Latest VCDSToolbox version
NEtech
Denmark
C?ID=56995
Here is the latest VCDSToolbox test version.
Feature list Version: 20.11.0
Drag and drop Autoscan file, you are then able to use/see this information:
Number of DTC, search DTC on Ross-Tech wiki/forum​
Engine data (if engine name available)​
Change power Hp/kW and link to Engine Wiki
Model year, Model type, Platform​
Mileage if in Autoscan​
Link to erWin for current Model​
Where car is produced, link to factory in Google maps​
Link of Distributor for the current showed Autoscan​
Click on VIN, if you have access to Partslink24​
You can also click on Tree-view Window to find and load an Autoscan file
Open the current Autoscan in Windows Notepad Program
Buttons with link to:
Ross-Tech Wiki
Distributor​
Partslink24​
Ross-Tech videos​
Distributor shop​
12 Buttons with different help/programs for VCDS, several can be added/changed in vcdsscan.ini​
Search possibilities:
Search in all Autoscan files​
Search and show Abbreviations​
Search direct at Ross-Tech Wiki/Forum​
Easy send Autoscan files to NEtech/Ross-Tech for development (NOT support, use Ross-Tech Forum for support!)
See many information's of Battery History data made with VCDS, if available.
Analyze different Adaptation or measurement values.
Compare log files for adaptation or coding changes, made with VCDS.
Calculate Coding for Injector for CFW engine.
Latest change log:
{ 19.8.0}
{ Show German umlaut correct}
{ Model info corrections }
{ 19.9.0}
{ A search icon instead of to short text in some languages}
{ Show differences in color for coding read from coding change log }
NEtech
Denmark
C?ID=56995
{ 19.10.0}
{ Show German (and some other UTF) umlaut correct again - file saved with MAC!}
{ 19.11.0}
{ 19.11.1}
{ Alternator information bottom of autoscan }
On many new CAN Gateways from 2018, there is LIN data for Alternator.
First try on decryption of the data (a lot is still missing), here an example from Autoscan:
  • Alternator:
  • Component: 4-00-03-00-04
If Alternator data is available in the Autoscan, it is showed at the bottom of VCDSToolbox screen.
Amp data are from PR-codes.
NitrousOxide
Jamaica
C?ID=269481
I'm just looking at these screenshots here.
Does CFW Injector Coding, mean I can now do some calibration to these new Audi S3 injectors that has been giving me a rather lumpy idle on my MK5 GTI (but OEM smooth everywhere else in the revv range)?
NEtech
Denmark
C?ID=56995
This is special injector coding for CFWA engines.
Please make a new thread with autoscan about your problem, for coding new injectors.
NEtech
Denmark
C?ID=56995
{ 20.02.0}
{ Model info corrections}
{ Text changed in "Sendscan"} It is not for support ;)
Definition and English changed a little in GitLab.
Link is updated in #1.
NEtech
Denmark
C?ID=56995
{ 20.02.1}
{ New Acronyms added}
{ New controller for Battery history}
{ 20.03.0}
{ Program action button failure improved}
{ First test for comparing two UDS Adaptation Channel files}
Comparing 2 UDS Adaptation Channel files, can be done from different languages, but must be from same controller.
For comparing you can either choose the two files (In Explorer) and Drag&Drop them into VCDSToolbox.
Or choose the two files, Right click > Copy, then Right click in VCDSToolbox and choose [Insert (Paste) 2 UDS adaptation files].
Drag & Drop:
Right Click:
Compared:
^^^ NEtech: very impressive indeed - yet another in a long list of VCDS triumphs!!!
May I ask 3x related questions, please?
First- Sort Criteria: given that most (all?) instances where a user would seek to compare 2 x admaps is to find instances in which the settings are different, is it possible for your App to sort the compare-results by this variable, rather than by Tag number (which I assume is what happens now) - and is it possible to display those channels with different settings first? This would streamline the subsequent user task greatly, especially in modules with a high channel count - like the BCM for modern MQB vehicles (I think).
