2015 Q7 steering column reset help
Butch525
C?ID=336662
Helllo,
I am having an issue with my wifes 2015 Audi Q7. We purchased it used about a year ago and have had no issues up until about a month ago when the steering column stopped responding to the up command. Now it isn't moving at all. After searching on the internet it seems like this is a common enough issue however the only fix I have found is a dealership reset on the column. Can this reset be done with the vcds? I have scanned the car and found no trouble codes to investigate. Any help on this would be greatly appreciated.
If you've scanned it, please post the scan so people can see exactly how the vehicle is equipped. Even if you didn't explicitly save the scan, there should be an archival copy of it in your Scans sub-folder.
Butch525
C?ID=336662
Here is a scan from today as requested.
Wednesday,09,January,2019,12:02:10:63587
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WA1LGBFE2FD011021   License Plate: Q7 1-9-19
Mileage: 111940km-69556mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 6C 6D 6F 72
VIN: WA1LGBFE2FD011021   Mileage: 111940km-69556miles
Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4L0 910 551 P    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0030
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0128
   Shop #: WSC 31414 790 00001
   VCID: 3537DD89A94EF09F7D3-8060
   Part No SW: 0C8 927 750 N    HW: 0C8 927 750 N
   Component: AL1000 AISIN  002 2441
   Coding: 001378
   Shop #: WSC 42420 001 1048576
   ASAM Dataset: EV_TCMAL991031 002112
   ROD: EV_TCMAL991031_002.rod
   VCID: 372BD781BFC2028F6FF-8062
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Component: ESP ALLRAD MK25E1   0020
   Revision: 00H02001
   Coding: 0099409
   VCID: 3431E08DA234E9974AD-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902170038
   Coding: 0000135
   VCID: 25170DC919EE801FCD3-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H04 0020
   Subsystem 2 - Part No: 4F0 910 335 B
   Component: FBSAUDIC6 KSG   H03 0020
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 143
                    Mileage: 105556 km
                    Date: 2018.10.07
                    Time: 11:08:22
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Fault Frequency: 7
                    Reset counter: 252
                    Mileage: 105556 km
                    Date: 2018.10.07
                    Time: 11:08:22
02639 - Antenna Reader for Keyless Access Authorization
                    Reset counter: 65
                    Mileage: 110951 km
                    Date: 2018.12.24
                    Time: 19:46:52
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Component: KLIMA 4 ZONEN H15 0070
   Revision: 00---031    Serial number: 00000030357689
   Coding: 000CC026
   VCID: 25170DC915EE801FCD3-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E8532E58C9883477C9-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931429300602
   Coding: 24011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3431E08DAEB4E9974AD-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 72 AIRBAG AUDI8RH45 0230
   Revision: 09H45000    Serial number: 0038QD90DH03
   Coding: 0014130
   VCID: 2B03FBF17F0AB66F1B7-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME0B4714529
   Subsystem 3 - Serial number: 6342QSME73470742A
   Subsystem 4 - Serial number: 6352QSME6F473E56.
