Hi folks, thanks so much taking a look at my problem. Car is 2012 Q7 TDI
Few weeks ago I lost ac, there were no codes present, HVAC control ac button would stay on, and did not blink. Checked the AC low and high pressure and it was within specs. On audi g65 valve goes our pretty frequently so I replaced it as a first step. That did not resolve the issue, I had a hard time determining if the compressor clutch was engaging so I spliced the compressor wire about 8 inches from the compressor wire plug (please note, I did not cut the wire just spliced it) and give it 12V I did not hear the clutch engaging but I did get a code: 01232 - A/C Compressor Regulator Valve (N280) - not sure if me splicing the wire and applying the voltage caused an HVAC controller issue. I also had 01320 - Control Module for Climatronic (J255). Deleting both codes did not work, they came right back up, I tried multiple times.
I got a new compressor and changed it out, the old compressor was bone dry and the clutch seized for sure so I was on the right track, bonus here is that compressor comes with brand new N280 valve built into it, but the code 01232 did not go away. I was unable to charge the AC because this code prevented the compressor from turning on. I then consulted a mechanic friend and he instructed me to cut the compressor wire and run power directly to it - please note that this time I cut the wires completely off. This got the compressor on and I was able to refill the system and the temp in cabin dropped as well, but when I connected the wires back into the loom the codes were still present and AC did not work, the AC button on the controller in the cabin did not blink, and it did stay on. This is what I did next without any success of getting rid of 01232:
-located the ground for the compressor wire - checked continuity and it was good
-I cut the ground wire about 8 inches from the compressor plug and ran new ground to new spot
-I checked the continuity from my cut to the female socket on the plug - it was good
-performed adaptation on the front HVAC control unit - channel 1 and 3, cannel 5 caused the "upper limit exceed code"
-put in used rear HVAC control - the 01320 code also remained with the new unit
I think that my issue might be the front HVAC controller but I don't know how to code the used unit to the car, it tells me that the vin is an issue - rear used unit did not require coding. Can someone help me with how to "teach" the new unit what the vin is. Channel 81 under HVAC adaptation says error and does not let me input anything the cell for entering values is grayed out. Any other input and ideas are welcomed, thanks in advance!
Here is the scan:
Here is the scan:
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA H18 0009
Revision: 54H18--- Serial number:
Coding: 2A2A4012252600050000
Shop #: WSC 09178 003 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 61C9CF72706E008E7C-8034
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Coding: 001378
Shop #: WSC 99999 999 83333
ROD: EV_TCMAL991031_002.rod
VCID: 3C775E06B74C0D660F-8068
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
Shop #: WSC 31414 790 00001
VCID: 34677626571CC526C7-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603501930676
Coding: 0000131
Shop #: WSC 49318 000 1048576
VCID: 25419B62ECC6ACAE40-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH
Revision: 00---026 Serial number: 00000000306780
Coding: 0002A036
VCID: 25419B622CC6ACAE40-8070
007 - Short to Ground
Fault Status: 01100111
Reset counter: 223
Mileage: 120872 km
Date: 2020.12.12
Time: 12:30:24
Current: 0.780 A
01487 - System Function Test
001 - Upper Limit Exceeded
Fault Status: 01100001
Reset counter: 223
Mileage: 120872 km
Date: 2020.12.12
Time: 10:49:57
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0039123
VCID: 6FEDB94A7EBAA6FEFA-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09YJ7X
Coding: 0014131
VCID: 2B556D5A8A229ADE96-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME3F665344L
Subsystem 3 - Serial number: 6342QSME3F662966T
Subsystem 4 - Serial number: 6352QSME6B685750P
Subsystem 5 - Serial number: 6362QSME12671D5CP
Subsystem 6 - Serial number: 63734SME1865155E3
Subsystem 7 - Serial number: 63834SME38640960
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026113300149
Coding: 0002042
VCID: 285F92569BD4B1C67B-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 R HW: 4L0 920 984 R
Component: KOMBIINSTR. H22 0411
Revision: 00200000 Serial number: LWW40CW6H
Coding: 8BD664040100CF05020205
Shop #: WSC 59040 001 1048576
VCID: 428B20FEDDA87B9645-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0057
Revision: LB500035 Serial number: 3500L11B240156
Coding: 00C303
VCID: 3E73540EA9501F7621-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790123736
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AA
Revision: 00---010 Serial number: 00000000306442
Coding: 0000006
VCID: 68DFD2565B5471C6BB-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 223
Mileage: 120872 km
Date: 2020.12.12
Time: 12:30:24
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000018913052
Coding: 00581300000011110000
VCID: 326B703E6D08CB16D5-8066
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000019198419
Coding: 011F07205E40440004
VCID: 489F32D6FB9451C69B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01613365920000
Coding: 3569693
VCID: 387F42164B742146EB-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0160
Revision: CH003000 Serial number: 00000000018891
Coding: 030000
Shop #: WSC 44064 001 1048576
VCID: 2959975240DE88CE64-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190137491
Coding: 0758477
VCID: 2345857AE2F2529E2E-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000100753
Coding: 0012001
VCID: 5EB3F48E89103F7641-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000019219269
VCID: 479D31EAF68A5EBE92-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 111209-0001-008
Coding: 1147A71010020000
ROD: EV_HeadlRegulBasic.rod
VCID: 428B20FED5A87B9645-8016
Component: Radio U SIRIU H53 0133
Revision: AB001007 Serial number: 236L%0B7501379
Coding: 020007010000000000
VCID: 2447866627FC55A657-8070
Part No SW: 4L2 035 746 G HW: 4L2 035 746
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 097L70B7507673
Coding: 180200060004E3EF41000345EF632003140000000100000000
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130K90BS066802
Subsystem 3 - Part No SW: 4L0 919 614 B HW: 4L0 919 614 B
Component: E0380 Bedient H01 0060
Serial number: 00000001955119
Component: CD-Database 3371
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000019175498
Coding: 010E07204040230004
VCID: 46833CEEF18047B669-8012
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J1Y40S3
Coding: 1021101
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7AE464FAC5DE6DF-8038
Subsystem 3 - Serial number: RD08.12.11--H57001001A0012ÿ
Subsystem 4 - Serial number: 1A0012ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 122747277-----
Coding: 0003595
VCID: 26439C6E91C0A7B649-8072
Component: J_245_EE16_SKB10H12 0220
Component: J_394_EE16_SKB10H12 0220
Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000019174239
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37361132301776
Coding: 0221266
VCID: 2A5B685E85D883D66D-807E
