- Jan 30, 2014
- 3,191
- 5,171
- Near Philadelphia, PA, USA
Well Miss Tiggy just had an oil change and full service 3 weeks ago. This week, she is going bonkers and running really rich. Here are the fuel trims:
I suspect based on the fuel trims we have a coolant temp sensor going, or an input air temp sensor, or maybe even a vacuum leak.
Here is the Autoscan... looks like the fan controller is going or has gone.
Symptoms: Can barely idol at start in the morning... has to have help with go pedal... Once fully warmed, it will run but it is getting 10-12mpg in town.
We need to find which sensor has gone up or where the vacuum leak lays...
This Tiguan with 88,400 on it will be leaving the family soon. It's been maintained at the highest level... never a service missed. If there is interest and you are in the Lansdale area, you know where to find me.
Address 01: Engine (06J 906 026 DP)
15:31:29 Group 032: Lambda Control (Mixture Adaptation)
1.1 % Adaptation (Idle) Bank 1 Sensor 1
3.1 % Adaptation (Partial) Bank 1 Sensor 1
15:31:29 Group 033: Lambda Control
-9.4 % Lambda Control Bank 1 Sensor 1
0.45 V Sensor Voltage Bank 1 Sensor 1
Wednesday,10,July,2019,15:32:09
VCDS Release 19.6.1 (x64): Generic OBD2
Mode 1:Read Data
06:Short Term Trim - Bank 1 -1.6 %
07:Long Term Trim - Bank 1 6.3 %
Wednesday,10,July,2019,15:31:04:52622
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Chassis Type: AX-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F 52
53 55 56 62 65 6C 72 77
VIN: WVGBV7AX9AW510081 Mileage: 142300km-88421miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 DP HW: 06J 906 026 DA
Component: MED17.5 TFSI 2,0 8220
Revision: AAH07--- Serial number:
Coding: 0423010A190F0160
Shop #: WSC 39837 001 1048576
VCID: FBB6B1BABA286E974C-80AE
006469 - Control Module 1 for Cooling Fan
P1945 - 000 - Output Short Circuit - Intermittent
Fault Frequency: 14
Mileage: 140216 km
Date: 2013.10.09
Time: 12:32:36
RPM: 2757 /min
Load: 61.2 %
Speed: 119.0 km/h
Temperature: 90.0°C
Temperature: 38.0°C
Absolute Pres.: 1000.0 mbar
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 28
Mileage: 140222 km
Date: 2013.10.09
Time: 12:35:36
RPM: 2773 /min
Load: 48.2 %
Speed: 120.0 km/h
Temperature: 92.0°C
Temperature: 38.0°C
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 25
Mileage: 140255 km
Date: 2013.10.09
Time: 12:52:26
RPM: 2792 /min
Load: 27.4 %
Speed: 121.0 km/h
Temperature: 91.0°C
Temperature: 43.0°C
Absolute Pres.: 990.0 mbar
Part No SW: 09G 927 750 KN HW: 09G 927 750 KN
Component: AQ 250 6F 1704
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 06485 444 64721
VCID: 875EDD4AF6E03A7758-80D2
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 - - Intermittent
Fault Frequency: 6
Reset counter: 197
Mileage: 79105 km
Date: 2010.01.08
Time: 08:59:51
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000002168669
Coding: 0002332
VCID: B93A6BB2F0949C871E-80EC
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 133 1213
Revision: 00133024 Serial number: 00000000000000
VCID: ED928FE2F45CF027C2-80B8
Part No SW: 5K0 937 087 C HW: 5K0 937 087 C
Component: BCM PQ35 H+ 008 0019
Revision: BL008001
Coding: 6D580A3BF8232EC48088008534000D0441555186536D8D605C8000000000
VCID: B52267821C8C78E7FA-80E0
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14080 012 0203
Serial number: N1955119 °203!
