Hi, I'm looking for some coding assistance, I retrofitted highline genuine audi rear camera,
wired in as per previous threads, live, earth,
Black wire FBAS to pin 12 blue connector on mmi
Clear wire FBAS to pin 6 blue connector on mmi
Splicing into can bus high & low grey connector on mmi.
Followed coding as best as possible 5f module bap-vps 0x0b activated
bap-vps 0x0b msg terminal 15.
10 park/steer camera activation.
Tried reseting mmi unit, still no camera action.
I must be missing something?
Thank you in advance!
Monday,11,January,2021,11:51:56:32406
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
VIN: WAUZZZ8V2GA108140 License Plate: GF16
Mileage: 30740km-19100mi Repair Order: 02
Gateway Installation List: 5Q0 907 530 AJ
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F 6C BB BC
VIN: WAUZZZ8V2GA108140 Mileage: 30740km-19100miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BQ HW: 04L 907 309 R
Component: R4 2,0L EDC X22 1199
Revision: B5X22---
Coding: 02190012032701082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
ROD: EV_ECM20TDI01104L906026BN_002_AU37.rod
VCID: 7AADF581AC58B0BB3D6-802E
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 63555000002396
Coding: 12F18AA224200A740178070441C3294851245080E08294F2026100788008
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79AFEA8DA95EBBA334C-802C
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001018334
Coding: 03100104002000011000000000001100
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 40D947698A042A6B332-8014
Humidity sensor: exterior:
Serial number: E818C908000000000001
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 124
Mileage: 30740 km
Date: 2021.01.11
Time: 10:14:45
Outside temperature: 4.5 °C
Engine RPM: 0.00 /min
Temperature downstream of evaporator: 4.5 °C
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061600801716
Coding: 07040A46C24122FD03844004B31C07A80000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 094F9A4DF9BEAB2324C-805C
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 151121 043 0580
Serial number: 151129031738
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61151221
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Serial number: 17 10 2015 00000418
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1532121U5
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000034299272
262912 - Sensor for Anti-Theft Alarm System
B1330 F5 [009] - Alert Emergency Activation Stage 1
Reset counter: 124
Mileage: 30740 km
Date: 2021.01.11
Time: 10:14:44
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291535503325
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002024
VCID: 3C213399E6EC4E8B6FA-8068
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R1BXC8X
VCID: 4BC36045B342F933D60-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 304 13
Serial number: 357670000006D249EC02
Subsystem 2 - Part No SW: ----------- HW: 480 001 201 16
Serial number: 358670000003BC6C281+
Subsystem 3 - Part No SW: ----------- HW: 480 401 712 15
Serial number: 3516502C71E3EAA0922K
Subsystem 4 - Part No SW: ----------- HW: 480 401 712 15
Serial number: 3526502C71E3EAA4E17Y
Subsystem 5 - Part No SW: ----------- HW: 480 401 103 14
Serial number: 3556502A314476B1820/
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 400 712 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B11D73C6032A8
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 011 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C31DBD6140105
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 011 15
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A71E34431B18%
Part No SW: 8V0 953 521 EH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 22121504401425
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 04518B79DE9CF64B57A-8050
Part No SW: 8V0 920 971 R HW: 8V0 920 971 R
Component: KOMBI H03 6423
Coding: 27A408002B8026000100E8001000000000000000
VCID: 4CC16359B64CFE0BDFA-8018
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004342018
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ROD: EV_GatewLear_013.rod
Generator:
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20160825205412 21468
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001512270641
U1101 00 [009] - Active
Reset counter: 124
Mileage: 30740 km
Date: 2021.01.11
Time: 10:14:45
Terminal 30 power supply: 11.1 V
Terminal 15: On
Serial number: HA1-00026.11.15
Coding: 0001
VCID: 4ACD6541BC38E03BED6-801E
Component: TSG FS 020 0041
Serial number: 191015BJH17524
Coding: 005D8A205C01040000001002
VCID: 43D348659B1231732E0-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8103
VCID: 44D14B799E1C364B17A-8010
Component: TSG BFS 020 0041
Serial number: 221015BJL13505
Coding: 005D82205E01040000001002
VCID: 42DD4D618408387B256-8016
Component: LWR-ECU 005 0080
Coding: 01AE000001000000
VCID: 75B7E6BD8546DFC3504-8020
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012A01000300
Shop #: WSC 12345 123 12345
ROD: EV_2CamSysRearPASE.rod
VCID: 303917A93AA4BAEBC32-8064
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Reset counter: 124
Mileage: 30740 km
Date: 2021.01.11
Time: 10:14:44
passive
13705496 - Databus
[message Getriebe_11 not received]
Reset counter: 124
Mileage: 30740 km
Date: 2021.01.11
Time: 10:14:44
passive
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 251115BKO06471
Coding: 004D82204001040000001002
VCID: 45D7567D95260F43004-8010
Component: TSG HBFS 020 0041
Serial number: 251115BKO06142
End----(Elapsed Time: 01:22, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
Address 10,5Q0 919 283 F,recoded (Long Coding-exp),from,0000050001,to,0000150001,(06314/790/00021),
VCDS Release 20.12.0: SRI Reset-SRI3.CLB
Control Module Part Number: 8V0 920 971 R Labels: .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI H03 6423, Coding:27A408002B8026000100E8001000000000000000
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status no warning ---
IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 0 km ---
IDE00511-ESI: time from inspection ESI: Time since Inspection 16 d ---
IDE00515-ESI: oil quality ESI: Oil Quality poor oil quality ---
IDE00517-ESI: soot entry ESI: Soot Quantity 0 km ---
IDE00518-ESI: thermal load ESI: Thermal Load 0 km ---
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 7500 km ---
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 180 d ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection FIX: Maximum Distance to Inspection 30600 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 730 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 400 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 738 d ---
Address 10,5Q0 919 283 F,recoded (Long Coding),from,0000050001,to,0000150001,(06314/790/00021),
Address 10,5Q0 919 283 F,recoded (Long Coding-exp),from,0000150001,to,0000150000,(06314/790/00021),
Address 10,5Q0 919 283 F,recoded (Long Coding),from,0000150001,to,0000150000,(06314/790/00021),
Address 5F,8V1 035 035 B,recoded (Long Coding-exp),from,017351010000000011111102000A00332F002BE7017001009E,to,017351010000000011111102000A00312F002BE7017001009E,(00046/000/00000),
