A huge thanks to you @NEtech for fixing this so quickly!
Great work!
Great work!
Try updating your LCode.exe to the one linked in Post #100 of this thread.i got an error today:
already downloaded the latest version, same errorTry updating your LCode.exe to the one linked in Post #100 of this thread.
Sorry, i mean a programming syntax list (for the LBL-file), if i want to create a new LBL file.Most are shown in help, if you press F1.
Added a pdf file link in the first post, also new LCode version, 2.0.18.0
Found out I had forgotten to program [Insert] for short Coding, long time ago.
Here is latest LCode and pdf file.
Yes i know, but threre is no Long Coding example inside. We write here about your LCode and i want to know it for your great program. Is there more "programming language" than the following 7 lines:You have an template.lbl file in \Labels
LC,01,0,Enable
LC,02,7=,Check Byte
LC,05,0-7,50,Headlight
LC,05,0-7,50,Decimal Value (Resolution 50 ms) (Example: 20 is 20 x 50 = 1000 ms)
LC,15,0~1,00,- EDS 2
LC,15,0~1,01,- EDS 3
LC,15,0~1,02,- EDS 4
No, sorry, I don't understand what yo meanOr a function where i can discribe, that if for example i set in Byte 5 Bit 1, then it automatic sets in Byte 10 Bit 3.
LC,01,3,Enable Function A ;if Byte 1/Bit 3 is set (=1)
LC,01,3>,05,6,= ;then Byte 5 /Bit6 is also set (=1)
LC,01,3>,06,7,- ;then Byte 6 /Bit7 is negated set (=0)
;Brake Master Cylinder / Brake Servo
LC,00,0~3,I,INFO: Define the Brake Master Cylinder and the "Dual-Rate" Brake Servo
LC,00,0~3,01,- TMC D22,2 | 10" single brake servo (LHD)
LC,00,0~3,02,- TMC D22,2 | 11" single brake servo (LHD) (Caddy,Touran)
LC,00,0~3,03,- TMC D22,2 | 7/8" tandem brake servo (RHD)
LC,00,0~3,04,- TMC D23,8 | 10" single brake servo (LHD)
LC,00,0~3,05,- TMC D23,8 | 11" single brake servo (LHD) (Passat NMS)
LC,00,0~3,06,- TMC D23,8 | 7/8" tandem brake servo (RHD)
LC,00,4~7,I,INFO: Define the vehicle variant
LC,00,4~7,10,- A3(8P) / Golf,Jetta(1K+5K) / Leon(1P) / Octavia(1Z)
LC,00,4~7,20,- Golf Plus (5M/52) / Altea & Toledo (5P)
LC,00,4~7,30,- Touran (1T3)
LC,00,4~7,40,- Caddy (2K,2C)
LC,00,4~7,50,- Eos (1F/AH)
LC,00,4~7,60,- Caddy Maxi (2K,2C)
LC,00,4~7,70,- Scirocco (13)
LC,00,4~7,80,- Superb (3T)
LC,00,4~7,90,- Yeti (5L)
LC,00,4~7,A0,- Jetta Mk6 (162)
LC,00,4~7,B0,- Jetta Mk6 (162) [NAR >>MY'13]
LC,00,4~7,C0,- Passat NMS (A3)
LC,00,4~7,E0,- Beetle Mk2 (5C) [some MY'12&13]
LC,00,4~7,F0,- Beetle Mk2 (5C)
LC,00,7=,Check Value of Byte 8