   Subsystem 5 - Serial number: 6362QSME73472474G
   Subsystem 6 - Serial number: 63734SME22451566W
   Subsystem 7 - Serial number: 63834SME7D441A727
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026142600045
   Coding: 0012242
   VCID: 280904FD6EFC9D77F65-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2R407PAF
   Coding: 8BD663040100CF05020205
   VCID: 44D1B04DFE945917FAD-8010
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M1491904D6
   Coding: 00C303
   VCID: 3FDBBFA197723ACFA7F-806A
   Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
   Component: J367-BDM  H07 0125
   Serial number: 31287532274121941088
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 79
                    Reset counter: 88
                    Mileage: 105563 km
                    Date: 2018.10.07
                    Time: 15:05:00
            000 -  -  - Intermittent
                    Fault Frequency: 103
                    Reset counter: 88
                    Mileage: 105563 km
                    Date: 2018.10.07
                    Time: 19:05:00
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 18
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Component: KLIMABETAETIGUNGH06 0060
   Revision: 00---011    Serial number: 00000030356735
   Coding: 0000006
   VCID: 688944FDAE7C5D77365-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000119084875
   Coding: 00581B00000011110000
   VCID: 323DE6955420E7A7581-8066
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   Coding: 0000001
   VCID: 2E05F2E54C18C3473C9-807A
   Subsystem 1 - Part No: 4L0 910 568 C
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 2 - Serial number: 6PZ 009 014-30
   Subsystem 3 - Serial number: 5F02.10.1400H03000AMS14244ÿ
   Subsystem 4 - Serial number: S14244ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000121988890
   Coding: 011F57205E40440004
   VCID: 48C9A47DC2BC7D77165-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82009349590000
   Coding: 3569949
   VCID: 3829D4BDBE5C0DF7665-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000062796
   Coding: 030000
   VCID: 290F01F979F6A47FE9B-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191074956
   Coding: 0693965
   VCID: 231313D117DA7E2FA37-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000201081
   Coding: 0012001
   VCID: 5EE562257C3813C7CC9-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000121918347
   VCID: 47CBA741CFA2720F1FF-8012
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 141021-0002-194
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DDB655E4005727C81-8016
   Revision: AB001007    Serial number: 156J/0E8081641
   Coding: 020007010000000000
   VCID: 241110CD1ED47917DAD-8070
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 513JU0E7500117
   Coding: 180200060004E1EF510003456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130JY0E3163467
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002212355
   Component: CD-Database  5950
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000122643492
   Coding: 010E57204040230004
   VCID: 46D5AA45C8A86B07E49-8012
   Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
   Component: J772__Rearview      0030
   Revision: --H09---    Serial number: 525PA8-J49430T
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C8138EDBA84715752D-8038
   Subsystem 3 - Serial number: RD23.10.14--H58001001C0224ÿ
   Subsystem 4 - Serial number: 1C0224ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0122994640----
   Coding: 0003595
   VCID: 26150AC564E88B07C49-8072
   Component: J_245_EE16_SKB10H15 0220
   Subsystem 2 - Part No: 4L0 910 591 A
   Component: J_394_EE16_SKB10H15 0220
   Subsystem 3 - Part No: 4L0 910 591 A
   Component: J_392_EE16_SKB10H15 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000122643491
End----------(Elapsed Time: 02:02, VBatt start/end: 14.3V/14.3V)-----------
Address 19: DTCs cleared
Yes, VCDS should be able to do that.
[Select]
[09-Cent. Elect.]
[Basic Settings]
Group 001.
The note I have is: Make sure to approach all 4 end positions (up, down, forward, back) before performing the basic setting.
You probably should read the TSB posted two messages above.
darren_de_vos
Canada
C?ID=347864
The steering column was working in/out but not up/down, was enabled in vcds. Did the vcds basic settings on and now shows as disabled and the steering column does not adjust at all now. First time trying out vcds and i guess i got lots to learn and be careful. Seemed like an easy fix. Appreciate any help on this. Thanks D.
studioRS
C?ID=338222
I did the same exact steps as you. My steering column was only working in/out and not up/down. Basic settings initially showed it as “enabled”, but now after setting basic setting ON, is now showing “disabled” every time I open VCDS and doesn’t work.
I think the problem might be we both opened the controller and instructed VCDS to set the basic settings, but we didn’t even use or extend or reach the end points for the 4-way toggle switch (not sure how this would have worked for the up or down anyway since my up/down didn’t work before). Now all adjustment is stopped and disabled.
Is this something that can be reset so the setting displays as enabled or? If so, please advise.
studioRS
C?ID=338222
@Uwe - is there an exact procedure to reset the steering column setting so I goes back to enabled?
If I knew more than I've already written here, I would gladly share it with you.
studioRS
C?ID=338222
Appreciate the quick response, thank you.
RichS
C?ID=222890
I'm having the same problem - the up and down on my 2014 Audi Q7 steering column does not function.
