- Feb 7, 2014
- 3,590
- 5,725
- Denmark
- C?ID=56995
Here is the latest VCDSToolbox test version.
Feature list Version: 20.11.0
Drag and drop Autoscan file, you are then able to use/see this information:
Open the current Autoscan in Windows Notepad Program
Buttons with link to:
Search possibilities:
Easy send Autoscan files to NEtech/Ross-Tech for development (NOT support, use Ross-Tech Forum for support!)
See many information's of Battery History data made with VCDS, if available.
Analyze different Adaptation or measurement values.
Compare log files for adaptation or coding changes, made with VCDS.
Calculate Coding for Injector for CFW engine.
Latest change log:
{ 19.8.0}
{ Show German umlaut correct}
{ Model info corrections }
{ 19.9.0}
{ A search icon instead of to short text in some languages}
{ Show differences in color for coding read from coding change log }
Number of DTC, search DTC on Ross-Tech wiki/forum
Engine data (if engine name available)
Change power Hp/kW and link to Engine Wiki
Model year, Model type, Platform
Mileage if in Autoscan
Link to erWin for current Model
Where car is produced, link to factory in Google maps
Link of Distributor for the current showed Autoscan
Click on VIN, if you have access to Partslink24
You can also click on Tree-view Window to find and load an Autoscan fileOpen the current Autoscan in Windows Notepad Program
Ross-Tech Wiki
Distributor
Partslink24
Ross-Tech videos
Distributor shop
12 Buttons with different help/programs for VCDS, several can be added/changed in vcdsscan.ini
Search in all Autoscan files
Search and show Abbreviations
Search direct at Ross-Tech Wiki/Forum
Latest change log:
{ 19.8.0}
{ 19.9.0}
