Audi A3 8V 2016 Pfl to facelift highline camera coding
green30800
C?ID=385454
Hi, I'm looking for some coding assistance, I retrofitted highline genuine audi rear camera,
wired in as per previous threads, live, earth,
Black wire FBAS to pin 12 blue connector on mmi
Clear wire FBAS to pin 6 blue connector on mmi
Splicing into can bus high & low grey connector on mmi.
Followed coding as best as possible 5f module bap-vps 0x0b activated
bap-vps 0x0b msg terminal 15.
10 park/steer camera activation.
Tried reseting mmi unit, still no camera action.
I must be missing something?
Monday,11,January,2021,11:51:56:32406
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WAUZZZ8V2GA108140   License Plate: GF16
Mileage: 30740km-19100mi   Repair Order: 02
Gateway Installation List:  5Q0 907 530 AJ
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F 6C BB BC
VIN: WAUZZZ8V2GA108140   Mileage: 30740km-19100miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BQ    HW: 04L 907 309 R
   Component: R4 2,0L EDC   X22 1199
   Revision: B5X22---
   Coding: 02190012032701082000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
   ROD: EV_ECM20TDI01104L906026BN_002_AU37.rod
   VCID: 7AADF581AC58B0BB3D6-802E
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63555000002396
   Coding: 12F18AA224200A740178070441C3294851245080E08294F2026100788008
   Shop #: WSC 06314 790 00021
   VCID: 79AFEA8DA95EBBA334C-802C
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001018334
   Coding: 03100104002000011000000000001100
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D947698A042A6B332-8014
   Humidity sensor: exterior:
   Serial number: E818C908000000000001
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 124
                    Mileage: 30740 km
                    Date: 2021.01.11
                    Time: 10:14:45
                    Outside temperature: 4.5 °C
                    Engine RPM: 0.00 /min
                    Temperature downstream of evaporator: 4.5 °C
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061600801716
   Coding: 07040A46C24122FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9A4DF9BEAB2324C-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151121  043 0580
   Serial number:         151129031738
   Coding: 0A47F7
   Serial number: 61151221
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 17 10 2015  00000418
   Serial number: 000000000ZY1532121U5
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034299272
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 124
                    Mileage: 30740 km
                    Date: 2021.01.11
                    Time: 10:14:44
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291535503325
   Coding: 0000050001
   VCID: 3C213399E6EC4E8B6FA-8068
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R1BXC8X
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4BC36045B342F933D60-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 304 13
   Serial number: 357670000006D249EC02
   Subsystem 2 - Part No SW: -----------    HW: 480 001 201 16
   Serial number: 358670000003BC6C281+
   Subsystem 3 - Part No SW: -----------    HW: 480 401 712 15
   Serial number: 3516502C71E3EAA0922K
   Subsystem 4 - Part No SW: -----------    HW: 480 401 712 15
   Serial number: 3526502C71E3EAA4E17Y
   Subsystem 5 - Part No SW: -----------    HW: 480 401 103 14
   Serial number: 3556502A314476B1820/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 712 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B11D73C6032A8
   Subsystem 7 - Part No SW: -----------    HW: 480 402 011 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502C31DBD6140105
   Subsystem 8 - Part No SW: -----------    HW: 480 402 011 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502A71E34431B18%
   Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 22121504401425
   Coding: A408
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 04518B79DE9CF64B57A-8050
   Part No SW: 8V0 920 971 R    HW: 8V0 920 971 R
   Component: KOMBI         H03 6423
   Coding: 27A408002B8026000100E8001000000000000000
   VCID: 4CC16359B64CFE0BDFA-8018
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004342018
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   Generator:
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20160825205412 21468
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001512270641
          U1101 00 [009] - Active
                    Reset counter: 124
                    Mileage: 30740 km
                    Date: 2021.01.11
                    Time: 10:14:45
                    Terminal 30 power supply: 11.1 V
                    Terminal 15: On
   Serial number: HA1-00026.11.15
   Coding: 0001
   VCID: 4ACD6541BC38E03BED6-801E
   Serial number: 191015BJH17524
   Coding: 005D8A205C01040000001002
   VCID: 43D348659B1231732E0-8016
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 44D14B799E1C364B17A-8010
   Serial number: 221015BJL13505
   Coding: 005D82205E01040000001002
   VCID: 42DD4D618408387B256-8016
   Coding: 01AE000001000000
   VCID: 75B7E6BD8546DFC3504-8020
   Coding: 027300012A01000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 303917A93AA4BAEBC32-8064
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 124
                    Mileage: 30740 km
                    Date: 2021.01.11
                    Time: 10:14:44
                    passive
13705496 - Databus
