VA EOS Roof troubleshooting
Pfaizulla
C?ID=322498
Hello RossTech,
I need your help please with troubleshooting this EOS roof. Currently the trunk is stuck as the two latches on both sides (right & left inside) are in close position preventing the trunk to open. The roof is close and everything else but those two latches do not go back to Open position to let the trunk to open from outside.
I am aware of the rest of the errors for engine and airbag, I will fix those once I am done with the roof. Thanks in advance!
here is a full scan
Sunday,08,March,2020,18:45:46:15095
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 19.6.2.2
VIN: WVWAA71F67V020165   License Plate: EOS 2007
Mileage: 168590km-104756mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 65 72
VIN: WVWAA71F67V020165   Mileage: 168590km-104756miles
26-Auto Roof -- Status: Malfunction 1010
   Part No SW: 1Q0 907 115 E    HW: 1Q0 907 115 B
   Revision: 5BH15---    Serial number: VWX7Z0F83NR97O
   Coding: 041C010A18070160
   Shop #: WSC 09148 444 00518
   VCID: 2E7DE714B92DB23F07-807B
001092 - EVAP Purge Control Valve (N80)
               P0444 - 004 - Circuit Open - MIL ON
                    Fault Status: 11100100
                    Mileage: 168597 km
                    Time: 00:08:03
                    RPM: 696 /min
                    Load: 20.0 %
                    Temperature: 57.0∞C
                    Temperature: 18.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit
                    Mileage: 168597 km
                    Time: 00:08:03
                    RPM: 696 /min
                    Load: 20.0 %
                    Temperature: 57.0∞C
                    Temperature: 18.0∞C
                    Voltage: 14.605 V
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 004 - Malfunction - MIL ON
                    Mileage: 168597 km
                    Time: 00:08:03
                    RPM: 696 /min
                    Load: 20.0 %
                    Temperature: 57.0∞C
                    Temperature: 18.0∞C
                    Voltage: 14.605 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021218
   Shop #: WSC 00020 000 00000
   VCID: 73CB3660128FDFD7A8-8027
   Part No SW: 1Q0 907 044     HW: 1Q0 907 044
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: 6AF52B0445451E1F1B-803F
00830 - Convertible Top Control Module (J256)
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000006128806
   Coding: 118C0F0340041500470000000F00000000285D035C0000
   VCID: 3753C270467773F754-8063
   Component: Wischer 181006 020  0501
   Coding: 00038805
   Shop #: WSC 00020
9 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Fault Status: 00101010
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.10 V
                    Reset counter: 22
                    Mileage: 168597 km
                    Voltage: 12.00 V
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 13 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B30011PZ-
   Coding: 0012595
   VCID: 3A55DB4475656E9FAB-806F
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3ECX7
   Subsystem 3 - Serial number: 0001.01.000000700000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332SRB40419D49A5ˇÜ63
   Subsystem 5 - Serial number: 9D49A5ˇÜ6342SRB403CC52ACCˇÜ63
   Subsystem 6 - Serial number: C52ACCˇÜ6372URB4017D47C49ˇÜ63
   Subsystem 7 - Serial number: D47C49ˇÜ6382URB4017D47824ˇ
   Subsystem 8 - Serial number: D47824ˇ
01218 - Side Airbag Igniter; Passenger Side (N200)
                    Fault Status: 11100001
                    Mileage: 168597 km
                    Time: 00:08:49
   Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
   Coding: 0000021
   VCID: 022563A45D35E65FB3-8057
   Part No SW: 1Q0 920 953 D    HW: 1Q0 920 953 D
   Revision: V0003000    Serial number: VWX7Z0F83NR97O
   Coding: 0023207
   Shop #: WSC 09150 444 58449
   VCID: 3245F364AD1596DF63-8067
                    Reset counter: 22
                    Mileage: 168597 km
                    Time: 00:29:41
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 3100106A048A3D
   Coding: 3DBF234007005000
   VCID: 2C79ED1C8F31C02F29-8079
                    Reset counter: 21
                    Mileage: 168597 km
                    Time: 00:29:42
   Component: IMMO            VDD 1610
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
   Component: Verdecksteuergeraet 0622
   Revision: 0032000K    Serial number: 062980126
   Coding: 0655360
02805 - System Interference
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 237
                    Mileage: 168597 km
                    Time: 00:48:18
                    Voltage: 12.20 V