Uwe's comment (Make sure to approach all 4 end positions (up, down, forward, back) before performing the basic setting) is helpful in that perhaps if we place a current source into the up / down functions of the column motor, cause it to reach the end points, and cause J519 to realize that the column moves, we can then reset the basic setting?
I found a thread on AudiWorld that references a procedure: https://www.audiworld.com/forums/q7-discussion-112/steering-wheel-column-wont-telescope-2807042/
Summarized here -
[09] - Central Electronics
Basic Setting
Steering Column Adjustment
[Select]
[09 - Central Electronics]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
Can we somehow make procedure out of this that involves moving the column with an external current source? There is a connector for the motors that is easily reachable.
Here's another thread where someone used an external current source to move the column, just to get it to a reasonable position https://www.audiworld.com/forums/q7...st-steering-column-not-working-2885150/page2/
"I used the TSB wiring schematic and tested the voltage and current on the in/out to test. Normal Volts/Amps. I then tested the up/down and no voltage present to the motor connector. I then shut off the car accessories. I disconnected the wiring adapter to the motors from the control circuit. I used my 12v car battery charger to apply a voltage to the up/down motor. Low and behold.. it adjusted!! I moved it to my normal position (most of the way down) and reconnected everything. I wanted to see what would happen and if it would try and reset it to the top position. Nope... stayed there... still not sending control voltage to the motor. But the in/out worked like normal... so at least it's in the vertical position i wanted."
I wish I could buy the shop manual for my Q7 the same way I did did for my d2 A8 and B6 S4 cabriolet - and Uwe graciously gifted me the A8 d3 manual, which is now well used (thank you!). I would like to know if G357 and G358 are position sensors.
RichS
C?ID=222890
And here is another thread.. https://www.audiworld.com/forums/q7-discussion-112/q-steering-adjustment-issue-2994129/
The author uses relays to substitute one column switch appear to be another - to make J519 to think everything's ok.
"If you attempted to do a Basic setting of the steering column and did not make sure that the column adjustment for both vertical and axial plains were operational as I did, you end up disabling the Voltage supply of terminal 30 left.
To return to only one of the 2 functions being operational you need to make J519 think that both adjustments work without drawing excessive current and position senders return credible feedback.
To do this I temporarily wired in a 4 pole C contact relay and a switch controlling it to sequence both outputs and corresponding position senders so that J519 saw the operational motor and positioning sender twice. In my case the axial adjustment motor is failed open, therefore I disconnected both motors V123 and V124 as well as both position sending units G357 and G358 and wired the 2 individual motors and position senders to a set of 4 NO and NC contacts and wired the common of those contacts to the only functioning motor and position sending unit. Please see drawing below. I then initiated the Basic Settings with VCDS which first moves the steering column all the way up then all the way down and back to center, then I flipped the relay on which connected the axial motor output from J519 to the vertical motor and position sender via the NO contact on the 4 pole relay which moved the Vertical adjustment motor all the way down then all the way up and back to center for a second time, thus simulating a working axial motor and position sender."
So G 357 and G358 are position sensors...
A question - During basic settings -04, group 1, does the module attempt to move the wheel up, down, in out? Can we just try that? Or do I need to move the wheel / fool the module before attempting basic settings?
Quote Reply
Report Edit
A-Aron
80134, USA
C?ID=522024
Did this ever get resolved? I have the same issue with mine.
RichS
C?ID=222890
It did not get resolved...So many things to fix...but I do enjoy. I may try this again during indoor fixit season in Iowa ("Winter").
davek181
USA Idaho territory
C?ID=5170
I had a similar problem on an A6 2010 model. Customer stated up/down worked, but not in out. i tried resetting basic settings and disabled terminal 30 in the process. Since we knew the motor was likely the issue I got a used and tested column assembly and swapped over the steering lock from the original and put it in. Terminal 30 was alive and I misread/misunderstood the procedure and tried basic settings again to initialize the column. It disabled Terminal 30, but before that it pushed the column out to its fully extended position so I knew the motor worked at least.
