Audi A5 0BK ZF 8HP transmission -- adaptation reset / basic settings
findalex
C?ID=95887
Hi,
I was looking thru the wiki but couldn't find the procedure, so I figured maybe I can ask here.
What is the proper way to reset the adaptation for this TCU?
I tried "Fast Adaptation" but the text box shows "aborted -- safety reasons" so I stopped. The engine wasn't running, so please let me know if the engine needs to be running as well.
Thanks.
Alex
Mrdeli
C?ID=165159
I’d also be interested to know how to do this. Thanks mark
Moving to Car Repair Support.
What's wrong with the tranny that makes you think it could benefit from this?
Please post an Auto-Scan so people can see exactly what TCU this car has.
Mrdeli
C?ID=165159
Hello. Thank you for taking an interest. I will post a scan log when I get home.
If stationery, in drive and at idle my car sounds as expected. If I shift to either Park, Reverse or Neutral it makes a soft knocking noise. If I increase the rpm it goes away. Also if cold it tends not to be there (again the revs are higher when cold).
I have read that a adaption of the box is required (but have no real idea myself).
Any suggestions welcome. Thank you Mark.
Mrdeli
C?ID=165159
Dual Mass Flywheel - I hadn't considered that - thought that was only on manuals - clearly not. :(
Mrdeli
C?ID=165159
Monday,08,July,2019,20:47:13:24455
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ********796   License Plate: ******
Mileage: 42490km-26402mi   Repair Order: 08-07-2019
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 42 44 46 52 53 56 5F 62 6D
          72 A9 AC C0
VIN: WAUZZZ********796   Mileage: 42490km-26402miles
Address 01: Engine (J623-DEHA)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0004
   Revision: 54H23---
   Coding: 2A2A4032252603030000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589C 001006
   ROD: EV_ECM30BTD0118K5907589C.rod
   VCID: 41834E32D0D64D47D6-8014
   Part No SW: 8R0 927 158 BC    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRDW H19 1003
   Revision: --H19---
   VCID: 7F0708CAE6A2FBB7E0-802A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Component: ESP8 quattro  H09 0020
   Coding: 385DCE01
   Shop #: WSC 06335 000 00000
   VCID: 050B9A228C7EA167AA-8050
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 01B54040000000000000
   VCID: 7F0708CAEEA2FBB7E0-802A
   Subsystem 1 - Part No SW: 8K0 959 754 BM    HW: 8K0 959 754 BM
   Serial number: 0816000029683005
   Serial number: 3216000031757016
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01070320162107
   Coding: 3625028000
   VCID: 78F5E3D6CB8CCC8FA1-802C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001303100201
   Coding: 260000108034AFE01781404300001D0D0F9D470827090201000008004400030100000024000000
   Shop #: WSC 06335 123 12345
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160222  H13 0050
   Serial number: 90243015160202145339
   Coding: 01DD13
   Serial number: 61453192
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000203160313
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: FDE8861800PAG0MUFU01
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD1TZ09
   Coding: 30473531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48955316F3EC7C0F11-801C
   Serial number: 6334MSME572A0C46J
   Serial number: 6344MSME572B6949R
   Serial number: 6352QSME49762278M
   Serial number: 6362QSME24514C76J
   Serial number: 63732SME43763262W
   Serial number: 63832SME437647480
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PC200044
   Coding: 000037
   VCID: 448D4726C7C4586FFD-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 T    HW: 8R0 920 950 T
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03F22593H
   Coding: 33A7220083012600010000
   VCID: 4797502AF6F2737718-8012
   Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0070
   Revision: 1Y090032    Serial number: 3241Y16218092B
   Coding: 80CD07FF00
   VCID: 50A57B7603BCB4CF49-8004
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 1866917603
   Serial number: 16068004209011200181
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000303160001008
   VCID: 2F67188A7642CB3730-807A
0057 - Please Check Fault Codes in Body Control / Central Electric Module
          U1021 00 [009] - -
                    Reset counter: 90
                    Mileage: 42492 km
                    Date: 2019.07.08
                    Time: 20:41:36
   Component: TSG FA        H03 0511
   Revision:             Serial number: 0000188863247
   Coding: 011D02214001440004
   VCID: 4FA7780A1E82AB3750-801A
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000002    Serial number: 0000714968
