Retrofitting AWD to Scirocco mk3
   #21
Hmm, please see if SA code 11908 is accepted at all by this controller. If it is rejected do NOT try any other codes (because that will result in lock-time) but if it happens to be accepted ... see if the same coding will copy/paste back in without an error.
   #22
Heikki J.
Finland
C?ID=14516
"Controller refused the key! Error 35: Invalid key"
   #23
OK, I figured that because most (if not all) of the 1K0-907-379-B? (Those are common in 2011+ M.Y. cars and typically use 19 bytes rather than the older 18 byte string) series controllers simply accept copy and paste coding without a SA code. I don't have anything else to suggest at this point in time.
   #24
Heikki J.
Finland
C?ID=14516
OK. By the way, yesterday I was helping a friend to replace a CAN gateway with a used one and when I recoded that I got the same "out of range" error when two bytes were not matching. There were two bytes that needed to change when installing a gateway from 4 door car to 2 door car... and I first changed only one byte and got the error. When changed the other too, coding was accepted.
So this got me thinking that perhaps I get the error simply because everything just don't match. I just need to figure out coding that'll match with all the correct parts in my car?
   #25
richard
C?ID=125483
Hi with richard
I have on my car the same problem with the abs after the car adjust from 2 wheel drive to 4 wheel drive
vw transporter bj 2011 2.0 diesel dsg 180hp
is now resolved this problem of yours if so what did you done
best regards richard
   #26
Heikki J.
Finland
C?ID=14516
No, unfortunately I haven't solved the problem yet.
   #27
richard
C?ID=125483
Hi with richard
is your problem with the abs of encoding already fixed my problem is fixed with 2 numbers per today to change from 09 to 11 in position 4 and 90 to 88 in position 10
   #28
Heikki J.
Finland
C?ID=14516
Hi,
No, I haven't solved my problem yet. Could you post your complete code before and after so I could double check if it has anything to do with my coding. Those two bytes seem so much different from my byte 04 and 10.
My byte 04 is 49 and in my Golf R it was 09.
My byte 10 is 01, same in Golf R. So far only documented bit has been the last bit which means the brake disc size.
   #29
richard
C?ID=125483
20 87 64 ad 09 aa 04 98 26 a6 90 74 6a 5e 16 dsg 180hp old
20 87 64 ad 11 aa 04 98 26 a6 88 74 6a 5e 16 dsg 180hp 4motion new
   #30
Heikki J.
Finland
C?ID=14516
Thanks Richard! Seems it's quite different, mine is 19 bytes long, yours is only 15 bytes.
How did you find the right code? Did you ask some Company to help?
   #32
richard
C?ID=125483
ECU Navn Mod. Bil Årg. Mot. Resv.nr. Komponent Kodning WSC Ekstra1 Tilføjet Af
03 ABS 13 VW Scirocco 2009 CAVD 1K0 907 379 AD ESP MK60EC1 H35 0104 743B60F5092200002E1206E7901A00403000 00020 2008-09-26 nez
03 ABS 13 VW Scirocco 2009 CAWB 1K0 907 379 AD ESP MK60EC1 H35 0104 743B60F5092200022E1006E9901D00413000 00020 2009-01-05 nez
03 ABS 13 VW Scirocco 2009 CAVD 1K0 907 379 AD ESP MK60EC1 H35 0106 743B60F5092400FA2E0F06E7901900403000 00020 2009-04-25 jjberends
03 ABS 13 VW Scirocco 2009 CAWB 1K0 907 379 AE ESP MK60EC1 H35 0106 763B60F5092300026E1106EA901D0081B500 00020 2009-04-28 raymond
03 ABS 13 VW Scirocco 2010 CBDB 1K0 907 379 AH ESP MK60EC1 H30 0107 743B40F5492500FF2E0E02EA92190042300000 00020 2010-03-08 nez
03 ABS 13 VW Scirocco 2012 CFHC 1K0 907 379 BJ ESP MK60EC1 H31 0121 743B40F5492200FF2E0B02EA921A0052350000 00020 2011-08-12 nez
03 ABS 13 VW Scirocco 2012 CFHC 1K0 907 379 BJ ESP MK60EC1 H31 0121 743B40F5492280012E0F02E8921D0152350000 00020 2011-08-16 nez
03 ABS 13 VW Scirocco 2009 CAWB 1K0 907 379 AE ESP MK60EC1 H35 0106 743B60F5092300022E1406E990190041B100 00020 2012-12-13 nez
Gå til top
   #33
richard
C?ID=125483
And required a scan of original car
   #34
NEtech
Denmark
C?ID=56995
One guess is:
743B80F5492400FC2E0E01E8902200413D0800
   #35
Heikki J.
Finland
C?ID=14516
So try to change byte 12 from 92 to 90. I believe I had tried that already, but decided to give it a go again. Still no luck. But definitely that could be one of the key bytes as in Golf R that's 90 for sure.
I'm starting to believe more on my theory that it just won't accept the combination of Scirocco and 4WD. Perhaps I need to code all possible control modules with e.g. Golf coding. Anyone have a list of all ECUs that are connected to powertrain data bus so I can start looking at their coding?
   #39
Sebastian
Magdeburg, Germany
HN0-nnnnnn
golfi_vend, please don't post/upload files like that which are neither correct, nor complete and will likely result in incorrect coding values. Remember - we are talking about a safety related system here.
Based on the information available to me so far and my understanding of the MK60EC1 coding, what you are trying to achieve cannot be done because something like that was never specified by VW. The MK60EC1 coding highly depends on what characteristics VW put into the module firmware, it isn't as easy as switching between AWD and FWD. The entire combination has to be plausible...
   #40
golfi_vend
Tartu, Estonia
C?ID=195131
When looking at Golf and Scrocco auto scans they both have same HW SW and revision. Is there really something that internally different?
Talking about the label file, i used information found in Polish made mk60ec1 coding program.
We have this saying: "He who doesn't risk, never gets to drink champagne", everything about this project is experimental, so why not ABS coding?