                    Voltage: 12.20 V
                    Voltage: 4.90 V
                    Error Code: 4
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1Q0 959 701 C
   Component: Tuer-SG         024 2737
   Coding: 0000247
   Shop #: WSC 21124 210 01865
   VCID: 3449F57C570198EF71-8061
00120 - Outside Warning Light/Door exit Light Driver Side
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Part No SW: 1K0 959 433 CT    HW: 1K0 959 433 CL
   Component:    KSG PQ35 RDK 051 0218
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13908A800186281B0804040FB0080E0488DCA0
   VCID: 042965BC4721E86F81-8051
                    Reset counter: 22
                    Mileage: 168597 km
                    Time: 21:51:35
                    Reset counter: 22
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1Q0 959 702 B
   Component: Tuer-SG         024 2729
   Coding: 0001206
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0016
   Revision: 00014000    Serial number: VWZ4Z7F6164335
   Coding: 0040401
   VCID: 1E1D37D4C98D22BFB7-804B
   Part No: 1Q0 959 703
   Component: Tuer-SG         021 2705
   Coding: 0000128
   Component:    RDK              0440
   Coding: 0100101
                    Fault Status: 00110100
                    Reset counter: 247
                    Mileage: 167867 km
                    Time: 12:21:52
00667 - Ambient Temperature Signal
                    Fault Status: 00111000
                    Reset counter: 22
                    Mileage: 168597 km
00625 - Vehicle Speed Signal
                    Fault Frequency: 9
                    Reset counter: 22
                    Mileage: 168597 km
                    Time: 00:00:06
   Part No: 1Q0 959 704
   Coding: 0000128
   VCID: 74C9357C1781D8EFB1-8021
End-------------------------(Elapsed Time: 01:19)--------------------------
Moving to Car Repair Support.
Jef
HQ
Pfaizulla
C?ID=322498
Hi Jef,
The windows go down all 4 of them, then run roof all the way, then I heard the roof pump- that is all I heard. next when I closed everything again, and when I tried to open the trunk from Outside, it did not open because the two latches on left and right side holding the trunk are engaged and preventing the trunk to be opened. RIght now I need a process to set those two latches to set to unlock and let the trunk to be opened from outside (what basic setting perform this task?)
here is photos of current roof status:
finally, I honestly do not undrestand the last part of your reply
In the video, at about what time does it physically match up your car in terms of so far open or closed? What is the data from 26-08-002 show? Can you post a photo of your car in its current state?
Also, DO NOT CLICK ON THIS LINK -----> For real, do not do this... bad things can happen.
I am sorry
Jef
HQ
Your photos don't show up. You can freely host photos on imgur.com
https://forums.ross-tech.com/showthread.php?95-How-To-Post-Pictures
The final part has information that if used incorrectly can damage/destroy things. I've been keeping my eye open for a good working Eos to make a video on it. Anyway, get those photos up so we can see how things look.
Pfaizulla
C?ID=322498
Hi Jeff,
Please check and see if you can see below pictures.
I am not sure why do not they show on the post even though they are between
tags.
here is the URLs just in case the image did not show up here
https://imgur.com/JrdgxK5
https://imgur.com/7AbtLKQ
tags.
Because the URL you put between the IMG tags was for an Imgur page, not an actual picture. An actual picture will generally end in .jpg or .png.
Jef
HQ
I would say based on my past experience with various Eoses... Eoss... how does one make Eos plural? Anyway, I would suspect you can do the Basic Settings steps to manually go through each step of top operation.
DANGER DANGER DANGER ---> click here for dreadful information <--- DANGER DANGER DANGER
I would say that after "BS 013, tailgate opening" is complete, normal top operation with the switch will occur an the fault code can be cleared out.
Pfaizulla
C?ID=322498
thank you for fixing it!
Pfaizulla
C?ID=322498
Thank you Jeff.
I Will take a look tomorrow, any special configuration if I install a new roof module?
Jef
HQ
I would be cautiously optimistic that carrying out the first few Basic Settings steps will get things to where they need to be. I don't have any reason to think the Roof Electronics module is bad at this time. Do you have a grasp of the dangerous instructions?
Pfaizulla
C?ID=322498
I ended up selling the car like this as the latches never opened to let the trunk open. Thank you for providing support.
Jef
HQ
So you tried the Basic Setting steps?
