Now with the SA code accepted, I was able to change two more bytes - now my coding is 743B80F5092400FC2E0E01E8902200413D0000. Only two bytes are different to Golf coding - I guess they are the vehicle type bytes.
00010203040506070809101112131415161718 Byte no.
743B80F5492400FC2E0E01E8922200413D0800 2011 Scirocco ABS original coding
143B800D092800FC280C01E5901900413D0000 2010 Golf R ABS original coding
143B800D092B0002281001EC901C00413D0000 2011 Golf R ABS original coding
743B80F5492400FC2E0E01E8922200413D0800 2011 Scirocco ABS original coding (VIN WVWZZZ13ZBV022349)
74 80 49 00 2E 01 92 00413D0800 Scirocco ABS coding after SA code 11908
3B F5 24 FC 0E E8 22 Bytes that were excluded with SA code
And check how I can mate Golf and Scirocco clusters. It seems they could be split and have Scirocco face on Golf cluster. Screws to dashboard are on same location.
That should be most of it.
I'm not familiar with Leon Cupra mk2 trunk floor, but I believe you may need to do some work with it to fit the rear axle.
Also, I had a lot of issues to get the ESP function - my original 2wd scirocco cluster did not work with 4wd Golf one - I had to use the Golf cluster internals. Someone with some firmware modifying skills can probably get it working.
Thanks for any reply , i have started now.... to install FIX all parts.
i have installed ABS 4wd gen2 from audi s3 + yaw sensor 4wd( under the passenger seat ) , i have selected AWD option in Engine , AWD now status ok and properly coded ( i can see all haldex value example oil temp ecc.. ) at the moment i haven't engine installed and i can't finish power steering procedure to see steering angle on AWD , ABS , and 044 .( i can see only steering speed in second,Torque on steering ecc.... missing only degree ° error stored: G85 frame freeze 00778 and 02546 steering n./init)
Also i have installed the second sender lever from the 4wd tank..... but i my J285 instrument cluster i can't selected channel 29/31 only channel 30. in the menu i can't selected 4wd trasmission.
If i go in ADV. meas. block. i can see that OHM from 2nd line sender Work... because when i disconnet go to 500 ohm ( connection is Ok) and if i disconnet the 1st line sender i have an error and no fuel indication.
i need coding j285 instrument cluster to achieve 2nd lever sender.
Can you help me? in my leon 2wd i haven't the same menu of any 4wd car!
Thanks