I was able to restore terminal 30 by pulling the fuse for the steering column control control module and walking away for a couple hours to do other things. When i put the fuse back in after giving it a rest the terminal was alive again. I had since read many accounts of successful basic settings adventures. From my digesting the info the procedure I interpreted is to go to 09, basic settings with the memory switch on the door off, cycle the switch to extend and compress the column to the ends and do the same with the up/down. Then activate basic settings and the module repeats the performance and all works.
I had terminal 30 enabled but no response from the switch to move the column. I tried unsuccessfully again to enable the column with basic settings and disabled terminal 30 again. So after reawakening the terminal 30 I then moved the switch to column extend with no response from the column, but I held the switch the amount of time I figured it would have taken to extend. I then did the same with retract, no response but held the switch one cycle time. Repeated the same with up, then down, still no response but held them a while.
I then initiated basic setting and the controller took off and did its sequence of cycles. Afterwards the column switch worked too. I think there is a serious bug in the column software that allows this problem and I was glad to have worked around it in my clumsy way and illogical thinking.
And no I did not disable it and retry again to test my results, rather release the car to service and not know for sure.
GeriatricGinger
Virginia, USA
C?ID=255667
I just picked up a 2013 Q7 with the issue of no vertical movement. @davek181 so you had a similar issue? Are the 'basic settings' operations straight-forward? I'm not sure I've seen anything aside from:
Basic Setting
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Does the bolded section step through instruction on-screen for resetting basic settings? I ask because I've read various random things about moving the control knob to a position, etc..
Any assistance is appreciated. I'm not new to using VCDS for basic diag, but not really falimiar with basic settings, adaptation, etc.
jwt27ta6
C?ID=536046
I had same problem as many of you on 2015 Audi Q7 TDI. Up/down worked, In/out didn't. Did the adaptation above and Terminal 30 Disabled!!!! I tried everything mentioned on the internet, ie...pull fuses, unplug battery (overnight even), unplugged battery and shorted postive and neg cables together for 5min (10min actually), and entered the security code on 09 Central Elect module. But still disabled!!!
Then read about the little button next to the steering column 4-way switch. Button??? Low and behold, there it is!!! Pushed it. Did a little dance, said a prayer, asked for forgiveness of all my sins, and tried this YET AGAIN and didn't do any prerequisites of trying to go down/up/in/out......AND THE STEERING COLUMN STARTED MOVING THRU ALL 4 DIRECTIONS. DONE/FIXED/HASTA LA VISTA BABY:
Basic Setting
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
https://lh3.googleusercontent.com/p...EGROeeYe4C0A4Y=w2202-h1071-s-no-gm?authuser=0
RichS
C?ID=222890
jwt27ta6,
Basic Setting
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
That's the first success I've heard! The button on the steering column in question is called the easy entry button - pressing it toggles the steering column easy entry feature on or off. Should the column easy entry feature be turned off, or turned on? How can you tell if it is on or off? And then you performed the procedure teaching the basic setting? Was the driver's seat memory switch in the on position or in the off position? (on=seat memory switch in depressed position).
How sure are we that we can wake up terminal 30 - by depressing and releasing the easy entry button on the steering column? Or by removing the control module fuse for a few hours?
I cannot see the images you posted - I'm not sure why. Do those two images posted show up for anyone else / what do I need to learn here?
Thanks!! First hopeful procedure I've seen.
jwt27ta6
C?ID=536046
Memory Seat "Off" per what others have said
Easy Entry/Exit Button ON ("out" position) - this is what fixed the "Terminal 30 Disabled" status when coding. And now my steering column manually moves with the up/down buttons and moves to the saved seat memory locations. However, I've realized the Easy Entry/Exit function does not work. I've tried the button in and out. The steering wheel does not move up out of the way and the seat doesn't go back when I turn the car off, nor when I open the door. Not a big deal really, but would be nice to know "why" it doesn't work.
RichS
C?ID=222890
Here's another link...trying to track down the success stories. The door memory switch in question has an on / off indication, so you can tell it is off.
