This is the scan from my Golf 8 Style e-Hybrid DSG 6-speed:
Installed packages and options:
Park Assist
Side Assist with RTA
Lane Assist
Travel Assist
Rear view camera
IQlights Matrix Dynamic Front/Rear Indicators
Heated Steering and Seats
Ergoactive Driver Seat with massage
Progressive steering
Folding Mirrors with curb function
Discovery Pro
Keyless
Interior Background light version 2
Exterior Light on mirrors/handles and front grille
Park Assist
Lane Assist
Travel Assist
Rear view camera
Discovery Pro
Keyless
Wednesday,06,January,2021,14:51:32:29555
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WVWZZZCDZMW3 License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 4B 4B 51
52 5F 6C 75 82 8C A5 C6 D6 D7 8107 811E 811F 8120 8121 C002 C003
VIN: WVWZZZCDZMW3-----
6C-Back-up Cam. -- Status: Cannot be reached 0100
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DGEA) Labels: None
Part No SW: 04E 906 014 AB HW: 04E 907 309 FH
Component: 1.4l TFSI hy H20 1211
Revision: K2H20000
Coding: 011D403263640D0830080000000000000000000000000000
ASAM Dataset: EV_ECM14TFS01104E906014AB 001008
ROD: EV_ECM14TFS01104E906014AB_VW38.rod
VCID: 609855427AC4943B132-8034
34193 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Reset counter: 39
Mileage: 4 km
Date: 2020.12.01
Time: 09:27:14
Engine RPM: 0.00 /min
Coolant temperature: 38 ∞C
Intake air temperature: 31 ∞C
Voltage terminal 30: 13.980 V
Drive train coordinator irreversible switch off conditions: 0
Drive train coordinator reversible switch off conditions: 2155905024
Drivetrain coordinator: brake fault status: 5
23419 - Implausible Data Received from Diagnostic Gateway Module
U0447 00 [032] - -
Reset counter: 39
Mileage: 4 km
Date: 2020.12.01
Time: 09:27:15
Engine RPM: 1597.50 /min
Normed load value: 30.2 %
Vehicle speed: 34 km/h
Coolant temperature: 63 ∞C
Intake air temperature: 13 ∞C
Voltage terminal 30: 14.880 V
Outside temperature: 10 ∞C
Absolute intake pressure: 65 kPa abs
Engine torque: 75.2 Nm
Fuel: tank fill level: 6.0 l
Electric drive torque: actual value: -30.5 Nm
Operating mode control expanded electrical driving: False result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
High-volt. battery: charge state: abs. value: 36.70 %
23765 - Control unit for information electronics 1
U1054 00 [032] - No Communication
[Information electronics control module 1No Communication]
Reset counter: 39
Mileage: 4 km
Date: 2020.12.01
Time: 09:27:21
Coolant temperature: 15 ∞C
Intake air temperature: 10 ∞C
Voltage terminal 30: 13.960 V
Outside temperature: 9 ∞C
Absolute intake pressure: 102 kPa abs
Engine torque: 0.0 Nm
Fuel: tank fill level: 4.8 l
Electric drive torque: actual value: 0.0 Nm
High-volt. battery: charge state: abs. value: 33.35 %
43768 - Release / Enable Active
B184C 00 [032] - -
4178 - Fuel Injection Malfunction
P0148 00 [096] - -
Reset counter: 39
Mileage: 11 km
Date: 2021.01.04
Time: 10:21:12
Engine RPM: 385.50 /min
Normed load value: 37.3 %
Intake air temperature: 11 ∞C
Voltage terminal 30: 14.760 V
High fuel pressure: specified value: 20.828 MPa
Fuel high-pressure: actual value: 16.960 MPa
High fuel pressure: regulator output value: 2.3080 MPa
Low fuel pressure: specified value: 547.8 kPa
Fuel pump: specified value: 64.59 %
Low fuel pressure adaptation value for EFP: modeled: 120.0 kPa
Fuel: tank fill level: 5.0 l
4201 - Fuel Level too Low
P1250 00 [047] - -
Reset counter: 0
Mileage: 11 km
Date: 2021.01.04
Time: 10:21:13
Engine RPM: 1114.50 /min
Normed load value: 12.9 %
Voltage terminal 30: 14.820 V
Unlearning counter according OBD: 0
Absolute intake pressure: 37 kPa abs
Engine torque: 18.3 Nm
Electric drive torque: actual value: -8.0 Nm
High-volt. battery: charge state: abs. value: 33.10 %
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DD 906 556 HW: 0DD 300 046 J
Component: GSG DQ400 H33 0361
