Looks like Miss Tiggy is going for service again! 2010 Tiguan SEL 2.0L Auto
Bruce
Near Philadelphia, PA, USA
Well Miss Tiggy just had an oil change and full service 3 weeks ago. This week, she is going bonkers and running really rich. Here are the fuel trims:
                Address 01: Engine  (06J 906 026 DP)
15:31:29 Group 032: Lambda Control (Mixture Adaptation)
  1.1 %  Adaptation (Idle) Bank 1 Sensor 1
  3.1 %  Adaptation (Partial) Bank 1 Sensor 1
15:31:29 Group 033: Lambda Control
  -9.4 %  Lambda Control Bank 1 Sensor 1
  0.45 V  Sensor Voltage Bank 1 Sensor 1
Wednesday,10,July,2019,15:32:09
VCDS Release 19.6.1 (x64):  Generic OBD2
Mode 1:Read Data
06:Short Term Trim - Bank 1     -1.6 %
07:Long Term Trim - Bank 1     6.3 %
I suspect based on the fuel trims we have a coolant temp sensor going, or an input air temp sensor, or maybe even a vacuum leak.
Here is the Autoscan... looks like the fan controller is going or has gone.
Symptoms: Can barely idol at start in the morning... has to have help with go pedal... Once fully warmed, it will run but it is getting 10-12mpg in town.
We need to find which sensor has gone up or where the vacuum leak lays...
Wednesday,10,July,2019,15:31:04:52622
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Chassis Type: AX-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F 52
          53 55 56 62 65 6C 72 77
VIN: WVGBV7AX9AW510081   Mileage: 142300km-88421miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 DP    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    8220
   Revision: AAH07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 39837 001 1048576
   VCID: FBB6B1BABA286E974C-80AE
006469 - Control Module 1 for Cooling Fan
               P1945 - 000 - Output Short Circuit - Intermittent
                    Fault Frequency: 14
                    Mileage: 140216 km
                    Date: 2013.10.09
                    Time: 12:32:36
                    RPM: 2757 /min
                    Load: 61.2 %
                    Speed: 119.0 km/h
                    Temperature: 90.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 28
                    Mileage: 140222 km
                    Date: 2013.10.09
                    Time: 12:35:36
                    RPM: 2773 /min
                    Load: 48.2 %
                    Speed: 120.0 km/h
                    Temperature: 92.0°C
                    Temperature: 38.0°C
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 25
                    Mileage: 140255 km
                    Date: 2013.10.09
                    Time: 12:52:26
                    RPM: 2792 /min
                    Load: 27.4 %
                    Speed: 121.0 km/h
                    Temperature: 91.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 990.0 mbar
   Part No SW: 09G 927 750 KN    HW: 09G 927 750 KN
   Component: AQ 250 6F           1704
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 06485 444 64721
   VCID: 875EDD4AF6E03A7758-80D2
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -  - Intermittent
                    Reset counter: 197
                    Mileage: 79105 km
                    Date: 2010.01.08
                    Time: 08:59:51
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000002168669
   Coding: 0002332
   VCID: B93A6BB2F0949C871E-80EC
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: ED928FE2F45CF027C2-80B8
   Part No SW: 5K0 937 087 C    HW: 5K0 937 087 C
   Component: BCM PQ35 H+   008 0019
   Revision: BL008001
   Coding: 6D580A3BF8232EC48088008534000D0441555186536D8D605C8000000000
   VCID: B52267821C8C78E7FA-80E0
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels:  1KX-955-119.CLB
   Component: Wischer 14080  012 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 250809 05  54  0402
   Coding: 07304D
   Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E3PF8STTP
   Coding: 0012336
   VCID: C5C217428C6CE8676A-8090
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 00000000004N1T
   Subsystem 3 - Serial number: 0014.07.090000100000660049ÿ† 63
   Subsystem 4 - Serial number: 660049ÿ† 6332MTS666071909 ÿ† 63
   Subsystem 5 - Serial number: 71909 ÿ† 6342MTS614721929 ÿ† 63
   Subsystem 6 - Serial number: 21929 ÿ† 6351HTS6IDMNV8KR ÿ† 63
   Subsystem 7 - Serial number: NV8KR ÿ† 6361HTS6ODC4V8KR ÿ† 63
   Subsystem 8 - Serial number: 4V8KR ÿ† 63727TS6L56526KR ÿ† 63
   Subsystem 9 - Serial number: 526KR ÿ† 63827TS6JV0626KJ ÿ
   Subsystem 10 - Serial number: 626KJ ÿ
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0001332
