Retrofitting AWD to Scirocco mk3
Heikki J.
Finland
C?ID=14516
I've recently done a retrofit of AWD from 2010 Golf R to my 2011 Scirocco R. To keep it simple, mechanically it required changing the boot floor, gearbox (DSG) and rear axle (together with Haldex coupling) from Golf to Scirocco. Some work with fuel tank and exhaust pipe also. Wiring was simple, Haldex control unit only requires power, signal from brake pedal and powertrain CAN bus.
With VCDS I've activated AWD on engine ECU and CAN gateway. All the fault codes are gone except one on ABS which leads to ESP not working. Not sure if I need to recode something on ABS control unit.
Any idea if there is some other control unit on powertrain data bus where I need to enable AWD or is just about the coding on ABS control unit?
Tuesday,04,March,2014,20:08:34:03166
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BE    HW: 1K0 907 379 BE
  Component and/or Version: ESP MK60EC1   H31 0108
           Software Coding: 743B80F5492400FC2E0E01E8922200413D0800
            Work Shop Code: WSC 00020 790 00000
                      VCID: 76E98FD6C1CB63AEBEF-8023
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 127
                    Mileage: 51184 km
                    Date: 2036.14.26
                    Time: 20:07:41
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 197
                    Count: 41216
Luckily I have another 2011 Golf R available for comparison. It has the ESP control unit with same part number (1K0 907 379 BE). Just the coding is different. If been searching and found out that part of the ESP coding is the last 5 digits of VIN. Besides those, there are just a few bits that are different between FWD Scirocco and AWD Golf. I still haven't tried coding the ESP to play with those bits (will do this coming weekend). Golf has DCC, Scirocco not. That might also explain some of the differencies on coding.
Any hints for MK60EC1 ABS/ESP coding or will I just go with trial and error? Or am I even able to change the coding on that unit? I've read that it could be something that can only be done with dealer's tools? Basically this is the same situation if I'd try to install a used ABS control unit from FWD car to a AWD car without knowing the original coding... but if I plugged my car to dealer's system I doubt it would offer me the AWD coding anyway ;)
Anyway, I'll post my findings after the weekend, might be interesting for someone :)
dubTECH
Northern ireland
C?ID=104757
This is very interesting, I have the same conversion to do from a mk6 gti to AWD, I have most parts except from the abs unit which I was told I need to replace?! So I'll wait to see what you find before ordering anymore! 😄
Right, it most likely wouldn't, because the dealer's tool doesn't have a coding script for these MK60EC1 modules, instead it queries SVM database which simply returns the coding that the car had when it left the factory, with the factory installed equipment. With some approved retrofits, e.g. a trailer hitch installation, it's possible for the dealership to enter an "SVM Code" that tells the SVM server that there's now a trailer hitch on on this car and the SVM server then calculates a new coding for the car (and remembers that the car is supposed to be coded that way from now on).
Unfortunately, this also makes it very hard for anyone to derive a reasonably complete coding chart for these modules. Some people claim to have it figured out; I'm not sure we really do. What should be helpful in your case is that your ABS module still has the coding for your care pre retrofit. Hopefully we'll get the right eyeballs and brain cells on this to find you a solution.
Heikki J.
Finland
C?ID=14516
I tried to change the coding over the weekend without success. I get an error message "coding out of range".
In this case I only tried to alter one of the last bytes to match the Golf coding.