Serial number: 5ZV02008220590
ASAM Dataset: EV_TCMDQ400022 001001
ROD: EV_TCMDQ400022.rod
VCID: 77AA1E1ECF4A7383428-8022
18 Faults Found:
21352 - ROD - Unknown Error Code
- 00 [002]
60353 - ROD - Unknown Error Code
- 00 [002]
60354 - ROD - Unknown Error Code
- 00 [002]
60355 - ROD - Unknown Error Code
- 00 [002]
60356 - ROD - Unknown Error Code
- 00 [002]
60357 - ROD - Unknown Error Code
- 00 [002]
60358 - ROD - Unknown Error Code
- 00 [002]
60359 - ROD - Unknown Error Code
- 00 [002]
60360 - ROD - Unknown Error Code
- 00 [002]
60361 - ROD - Unknown Error Code
- 00 [002]
60362 - ROD - Unknown Error Code
- 00 [002]
60363 - ROD - Unknown Error Code
- 00 [002]
60364 - ROD - Unknown Error Code
- 00 [002]
60365 - ROD - Unknown Error Code
- 00 [002]
60366 - ROD - Unknown Error Code
- 00 [002]
60367 - ROD - Unknown Error Code
- 00 [002]
60368 - ROD - Unknown Error Code
- 00 [002]
60369 - ROD - Unknown Error Code
- 00 [002]
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5WA 614 517 BF HW: 5WA 614 517 P
Component: ESC H14 0127
Serial number: 62870000000235
Coding: 64FC269032224C725279A00905C76186AA5558504AC8670841BCA231018FF121842814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013051
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 0D465CF6DDD66953084-8058
1905 - Transport Mode Active
U1105 00 [032] - -
590080 - Release / Enable Active
B184C 00 [040] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Reset counter: 39
Mileage: 4 km
Date: 2020.12.01
Time: 09:27:06
33015 - Switch for Electric Parking Brake
C100C 29 [040] - Signal Implausible
[Switch_disturbance_failure]
Reset counter: 39
Mileage: 8 km
Date: 2020.12.08
Time: 21:42:25
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0703
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003_VW38.rod
VCID: 54F089923E7C789B87A-8000
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 007 S HW: 5WA 907 007 S
Component: AC Automat H31 3150
Coding: 002101017011120010100010111011102000131100201001000000000000
ASAM Dataset: EV_ACClimaHVPREVW38X 001084
ROD: EV_ACClimaHVPREVW38X.rod
VCID: 57EA7E9E2F8A5383628-8002
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5WA 937 086 Q HW: 5WA 937 086 J
Component: BCM 37W BOSCH 016 0137
Serial number: BXJ53F031120951
ASAM Dataset: EV_BCM37w 005001
ROD: EV_BCM37w_005_VW38.rod
VCID: 5F9A56BE47BAABC32A8-800A
155136 - Unknown Error Code
B1A61 F0 [046] - Unknown Error Elaboration
Mileage: 21 km
Date: 2021.01.06
Time: 12:53:03
267032 - Alarm Horn / Siren for Anti-Theft System
B131D 29 [104] - Signal Implausible
Reset counter: 27
Mileage: 11 km
Date: 2021.01.04
Time: 11:01:15
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 A HW: 5WA 919 298
Component: PLA 12K Kanal H04 0230
Serial number: 000030092094560
Coding: 9300026011
ASAM Dataset: EV_EPHBO2CVW3800000 002028
ROD: EV_EPHBO2CVW3800000_VW38.rod
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 A HW: 5WA 907 572
Component: ACC Bosch MQB H10 0246
Coding: 2E0318FF407540451247400000004005AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
ROD: EV_FRONTRADARBOSCHVW380_003_VW38.rod
VCID: 4CC091F2E64C205BDFA-8018
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 K HW: 5WA 959 655 K
Component: AirbagVW40 007 0636
Serial number: 000000003C0J1R6
Coding: 88CC000000C0C000000000200000000051540000205400004000F68000930065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X_VW38.rod
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 A HW: 5H0 920 340 A
Component: KOMBI 203 3450
Coding: 24A400406B9C00080180620B2100080810B00C00
ASAM Dataset: EV_DashBoardVDDMQB37W 003032
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 201815423A44D43B532-8074
16777018 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Mileage: 16 km
Date: 2021.01.04
Time: 17:33:50
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Mileage: 16 km
