MK8 GOLF
CD CODING
Manchester, UK
C?ID=421908
Hi anyone has anyone done a MK8 golf yet? Plugged in and tried doing simple adaptations ie. needle sweep (staging) beep on lock/unlock (acoustic confirmation) however it’s asking for security access and it not coming up as recommended when hovering over the field also nothing online. Any help appreciated thanks
Many modules in the Mk.8 have changes blocked by SFD.
@CD CODING Hi. Some of us have been discussing mk8's and SFD in another place - my contribution has been minimal (mostly voyeuristic!!:eek:) because I don't have access to a mk8.
Anyhow, interesting developments of late -oddly it seems that notwithstanding the new protection protocols on the key modules, there are still some allowable tweaks on these SFD encrusted modules that don't require Geko/token access.
I have no idea why this is the case - but it seems that at least one third party diagnostic device has been able to change the look of the instrument cluster - even though the hex17 module has been reported to have SFD on a mk8 - go figure!!
It would be interesting (simply from an intellectual stand-point) to see if VCDS can also implement this tweak which apparently doesn't need a SA (I thought that SA s were superfluous on vehicles with SFD - why are they necessary with such strong validation processes via the new protocols?).
So, if you have an interest and the time to spare - here is the instruction from @massimo23 (in VCDS speak- of course)
  1. Go to the Instruments module @ address hex17
  2. Select Adaptions
  3. This bit is a tad vague - but @massimo23 says "go to Logo menu and select one of the logo items"
  4. Change as follows:
    • Logo_1= Golf R
    • Logo_2 = Golf R (too)
    • Logo_3 = Golf GTE
    • Logo_4 = Golf GTI
    • Logo_5 = Golf GTD
If this is correct (and there is no reason to expect that the instructions are NOT true)- then what other little-gems are lying in wait as sleepers for valiant "early adopters" to find and report in web forums?
PS: I note that @massimo23 is actually a member of this forum - my apology if I have stolen your thunder!!
massimo23
Ireland
C?ID=364379
Hi there just to further simplify in vcds language: (thanks DV52)
To change or add a Logo in the dashboard:
  2. Select Adaptions
  3. Select Channel IDE15080-Logo
  4. Change to one of the following:
    1. kein_logo for no logo
    2. Logo_1 = Golf R
    3. Logo_2 = Golf R different logo style
    4. Logo_3 = Golf GTE
    5. Logo_4 = Golf GTi
    6. Logo_5 = Golf GTD
To add the Golf GT And Golf R Speedo View try this:
  • Go to the Instruments module @ address hex17
  • Select Adaptions
  • Select Channel IDE14875-MAS19489-Activation of views
  • Change the following View settings to active :
    1. View 7 for GTE Hybrid View (image below)
    2. View 8,for GT View (see images above)
    3. View 9 for Golf R View (image below)
Golf R View:
Golf GTE Hybrid View:
To activate the Off-Road View:
  • Select Adaptions
  • Select Channel MAS01299-Offroad and set it to display
  • Change View 10 to active
Some of these codings will not work with every Golf 8 and remember to open the bonnet when coding.
hadez16
C?ID=289891
There is a thread in a german VCDS forum where a MK8 owner reported that these "View"-Channels could not be changed without SFD ticket / SFD unlock.
massimo23
Ireland
C?ID=364379
I changed these views and more as did others with no token or unlock.
hadez16
C?ID=289891
Interesting.
Are there regional differences for having SFD implemented?
Do you have some blockmaps from that Car? Especially Gateway and/or Cluster?
AINils
Germany (AIB)
C?ID=56975
Does it really work? Afaik SFD will stop this changes in my opinion.
@hadez16 Maybe it depend on Software version of AID, same story like GW software. In GW there are some SW which seems to don`t have SFD or accept changes in equipped ECU List
massimo23
Ireland
C?ID=364379
I have uploaded the scan here:
About the mod, I have done these with the other obd tool but should be the same with VCDS.
Any other coding that was not these (probably more) was met with a login code...
massimo23
Ireland
C?ID=364379
09 - Central Electric
;SW:5WA-937-086-Q   HW:5WA-937-086-J ---  Cent. Elect.