   Coding: 100000010001
   Shop #: WSC 06334 123 12345
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46895D2EF9F86A7FE3-8012
   Revision: 00002001    Serial number: 0397921012
   Coding: 013B0622A0B930148720053680040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Component: TSG BF        H03 0511
   Revision:             Serial number: 0000189182048
   VCID: 4E99650E1988A23F5B-801A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 10000000649248
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7139DEBD001E9F97-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109CY0G2537516
   Coding: 010103020100000001
   VCID: 2B5F0C9A4A5AB7171C-807E
00417 - Left Front DSP Mid-Bass Speaker (R101)
                    Reset counter: 90
                    Mileage: 42492 km
                    Date: 2019.07.08
                    Time: 20:41:39
                    Voltage: 12.30 V
00418 - Front Right DSP Mid-Bass Speaker (R102)
                    Reset counter: 90
                    Mileage: 42492 km
                    Date: 2019.07.08
                    Time: 20:41:39
                    Voltage: 12.30 V
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 90
                    Mileage: 42492 km
                    Date: 2019.07.08
                    Time: 20:41:39
                    Voltage: 12.30 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 90
                    Mileage: 42492 km
                    Date: 2019.07.08
                    Time: 20:41:39
                    Voltage: 12.30 V
   Part No SW: 8R2 035 666 K    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0946
   Revision: --------    Serial number: 515CA0GS009523
   Coding: 1A0101060205A1ED05808B5E00000403E40000020000000000
   VCID: 41834E32D8D64D47D6-8014
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H42 0104
   Serial number: A130CN0G3542064
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002483434
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000189790786
   Coding: 010C02204001240004
   VCID: 46895D2EF1F86A7FE3-8012
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D7B32C2A42E29A7B2-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000189790878
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 160210201456
   VCID: 79F3E6D2F886D587DE-802C
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160421420
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 160223200194
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 326111FE6570E6DF5F-8066
End-------------------------(Elapsed Time: 04:26)--------------------------
Mrdeli
C?ID=165159
Oh well thanks to those who helped.
findalex
C?ID=95887
Just wanted to revive this thread a little.
According to SSP 385 (pg 58) for the ZF 6HP transmission, it is necessary to read, evaluate, or delete adaptation values and carry out an adaptation run after:
- following complaints about gearshift comfort
- after repair work has been done on gearbox
- after replacing the gearbox
- after replacing the ATF
- after replacing the mechatronics
- after software update
- after engine repairs
So it stands to reason that the 8HP transmission has similar requirements. So is it possible to delete the adaptation values? I'll post the autoscan for my car asap. But this should apply to mrdeli as well.
The procedure outline in the SSP 385 (pg 63) basically says the below. SSP 457 (pg 53) says to use the same procedure for 0BK and 0BL gearboxes.
1) 02 - gear box
2) 006 - basic settings
3) delete system-specific adaptation values
4) start
Perhaps step 3 above corresponds to "IDE00794 - Erasing of system-specific adaptation values"" mentioned in this thread?
Thanks!
Alex
findalex
C?ID=95887
I just tried this after researching on the web and found a few others who've performed the same procedure with good results.
Erasing the system-specific adaptation values does exactly what the SSP says it would. It erased all the adaptation values and counters for each of the clutches. You can see the values in Advanced Measured Values IDE07437 to IDE07456.
Immediately after the reset, the car shifts a bit rough. There are three types of adaptations the transmission needs to perform: quick, pulse, and slip.
A. Quick adaptation is the first thing to do:
1. ATF temp over 40 C
2. In D, drive with light throttle (60 - 100 Nm), max rpm 2100, 1 ->2 up shift, 2 ->3 upshift, 3 ->4 upshift
3. If possible, decelerate your speed without brake down to 40 kph/24 mph, let transmission downshift itself to proper gear
B. Slip adaptation is next:
4. After less than 24 mph, brake and stop the car completely. While still in D, hold brake and stay stationary for 7 seconds.