Date: 2021.01.04
Time: 17:33:50
16777022 - Control unit for information electronics 1
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Mileage: 11 km
Date: 2021.01.04
Time: 10:55:52
16777024 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
[BCME_0x23 communication error bap_error_timeout heartbeat]
Reset counter: 41
Mileage: 11 km
Date: 2021.01.04
Time: 11:00:09
Part No SW: 5WA 907 530 E HW: 5WA 907 530 C
Component: GW2020 High 752 7075
Revision: -------- Serial number: 771049050020314
Coding: 0000113D6600000000000100010301377301610902000100030100010001010000000000000000000000000000000000
ASAM Dataset: EV_GatewMQB2020 004003
ROD: EV_GatewMQB2020_VW38.rod
VCID: 4ACC97EAEC383E6BED6-801E
2494569 - Unknown Error Code
U1643 00 [047] - -
[Rearview_camera_system_control_module_no_communication_vlan]
Mileage: 11 km
Date: 2021.01.04
Time: 10:40:57
2097338 - Unknown Error Code
U1646 00 [046] - -
[Antenna_control_module_1_no_communication_vlan]
Fault Frequency: 39
Mileage: 11 km
Date: 2021.01.04
Time: 10:48:36
B184C 00 [040] - -
Reset counter: 37
Mileage: 11 km
Date: 2021.01.04
Time: 10:40:57
8482816 - Activatable Functions
B18D3 F4 [046] - Authentication of Transmission Failed
[Fs_id_authentification_failed]
Mileage: 38 km
Date: 2021.01.06
Time: 02:26:21
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 H HW: 3Q0 909 059 A
Component: EBKV H06 0112
Serial number: BPA085201020013
Coding: 1102C504740000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
ROD: EV_BrakeBoostG2BoschVW37W_014_VW38.rod
VCID: 55F6749635866193704-8000
107024 - Unknown Error Code
U14E4 00 [032] - -
[Scl_Getriebe_11_GE_Fahrstufe_Error]
1024304 - Release / Enable Active
B184C 00 [032] - -
[SECDIAG_ROLE_UNLOCKED]
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 20000265209008
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 323CEF0A64A856ABB56-8066
12666386 - Databus
[Timeout Getriebe_11_alt]
Mileage: 21 km
Date: 2021.01.06
Time: 12:14:25
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: OFF
Clamp 15: OFF
Clamp 15 Status: valid
Remote Start: not active
Driver door: to
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 12.4 V
UMotorBridge: 6.7 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition met
Lock condition timeout vehicle speed: Condition met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition not met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0361
Serial number: 20A1701KA00329
Coding: 01789A400000A0508803010101010000000000212100000000000000215000
VCID: 59EE78A6599E45F354C-800C
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 D HW: 2Q0 907 686 D
Component: HRE_Master H25 0276
Serial number: 00000559544528
Coding: 969945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001013
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 3B22C22EB3E297E3660-806E
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007TJ51019E
Coding: 003B1620D201040000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW38.rod
VCID: 49CEA8E6E93E3573E4C-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000045025148
Coding: 0D0000
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 00395354
Coding: 0000000100000101000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
VCID: 4EC49BFA1050124BB1E-801A
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 HW: 5WA 907 338
Component: FCM2020 Low 009 1372
Serial number: 150151220442193
Coding: 00000000090007CE01002F10020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 002010
ROD: EV_MultiModulContiVW38X_002_VW38.rod
VCID: 0B4252EEA3C26763160-805E
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5WA 907 080 B HW: 5WA 907 080 B
Component: LE Gen 3.3H19 0222
Revision: 00H19000
Coding: 03090000000000000000
ASAM Dataset: EV_DMCM08530115WA907080B 001016
ROD: EV_DMCM08530115WA907080B.rod