;Component:BCM 37W BOSCH 016 0137, Coding:
;EV_BCM37w,005001,EV_BCM37w_005_VW38.rod
;Thursday,14,January,2021,15:02:21:29555
;VCDS Version: Release 20.12.0 (x64)  Data version: 20201125 DS322.1
;VCID: 5F9A56BE47BAABC32A8-800A
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE00973,Outside temperature,14.0, ∞C
IDE02711-IDE05228,Rear wiper-Operating hour counter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Selector lever in position P,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,0,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,14.0, ∞C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,13.2, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,OFF,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Terminal 15 ignition button: signal 2,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,16.0, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,300,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,4000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,960, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,not coded/not installed,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,not coded/not installed,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,not coded/not installed,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded/not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded/not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07159-MAS01155,Control module switch-off: counter-Control module,7,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2021,
IDE08211-MAS00107,History data control module reset-Month,1,
IDE08211-MAS00108,History data control module reset-Day,12,
IDE08211-MAS00109,History data control module reset-Hours,22,
IDE08211-MAS00110,History data control module reset-Minutes,50,
IDE08211-MAS03129,History data control module reset-Reset counter,10,
IDE08211-MAS06734,History data control module reset-last cause of reset,SBC_Watchdog_overflow,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,F8,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,74 30 52 B0,
IDE08240,Transponder ID Key 2,F1 A3 51 B0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS11095,Configuration immobilizer-Cause,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,1A 8C 19 52,
IDE08343,Immobilizer Challenge,27 0C 9B 9E,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-ENG124469,Operating current: light driver-Connector_pin_42,0, mA
IDE08949-ENG124470,Operating current: light driver-Connector_pin_43,0, mA
IDE08949-ENG124471,Operating current: light driver-Connector_pin_44,139, mA
IDE08949-ENG124472,Operating current: light driver-Connector_pin_45,0, mA
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded/not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED not installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded/not installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,7F B2 A6 A3,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded/not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded/not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded/not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded/not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG125330,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG124149,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCDZMW
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE13845,Production mode status,not active,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-MAS01493,Key position replication: input signals-Engine running,not active,
IDE13956-MAS02248,Key position replication: input signals-Signal state,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,0,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG124460,Key position replication: input signals-clampcoordinator_approval,OFF,
IDE13956-ENG124553,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG125170,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG125477,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG125478,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG125479,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,1.0, ∞
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 2,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 07,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 6F 6E 46 30 A1 CD 86,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,2,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-Climate Control Module,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not detected,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not detected,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not detected,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not detected,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not detected,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary Protection Control Module FL,detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary Protection Control Module FR,detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary Protection Control Module RL,detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary Protection Control Module RR,detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary Protection Control Module interior,not detected,
IDE14958-SFT09746,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT09747,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT09804,Recognized actual fitting list: adapt-Rear Driver Side Door Control Module,detected,
IDE14958-SFT09805,Recognized actual fitting list: adapt-Rear Passenger Door Control Module,detected,
IDE14958-SFT09963,Recognized actual fitting list: adapt-Antenna for short-range communication,not detected,
IDE14958-SFT09995,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not detected,
IDE14958-ENG124300,Recognized actual fitting list: adapt-bap_test,not detected,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.20, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.20, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.20, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.20, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,17.75, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,83,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,17 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-MAS10132,Immobilizer-Configuration Kessy coded,Yes,
MAS00077-MAS10133,Immobilizer-Configuration E vehicle,Yes,
MAS00077-MAS10134,Immobilizer-Configuration SHE,Yes,
MAS00077-MAS20275,Immobilizer-Mobile key configuration,Yes,
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,14,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,0,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,142, km
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,valid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Not available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,55,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG01585-MAS06423,Dataset_download_written_rdids-Data set ID,72 0E,
ENG01585-MAS14275,Dataset_download_written_rdids-Record Data Identifier,11 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG01585-MAS18508,Dataset_download_written_rdids-Number of nodes,1,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,10, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,6, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0.1667, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,300,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,19635,
ENG116813-ENG28575,Entwicklermesswerte_CONTI-KurzSchlussZaehler,0,
ENG48509-ENG49940,FoD_slave_operating_state-FoD_slave_state,02,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,valid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0E 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,Not available,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,not OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,n/a,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG124746,Kopfraumheizung_Entwicklung-KRH_l_ErrorGueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG09640,Kopfraumheizung_Entwicklung-KRH_l_Response_Error,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG124748,Kopfraumheizung_Entwicklung-KRH_r_ErrorGueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG09641,Kopfraumheizung_Entwicklung-KRH_r_Response_Error,not coded/not installed,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG124951,LIN activity-LIN 10,active,
ENG116909-ENG124952,LIN activity-LIN 11,not coded/not installed,
ENG116909-ENG124953,LIN activity-LIN 12,not coded/not installed,
ENG116909-ENG124954,LIN activity-LIN 13,not coded/not installed,
ENG116909-ENG124955,LIN activity-LIN 14,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,active,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG116909-ENG124958,LIN activity-LIN 7,not coded/not installed,
ENG116909-ENG124959,LIN activity-LIN 8,not coded/not installed,
ENG116909-ENG124960,LIN activity-LIN 9,active,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,18,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,300,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,44.6756, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,20.01, ∞
