Latest VCDSToolbox version
   #41
Apparently he always starts VCDS as administrator
I don't suppose you asked him why he does that? :confused:
"Doctor, I get terrible headaches when I bang my head on the wall!"
J.Wittl
Germany (PCI)
Oh, I did ask him :D This was the response:
VCDS und manche andere Programme lassen sich auf meinem PC nur mit Adminrechten starten. Warum das so ist kann ich nur mutmaßen . (eventuell sind es die Sicherheitseinstellungen oder Userrechte)
VCDS and some other programs can only be started with admin rights on my PC. Why this is the case I can only speculate. (maybe it is the security settings or user rights)
So I left it at that point and didn't ask any further ;)
  • Informative
Personally, if I couldn't figure out how to fix that some other way, I'd re-install Windows.
NEtech
Denmark
C?ID=56995
{ 23.10.0 }
{ New Model info }
{ New Acronyms added }
{ Data added for HV battery }
{ Data (Debug) for charging connector [19]}
Link here.
   #49
AINils
Germany (AIB)
C?ID=56975
@NEtech Just a small hint, nothing which is really important. But maybe it's easy to fix.
If a customer load a Seat Ateca, it will show as Seat Leon as both cars use "5F" in 7+8th digit of VIN. But you can differ them by using Production digit as Ateca is produced in "R - Martorell"
   #50
NEtech
Denmark
C?ID=56995
Thank you, I just checked, it is not so easy, there are Leon's made in Martorell and there are also a Cupra Ateca made in Kvasiny.
Until now I check with VIN above 500000 and yes that is not completely correct.
I see if I can make it better.
   #51
AINils
Germany (AIB)
C?ID=56975
Not a real issue in my opinion, but got a customer request in this case.
If you need some help with files or research let me know
   #55
NEtech
Denmark
C?ID=56995
   #56
NEtech
Denmark
C?ID=56995
There are really many Acronyms, used in VAG data.
Some years we had a list of unknown, here is a list again, maybe someone has some input.
AAA
ABA    Autonomous Braking? No
ABBA
ABP
AFR    Airgap Front Right / Amplitude.. / Average.. /
AMB
AMR
APC
AV    Autonomous Vehicle ?
AZK    bruges i instrument?
AXS
BFU    Boot and Firmware Update ?
BSC
BHM
BKL
BCO
CHA
CHC
CHS
CTA
CSI
COA
CSW
DAF
DCL
DFCC    Decimal Fault Code Checks Decimal Fault Code Ciffer ?
DGM
DNH
DR
EFM
LVC
EFC
EPAS    Electric Power Assisted Steering
EC
ECE
EEH
EMA
ENI
ESM
EQC
FDC    FahrDynamik Kontroll
FOC    Field Oriented Control (ic)
FSF
FTA
FuSI
GE
GEM
HDV    Hill Descent ??
HMS
HSB    Hill Start ??
HTO
HWI
KFC    Kupplung  ? (power steering)
KSB    KS B?
LFC
LBS    something with doorlock
LER    Lock E R  something with doorlock - Liftgate - Keyless Entry
LGI
LPS
LRD
LRH
LTC
LUB
MCC
MDK    used in instrument?
MO_BZS
MWP
NG
NMH
NR
NSW
NT
OCC
ORH    ? DC link voltage
ORL    ? DC link voltage
PAO
POR
PSF    Pre S? Front?
QS
RAT
RBF
RPC
RPH
RSF
RSR
RV
RWB    Range W B calculation
SAG
SAK    (Charisma (driving profile))
SCB
SCG
SCL
SHPS
SFH
SNA
SSG
STP
SWL
TGR
TGS
TIG
TSR    something with camera?
TST
UOTA
USHL    Garage opener?
USZ
VIC
VIT
VKU    something with gearbox?
VSL
VMM
VZM
WDT
WLA    something with camera?
WPCA
WSS
WUN
ZFH
ZFO
ZPC
ZSM
ZSS    ?
RDL    Rear Dynamic Light?
RDL    Rear Drive Light?
PTI    service?
SB    SeatBelt?
ISM    Intelligent Stepper Motor?
sLWR    ?LeuchtWeitenRegelung (Licht Weiten Regulierung)
SIECU    Sensor Integrated Electronic Control Unit
CoCo
HoCo
PKE
EOE
NVEM
TTNR
HLR
SEPIC
DSRC
MAR    Monitor Activity Ratio?
VTA
IMS    ?
PSA    Port Security Assessment ?
LVI    LastVerteiler Innenraum ()?
   #58
NEtech
Denmark
C?ID=56995
Every time I code Batteries in UDS CAN Gateway, where there are no pull-down, I have to look in label files, what code for manufacturer is.
I have just added this text on "VCDS support tips"
Are there errors or comments?
   #59
NEtech
Denmark
C?ID=56995
{ 25.11.0 }
{ New Model info }
{ Added 12V Battery codes in Important tips}
{ Added 2 data items with [19] drag+drop in VCDSToolbox}
{ Added no. HV bat. cell installed with [8C] drag+drop in VCDSToolbox}
{ Added calculated mean cell voltage with [8C] drag+drop in VCDSToolbox}
{ Added more HV batteries part numbers}
Link here https://forums.ross-tech.com/
   #60
NEtech
Denmark
C?ID=56995
{ 25.12.0 }
{ New Model info }
{ Some change in default ini file links }
{ Changed different HV battery data items with [19]+[8C] drag+drop in VCDSToolbox}
{ Possible to export all HV battery data to comma separated txt file (Press [Save data])}
{ Info: REMEMBER to use SA 20103 producing [8C] controller map! (if there is no SFD)}
{ Info: for importing txt into excel if your country use , (comma) and not . (Dot)}
{ Check delimited > Next > check Comma > Next > check Advanced > Choose Decimal separator . and Thousand separator , }
Example from HV bat. data
