Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
edwyun
C?ID=159254
Just auto updated the VCDS software on my laptop. I am using a HEX-NET enthusiast version. On VCDS, I tested the USB port via the laptop and the HEX-NET is found. However, when I try to auto scan, I get an error message:
Scan: Auto-Detect
Function not supported by the gateway
VIN: xxx
End------(Elapsed Time: 00:07, VBatt start/end: 12.9V/12.9V)-----
Used to be able to auto scan, etc., with my setup before (2 months ago) with no problem.
Can someone help?
edwyun
C?ID=159254
BTW, this is for a 2019 Audi SQ5.
edwyun
C?ID=159254
Just tried connecting with WiFi and using my smartphone/app. With auto-scan on the app, I get a different message: Can't check ASAM data in AP mode. Unable to reach server.
Any thoughts?
NEtech
C?ID=56995
Car front hood is open ?
What are the exact results when you do [Options] -> [Test] in VCDS with the HEX-NET connected to your PC via USB and plugged into the car?
No, it wasn't. Tried with ignition on as well as engine on too.
Try again with the hood open - some newer models require the hood to be open for the diagnostics to connect...
Should not affect the ability to do an Auto-Scan. The "Diagnostic Firewall" does not prevent reading data from modules, only writing to them.
Shaun
This is expected, you don't have access to the outside internet in AP mode, and it needs to download data from the server. You can either use a wifi tether, or you can take it back inside and now download the data with VCIConfig -> "Check for Updates"
edwyun
C?ID=159254
Will try again and let you know tonight.
edwyun
C?ID=159254
After i updated the VCDS software, I did download data via the VCIconfig so I don't think that is the issue. Maybe the data for the 2019 SQ5 does not exist yet. In any case, I will try again tonight.
Eric
HC800000
We've found an issue with recent builds of VCDS and autoscanning vehicles with a UDS gateway (like your MLB-Evo based Q5). New builds are ready, just stay tuned for an announcement here.
edwyun
C?ID=159254
Port Status: OK
Interface: Found!
Type: HEX-NET
Version:
CB: 0.4505.4
FW: 0.256
WiFi: 310C
Status: Ready
CAN: OK, K1: OK, K2: OK
VBat: 13.28V, VIgn: 13.32V
Got the Laptop and Smartphone to connect via WiFi but still no auto scanning on either.
edwyun
C?ID=159254
Will do. Also seems like you can't use the smartphone WiFi to connect to the HEX-NET and also download the updates/ASAM data. Is this correct?
Shaun
Not it AP mode. To do this, you need to put you phone into hotspot mode so your phone broadcasts an AP, then configure the HEX-NET to connect to your phone's hotspot. Then the HEX-NET should be able to get out to the internet using your phone's 4G. Of course this depends on a lot of things, like signal strength and your phones ability to run as a hotspot, so your mileage may vary.
edwyun
C?ID=159254
FYI, a fresh download of VCDS is available from our website which should address this issue:
https://www.ross-tech.com/vcds/download/current.php
Please give it a try and let us know the results.
Did a fresh download of VCDS and a new update that was available via interface config. Auto Scan worked almost to the end, but did not complete. I received the following error message:
index.php
edwyun
C?ID=159254
If you want me to send the autoscan results via email or PM, let me know as I saved the file.
andyhud
C?ID=32695
Just to let you know I have the same issues too since updating from 18.9 to 19.6.0.4 and 19.6.0.6. The issue still persists
I updated my HEX-NET firmware also to latest version when VCDS prompted me and now autoscans fail on my 2016 Q7 4M which have worked absolutely fine on 18.9
I get "Function not supported by the gateway" when I do an autoscan and if I keep Clicking the "Gateway installation list" it eventually works. I then try and take a full AutoScan by hitting the Start button but I just got 4/5 modules, not the entire car
I'm working with Andy @ Ross-Tech support but sadly its still not working, so I'm trying now to revert my VCDS install back to 18.9.x - very frustating and VCDS is normally rock solid.
You can see below it only picks up 4 random modules. I also noticed when I start an Autoscan it starts with Module 17 (Instruments) where as in 18.9.x it started with Module 01 (Engine).
Something definitely isnt right with VCDS on its current release but hopefully with the triage I'm doing with Andy @ Ross-Tech support we will get there.
Tuesday,11,June,2019,15:26:03:50897
VCDS Version: 19.6.0.4  HEX-NET CB: 0.4505.4
Workshop Code: 001 61854 048576
VIN: WAUZZZ4MXGD017791   License Plate:
Mileage: 72870km-45279mi   Repair Order:
Chassis Type: 4M-AU73 (4M2)
Scan: 0E 47 57 5F
VIN: WAUZZZ4MXGD017791   Mileage: 72870km-45279miles
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4M0 035 108 C    HW: 4M0 035 108
   Component: DVD Changer   H40 0103
   ASAM Dataset: EV_DVDCALPI 001010
   ROD: EV_DVDCALPI.rod
   VCID: 25023D992427D767C4-8070
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0440
   Serial number: 00000000001999
   Coding: 0135060A008AF53AAF0000010000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 230623812A132957AA-8076
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 191 D    HW: 8V0 919 191
   Component: DVB-DTV       H08 2260
   Coding: 0104030000000100000000
   ASAM Dataset: EV_TVMELC 001036
   ROD: EV_TVMELC_VW37.rod
   VCID: 40CC8C0DDB45124FD7-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 035 G    HW: 4M0 035 035 A
   Component: MU-P-LND-EU   050 0976
   Serial number: A649H0F7500568
   Coding: 013706010000000013111102000A00332F001BE701700100BE
   Shop #: WSC 48154 001 1048576
   VCID: 281C34AD5335CA0FFF-807C
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0175
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9JJ406YA0
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0209
   Serial number: 31071500000000000006
   Component: Gracenote2  --- 1011
6936 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Night vision (0x18) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 153
                    Mileage: 72870 km
                    Date: 2019.06.11
                    Time: 15:23:08
                    Voltage terminal 30: 14.8 V
7192 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Night vision (0x18) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 153
                    Mileage: 72870 km
                    Date: 2019.06.11
                    Time: 15:23:11
                    BAP-BAP_Function_ID: 02
End------(Elapsed Time: 00:28, VBatt start/end: 14.6V/14.7V, udsna)--------
jagpurr
C?ID=275617
I am having the same problems with my HEX-V2
Trying to scan and getting "not supported by gateway" message in post one.
Worked fine yesterday but after updating firmware today nothing but hassle!
I have to play arroung reconnecting and re booting to get a scan working and half of the modules are sometimes missing.
Whats going on?