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,20.02, ∞
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,20.02, ∞
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,13.22, V
ENG123723-MAS00107,Personalized_Signals_2_0-Month,0,
ENG123723-MAS00108,Personalized_Signals_2_0-Day,0,
ENG123723-MAS00109,Personalized_Signals_2_0-Hours,0,
ENG123723-MAS00110,Personalized_Signals_2_0-Minutes,0,
ENG123723-MAS13457,Personalized_Signals_2_0-Status of personalization,Customization coded 2.x,
ENG123723-MAS19264,Personalized_Signals_2_0-Current profile slot number for customization,Personalization of user account 2,
ENG123723-MAS19265,Personalized_Signals_2_0-Customization control command,no control,
ENG123723-MAS19268,Personalized_Signals_2_0-Control point customization,Initial value,
ENG123723-MAS19269,Personalized_Signals_2_0-Enable customization adjustment,Enabled,
ENG123723-ENG28774,Personalized_Signals_2_0-Perso_Steuerungs_parameter,No user account,
ENG116792-ENG115817,Power up history-Funktionsanforderung,2,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,-0.06, km/(hïs)
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,24, s
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,31,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,10,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,192,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,255,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,12.3, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,2, ∞C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,21.4914, min
ENG122923-ENG125592,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG125593,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG125594,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG125595,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG125596,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG125597,shadow_error_table-wiper_error_10_temp,0, ∞C
ENG122923-ENG125599,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,52,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,4,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,0,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,0,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.3, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,2, ∞C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,21.3248, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,15,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,3,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,0,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,12,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,13.7, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,16, ∞C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,4.9980, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,34,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,3,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,80,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,12,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,14.7, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,15, ∞C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,4.9980, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,51,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,2,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,254,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,12.1, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,18, ∞C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,0.3332, min
ENG122923-ENG125604,shadow_error_table-wiper_error_6_code,0,
ENG122923-ENG125605,shadow_error_table-wiper_error_6_count,0,
ENG122923-ENG125606,shadow_error_table-wiper_error_6_data_ec4,0,
ENG122923-ENG125607,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG125608,shadow_error_table-wiper_error_6_power_supply,0.0, V
ENG122923-ENG125609,shadow_error_table-wiper_error_6_temp,0, ∞C
ENG122923-ENG125611,shadow_error_table-wiper_error_6_timestamp,0.0000, min
ENG122923-ENG125612,shadow_error_table-wiper_error_7_code,0,
ENG122923-ENG125613,shadow_error_table-wiper_error_7_count,0,
ENG122923-ENG125614,shadow_error_table-wiper_error_7_data_ec4,0,
ENG122923-ENG125615,shadow_error_table-wiper_error_7_data_ec5,0,
ENG122923-ENG125616,shadow_error_table-wiper_error_7_power_supply,0.0, V
ENG122923-ENG125617,shadow_error_table-wiper_error_7_temp,0, ∞C
ENG122923-ENG125619,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG125620,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG125621,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG125622,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG125623,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG125624,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG125625,shadow_error_table-wiper_error_8_temp,0, ∞C
ENG122923-ENG125627,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG125628,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG125629,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG125630,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG125631,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG125632,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG125633,shadow_error_table-wiper_error_9_temp,0, ∞C
ENG122923-ENG125635,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG123744,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG119226-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG119226-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123753,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,136, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,15.0, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.2, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,10, ∞C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,14, ∞C
ENG122921-ENG121629,values_motorloads-temp_pcb,11, ∞C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG123782-ENG30408,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG123782-ENG30409,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG123782-ENG30410,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG123782-ENG30411,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG123782-ENG30412,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG123782-ENG31587,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG123782-ENG31588,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG123782-ENG31589,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG123782-ENG31590,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG123782-ENG31591,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG123782-ENG32338,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG123782-ENG32339,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG123782-ENG32340,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG123782-ENG32341,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG123782-ENG32342,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG123782-ENG32343,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG123782-ENG32344,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG123782-ENG32345,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG123782-ENG32346,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG123782-ENG32347,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG123782-ENG32348,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG123782-ENG32349,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG123782-ENG32350,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG123782-ENG32351,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG123782-ENG32352,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG123782-ENG33133,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG123782-ENG33134,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG123782-ENG33135,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG123782-ENG33136,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG123782-ENG33137,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG123782-ENG33359,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG123782-ENG33360,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG123782-ENG33361,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG123782-ENG33362,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG123782-ENG33363,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG02679-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG02679-ENG30347,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),304,
ENG02679-ENG98439,Wischermesswerte 1-Battery voltage,13.2042, V
ENG02679-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG02679-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG02679-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG02679-ENG98786,Wischermesswerte 1-Engine angle,21.9, ∞
ENG02679-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG02679-ENG115795,Wischermesswerte 1-Operating Hours,161092.739, s
ENG02679-ENG115650,Wischermesswerte 1-PCB-Temperatur,71624.007, ∞C
