I have a MY19 Golf R with LED adaptive headlights. Before this car, I had a MY18 GTI with the same headlights. Upon starting the car, the GTI’s headlights would level like this:
As you can see, they lower, move to the left, move the right, then go back up.
My Golf R’s headlights do level when I start the car, but don‘t seem to do it fully. Instead, they will lower, move to the left, then go back up. (no right movement). They do however function fully when driving and no fault codes are present (yes, the scan I posted below is a few weeks old, but nothing has been changed).
I don’t remember whether or not this is how they functioned when I bought the car/before I started making coding/adaptation changes, but I did reach out on Vortex forums to see if any other fellow R owner’s headlights level the way mine do. They declined, saying theirs do the full left-right movement before returning to level position. I assume it must be just a minor coding/adaptation change to get them to fully level. Any help would be much appreciated.
Tuesday,25,August,2020,08:19:37:52534
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WVWVA7AU1KW224276 License Plate:
Mileage: 6550km-4069mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU1KW224276 Mileage: 6550km-4069miles
Address 01: Engine (J623-DLRA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 092500122466010E3004
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: 4EC56B49D05BF61B90F-801A
Readiness: 0010 0101
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2405
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: 2411E9E1EE572C4B16B-8070
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 61059000000609
Coding: 01FA6BA1502221704579030760C96980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
VCID: 0655936978ABFE5B68F-8052
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 6103279128
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D34A7D0B190B730F1-8016
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000110500401211140A
VCID: 6D87CCC57D1D2D03895-8038
Air quality sensor:
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 01001915701239
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 0B43A25D63C98333371-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 190523 043 0551
Serial number: 190529040911
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0205
Serial number: S7Y19M06D18H23M45S55
Coding: 0008DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000008061904220204
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418319168
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CC161412647C40BFEB-8018
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 330047C159FFC728949C810580401600000000000000000004
VCID: 44D149610E170C4B36B-8010
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 28051941350748
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292D9142DF58ABAA3-806C
Serial number: 003GCR0C22G4
VCID: 47CB5E6D3F212753D39-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000BKP8VC
Coding: 303344
Subsystem 2 - Part No SW: ----------- HW: 480 001 506 19
Serial number: 357000000004F374CD3X
Subsystem 3 - Part No SW: ----------- HW: 480 001 506 19
Serial number: 358000000003A020FC3I
Subsystem 4 - Part No SW: ----------- HW: 480 401 906 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B2EFDF5B5226P
Subsystem 5 - Part No SW: ----------- HW: 480 401 906 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001A6F001345535P
Subsystem 6 - Part No SW: ----------- HW: 480 401 706 19
Component: FrontSensor_D 005 6149
Serial number: 35500019CF001346C853
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 706 19
Component: FrontSensor_P 005 6149
Serial number: 35600019CF001346746$
Part No SW: 5G1 920 891 B HW: 5G1 920 891 B
Component: KOMBI 403 4191
Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
VCID: 2C0101C18687E40BDEB-8078
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 06061911603847
Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CBC9701BD61BB0F-803A
Component: 0-01-0d-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 29190001188330099222
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 4546471505
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00017.05.19
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000163099011
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F10B5A1A589E3EDD-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0518404430
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D273C856DFD7D83795-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0518694848
Coding: 020111
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS002 0287
Serial number: YE007SDI2875A
Coding: 003E13208000040000000000
ROD: EV_DCU2DriveSideMAXHKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000031016617
Coding: 111000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21318176E7748B4EB-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD05GS0V
Coding: 2200000002AAAAAA000000000000
VCID: 2E050BC9B09B961BF0F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 09061910524172
Coding: 000000050900165206710F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 353724A555CDA5C3B15-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS002 0287
Serial number: YE007SDR01781
ROD: EV_DCU2PasseSideMAXHKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000031198255
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 026 E HW: 5NA 035 026
Component: MU-H-NS-US H55 1418
Serial number: A851L0KB000501
Coding: 027310020000000021220002001808001F0507F401200405DE
Shop #: WSC 12345 123 12345
VCID: 392F289579D541A355D-806C
Subsystem 1 - Part No SW: 5G6 919 606 B HW: 5G6 919 606 B
Component: ABT_High-2 H61 9214
Serial number: VWZ6ZJX0573408
Subsystem 2 - Part No SW: V03 959 806 NE HW: -----------
Component: NAR 2020 --- 0076
Component: Gracenote2 --- 3013
Component: OCULowMQBUS 009 0570
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H11 0610
Serial number: 05021915K12530
Coding: 0003070000000201002213548150890084000E20012000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D945711A0F106B123-8014
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 190419202209
VCID: 2F3B16CDB7919F13FB9-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