And apropos of my third question below - can the sort criteria for channels with different settings separately identify the "missing channels" as a bunch?
Second- File Export: Is it possible to export the admap compare results from your App- perhaps as a .CSV file?
Third- Missing Channels: Can you confirm that the "join-string" in what I assume is an SQL search algorithm in your App - will return ALL the channels in BOTH admaps regardless of whether they appear in both admaps (i.e. how does the compare facility handle channels that appear in only 1 x admap and in particular - if the the channel appears only in the 2nd selected admap)? I ask because this scenario has proven problematic for me in the past (but then I'm terrible with SQL queries!!)
Again - much kudos for simplifying what can be often a tedious process!!
NEtech
Denmark
C?ID=56995
It is a very simple search/compare, nothing sql or something like that.
I check which file is biggest, that goes on the left side (I asume it has most lines).
I just take one line at a time, so it is not possible to do a lot of search hocus Pocus :)
If a line is missing on the right that should mostly be found and show empty cell, if there is an line on the right that is not in the left, it should be showed at the end.
But there are certainly files, where there will be a problem.
I will think about csv file, thanks.
technodevotee
Worcester, UK
C?ID=339141
This is a great tool.
I have a slight issue though.
When I load an autoscan from my Touareg, the engine is shown as 190kw (258 HP) but according to the vehicle data sticker in the handbook and spare wheel well it is actually 210kw.
4RJ CR7
CR74RJ Touareg BMT V6TDI 210KW
SBT LC5M ID TDI A8A DEN
The autoscan contains
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 G    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---
   Coding: 292A4032057E050335180000000400000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TDI011760907401G 001002
   ROD: EV_ECM30TDI011760907401G.rod
   VCID: 197A3B6B18550E4EE5-804C
BTW, the label for this value in the software has changed from HP to Hk somewhere along the line
NEtech
Denmark
C?ID=56995
Thank you very much, I have fixed it.
NEtech
Denmark
C?ID=56995
New version, link is updated and feature list added, in #1.
{ 20.11.0}
{ Pull down menu for more search options}
NEtech
Denmark
C?ID=56995
New test version, link is updated in #1.
{ 21.2.0 }
{ New Acronyms added }
{ UK DE CZ translation }
{ 21.3.0 }
{ CI translation }
{ 21.4.0 }
{ Information about Service History }
{ High resolution mileage is shown also }
Drag and drop file named: "blockmap-17*.csv"
The Controller Blockmap csv file made by VCDS, must include IDE03911 etc.
They are used in many model, like these for example:
MQB
Golf 8 platform
Skoda superb (3V)
Skoda Rapid (NH)
Skoda Fabia (NJ)
VW Polo (6C)
VW Polo (AW)
VW Touran (5T)
VW Tiguan (AD)
VW Arteon (3H)
VW Passat (3G)
VW Tourareg (7P6)
VW Crafter (SY)
Audi A6/A7 (4G)
Audi Q7 (4M)
Audi Q5 (FY)
Just drag & drop one file, as showed above for comparing controller map files.
NEtech
Denmark
C?ID=56995
New version, link is updated in #1.
{ 21.4.2 }
Additional info for service history, from Drag and drop file named: "blockmap-17*.csv"
These models have a high resolution mileage, seems to be 1 mm instead of normal 1 meter !
(4G) 2013-2018?
(4H) 2010-2017?
(7P5) 2013-2014
(7P6) 2015-2018?
If it is possible to calculate, I have not been able to find out (yet).
NEtech
Denmark
C?ID=56995
{ 21.5.0 }
NEtech
Denmark
C?ID=56995
{ 21.6.0 }
{ ID.3/4 Battery history file support}
I have no success finding what the data in Record 16 is related to :cry:
NEtech
Denmark
C?ID=56995
{ 21.8.0 }
NEtech
Denmark
C?ID=56995
{ 21.9.0 }
NEtech
Denmark
C?ID=56995
{ 22.1.0 }