   VCID: FAB8B4BEB512579F57-80AE
   Component: E0221           002 0030
00194 - Ignition Key Removal Lock
   Part No SW: 5N0 920 971 A    HW: 5N0 920 971 A
   Component: KOMBI         H05 0206
   Coding: 210F00
   VCID: B02C5696EBEE5DCFA9-80E4
   Part No: 1K0 907 530 AE
   Component: J533  Gateway   H06 0110
   Revision:   H06 01    Serial number: 100809F2000398
   Coding: FD83FF07504613006002
   VCID: EA9884FEC5B2E71FA7-80BE
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: CBD6217AAA081E17BC-809E
   Component: IMMO          H05 0206
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667540744
   VCID: A600B0CED12A037F43-80F2
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001322296
   Coding: 20581300000044440011
   VCID: B83C6EB60B9E858FE1-80EC
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 A
   Component: RNS-MID       H02 1040
   Revision: AB001001    Serial number: VWZ6Z7J8154076
   Coding: 040500000100008600
   VCID: A306A9DAA218F65724-80F6
                    Reset counter: 211
                    Mileage: 133592 km
                    Fault Status: 00100111
                    Reset counter: 251
                    Mileage: 141770 km
                    Date: 2013.10.15
                    Time: 14:01:06
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0005567
   VCID: B5226782DC8C78E7FA-80E0
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.163 0703
   Revision: 1AH03273    Serial number: 00091830417102
   Coding: 0000258
   VCID: BA3874BEF592979F17-80EE
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198613481
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: E79EFDCA1EA0DA77B8-80B2
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0110
   Coding: 050B0500
   VCID: E680F0CE11AAC37F83-80B2
   Component: J245EE19SKB12  H01 0220
   Component: J394EE19SKB12  H01 0220
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0005566
   VCID: B620608EC18A73FFF3-80E2
   Part No SW: 5N0 907 801 E    HW: 5N0 907 801 E
   Component: J540 EPB3  VW-13948 0008
   Revision:   H10       Serial number: 00000000035057
   Coding: 0000057
   VCID: B12A539228E454C7A6-80E4
   Component: AFS-Steuergeraet    0142
   Coding: 1356998
   VCID: B4245A86D7F661EFCD-80E0
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
                    Reset counter: 211
                    Mileage: 133592 km
                    Reset counter: 251
                    Mileage: 141770 km
                    Date: 2013.10.15
                    Time: 14:01:06
   Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
   Component: Tuer-SG         007 2001
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: B73E6D8AC6808AF7E8-80E2
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
   Part No SW: 5N0 907 441     HW: 5N0 907 441
   Component: J772__Rearview      0021
   Revision: 00H05000    Serial number:    PA8 J973108
   Coding: 0100010
   VCID: EC9482E6CF46F92FD5-80B8
   Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
   Coding: 0001168
   VCID: B83C6EB6CB9E858FE1-80EC
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005074112
   Coding: 0011070
End----------(Elapsed Time: 02:23, VBatt start/end: 13.6V/13.5V)-----------
This Tiguan with 88,400 on it will be leaving the family soon. It's been maintained at the highest level... never a service missed. If there is interest and you are in the Lansdale area, you know where to find me.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Don't hold out on us, what will be replacing it? :)
Bruce
I'm thinking about a "Taco" as Uwe has named it... a Toyota Tacoma TRD - not sure of the trim level yet. There is a 2017 used one available with everything I would ever want. Gonna try to see it today.
I am not in favored status at RT with this decision! Oh well!
If the Amarok were available in the US, I would consider a lease on an Amarok. I did ride in one of those a lot in South Africa. Very nice machine.
I'm not thrilled with the cost of maintaining a VAG car. in the 10 years I have owned Miss Tiggy, Maintenance of the vehicle has cost over $20k - and most of that coming in the last 6 years... I choose to not turn the wrenches on the cars myself. Tractors, lawn equipment and such - I'll all down on that. But I don't want to be turning wrenches on my daily ride. Lazy? Yep. At 63, I don't really want to be climbing around on and under and frankly, I never had great interest in cars... Can't really say why. Put a farm machine - lawn machine - and I am all about that... go figure... weird is what I am!