ENG02679-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG02679-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG02679-ENG16634,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG02679-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG02680-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,21.9, ∞
ENG02680-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, ∞
ENG02680-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.9936, ∞
ENG02680-ENG124220,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,21.9, ∞
ENG02680-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,31,
ENG02680-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, ∞
ENG02680-ENG16636,Wischermesswerte 2-Blockzaehler (Ueberlast),18,
ENG02680-ENG16637,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG02680-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG02680-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG02680-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG02680-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG02680-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG02680-ENG98396,Wischermesswerte 2-Operating time,77727.192, s
ENG02680-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,163.7, ∞
ENG02680-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG02680-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG02680-ENG99020,Wischermesswerte 2-Supply voltage,12.2924, V
ENG02680-ENG98969,Wischermesswerte 2-Temperature,2.102, ∞C
ENG02680-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,24.0, ∞
ENG02671-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG02671-ENG124459,Wischermesswerte 3-Chip number Infineon,4E 5E 58 42 05 40 01 9F 84 45 62 75,
ENG02671-ENG125000,Wischermesswerte 3-EOL number,40,
ENG02671-ENG125001,Wischermesswerte 3-Error state,0,
ENG02671-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG02671-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG02671-ENG98897,Wischermesswerte 3-Serial number,39 30 37 33 35 33 46 30 34 30 32 30 32 34 39 30 30 36 35 37,
ENG123784-ENG124281,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,85,
ENG123784-ENG124282,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,0,
ENG123784-ENG124284,WWS Historie-Anzahl Wischzyklen max. UBatt,85,
ENG123784-ENG01635,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,18,
ENG123784-ENG01636,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,257,
ENG123784-ENG01637,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,0,
ENG123784-ENG01638,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,1,
ENG123784-ENG01639,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,0,
ENG123784-ENG01640,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,1,
ENG123784-ENG01641,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,0,
ENG123784-ENG01642,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,27,
ENG123784-ENG124321,WWS Historie-Betriebsstunden max MCU Temperatur,446.395946, s
ENG123784-ENG124322,WWS Historie-Betriebsstunden max. LIN Temperatur,0.774774, s
ENG123784-ENG124324,WWS Historie-Betriebsstunden max. UBatt,607.089477, s
ENG123784-ENG124740,WWS Historie-Kl_15_Zyklenzaehler,195,
ENG123784-ENG124741,WWS Historie-Kl_X_Zyklenzaehler,45,
ENG123784-ENG124974,WWS Historie-max_power_supply,15.1, V
ENG123784-ENG125248,WWS Historie-Sleep_Counter,0,
ENG123784-ENG125568,WWS Historie-Wakeup_Counter,588,
ENG123784-ENG115675,WWS Historie-wiper_error_1_temp,-110, ∞C
ENG123784-ENG115675,WWS Historie-wiper_error_1_temp,0, ∞C
ENG123784-ENG115675,WWS Historie-wiper_error_1_temp,95, ∞C
Elapsed Time: 01:09
17 - Instrument:
;SW:5H0-920-340-A   HW:5H0-920-340-A ---  Instruments
;Component:KOMBI         203 3450, Coding:24A400406B9C00080180620B2100080810B00C00
;EV_DashBoardVDDMQB37W,003032,EV_DashBoardVDDMQB37W_003_VW38.rod
;Thursday,14,January,2021,14:58:27:29555
;VCID: 201815423A44D43B532-8074
IDE00019,Voltage terminal 30,12.9, V
IDE00021,Engine RPM,0.00, /min
IDE00025,Coolant temperature,75.00, ∞C
IDE00196,Engine oil temperature,51, ∞C
IDE00310,Outside temperature,14.0, ∞C
IDE00316-IDE00500,Time-Hour,14, H
IDE00316-IDE00501,Time-Minute,58, min
IDE00316-MAS00111,Time-Seconds,27, s
IDE00317-IDE00502,Date-Year,2021, yr
IDE00317-IDE00503,Date-Month,1, Months
IDE00317-IDE00504,Date-Day,14, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1957, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2035, mm
IDE01076,Time since ignition off,877, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B5 68 F4 59,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,9.0, ∞C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,242,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,100,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,100,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,182,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG33312,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG43637,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,12.9, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,35.4, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,35.4, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,12.2, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,4.1, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,24.9, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,24.9, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,3.8, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,0.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,0.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,127, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,32767, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1610,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2144,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,129,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,219,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,33.9, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,125, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,32.7, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,41.5, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,32.7, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,3276.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,32.7, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,3276.7, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,32.7, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,32.7, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,32.7, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,0.2000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.43750, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-12.03125, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,32.6, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,119,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0012493,
IDE03477-IDE00500,GPS time-Hour,14, H
IDE03477-IDE00501,GPS time-Minute,58, min
IDE03477-IDE00501,GPS time-Minute,47, min
IDE03477-IDE00502,GPS time-Year,2021, yr
IDE03477-IDE00503,GPS time-Month,1, Months
IDE03477-IDE00504,GPS time-Day,14, d
IDE03477-MAS00111,GPS time-Seconds,42, s
IDE03477-MAS00111,GPS time-Seconds,30, s
IDE03477-MAS03493,GPS time-last synchronization year,2021, yr
IDE03506,Distance: high resolution,00 02 2D 54,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 2F,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0B,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0B,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 2F,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-ENG01075,Service -interval- display: history 1-Block_16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-ENG01075,Service -interval- display: history 2-Block_16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG01075,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG01075,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06924,Performance display,4092,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,EF BB 61 47,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31,
IDE11755-MAS14856,IP network: VLANs-VLAN,5,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,3,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,02 7D FA 00 14 00,
IDE11869-IDE09467,IP network: NDP cache-MAC address,00 36 F8 58 8C 82,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10,
IDE11869-MAS14856,IP network: NDP cache-VLAN,5,
IDE12238,I network: discarded messages counter,1685,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12972,Oil: theoretical service interval,15000.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,14870, km
IDE12976,Oil: remaining running time,356, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,Kilometers,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,14900,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of dist. travelled,Kilometers,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,29900,
IDE12977-MAS07273,Oil status-Inspection: time,721,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,356,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,100,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCDZMW,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0),