Coding: 009795
Component: RLS 250809 05 54 0402
Coding: 07304D
Part No SW: 5N0 959 655 K HW: 5N0 959 655 K
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E3PF8STTP
Coding: 0012336
VCID: C5C217428C6CE8676A-8090
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000004N1T
Subsystem 3 - Serial number: 0014.07.090000100000660049ÿ† 63
Subsystem 4 - Serial number: 660049ÿ† 6332MTS666071909 ÿ† 63
Subsystem 5 - Serial number: 71909 ÿ† 6342MTS614721929 ÿ† 63
Subsystem 6 - Serial number: 21929 ÿ† 6351HTS6IDMNV8KR ÿ† 63
Subsystem 7 - Serial number: NV8KR ÿ† 6361HTS6ODC4V8KR ÿ† 63
Subsystem 8 - Serial number: 4V8KR ÿ† 63727TS6L56526KR ÿ† 63
Subsystem 9 - Serial number: 526KR ÿ† 63827TS6JV0626KJ ÿ
Subsystem 10 - Serial number: 626KJ ÿ
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0001332
VCID: FAB8B4BEB512579F57-80AE
Component: E0221 002 0030
00194 - Ignition Key Removal Lock
Part No SW: 5N0 920 971 A HW: 5N0 920 971 A
Component: KOMBI H05 0206
Coding: 210F00
VCID: B02C5696EBEE5DCFA9-80E4
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No: 1K0 907 530 AE
Component: J533 Gateway H06 0110
Revision: H06 01 Serial number: 100809F2000398
Coding: FD83FF07504613006002
VCID: EA9884FEC5B2E71FA7-80BE
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: CBD6217AAA081E17BC-809E
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667540744
VCID: A600B0CED12A037F43-80F2
Part No SW: 5N0 959 760 A HW: 5N0 959 760 A
Component: MEM-FS H04 0032
Revision: AA000000 Serial number: 00001001322296
Coding: 20581300000044440011
VCID: B83C6EB60B9E858FE1-80EC
Part No SW: 3C0 035 684 C HW: 3C0 035 684 A
Component: RNS-MID H02 1040
Revision: AB001001 Serial number: VWZ6Z7J8154076
Coding: 040500000100008600
VCID: A306A9DAA218F65724-80F6
Reset counter: 211
Mileage: 133592 km
Fault Status: 00100111
Reset counter: 251
Mileage: 141770 km
Date: 2013.10.15
Time: 14:01:06
Part No SW: 5N0 959 701 C HW: 5N0 959 701 C
Component: Tuer-SG 008 2005
Coding: 0005567
VCID: B5226782DC8C78E7FA-80E0
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.163 0703
Revision: 1AH03273 Serial number: 00091830417102
Coding: 0000258
VCID: BA3874BEF592979F17-80EE
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198613481
VCID: E79EFDCA1EA0DA77B8-80B2
Part No SW: 1K0 907 532 HW: 1K0 907 951
Component: EZE_2 H06 0110
Coding: 050B0500
VCID: E680F0CE11AAC37F83-80B2
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE19SKB12 H01 0220
Part No SW: 5N0 959 702 C HW: 5N0 959 702 C
Coding: 0005566
VCID: B620608EC18A73FFF3-80E2
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 E HW: 5N0 907 801 E
Component: J540 EPB3 VW-13948 0008
Revision: H10 Serial number: 00000000035057
Coding: 0000057
VCID: B12A539228E454C7A6-80E4
Component: AFS-Steuergeraet 0142
Coding: 1356998
VCID: B4245A86D7F661EFCD-80E0
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000020
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000020
Reset counter: 211
Mileage: 133592 km
Reset counter: 251
Mileage: 141770 km
Date: 2013.10.15
Time: 14:01:06
Part No SW: 5N0 959 703 C HW: 5N0 959 703 C
Component: Tuer-SG 007 2001
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: B73E6D8AC6808AF7E8-80E2
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 008 0817
Coding: 018705
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 HW: 5N0 907 441
Component: J772__Rearview 0021
Revision: 00H05000 Serial number: PA8 J973108
Coding: 0100010
VCID: EC9482E6CF46F92FD5-80B8
Part No SW: 5N0 959 704 C HW: 5N0 959 704 C
Coding: 0001168
VCID: B83C6EB6CB9E858FE1-80EC
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005074112
Coding: 0011070
End----------(Elapsed Time: 02:23, VBatt start/end: 13.6V/13.5V)-----------