Have loved driving Miss Tiggy. She's been a lot of fun. She's done a lot of service. But I think it is time to try something different and to have it paid for before I hit 67!
Bruce
I did not go the Taco route. I went with a Honda Ridgeline. So far I love it.
On the last service of Miss Tiggy, the problem was not a VAG problem. The Gulf gas station where I buy all of the fuel locally for Miss Tiggy, had an issue where their supplier dumped diesel into the gas tanks. While they had the tanks pumped out on July 4, I bought gas from them on July 8. Miss Tiggy ran terribly.
Roth Auto Repair, checked everything involved with fueling, then decided it was bad fuel. Called the Gulf station and learned the above. They drained the tank, put fresh gas in, added injector cleaner, and ran her for a bit. She was running fine when I picked her up.
She has been sold. May the new owner have happy days with her. She is a good machine but she is like many women - high maintenance!
Mike@Gendan
Swansea, UK
C?ID=57030
Will Uwe still let you play with the full-size Tonka toys on the mountain if you've bought a non-VAG car though? :eek:
Bruce
I'll keep it parked away from the approved vehicles. I am doing the same at the office. Hopefully that allows some acceptance and tolerance.
^^^ Bruce: congratulations on the new car.
Clearly you are of the type that likes to "personalize" their vehicles (there are lots of folk that have this trait - IME (in my experience).
Personally, I'm not of this ilk - to me it's just a lump of metal with a more interesting control protocol and very easy emotionally to change if I so desire.
But - without intending any offense, or judgement - I never cease to be amazed at man-kind's tenancy to anthropomorphize every thing that is not a sentient human. Probably a consequence of our capacity to be empathic - which says much about your personality and alas it also speaks volumes about mine!!!
Bruce
Don, you are much too hard on yourself...
As to naming my rides, I do it to make it easy for people to know which ride I am speaking of. Haven't come up with a handle on the truck - or psuedo-truck as some have called the Ridgeline. I find it a truck and I like it's useful ways such as the copious storage space for bringing things to Ross Mountain. It's towing capacity is just like that of T-Reg. It's payload in the bed is pretty good at 1500lbs.. I think it will serve my needs.
In my career, I used to have to deal with machines on production floors. Whenever I had to go and learn of a problem, I pushed the management people away and asked to sit with the operators. They always talk to their machines as if the machine were sentient. They always assigned names. From that Don, I have come to the conclusion that these things are not just hunks metal hung together under the control of linkages and electrons. Rather, by some means, they get a personality. Most likely that means the human working with them assign a personality but I can tell weird stuff happens with machines that often I have been left wanting an explanation. Scoff as you might, I became a believer in the idea and treat my machines as if they were a person - doing my best to treat them as I would want to be treated.. never abused.. always encouraged to keep on keeping on.
Here on the mountain, I talk to the big machines.. Yep I am nuts.. certifiable. The Massey Tractor and I have gotten to know each other but have not formed a personal name as yet. The Massimo Buck - He is a buck.. and he likes to buck! The Great Dane mower - that bad boy likes to run.. don't get in front of him cause he is quick and goes like a bat out of hell - whatever that expression really means.
So yeah, I do personalize machines.. guilty as charged...
Uhm, no.
All T'regs are rated to tow 7700 lbs (3500 kg)
Ridgeline 2WD: 3500 lbs
Ridgeline 4WD: 5000 lbs
Bruce
I stand corrected. I went by my memory of what I thought I was told back in the day about your T-Reg when we pulled a trailer to Waterfest. My Ridgeline is 4WD and rated 5000 lbs.
Just more JapCrap - right Uwe?
I find your lack of faith -- in the brand that pays our bills -- disturbing. ;)
Santos
...in the brand that pays our bills ;)
our car repair bills...
I do have to say, my jetta has been good to me. However, the first time it breaks out of warranty, its getting traded into another VW with warranty. I felt the pain with my previous 3 VWs. It's nice not spending at least 2k a year to keep a car running (not including maintenance).
Let me be the first to point out that $2k per year is less than the payments on any new car.