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG130459,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0),
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG130459,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0),
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG130459,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0),
IDE14129-ENG130459,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0),
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0),
IDE14130-ENG130459,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0),
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG130459,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Mileage,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14213-ENG103300,Service Key Master current data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14214-ENG01100,Service Key Master write counter-Counter_current_clamp_15,0,
IDE14214-ENG01101,Service Key Master write counter-Counter_current_total,138,
IDE14214-ENG01102,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG01103,Service Key Master write counter-Counter_daily_total,62,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG01154,Service Key Master write counter-state_current,Engine_off,
IDE14214-ENG01155,Service Key Master write counter-State_daily,Engine_off,
IDE14214-ENG01077,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG01076,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2021, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,1, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,14, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,14, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,49, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,13, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,2021, yr
IDE14237-MAS00107,Authentic time: actual time-Month,1, Months
IDE14237-MAS00108,Authentic time: actual time-Day,14, d
IDE14237-MAS00109,Authentic time: actual time-Hours,15, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,0, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,18, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,00,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 6F 6E 46 30 A1 C3 75,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 04,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,00,
IDE15081,Authentic time: status of distribution signal trigger,1,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,not active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,100, km
ENG55049,Authentic_time_current_counter_kl15_since_last_sync,0,
ENG00802,Authentic_time_last_backend_response,e,
ENG55051,Authentic_time_last_client_response,2021-01-14T14:49:15Z,
ENG55051,Authentic_time_last_client_response,0,
ENG55051,Authentic_time_last_client_response,2021-01-14T14:49:13Z,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.0, â
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,98, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0, â
ENG105830-ENG01104,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG01105,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0, â
ENG105830-ENG01106,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0, â
ENG105830-ENG01107,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0, â
ENG105830-ENG01108,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0, â
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,94, %
ENG105830-ENG130458,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,3292,
ENG99439,Instrument_recorder,07 13 50 00 4D 51 42 32 30 32 30 32 30 53 31 46 41 43 47 66 36 32 65 31 64 66 78 00 02 01 34 00 30 00 00 01 04 00 00 00 08 00 00 00 02 00 05 B8 62 93 BD F5 98 00 31 00 0B 00 00 00 8F 00 00 00 00 80 00 00 02 00 05 B8 62 93 BE 01 50 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 FF FF FF FF FF FF FF 00 00 0B 00 31 00 8F 00 00 00 00 00 00 00 62 B8 05 00 50 01 BE 93 30 00 34 01 04 01 00 00 08 00 00 00 62 B8 05 00 98 F5 BD 93 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 2D 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 22 00 8C FF B7 00 00 10 1B 00 8C FF FF FF 00 00 C4 BD C8 BD AD AD 84 F2 00 00 00 0A 62 7D FF B7 00 00 00 00 00 00 54 21 54 24 40 00 20 00 29 3A 0E 00 00 00 00,
ENG128745,Instrument_recorder_graphic,05 13 50 00 4D 51 42 32 30 32 30 32 30 53 31 46 47 43 5F 56 57 DC B8 05 00 54 CA D3 C4 48 00 00 00 02 00 00 00 13 00 00 00 19 00 00 00 14 02 00 00 90 00 00 00 02 00 00 00 DD B8 05 00 A2 EC 25 4E B2 02 00 00 3E 00 00 00 7B 00 00 00 00 00 00 00 14 02 00 00 CF 02 00 00 02 00 00 00 DD B8 05 00 5A ED 25 4E F0 00 00 00 0F 00 00 00 88 01 00 00 00 00 00 00 14 02 00 00 CF 02 00 80 02 00 00 00 DC B8 05 00 7C 68 36 8B A3 00 00 00 08 00 00 00 41 1F 00 00 04 00 00 00 13 02 00 00 3C 00 00 00 02 00 00 00 16 B8 05 00 15 42 82 09 73 03 00 00 4C 00 00 00 E3 03 0C 00 00 00 00 00 8A 01 00 00 33 00 00 00 02 00 00 00 61 B5 05 00 8E 2D A5 83 C7 01 00 00 18 00 00 00 A5 01 00 00 00 00 00 00 39 00 00 00 00 00 00 00 04 00 00 00 B1 B7 05 00 9B 84 02 55 75 00 00 00 06 00 00 00 46 01 0F 00 00 00 00 00 80 01 00 00 01 00 00 00 02 00 00 00 64 B8 05 00 60 F2 4F E6 F7 04 00 00 6D 00 00 00 AB 00 18 00 00 00 00 00 BE 01 00 00 01 00 00 00 02 00 00 00 62 B8 05 00 25 C7 35 6F EB 00 00 00 0E 00 00 00 0E 04 00 00 01 00 00 00 B5 01 00 00 00 00 00 00 02 00 00 00 B2 B8 05 00 42 E6 5F 3F 51 04 00 00 5D 00 00 00 E0 00 00 00 64 02 00 00 FA 01 00 00 00 00 00 00 02 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 61 38 63 31 61 35 78 02 00 00 00 15 02 00 00 02 00 00 00 4A FB FF FF 00 00 00 00 61 C6 FF FF 0A 00 00 00 9D 22 6D 1C 01 FF FF FF,
ENG02308,Instrument_recorder_graphic_3,05,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,118,
Elapsed Time: 00:16
19- Gateway
;SW:5WA-907-530-E   HW:5WA-907-530-C ---  CAN Gateway
;Component:GW2020 High   752 7075, Coding:0000113D6600000000000100010301377301610902000100030100010001010000000000000000000000000000000000
;EV_GatewMQB2020,004003,EV_GatewMQB2020_VW38.rod
;Thursday,14,January,2021,14:58:50:29555
;VCDS Version: Release 20.12.0 (x64)  Data version: 20201125 DS322.1
;VCID: 4ACC97EAEC383E6BED6-801E
Group,Description,Actual
IDE00019,Voltage terminal 30,13.0, V
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,15,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,13,
IDE00634,Vehicle electrical system current,23.512, A
IDE00767-ENG18474,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG18475,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG18476,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG18477,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,9,
IDE00767-ENG18512,No. of unscheduled ECU resets-Muc_Reset_Counter,0,
IDE00767-ENG18534,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG18535,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG18536,No. of unscheduled ECU resets-Reason_of_4th_last_reset,2,
IDE00767-ENG18537,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG18538,No. of unscheduled ECU resets-Reason_of_latest_reset,0,
IDE00767-ENG18624,No. of unscheduled ECU resets-Watchdog_Reset_Counter,1,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.3, H
IDE01807-MAS00106,History data 21-Year,2021,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,12,
IDE01807-MAS00109,History data 21-Hours,15, H
IDE01807-MAS00110,History data 21-Minutes,54, min
IDE01807-MAS14375,History data 21-Cycle counter,179,
IDE01807-MAS14376,History data 21-ECU 1,00 7C,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.3, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 44,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.3, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 76,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.3, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 7B,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.3, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG28833,History data 21-Bus_ECU_1,Migration data bus,
IDE01807-ENG28836,History data 21-Bus_ECU_2,Hybrid data bus,
IDE01807-ENG28839,History data 21-Bus_ECU_3,Powertrain data bus,
IDE01807-ENG28842,History data 21-Bus_ECU_4,Hybrid data bus,
IDE01807-ENG28845,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16910,History data 22-Migration data bus,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN_Connect,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG124425,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG124426,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG124427,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG124428,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG124429,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.0, H
IDE01810-MAS00106,History data 24-Year,2000,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,0, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,0,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,00 00 00 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Unknown,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Unknown,