I also accidentally activated the system function test and can't complete it successfully (probably due to the coding issue) so now I have two fault codes active :)
As I told, I've tried to reverse-engineer the coding by comparing the same MY Golf R I also have, here's what I've been able to find out so far. I got a lot of help from a Polish Skoda site:
http://forum.octaviaclub.pl/printview.php?t=64157 (in Polish, use Google translator)
Golf has DCC suspension, Scirocco not…
Golf is originally AWD, Scirocco not…
Both are MY2011, same ESP control unit (1K0 907 379 BE)
BYTE 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18
I    --------------------------------------------------------
T    74 3B 80 F5 49 24 00 FC 2E 0E 01 E8 92 22 00 41 3D 08 00
0   | 0  1  0  1  1  0  0  0  0  0  1  0  0  0  0  1  1  0  0
1   | 0  1  0  0  0  0  0  0  1  1  0  0  1  1  0  0  0  0  0
2   | 1  0  0  1  0  1  0  1  1  1  0  0  0  0  0  0  1  0  0
3   | 0  1  0  0  1  0  0  1  1  1  0  1  0  0  0  0  1  1  0
4   | 1  1  0  1  0  0  0  1  0  0  0  0  1  0  0  0  1  0  0
5   | 1  1  0  1  0  1  0  1  1  0  0  1  0  1  0  0  1  0  0
6   | 1  0  0  1  1  0  0  1  0  0  0  1  0  0  0  1  0  0  0
7   | 0  0  1  1  0  0  0  1  0  0  0  1  1  0  0  0  0  0  0
00: 74 = 0111 0100 Scirocco R
    14 = 0001 0100 Golf R
01: 3B = 0011 1011 = ? (same in Scirocco and Golf)
02: 80 = 1000 0000 Brake disc diameter front 345 back 310
03: F5 = VW Scirocco
    0D = VW Golf mk6
04: 49 = 0100 1001 Scirocco R
    09 = 0000 1001 Golf R
05: 24 = 0010 0100 VIN 13. digit = 2
06: 00 = 0000 0000 = Original
    80 = 1000 0000 = 2-step ESP off -switch
07: FC = 1111 1100 VIN 14. digit = 2
08: 2E = 0010 1110 Scirocco R
    28 = 0010 1000 Golf R
09: 0E = 0000 1110 VIN 15. digit = 3
10: 01 = 0000 0001 Brake disc diameter front 345 back 310
11: E8 = 1110 1000 VIN 16. digit = 4
12: 92 = 1001 0010 Scirocco R
    90 = 1001 0000 Golf R
13: 22 = 0010 0010 VIN 17. digit = 9
14: 00 = 0000 0000 = Original
    01 = 0000 0001 = 2-step ESP off -switch
15: 41 = 0100 0001 bit 0~2 = 001 = 1 Engine type = 1.8 TSI/2.0 TFSI/2.0 TSI/3,6 FSI/1.6 TDI/1.9 TDI
                   bit 4 = 0 start-stop not installed
                   bit 6~7 = 01 = LHD
16: 3D = 0011 1101 bit 0 = 1 = Hill Hold Control (HHC) installed
                   bit 2 = 1 = Tire Pressure Monitoring (TPMS/PR-7K6) installed
17: 08 = 0000 1000 Scirocco R bit 3 = 1 = (Extended) Electronic Differential Lock (XDS - PR-UG3/UG4) active/installed
    00 = 0000 0000 Golf R (No XDS on Golf???)
18: 00 = 0000 0000 = ? (the same in Scirocco and Golf R)
Bytes 00 and 08 seem to be the same but bits in reverse order
Bytes 02 and 10 seem to be the same but bits in reverse order
Bytes 04 and 12 seem to be the same but bits in reverse order
Bytes 06 and 14 seem to be the same but bits in reverse order
Bytes 06 and 14 refer to the ESP-off switch. Not sure if's possible to change the behaviour though coding. Originally the switch only disable the traction control. At least in US models it should be possible change the behaviour (according to APR website)
Heikki J.
Finland
C?ID=14516
This is very interesting, I have the same conversion to do from a mk6 gti to AWD, I have most parts except from the abs unit which I was told I need to replace?! So I'll wait to see what you find before ordering anymore! ��
I do have one extra ABS unit from the 2010 Golf R that I took my parts (transmission and rear axle) from. It was with DCC suspension. But you'd need to recode it anyway.
https://onedrive.live.com/redir?res...uthkey=!ACzVZLYCtJapI6Y&v=3&ithint=photo,.jpg
Hello Heikki,
I don't know that we will be able to take the original ABS coding and tweak the AWD specific bits but a large part of the VIN is encrypted into the coding as you mentioned. If you could post the pre-retrofit ABS coding with the full VIN from this car and in another clip, the factory coding from the 2011 Golf R comparison car with factory installed AWD and the VIN from that vehicle I'll take a look at it. Wrapping separate
s would be best so I don't confuse them.
If you want to include Scirocco (or any other Golf based comparison scan clips and VINs feel free to do so - but I think the baseline from the two would be sufficient for now.
-Dana
Heikki J.