          [message Getriebe_11 not received]
                    Reset counter: 124
                    Mileage: 30740 km
                    Date: 2021.01.11
                    Time: 10:14:44
                    passive
   Serial number: 251115BKO06471
   Coding: 004D82204001040000001002
   VCID: 45D7567D95260F43004-8010
   Serial number: 251115BKO06142
End----(Elapsed Time: 01:22, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
Address 10,5Q0 919 283 F,recoded (Long Coding-exp),from,0000050001,to,0000150001,(06314/790/00021),
VCDS Release 20.12.0:  SRI Reset-SRI3.CLB
Control Module Part Number: 8V0 920 971 R       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         H03 6423, Coding:27A408002B8026000100E8001000000000000000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  0 km                                                            ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      16 d                                                            ---
IDE00515-ESI: oil quality        ESI: Oil Quality                                                poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                              0 km                                                            ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               0 km                                                            ---
IDE01153-SIA: maximum value of distance to service                                                      SIA: Maximum Distance to Service                                7500 km                                                         ---
IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    180 d                                                           ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection                                 FIX: Maximum Distance to Inspection                             30600 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Maximum Time to Inspection                                 730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  400 km                                                          ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      738 d                                                           ---
Address 10,5Q0 919 283 F,recoded (Long Coding),from,0000050001,to,0000150001,(06314/790/00021),
Address 10,5Q0 919 283 F,recoded (Long Coding-exp),from,0000150001,to,0000150000,(06314/790/00021),
Address 10,5Q0 919 283 F,recoded (Long Coding),from,0000150001,to,0000150000,(06314/790/00021),
Address 5F,8V1 035 035 B,recoded (Long Coding-exp),from,017351010000000011111102000A00332F002BE7017001009E,to,017351010000000011111102000A00312F002BE7017001009E,(00046/000/00000),
Thank you in advance!
darkchina811
ITALY
C?ID=333184
please elaborate on "still no camera action"
you miss Basic Settings which means the camera has to be calibrated, and, no, VCDS cannot do it.
or it actually could, but you still need the black and white pattern board and most of all need to know where to place it, relative to the car.
but you should see the feed... do you?
green30800
C?ID=385454
Hi, on engaging reverse the screen doesn't even change to camera mode. Surely you'd need the camera to be operating
to calibrate?
@green30800: Wow - what a VERY visually impacting post!! Did you intend the font to be so large?
As for your question - I suspect the DTC below from the hex6C module is telling:
10489856 - No Basic Setting  B2010 00 [009] - -
Officially, calibration of the camera needs VAS 6350 and the process is explained here. But apparently it has been successfully attempted with VCDS as explained here (I've not done this)
EDIT: oopps @downtime - my apology, I didn't see your response
green30800
C?ID=385454
Hi dv52,
But how could you calibrate without a display to begin with.
Would it not use the display lines to calibrate?
Fixed. :cool:
Hi dv52,
Yes, of course the display needs to be active for calibration to work. Clearly the CAN network is OK with the hex6C installation (because it talks to the bus) - but I suspect (guess really) there may be a lingering question regarding how your hex5F module talks to the CAN network.
I note that the Component Protection master module has recorded a CP error and that in performing its other role as the diagnostics master, the hex19 module has been unable to communicate with the MIB. Just joining dots, but this suggests that perhaps the MIB has been retrofitted with a unit that has been hacked to deal with CP.
If this is correct, it's anyone's guess how the hack affects other hex5F functions
green30800
C?ID=385454
Hi, yes the mib2 was hacked, I believe the cp will always linger as a fault code,
But I'm assuming the mib is still programmable/adaptable.
Has anyone else have a hacked mib2 and added factory back up camera?
m87a
Bosnia and Herzegovina
C?ID=156900
yes i have retrofited mib2.5 hacked and also high camera to passat 8.5, no issues at all
i would double check video cable from camera to mib also check maybe you swapped signal wires and ground on mib connector blue one pin 6 and 12
green30800
C?ID=385454
Hi m87a, BIG thank you to you for the rear led light issue i had. All fixed.
Thank you!!
Could confirm the right way round for the ground & signal wires to the mib2.
Would it cause any damage reversing them.
Do you happen to know of any other coding changes needed other than I've done already.