IDE01810-MAS14413,History data 24-Alert events in current cycle,0,
IDE01810-MAS20473,History data 24-Alerting message counter,0,
IDE01812-MAS01468,History data 26-Terminal 15,198,
IDE01812-MAS03173,History data 26-Powertrain data bus,2,
IDE01812-MAS03174,History data 26-Comfort data bus,580,
IDE01812-MAS03177,History data 26-Infotainment data bus,6,
IDE01812-MAS03178,History data 26-Suspension data bus,5,
IDE01812-MAS03180,History data 26-Local data bus,21,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,7,
IDE01812-MAS14374,History data 26-Totals,626,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,3,
IDE01812-MAS16910,History data 26-Migration data bus,2,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,424,
IDE01813-MAS03174,History data 27-Comfort data bus,403,
IDE01813-MAS03177,History data 27-Infotainment data bus,414,
IDE01813-MAS03178,History data 27-Suspension data bus,1068,
IDE01813-MAS12185,History data 27-Hybrid data bus,687,
IDE01813-MAS14374,History data 27-Totals,5640,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,1700,
IDE01813-MAS16910,History data 27-Migration data bus,944,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN_Connect,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,6913,
IDE01814-MAS03174,History data 28-Comfort data bus,200,
IDE01814-MAS03177,History data 28-Infotainment data bus,422,
IDE01814-MAS03178,History data 28-Suspension data bus,10,
IDE01814-MAS12185,History data 28-Hybrid data bus,45696,
IDE01814-MAS14374,History data 28-Totals,392,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,10,
IDE01814-MAS16910,History data 28-Migration data bus,56785,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN_Connect,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2021,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,4,
IDE01816-MAS00109,History data 30-Hours,10, H
IDE01816-MAS00110,History data 30-Minutes,17, min
IDE01816-MAS14375,History data 30-Cycle counter,101,
IDE01816-ENG20570,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG20572,History data 30-Bus_2,Infotainment data bus,
IDE01816-ENG20574,History data 30-Bus_3,Migration data bus,
IDE01816-ENG20576,History data 30-Bus_4,Hybrid data bus,
IDE01816-ENG20578,History data 30-Bus_5,Extended data bus,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,2.8, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,1.4, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,1.3, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.4, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.1, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.3, H
IDE01817-MAS00106,History data 31-Year,2021,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,12,
IDE01817-MAS00109,History data 31-Hours,15, H
IDE01817-MAS00110,History data 31-Minutes,54, min
IDE01817-MAS14375,History data 31-Cycle counter,179,
IDE01817-MAS14376,History data 31-ECU 1,00 7C,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.3, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 44,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.3, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 76,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.3, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 7B,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.3, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG28833,History data 31-Bus_ECU_1,Migration data bus,
IDE01817-ENG28836,History data 31-Bus_ECU_2,Hybrid data bus,
IDE01817-ENG28839,History data 31-Bus_ECU_3,Powertrain data bus,
IDE01817-ENG28842,History data 31-Bus_ECU_4,Hybrid data bus,
IDE01817-ENG28845,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.0, H
IDE01819-MAS00106,History data 33-Year,2000,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,0, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,0,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 00 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Unknown,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2021,
IDE01820-MAS00107,History data 34-Month,1,
IDE01820-MAS00108,History data 34-Day,14,
IDE01820-MAS00109,History data 34-Hours,14, H
IDE01820-MAS00110,History data 34-Minutes,45, min
IDE01820-MAS14375,History data 34-Cycle counter,197,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4A,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,1, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,198,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01831-MAS03159,Generator variant-Manufacturer,Others,
IDE01831-MAS06310,Generator variant-Generator identifier,Unknown (31),
IDE01831-MAS06311,Generator variant-ASIC manufacturer,7,
IDE01831-MAS06312,Generator variant-ASIC variant,31,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.2, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.1, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,EF 35 C8 34,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,can be reached,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not attainable,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,can be reached,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,can be reached,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,can be reached,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,can be reached,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not attainable,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not attainable,
IDE01995-ENG16990,Control module protocol information-Ethernet,Yes,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,Malfunction,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,Malfunction,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,Malfunction,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG124125,Readiness for bus sleep mode-Sleep-Bit 0,System_not_ready_to_sleep,
IDE03150-ENG124124,Readiness for bus sleep mode-Sleep-Bit 1,System_ready_to_sleep_or_sleeping,
IDE03150-ENG124123,Readiness for bus sleep mode-Sleep-Bit 2,System_not_ready_to_sleep,
IDE03150-ENG124122,Readiness for bus sleep mode-Sleep-Bit 3,System_not_ready_to_sleep,
IDE03150-ENG124121,Readiness for bus sleep mode-Sleep-Bit 4,System_not_ready_to_sleep,
IDE03150-ENG124120,Readiness for bus sleep mode-Sleep-Bit 5,System_not_ready_to_sleep,
IDE03150-ENG124119,Readiness for bus sleep mode-Sleep-Bit 6,System_ready_to_sleep_or_sleeping,
IDE03150-ENG124118,Readiness for bus sleep mode-Sleep-Bit 7,System_ready_to_sleep_or_sleeping,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 01 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,available.,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG124117,Bus identification-bus_number,TNF 167462,
IDE04343-ENG124116,Bus identification-bus_type,Bus master,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG124962,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG125035,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG124115,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,A0 0A 59 05 B1,
IDE05960-IDE01827,Generator-Specified generator voltage,13.2, V
IDE05960-IDE01828,Generator-Generator DF Signal,9.700, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,On,
IDE05960-IDE01855,Generator-Generator current,27.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,active,
IDE05960-MAS11758,Generator-Identification,No,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,207.0, A
IDE05960-MAS21325,Generator-Ramp time,3, s
IDE06011-ENG118665,Selected driving profile-driving_profile,INDIVIDUAL,
IDE06011-ENG124961,Selected driving profile-link_profile,link_profile_2,
IDE06011-ENG26214,Selected driving profile-Operation_mode,EV,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,552, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,373, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,84, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,324, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07159-MAS01155,Control module switch-off: counter-Control module,250,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,13.2, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,25, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,210, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,12.00,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,51, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,44, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,12 3F 85 9F,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,8.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,0, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,-40, ∞C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, ∞C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE08794,Battery cell analysis,Initialization,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Front windshield heater,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Plugin Hybrid,