VCID: 47CAAEDEFF2AC303F28-8012
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007TIT1735B
Coding: 003B1020DE01040000801000
ROD: EV_DCU2PasseSideMAXHKLO_VW38.rod
VCID: 48C8ADE2F234CC7BFB2-801C
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000043661741
Coding: 150000
Part No SW: 5H0 035 816 B HW: 5H0 035 816
Component: MU-O-ND-EU H56 1666
Serial number: WG8LGM101120000
Coding: 23800008000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_VW38.rod
VCID: 2614035A58603A0B29E-8072
12316 - Clock Syncronization Failure
U138F 00 [008] - -
Mileage: 31 km
Date: 2021.01.06
Time: 13:36:45
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 A HW: 5WA 980 556 A
Component: RV eCompact H21 0193
Serial number: FCL-K2017.10.20
Coding: 02038004E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_VW38.rod
VCID: 4FFA86FE175A1B43BA8-801A
10489856 - No Basic Setting
B2010 00 [046] - -
[System not calibrated]
Fault Frequency: 13
Date: 2072.00.24
Time: 24:16:16
13705507 - Databus
U1121 00 [047] - Missing Message
[Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
Fault Frequency: 13
Mileage: 720896 km
Date: 2072.03.21
Time: 07:56:16
Part No SW: 5WA 035 284 A HW: 5WA 035 284 A
Component: OCU3HMQB37W H12 0067
Serial number: 0000000911VIPA8
Coding: 023800009068A8209405460071502E07
ASAM Dataset: EV_OCU3HMQB37W 001039
ROD: EV_OCU3HMQB37W_001_VW38.rod
VCID: 44D0B9D2CE1CE81B17A-8010
0080 - Databus
[Ethernet Databus missing message - Transceiverbox]
Mileage: 38 km
Date: 2021.01.06
Time: 13:58:57
Voltage terminal 30: 12.0 V
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5H2 919 608 HW: 5H2 919 608
Component: HeadupDisplay H09 2032
Coding: 5740C0
ASAM Dataset: EV_HeadUpDisplMQB37W 001018
ROD: EV_HeadUpDisplMQB37W.rod
VCID: 70B82502AA2424BB832-8024
16777040 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[NAV_0x32_communication_error_bap_error_timeout_heartbeat]
Mileage: 16 km
Date: 2021.01.04
Time: 17:33:51
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5WA 915 183 B HW: 5WA 915 183 B
Component: J840 K8C BMC 004 0920
Serial number: 000000151020050
ASAM Dataset: EV_BMCeVWBSMQB37W 001004
ROD: EV_BMCeVWBSMQB37W.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H06 3129
Serial number: E57830712203180
Coding: 00000808216CC040109E40001030008000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 4DC69CF61D562953C84-8018
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 685 C HW: 5QE 915 685 C
Component: OBC KOSTAL H03 4632
Serial number: 0810202J80004Z
Coding: 115069222008
ASAM Dataset: EV_OBCSinglPhaseKLOMQB16P 001001
ROD: EV_OBCSinglPhaseKLOMQB16P.rod
VCID: 50F885820A6404BBA32-8004
12583680 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[BapErr_Timeout_Heartbeat]
Reset counter: 41
Mileage: 38 km
Date: 2021.01.06
Time: 13:57:21
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6596445665E6F113E04-8030
Component: LED1R H08 9202
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5WA 035 741 A HW: 5WA 035 741 A
Component: TrxModulHigh H10 0068
Serial number: 0000000008VIFW3
Coding: 02380011040080
ASAM Dataset: EV_TrxMLGEMQB37W 005006
ROD: EV_TrxMLGEMQB37W.rod
VCID: 42DCBFCAD408E62B256-8016
0081 - Databus
U1121 00 [040] - Missing Message
[Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
Fault Frequency: 0
0083 - Unknown Error Code
U1541 00 [040] - -
[Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
Fault Frequency: 0
0096 - Unknown Error Code
U153F 00 [109] - -
Fault Frequency: 0
Address 811E: Burglary Protection FL (J518) Labels: None
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518) Labels: None
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: None
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: None
ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:46, VBatt start/end: 13.1V/13.1V)-----------
