
MAS12668-ENG45632,Actual installation of sub-bus users-SubSystem present Bit 2,not attainable,
MAS12668-ENG45631,Actual installation of sub-bus users-SubSystem present Bit 3,not attainable,
MAS12668-ENG45630,Actual installation of sub-bus users-SubSystem present Bit 4,not attainable,
MAS12668-ENG45629,Actual installation of sub-bus users-SubSystem present Bit 5,not attainable,
MAS12668-ENG45628,Actual installation of sub-bus users-SubSystem present Bit 6,not attainable,
MAS12668-ENG45627,Actual installation of sub-bus users-SubSystem present Bit 7,not attainable,
MAS12669-ENG39147,Bus identification of sub-bus users-Bus ID,81,
MAS16744-IDE01836,12V battery-Battery current,0.455, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,11, ∞C
MAS16744-IDE01838,12V battery-Battery temperature,10, ∞C
MAS16744-IDE01839,12V battery-Battery charge level,97, %
MAS16744-IDE01841,12V battery-Battery internal resistance,4.6, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,38, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,4.8, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,59, Ah
MAS16744-MAS00362,12V battery-Battery voltage,13.178, V
MAS16744-MAS06086,12V battery-Total re-charge,72.3, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,63.5, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,89, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,89, %
MAS16744,12V battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge level,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.8, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-3.013, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 01 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,38,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,5F F5 91 F5,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG55051-ENG56247,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG55051-ENG124488,Authentic_time_last_client_response-Current_time_ used,2021-01-14T14:49:15Z,
ENG55051-ENG55667,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2021-01-14T14:49:13Z,
ENG123545-ENG122386,DoIP_Status-Node_address,05 01,
ENG123545-ENG18517,DoIP_Status-number_of_total_ecu,256,
ENG123545-ENG125024,DoIP_Status-number_tcp_connections_ecu,00,
ENG123545-ENG125221,DoIP_Status-routing_activation_status,not active,
ENG123545-ENG125222,DoIP_Status-RoutingActivation Response Code,02,
ENG123545-ENG125257,DoIP_Status-source_port,14 34,
ENG123545-ENG125358,DoIP_Status-tcp_connection_established,not active,
ENG123545-ENG125493,DoIP_Status-vehicle_announcement_identification_response_received,No,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG06005-ENG06085,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG06005-ENG06084,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG06005-ENG124624,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG123549-ENG124430,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG123549-ENG124431,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG123549-ENG124432,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG123549-ENG124473,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG123549-ENG124479,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,0,
ENG123549-ENG124481,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,0,
ENG123549-ENG124485,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,0.403, A
ENG123549-ENG124486,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG123549-ENG124487,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG123549-ENG124972,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,51, A
ENG123549-ENG124992,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,12.00,
ENG123549-ENG125029,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG123549-ENG125025,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG123549-ENG125026,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG123549-ENG125027,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG123549-ENG125028,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG123549-ENG125198,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG123549-ENG125548,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,463.7, V
ENG123550-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG123550-MAS21179,Energy_management_dashboard_display-Energy generator reports,0,
ENG123550-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG123550-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG125015,Gateway app. software identification-nf_name,routing_gateway,
ENG118782-ENG109174,Gateway app. software identification-SW_VERSION,9064,
ENG123653-ENG124625,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG123653-ENG124973,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG123653-ENG20971,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG123653-ENG124133,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG123655-ENG20957,HV-EM_energy_specification-High_voltage_battery_energy_information,1525,
ENG123655-ENG20960,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,1500, Wh
ENG123655-ENG20967,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG123656-ENG20958,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG123656-ENG20961,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG123656-ENG20964,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG123656-ENG20965,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG123657-ENG124461,HV-EM_operation_data-climate_power,0, W
ENG123657-ENG124509,HV-EM_operation_data-dcdc_power,330, W
ENG123657-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,HV-EM_active_clamp_15,
ENG123658-ENG20956,HV-EM_operation_limitation-High_voltage_battery_current_limitation,286.6, A
ENG123658-ENG124134,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,17.5, %
ENG123658-ENG01115,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,Release,
ENG123658-ENG20962,HV-EM_operation_limitation-HV-EM_NV_power_limitation,1500, W
ENG123658-ENG20963,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG123705,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0),
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG20114,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG20115-ENG125229,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG20116,MV-EM_48V_overvoltage_check,---,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,0.0, A
ENG20120,MV-EM_dc_power_desired,0, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,0, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG123711-ENG115189,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG123711-ENG12115,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG123711-ENG12116,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG123711-ENG12117,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG123711-ENG12118,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG123711-ENG124307,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG123711-ENG124308,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG123711-ENG124628,NVEM_12V_Rekuperation-Energienetz,1,
ENG123711-ENG124631,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG123711-ENG124665,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG123711-ENG124666,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG123711-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG123711-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG123711-ENG121521,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG123711-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG123711-ENG125004,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,not coded/not installed,
ENG123711-ENG125034,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG123711-ENG124093,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG123711-ENG125201,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG123711-ENG125234,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG123711-ENG101873,NVEM_12V_Rekuperation-Sonderveto,0,
ENG123711-ENG125292,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG123711-ENG125293,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG123711-ENG125294,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG123711-ENG125295,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG123711-ENG125296,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG123711-ENG125297,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG123711-ENG125327,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG123711-ENG125328,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG123712-ENG124214,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG123712-ENG124226,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG123712-ENG124107,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG123712-ENG124682,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG123712-ENG125326,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG123712-ENG125648,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG119298,NVEM_Grund_BEM_falsch_codiert,0,
ENG123714-ENG124236,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG123714-ENG124137,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG123715-ENG124227,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG123715-ENG124228,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG123715-ENG124707,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG123715-ENG124708,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG123716-ENG124297,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG123716-ENG124298,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG123716-ENG125351,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG123716-ENG125352,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG123716-ENG125353,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG123716-ENG125354,NVEM_Zustand_HLR-TabE_Crash,0,
ENG123716-ENG125355,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG123716-ENG125356,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG123716-ENG125357,NVEM_Zustand_HLR-TabNQ,0,
Elapsed Time: 00:55