IDE09074-MAS08256,Vehicle properties-Max energy content,10550, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),19.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,6.4, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,15.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,35.2, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,530, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,600, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,477, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,8, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,485, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,477, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,8, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,489,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,480,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,9,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometers,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,15.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,15.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,15.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,15.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,15.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,15.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,30.9, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,1525, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,5,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initialization,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No malfunction detected,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,23,
IDE11738,Ethernet counter connection interruptions: branch 3,23,
IDE11739,Ethernet counter connection interruptions: branch 4,27,
IDE11740,Ethernet counter connection interruptions: branch 5,13,
IDE11741,Ethernet counter connection interruptions: branch 6,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE11755-MAS14856,IP network: VLANs-VLAN,2,
IDE11756,IP network: counter messages with inadmissible VLANs,43632,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,1847,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,00 36 F8 58 8C 82,
IDE11762-IDE02766,Information break recommendation-Malfunction status,No malfunction,
IDE11762-MAS03095,Information break recommendation-Function status,Initialization,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869-IDE09467,IP network: NDP cache-MAC address,30 B4 B8 66 B3 DD,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE11869-MAS14856,IP network: NDP cache-VLAN,0,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,02 7D FA 00 14 00,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,44 3C 88 06 B5 F0,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,30 B4 B8 66 B3 DD,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,30 B4 B8 23 9D 37,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE03615,Component protection participant status-Variant,KS Slave,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 15,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS16979,Component protection participant status-Prioritisation,Not prioritized,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12133-MAS01896,Freewheel - energy-Free run,45, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,5,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,5,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,2,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,3,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,4,
IDE12238,I network: discarded messages counter,1857,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,84,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,left and right lightly handled,
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG124545,Diagnostic capability of the bus interface-Diag_path Bit 0,Control module/bus interface diagnostics capable,
IDE12806-ENG124546,Diagnostic capability of the bus interface-Diag_path Bit 1,Control module/bus interface not diagnostics capable,
IDE12806-ENG124547,Diagnostic capability of the bus interface-Diag_path Bit 2,Control module/bus interface diagnostics capable,
IDE12806-ENG124548,Diagnostic capability of the bus interface-Diag_path Bit 3,Control module/bus interface diagnostics capable,
IDE12806-ENG124549,Diagnostic capability of the bus interface-Diag_path Bit 4,Control module/bus interface diagnostics capable,
IDE12806-ENG124550,Diagnostic capability of the bus interface-Diag_path Bit 5,Control module/bus interface diagnostics capable,
IDE12806-ENG124551,Diagnostic capability of the bus interface-Diag_path Bit 6,Control module/bus interface not diagnostics capable,
IDE12806-ENG124552,Diagnostic capability of the bus interface-Diag_path Bit 7,Control module/bus interface not diagnostics capable,
IDE12807-ENG124572,Participant authenticity-Ecu_authentication Bit 0,Control module/bus interface authentic,
IDE12807-ENG124573,Participant authenticity-Ecu_authentication Bit 1,Control module/bus interface not authentic,
IDE12807-ENG124574,Participant authenticity-Ecu_authentication Bit 2,Control module/bus interface authentic,
IDE12807-ENG124575,Participant authenticity-Ecu_authentication Bit 3,Control module/bus interface authentic,
IDE12807-ENG124576,Participant authenticity-Ecu_authentication Bit 4,Control module/bus interface authentic,
IDE12807-ENG124577,Participant authenticity-Ecu_authentication Bit 5,Control module/bus interface authentic,
IDE12807-ENG124578,Participant authenticity-Ecu_authentication Bit 6,Control module/bus interface not authentic,
IDE12807-ENG124579,Participant authenticity-Ecu_authentication Bit 7,Control module/bus interface not authentic,
IDE12844-ENG20451,Installation list of the 10 bit node addresses-ECU ID,TNF 167462,
IDE12844-ENG20480,Installation list of the 10 bit node addresses-ECU Name,Data Bus OBD Interface,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 10,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG124632,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,58, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,production,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00000131*2021-01-14-13:46:27*6*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00000125*2021-01-14-12:23:34*6*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00000125*2021-01-14-10:36:04*6*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00000125*2021-01-14-09:55:07*6*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00000125*2021-01-13-23:33:49*6*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCDZMW,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,0, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,32,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,29.9, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.3, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,19.9, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,29.3, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,0, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,2046,
IDE14151-MAS17930,Route-based range calculation-Range from destination,2046,
IDE14151-MAS17931,Route-based range calculation-Route-based range,2046,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,activated,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,0,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,0,
IDE14260-ENG124430,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG124431,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 6F 6E 46 30 A1 C5 60,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
MAS00464-MAS00106,Standard - ambient data 1-Year,2082,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,28,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,29,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,142, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,5,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,70, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine running,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,active,
MAS12666-MAS01170,SubSystemNodeAddress of sub bus participant-Subsystem designation,Generator,
MAS12666-ENG39149,SubSystemNodeAddress of sub bus participant-SubSystem Node Address,00 1D,
MAS12668-ENG39150,Actual installation of sub-bus users-SubSystem present Bit 0,not attainable,
MAS12668-ENG45633,Actual installation of sub-bus users-SubSystem present Bit 1,can be reached,
MAS12668-ENG45632,Actual installation of sub-bus users-SubSystem present Bit 2,not attainable,
MAS12668-ENG45631,Actual installation of sub-bus users-SubSystem present Bit 3,not attainable,
MAS12668-ENG45630,Actual installation of sub-bus users-SubSystem present Bit 4,not attainable,
MAS12668-ENG45629,Actual installation of sub-bus users-SubSystem present Bit 5,not attainable,
MAS12668-ENG45628,Actual installation of sub-bus users-SubSystem present Bit 6,not attainable,
MAS12668-ENG45627,Actual installation of sub-bus users-SubSystem present Bit 7,not attainable,
MAS12669-ENG39147,Bus identification of sub-bus users-Bus ID,81,
MAS16744-IDE01836,12V battery-Battery current,0.455, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,11, ∞C
MAS16744-IDE01838,12V battery-Battery temperature,10, ∞C
MAS16744-IDE01839,12V battery-Battery charge level,97, %
