Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
   #61
jagpurr
C?ID=275617
Hi Uwe,
Pluged in my HEX-V2 went to Options / User interface, ID / Check for updates
"No updates available at this time" tried including beta , same result.
Am I missing something obvious?
   #62
Eric
HC800000
Options->Config. That will launch VCIConfig. Check for updates from there.
   #63
VASTech A.D.
SJ, RO
C?ID=345137
This is clearly not a "Can't Auto-Scan" problem. More info please.
- Is this with your HEX-NET, or with the older HEX+CAN that you also have?
- Is this ECU in a car? If so, please tell us exactly what car it is in.
- Please make a Debug file and send it to Support.
[Options] -> Set Debug Level to 1024 -> [Apply]
Then do whatever is necessary to reproduce the problem. Once it occurs,
exit VCDS and send the file DEBUG-01.DLM to our Support e-mail please.
Hi
Sorry for late reply, but I was forced to go out of town and do not have time to answer to your request here. But as I think you already know I sent files that you are required to your support team.
Thank You!
   #64
jagpurr
C?ID=275617
Found it!
Thanks Eric!
fzanicotti
Brazil
C?ID=201619
Ok, I'm back at home. What did I miss, any new version? Uwe, any special test you want me to run?
   #67
fzanicotti
Brazil
C?ID=201619
Updated to 19.6.1 and report that everything is fine, no more Auto-Scan issues. All modules read well.
