Auto leveling headlights not fully leveling mk7.5 Golf R
MK7.5
C?ID=402753
I have a MY19 Golf R with LED adaptive headlights. Before this car, I had a MY18 GTI with the same headlights. Upon starting the car, the GTI’s headlights would level like this:
As you can see, they lower, move to the left, move the right, then go back up.
My Golf R’s headlights do level when I start the car, but don‘t seem to do it fully. Instead, they will lower, move to the left, then go back up. (no right movement). They do however function fully when driving and no fault codes are present (yes, the scan I posted below is a few weeks old, but nothing has been changed).
I don’t remember whether or not this is how they functioned when I bought the car/before I started making coding/adaptation changes, but I did reach out on Vortex forums to see if any other fellow R owner’s headlights level the way mine do. They declined, saying theirs do the full left-right movement before returning to level position. I assume it must be just a minor coding/adaptation change to get them to fully level. Any help would be much appreciated.
Tuesday,25,August,2020,08:19:37:52534
VIN: WVWVA7AU1KW224276   License Plate:
Mileage: 6550km-4069mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU1KW224276   Mileage: 6550km-4069miles
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4EC56B49D05BF61B90F-801A
Readiness: 0010 0101
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2411E9E1EE572C4B16B-8070
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 61059000000609
   Coding: 01FA6BA1502221704579030760C96980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0655936978ABFE5B68F-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6103279128
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34A7D0B190B730F1-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500401211140A
   VCID: 6D87CCC57D1D2D03895-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001915701239
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B43A25D63C98333371-805E
   Component: WWS    190523  043 0551
   Serial number:         190529040911
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M06D18H23M45S55
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000008061904220204
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418319168
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC161412647C40BFEB-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330047C159FFC728949C810580401600000000000000000004
   VCID: 44D149610E170C4B36B-8010
   Serial number: 28051941350748
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292D9142DF58ABAA3-806C
   Serial number: 003GCR0C22G4
   VCID: 47CB5E6D3F212753D39-8012
   Occupant Detection:
   Serial number: IBH00000000000BKP8VC
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 357000000004F374CD3X
   Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 358000000003A020FC3I
   Subsystem 4 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B2EFDF5B5226P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A6F001345535P
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF001346C853
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF001346746$
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: 2C0101C18687E40BDEB-8078
   Serial number: 06061911603847
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CBC9701BD61BB0F-803A
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001188330099222
   Coding: 2DFFFF
   Serial number: 4546471505
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00017.05.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000163099011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F10B5A1A589E3EDD-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0518404430
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273C856DFD7D83795-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0518694848
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SDI2875A
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031016617
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C21318176E7748B4EB-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05GS0V
   Coding: 2200000002AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E050BC9B09B961BF0F-807A
   Component: FCM MQB Low   002 0345
   Serial number: 09061910524172
   Coding: 000000050900165206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353724A555CDA5C3B15-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SDR01781
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031198255
   Coding: 091000
   Part No SW: 5NA 035 026 E    HW: 5NA 035 026
   Component: MU-H-NS-US    H55 1418
   Serial number: A851L0KB000501
   Coding: 027310020000000021220002001808001F0507F401200405DE
   VCID: 392F289579D541A355D-806C
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0573408
   Subsystem 2 - Part No SW: V03 959 806 NE    HW: -----------
   Component: NAR 2020  --- 0076
   Compact Disc Database:
   Component: Gracenote2  --- 3013
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H11 0610
   Serial number: 05021915K12530
   Coding: 0003070000000201002213548150890084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D945711A0F106B123-8014
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190419202209
   VCID: 2F3B16CDB7919F13FB9-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
siLc
Tallinn, Estonia
C?ID=330192
The coding of the A5 camera says the LED lights aren't DLA (Dynamic Light Assist) - perhaps the GTI's lights were? See the PR number list on the vehicle data sticker - there should be either 8IU (DLA) or 8IT (non-DLA).
MK7.5
C?ID=402753
this is what i’ve got
MK7.5
C?ID=402753
Think it could be an adapatation under 4B module that somehow got changed? A lot of it is in german it looks like.
siLc
Tallinn, Estonia
C?ID=330192
This PR list doesn't even mention headlight type, so you probably got whatever comes stock with the NAR Golf R 7.5.
MK7.5
C?ID=402753
Ok gotcha, just wanted to make sure. It’s not an issue, because like I said, no fault codes and the headlights do work as they should.
I was just making sure I didn’t accidentally change something
MK7.5
C?ID=402753
UPDATE:
By reaching out to a member who retrofit Mk7.5 LED headlights to his GTI, I was able to find the adaptation. It’s called “Presentation Run Dynamic AFS Light”. It looks like it’s set to “Not Active” by default on NAR 2019 Golf R’s, changing it to “active” and now the lights auto level the same way my GTI’s did.
downtime
Finland
C?ID=280813
But it does not mean they function the same way. According to your AFS control unit D6 & D7 your headlights are either 8IX or 8IU.
My guess would be that they're 8IX so no DLA. And no change to functionality even you change the presentation mode to dynamic AFS.
MK7.5
C?ID=402753
Does DLA mean Dynamic Light Assist? Because the headlights do turn with the steering wheel, automatic high beams, and cornering lights come on when I turn on my turn signal/turn the steering wheel, which is the same way my GTI functioned. The only thing I was missing was the headlights auto leveling the way they do in the video.
I did find a Youtube video of a 2019 R, and their headlights did not do the full auto-leveling presentation either. So it looks like that feature is disabled from the factory on the NAR R, whereas is standard on the GTI.
Other than that, the headlights are the same. If DLA means something else, then neither the GTI or R headlights are DLA in the US
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Presentation mode will indeed turn on some more cool-looking wiggling-around at startup, that's what it means. High-beam assist will work either way, but that's not DLA.
NAR headlights don't have the shutter for DLA. You can code support for it and it'll sort of look like it's working, no fault codes, things will move around in a DLA-like fashion while you're driving, but it can't cut the notch out of the beam for cars in front of you. You don't want to configure NAR lights for that. Someday I'd like to import RoW headlamps, it's on the Round Tuit list.
MK7.5
C?ID=402753
Gotcha. All I was looking for was the presentation mode, I wasn’t looking to change anything else about the headlights. Thanks for your help everyone.
