Eos - Convertible top info
Jef
HQ
If you need help with your Eos, post your questions in the Car Repair Support section.
Circle of life:
http://wiki.ross-tech.com/wiki/index.php/VW_Eos_(1F)_Convertible_Top
MVB 002 has 12 bits originally, but around 2009 models, a 13th bit (G672) was added.
Bit 1 (G556)
  • Left upper A-pillar
  • When the sunroof separates from A-pillar, bit changes from 1 to 0
  • Should be 1 when M segment is fully seated to A-pillar
  • Bit 2 (G557) should flip at same time
Bit 2 (G557)
  • Right upper A-pillar
  • Bit 1 (G556) should flip at same time
Bit 3 (G560)
  • Left upper C-segment, on the striker pin
  • When C-segment unlocks from M-segment, value changes from 1 to 0
  • Bit 4 (G561)should flip same time
Bit 4 (G561)
  • Right upper C-segment, on the striker pin
  • Bit 3 (G560) should flip same time
Bit 5 (G562)
  • Left upper C-segment hinge
  • When C-Segment is fully raised onto roof, changes from 0 to 1
  • There is no right side version of this sensor
Bit 6 (G563)
  • Left forward area of trunk
  • When the left latch for the trunk lid unlocks, value changes from 1 to 0
  • Bit 7 (G564) should flip same time
Bit 7 (G564)
  • Right forward area of trunk
  • When the right latch for the trunk lid unlocks, value changes from 1 to 0
  • Bit 6 (G563) should flip same time
Bit 8 (G565)
  • Left side of trunk, close to left hydraulic cylinder for top
  • When top has been fully lowered into storage, changes from 0 to 1
  • Bit 13 (G672) should flip at the same time (2009 and newer)
Bit 9 (G566)
  • Left side, on frame/body, where the trim flap is located
  • When the roof pillar flaps are fully extend (rear lid tilted back), changes 0 to 1
  • Bit 12 (G567) should flip at the same time
Bit 10 (G558)
  • Left front area of Roof Pillar
  • When C-segment lifts to top of roof to unlock Roof Pillar from A-pillar, value changes from 1 to 0
  • Bit 11 (G559) should flip at the same time
Bit 11 (G559)
  • Right front area of Roof Pillar
  • Bit 10 (G558) should flip at the same time
Bit 12 (G567)
  • Right side, on frame/body, where the trim flap is located
  • Bit 9 (G566) should flip at the same time
Bit 13 (G672) (2009 and newer)
  • Right side of trunk, close to right hydraulic cylinder for top
  • Bit 8 (G565) should flip at the same time