Thank you in advance.
green30800
C?ID=385454
Hi darkchina811,
No don't see any feed, any other ideas?
vastechnics
C?ID=143747
Guys. This problem is related to the car. From factory 4K pdc and camera dont work. Need proper coding. That is problem!
when you have camera work optical parking will no display. Only camera and beeping
m87a
C?ID=156900
Thank you!!
no problem, glad you got it sorted, it depends on wiring harness sometimes they swap wires, there is no harm try to swap them and test to see if you have picture
green30800
C?ID=385454
Hi, I've followed this coding procedure. Does this seem 100% correct.
It kind of feels my reverse gear selection isn't triggering the camera.
Also on the BAP-VPS 0x0b some say terminal 15, this states Comfort data?
8. Coding (Using Ross-Tech VCDS)
coding side using his VCDS and VCDS knowledge]
a. 19 > Can Gateway
i. Installation List
ii. Add 6c Back up cam
iii. Adaption
iv. Ensure following coded - (108)-Installation list; specified installations-
Node_0x6C
b. 6C > Back Up Cam
i. Long Coding
ii. Select bits in bytes that are applicable to your vehicle
iii. (Mine was coded to [027300012201000300])
c. 5F > Information Electronics
i. Adaptions
ii. following MMI screen / display needed to be activated:
1. (21)-Vehicle function list BAP-VPS_0x0B - activated
2. (22)-Vehicle function list BAP-VPS_0x0B_msg_bus - Comfort data
bus
iii. Long Coding
iv. Byte 19 > Bit 1 = InActive (This is for Low only!)
d. 10 > Park/Steer Assist
i. Long Coding
ii. Byte 2 > Bits 4-5 = 10
Do I also need to use Long code helper in 6c module,
Anyone know what the changes in there should be?
vastechnics
C?ID=143747
Try this:
- Park steer assist put coding back to original. So make back up camera coding off.
- In 5F turn off byte 19 bit 1. Make this codings:
VPS to activated
VPS bus to Terminal 15
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,aktiviert ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,nicht aktiviert ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,nicht aktiviert ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,aktiviert ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,nicht aktiviert ,60
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,aktiviert ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Klemme 15 ,64
then reset MMI and test must work
green30800
C?ID=385454
Thank you Vastechnics, will give it a go.
green30800
C?ID=385454
Sunday,17,January,2021,18:34:39:32406
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 47 52 55 5F 6C BB BC
   Revision: B5X22---
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000821611
   VCID: 333318A5CBB281F3BE0-8066
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:56
                    Outside temperature: 5 °C
                    Temperature downstream of evaporator: 23.8 °C
329476 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [009] - Actuator stuck
                    Fault Frequency: 29
                    Reset counter: 166
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:57
                    Voltage terminal 30: 11.9 V
                    Inside temperature: 17.6 °C
                    Fresh air/recirculating air/back pressure door specified value: 872
                    Actual value for fresh air/recirculation air flow flap: 512
                    Actual value for fresh air/recirculation air flow flap: 84.5 %
   Coding: 0A47F7
   Coding: 00006C
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:55
   Coding: 0000050001
   Coding: A408
   Generator:
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:56
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Coding: 0001
   Coding: 8103
   Part No SW: 8V0 035 465 D    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0420
   Serial number: AUZ8ZAFN901USYA
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 392F2A8DE9DE7BA374C-806C
   Part No SW: 8V1 035 035 B    HW: 8V1 035 035
   Component: MU-P-LND-EU   054 1168
   Serial number: A698E0H2525659
   Coding: 017351010000000011111102000A00332F002BE5017001009E
   Shop #: WSC 00046 123 12345
   VCID: 313F12AD31AEB3E3CCC-8064
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0175
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY2053WV
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL106041700010242
   Compact disc data bank:
   Component: Gracenote2  --- 1016
9 Faults Found:
          B201A 00 [009] - -
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:04
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: MDUA201/Front
15360768 - Component Protection
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:58
                    Voltage terminal 30: 12.0 V
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:41
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:41
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:07
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:18:25
                    Voltage terminal 30: 15.0 V
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:00
                    BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:00
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:17:00
   Coding: 027300012201000300
          B2010 00 [009] - -
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:55
                    passive
13705496 - Databus
                    Reset counter: 126
                    Mileage: 30740 km
                    Date: 2021.01.17
                    Time: 18:16:55
                    passive
End----------(Elapsed Time: 01:30, VBatt start/end: 14.8V/14.8V)-----------
Hi Vastechnics,
I tried the couple of differences to the coding, carried out reset to mmi. still can't get any camera display.
anyone have any other ideas??