Finland
C?ID=14516
Scirocco original FWD (pre-retrofit):
VIN: WVWZZZ13ZBV022349
Golf R with factory AWD:
VIN: WVWZZZ1KZBW298583
Coding: 143B800D092B0002281001EC901C00413D0000
Would be fantastic if you could see what you can find out. As I wrote above I've spend couple of hours with some Polish websites trying to decrypt the coding :) This is what I've found so far in a bit more color coded version. If I'm right, only the bits highlighted in red are different:
Any idea why I wasn't able to change the coding with VCDS? What does this "request out of range" -error mean?
I'm not able to scan the Golf right now as it's being painted 50km from here. Scirocco's scan I already had on the first post. Or would you need the scan of the whole car?
Heikki J.
Finland
C?ID=14516
Hi Dana,
Any new information to share to me?
Not yet so we'll get this back to the top.
Heikki J.
Finland
C?ID=14516
I could get full scan of both cars tomorrow if that helps.
Heikki J.
Finland
C?ID=14516
Here's finally full scans from both cars.
Scirocco:
Wednesday,02,April,2014,21:53:32:03166
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ13ZBV022349   License Plate:
Chassis Type: 13 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 2E 37 42 44 46 47 52
          55 56 77
Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
   Part No SW: 1K8 907 115 B    HW: 8P0 907 115 B
   Revision: 5BH19---    Serial number:
   Coding: 0403000C1C0F0160
   Shop #: WSC 00020 790 12345
   VCID: 2D5B60BAB41D6076001-8078
   Part No SW: 02E 300 012 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2118
   Revision:    51112    Serial number: 00001003041720
   VCID: 1B3FBE62DAA99EC66E5-804E
   Revision: 00H31001
   Shop #: WSC 00020 790 00000
   VCID: 76E98FD6C1CB63AEB1B-8023
            P1647 - 000 -
                    Reset counter: 144
                    Mileage: 51401 km
                    Date: 2037.14.05
                    Time: 16:39:56
                    Count: 7
                    Count: 4608
                    Count: 197
                    Count: 50177
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 6ED9A7B6B19B5B6E79B-803B
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 0045
   Revision: BE011001
   Coding: 40100A388025E30040080088340048E643758288736D8D60E48000000040
   VCID: 3F872AF2AE71E2E6A2D-806A
   Subsystem 1 - Part No SW: 1K8 955 119 F    HW: 1K8 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 28081  10  0603
   Coding: 009795
   Component: RLS 091110 05  54  0403
   Coding: 0330ED
   Component: LIN BACKUP HO  H11 9004
Address 10: Park/Steer Assist (J446)       Labels: 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     005 1806
   Revision: 00005000    Serial number: 0 263 004 450
   Coding: 308101
   VCID: 3B7F5EE2BA69FEC68E5-806E
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D034WRA
   Coding: 0012359
   VCID: 6FE7BAB27E91526672D-803A
   Subsystem 1 - Serial number: 6332MSME574177619
   Subsystem 2 - Serial number: 6342MSME574154334
   Subsystem 3 - Serial number: 6352QSME2C753D16Q
   Subsystem 4 - Serial number: 6362QSME2E754B2CZ
   Part No SW: 5K0 953 501 F    HW: 5K0 953 569 H
   Component: LENKS.MODUL   008 0107
   Revision: FF010E23    Serial number: 20090311200036
   Coding: 1892140000
   Shop #: WSC 06745 128 00802
   ASAM Dataset: EV_VW360SteerWheelUDS S02006
   VCID: 2D5B60BA7C1D6076001-8078
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Serial number: ƒ
   Coding: 830000
   Part No SW: 1K8 920 872 B    HW: 1K8 920 872 B
   Coding: 170F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 326173C665233F8E5D3-8067
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 061110F2000866
   Coding: 354000
   VCID: 306579CE632F0D9E2B7-8065
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 1K8 857 511 B    HW: 8J0 857 511 C
   Component: FLA           H03 0006
   Revision: AA002001
   Coding: 0201856B74745D545420363E00
   VCID: 31637CCA68250496249-8064
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 438F260202998606C65-8016
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAD12BA60D73374EA53-80BF
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669750557
   VCID: 285591AE5BFF455EF37-807D
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H71 4120
   Revision: AB001001    Serial number: VWZ6Z7M4271034
   Coding: 00050040010000A00004
   Shop #: WSC 05314 123 12345
   VCID: 336F76C292393686565-8066
   Component: EU West V8  7690
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2129
   Coding: 0016437
   VCID: 397344EA7055CCD69C9-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 251    3001
   Revision: 00H17000
   VCID: 31637CCAA8250496249-8064
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K 0340
