Hello RossTech,
I need your help please with troubleshooting this EOS roof. Currently the trunk is stuck as the two latches on both sides (right & left inside) are in close position preventing the trunk to open. The roof is close and everything else but those two latches do not go back to Open position to let the trunk to open from outside.
I am aware of the rest of the errors for engine and airbag, I will fix those once I am done with the roof. Thanks in advance!
here is a full scan
here is a full scan
Sunday,08,March,2020,18:45:46:15095
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 19.6.2.2
VIN: WVWAA71F67V020165 License Plate: EOS 2007
Mileage: 168590km-104756mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 65 72
VIN: WVWAA71F67V020165 Mileage: 168590km-104756miles
26-Auto Roof -- Status: Malfunction 1010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1Q0 907 115 E HW: 1Q0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: VWX7Z0F83NR97O
Coding: 041C010A18070160
Shop #: WSC 09148 444 00518
VCID: 2E7DE714B92DB23F07-807B
001092 - EVAP Purge Control Valve (N80)
P0444 - 004 - Circuit Open - MIL ON
Fault Status: 11100100
Mileage: 168597 km
Time: 00:08:03
RPM: 696 /min
Load: 20.0 %
Temperature: 57.0∞C
Temperature: 18.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 004 - Malfunction / Open Circuit
Mileage: 168597 km
Time: 00:08:03
RPM: 696 /min
Load: 20.0 %
Temperature: 57.0∞C
Temperature: 18.0∞C
Voltage: 14.605 V
000579 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 004 - Malfunction - MIL ON
Mileage: 168597 km
Time: 00:08:03
RPM: 696 /min
Load: 20.0 %
Temperature: 57.0∞C
Temperature: 18.0∞C
Voltage: 14.605 V
Readiness: 0110 0101
Revision: 00H11001
Coding: 0021218
Shop #: WSC 00020 000 00000
VCID: 73CB3660128FDFD7A8-8027
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Part No SW: 1Q0 907 044 HW: 1Q0 907 044
Component: ClimatronicPQ35 093 0101
Revision: 00093002 Serial number: 00000000000000
VCID: 6AF52B0445451E1F1B-803F
00830 - Convertible Top Control Module (J256)
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000006128806
Coding: 118C0F0340041500470000000F00000000285D035C0000
VCID: 3753C270467773F754-8063
Component: Wischer 181006 020 0501
Coding: 00038805
Shop #: WSC 00020
9 Faults Found:
Fault Status: 00101100
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Fault Status: 00101010
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.10 V
Reset counter: 22
Mileage: 168597 km
Voltage: 12.00 V
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 13 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B30011PZ-
Coding: 0012595
VCID: 3A55DB4475656E9FAB-806F
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 3ECX7
Subsystem 3 - Serial number: 0001.01.000000700000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ6332SRB40419D49A5ˇÜ63
Subsystem 5 - Serial number: 9D49A5ˇÜ6342SRB403CC52ACCˇÜ63
Subsystem 6 - Serial number: C52ACCˇÜ6372URB4017D47C49ˇÜ63
Subsystem 7 - Serial number: D47C49ˇÜ6382URB4017D47824ˇ
Subsystem 8 - Serial number: D47824ˇ
Fault Status: 11100001
Mileage: 168597 km
Time: 00:08:49
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 036 0070
Coding: 0000021
VCID: 022563A45D35E65FB3-8057
Part No SW: 1Q0 920 953 D HW: 1Q0 920 953 D
Revision: V0003000 Serial number: VWX7Z0F83NR97O
Coding: 0023207
Shop #: WSC 09150 444 58449
VCID: 3245F364AD1596DF63-8067
Reset counter: 22
Mileage: 168597 km
Time: 00:29:41
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106A048A3D
Coding: 3DBF234007005000
VCID: 2C79ED1C8F31C02F29-8079
Reset counter: 21
Mileage: 168597 km
Time: 00:29:42
Component: IMMO VDD 1610
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
Component: Verdecksteuergeraet 0622
Revision: 0032000K Serial number: 062980126
Coding: 0655360
02805 - System Interference
014 - Defective
Fault Status: 01101110
Reset counter: 237
Mileage: 168597 km
Time: 00:48:18
Voltage: 12.20 V
Voltage: 12.20 V
Voltage: 4.90 V
Error Code: 4
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1Q0 959 701 C
Component: Tuer-SG 024 2737
Coding: 0000247
Shop #: WSC 21124 210 01865
VCID: 3449F57C570198EF71-8061
00120 - Outside Warning Light/Door exit Light Driver Side
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CL
Component: KSG PQ35 RDK 051 0218
Revision: 00051000 Serial number: 00000000000000
Coding: 13908A800186281B0804040FB0080E0488DCA0
VCID: 042965BC4721E86F81-8051
00532 - Supply Voltage B+
Reset counter: 22
Mileage: 168597 km
Time: 21:51:35
Reset counter: 22
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1Q0 959 702 B
Component: Tuer-SG 024 2729
Coding: 0001206
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0016
Revision: 00014000 Serial number: VWZ4Z7F6164335
Coding: 0040401
VCID: 1E1D37D4C98D22BFB7-804B
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 021 2705
Coding: 0000128
Component: RDK 0440
Coding: 0100101
Fault Status: 00110100
Reset counter: 247
Mileage: 167867 km
Time: 12:21:52
00667 - Ambient Temperature Signal
Fault Status: 00111000
Reset counter: 22
Mileage: 168597 km
00625 - Vehicle Speed Signal
Fault Frequency: 9
Reset counter: 22
Mileage: 168597 km
Time: 00:00:06
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1Q0 959 704
Coding: 0000128
VCID: 74C9357C1781D8EFB1-8021
End-------------------------(Elapsed Time: 01:19)--------------------------