C. Pulse adaptation is done automatically while you're driving under light-medium throttle (less than 2100 rpm)
I believe this is necessary because the transmission reduces the frequency of automatic adaptations the higher the adaptation counter is registered in the computer. This is because each adaptation causes slight stress on the clutches/brakes. However, if you have new ATF or new mechatronics, you should re-adapt asap so the transmission shifts at the optimal points. Rough shifts causes more wear. If you do nothing, the system will automatically re-adapt over time, but that may be a long time if the adaptation counter is high.
So basically all I did was drive around the block a few times under light throttle, coast to a stop sign, then start moving under light throttle again. The more I drove/coast/stop, the smoother the shifts became. This totally fixed the slightly rough downshift I had from 4 -> 3.
azet
Poland
C?ID=123840
Start engine, gear lever on D (not P!), handbrake ON, oil over 40C , foot on the brake , and then start "fast adaptation"- i'm sure it will start...
Kwesih
Trinidad and Tobago
C?ID=418078
Hi Azet. can you verify what is supposed to happen when you do this? am i supposed to remain like this until something is displayed?
EuroX
Northern NJ USA
C?ID=208579
All doors and hood need to be closed as well.
Kwesih
Trinidad and Tobago
C?ID=418078
understood when it says started though. will it eventually say finished or some other information? do i stay in that position?
EuroX
Northern NJ USA
C?ID=208579
I haven't done this using VCDS yet only using ODIS, but I would assume it would say started and possibly running while doing the adaption and then finished once complete just like ODIS does. I will say this, I always check fluid level and ensure that the level is correct before performing such and adaption as it will make a difference in the way the transmission behaves during shifts. Standstill adaption needs to be done on a level surface, engine running, trans fluid temp at 40C, all door closed including hood and trunk, Trans need to be in Drive with E brake set and your foot on the brake pedal the whole time. When adaption runs it will bang through all the gears you will feel the car/trans clunk as it engages different clutch packs. Standstill adaption I meant to supplement a driving adaption of clutches. I always do a Standstill then a driving adaption before releasing a vehicle.
If it start doing an adaption and you can feel it engaging different clutch packs as it should and then randomly fails give a warning "exited or ended for reasons due to safety" during the adaption its most likely because there is a fault stored. However based on what your saying it sounds like either a low fluid level, wrong fluid in the trans if changed or it could be normal based on the situation. The only other question that makes sense to ask is the one below.
This noise that you have does it occur if the car is only parked on a uphill or downhill position??
Kwesih
Trinidad and Tobago
C?ID=418078
I haven't done this using VCDS yet only using ODIS, but I would assume it would say started and possibly running while doing the adaption and then finished once complete just like ODIS does. I will say this. Standstill adaption needs to be done on a level surface, engine running, trans fluid temp at 40C, all door closed including hood and trunk, Trans need to be in Drive with E brake set and your foot on the brake pedal the whole time. When adaption runs it will bang through all the gears you will feel the car/trans clunk as it engages different clutch packs. Standstill adaption I meant to supplement a driving adaption of clutches. I always do a Standstill then a driving adaption before releasing a vehicle.
ok. Actually none of the above. i did a trans fluid change and wanted to re adapt the transmission. was only able to do the driving adaptation at the time. its been about 3 weeks since. does it make sense to do this now (go back thorough the reset and adaptation) or should i just leave it
EuroX
Northern NJ USA
C?ID=208579
I edited the post above please re read and provide all relevant answers. Type of fluid used if not factory or factory, what part number, how much did you put in and how did you check the level.
Kwesih
Trinidad and Tobago
C?ID=418078
fluid and filter was changed with a zf fluid and filter kit. it took 4.5 liters. was just a routine maintenance as i was not the original owner and was unsure if it was ever done (120km). the mech said the fluid was a bit darker than usual. was just looking to run the adaptation after as i see it is recommended to do after such a service. i did the reset and did the driving scenario on light throttle in D as the thread explained earlier. what i do have is some strong engine breaking at times when decelerating. it does not happen all the time.
i was not able to do the fast adaptation as i wasnt sure what was expected.
EuroX
Northern NJ USA
C?ID=208579
Does the noise only occur when parked on a uphill or downhill?? You did not answer everything. Fluid type, part number and so on.