MAS16744-IDE01841,12V battery-Battery internal resistance,4.6, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,38, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,4.8, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,59, Ah
MAS16744-MAS00362,12V battery-Battery voltage,13.178, V
MAS16744-MAS06086,12V battery-Total re-charge,72.3, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,63.5, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,89, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,89, %
MAS16744,12V battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge level,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.8, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-3.013, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 01 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,38,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,5F F5 91 F5,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG55051-ENG56247,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG55051-ENG124488,Authentic_time_last_client_response-Current_time_ used,2021-01-14T14:49:15Z,
ENG55051-ENG55667,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2021-01-14T14:49:13Z,
ENG123545-ENG122386,DoIP_Status-Node_address,05 01,
ENG123545-ENG18517,DoIP_Status-number_of_total_ecu,256,
ENG123545-ENG125024,DoIP_Status-number_tcp_connections_ecu,00,
ENG123545-ENG125221,DoIP_Status-routing_activation_status,not active,
ENG123545-ENG125222,DoIP_Status-RoutingActivation Response Code,02,
ENG123545-ENG125257,DoIP_Status-source_port,14 34,
ENG123545-ENG125358,DoIP_Status-tcp_connection_established,not active,
ENG123545-ENG125493,DoIP_Status-vehicle_announcement_identification_response_received,No,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG06005-ENG06085,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG06005-ENG06084,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG06005-ENG124624,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG123549-ENG124430,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG123549-ENG124431,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG123549-ENG124432,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG123549-ENG124473,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG123549-ENG124479,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,0,
ENG123549-ENG124481,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,0,
ENG123549-ENG124485,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,0.403, A
ENG123549-ENG124486,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG123549-ENG124487,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG123549-ENG124972,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,51, A
ENG123549-ENG124992,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,12.00,
ENG123549-ENG125029,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG123549-ENG125025,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG123549-ENG125026,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG123549-ENG125027,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG123549-ENG125028,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG123549-ENG125198,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG123549-ENG125548,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,463.7, V
ENG123550-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG123550-MAS21179,Energy_management_dashboard_display-Energy generator reports,0,
ENG123550-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG123550-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG125015,Gateway app. software identification-nf_name,routing_gateway,
ENG118782-ENG109174,Gateway app. software identification-SW_VERSION,9064,
ENG123653-ENG124625,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG123653-ENG124973,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG123653-ENG20971,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG123653-ENG124133,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG123655-ENG20957,HV-EM_energy_specification-High_voltage_battery_energy_information,1525,
ENG123655-ENG20960,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,1500, Wh
ENG123655-ENG20967,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG123656-ENG20958,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG123656-ENG20961,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG123656-ENG20964,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG123656-ENG20965,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG123657-ENG124461,HV-EM_operation_data-climate_power,0, W
ENG123657-ENG124509,HV-EM_operation_data-dcdc_power,330, W
ENG123657-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,HV-EM_active_clamp_15,
ENG123658-ENG20956,HV-EM_operation_limitation-High_voltage_battery_current_limitation,286.6, A
ENG123658-ENG124134,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,17.5, %
ENG123658-ENG01115,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,Release,
ENG123658-ENG20962,HV-EM_operation_limitation-HV-EM_NV_power_limitation,1500, W
ENG123658-ENG20963,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG123705,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0),
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG20114,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG20115-ENG125229,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG20116,MV-EM_48V_overvoltage_check,---,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,0.0, A
ENG20120,MV-EM_dc_power_desired,0, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,0, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG123711-ENG115189,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG123711-ENG12115,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG123711-ENG12116,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG123711-ENG12117,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG123711-ENG12118,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG123711-ENG124307,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG123711-ENG124308,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG123711-ENG124628,NVEM_12V_Rekuperation-Energienetz,1,
ENG123711-ENG124631,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG123711-ENG124665,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG123711-ENG124666,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG123711-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG123711-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG123711-ENG121521,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG123711-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG123711-ENG125004,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,not coded/not installed,
ENG123711-ENG125034,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG123711-ENG124093,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG123711-ENG125201,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG123711-ENG125234,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG123711-ENG101873,NVEM_12V_Rekuperation-Sonderveto,0,
ENG123711-ENG125292,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG123711-ENG125293,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG123711-ENG125294,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG123711-ENG125295,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG123711-ENG125296,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG123711-ENG125297,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG123711-ENG125327,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG123711-ENG125328,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG123712-ENG124214,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG123712-ENG124226,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG123712-ENG124107,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG123712-ENG124682,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG123712-ENG125326,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG123712-ENG125648,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG119298,NVEM_Grund_BEM_falsch_codiert,0,
ENG123714-ENG124236,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG123714-ENG124137,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG123715-ENG124227,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG123715-ENG124228,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG123715-ENG124707,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG123715-ENG124708,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG123716-ENG124297,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG123716-ENG124298,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG123716-ENG125351,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG123716-ENG125352,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG123716-ENG125353,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG123716-ENG125354,NVEM_Zustand_HLR-TabE_Crash,0,
ENG123716-ENG125355,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG123716-ENG125356,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG123716-ENG125357,NVEM_Zustand_HLR-TabNQ,0,
Elapsed Time: 00:55