   Revision: --------    Serial number: BP218109107033
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: E7D752921E610A26BAD-80B2
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016436
   VCID: 3A715BE67553C7CE953-806F
Address 55: Xenon Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 K
   Coding: 0000015
   VCID: 428123061D838F0ECD3-8017
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007660054703
   Coding: 0A01000000010101
   Shop #: WSC 08101 234 178948
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 244D859E2FD7A13EDFF-8071
Golf (there's a lot of fault codes due to front right door missing controller at the time of scan):
Wednesday,02,April,2014,21:39:00:03166
VIN: WVWZZZ1KZBW298583   License Plate:
Gateway Installation List:  7N0 907 530 C
52-Door Elect, Pass. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Wednesday,02,April,2014,21:43:41:03166
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 20 22 25 2E 37 42 44 46 47
          52 55 56 62 72 77
   Part No SW: 1K8 907 115 F    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH20---    Serial number:
   Shop #: WSC 11200 205 52248
Readiness: 0110 0101
   Part No SW: 02E 300 013 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2610
   Revision: 05351112    Serial number: 00001102071068
   VCID: 1C3DBD7EDFA799FE67F-8049
   Revision: 00H31001
   Revision: 00003001
   Coding: 0000000002
13701504 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:29
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:29
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AE
   Coding: 40180A3A8825F3C040080088740008E443550088736D8D60E48000240040
   VCID: 387541EE8B5FD5DE637-806D
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 23031  26  0512
   Coding: 009795
   Component: RLS 040411 05  54  0403
   Coding: 0330AD
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:29
                    Voltage: 11.10 V
                        Term 50 Off
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:29
                    Voltage: 11.10 V
                        Term 50 Off
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:29
                    Voltage: 11.10 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501106701046
   Coding: 108104
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 23031101940002
   Coding: 000180
   VCID: 2757929256E14A26FAD-8072
   Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
   Component: AirbagVW10G   013 0613
   Serial number: 003G7RA054WI
   Coding: 0000394E
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 336F76C29A393686565-8066
   Serial number: 3572MSME6756555EZZZ3
   Serial number: 3582MSME3A2D435EZZZ5
   Serial number: 3512QSME481F0A68ZZZ0
   Serial number: 3522QSME683F054CZZZ2
   Part No SW: 5K0 953 507     HW: 5K0 953 549 B
   Revision: --------    Serial number:  90472LBK0003U
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: EDDB20BA3C9D2076C01-80B8
   Serial number: 0029370
   Coding: 830000
   Part No SW: 5K6 920 871 B    HW: 5K6 920 871 B
   Coding: 170F01
   Revision:   H37       Serial number: 070411F2000017
   Coding: 350002
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:31
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:31
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 02018B6B74745D545420363E00
   VCID: 2D5B60BA741D6076001-8078
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   VCID: 448D251E0797813EFFF-8011
   Revision: A1001003    Serial number: 7669730649
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H52 2850
   Revision: AB001001    Serial number: VWZ6Z7L7089072
   Coding: 040700020100009000
   Shop #: WSC 18493 000 1048576
   VCID: 2E5967B6791B1B6E39B-807B
   Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
   Component: Tuer-SG         009 2151
   Coding: 0004278
   VCID: 346D75DE573731BE4FF-8061
Address 44: Steering Assist        Labels: None
   Part No: 5N0 909 144 M
   Component: EPS_ZFLS Kl. 251    3201
   Revision: 00H20000
   VCID: 3B7F5EE27A69FEC68E5-806E
Address 47: Sound System (R12)       Labels: None
   Part No HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109121274
   VCID: 55ABE85A340D08B6981-8000
9462291 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:31
9462803 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Reset counter: 194
                    Mileage: 28412 km
                    Date: 2000.14.15
                    Time: 11:18:31
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Coding: 1477724
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 356B48DA5C4D28B6781-8060
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603390787
   Coding: 020000000101000000000000
   Shop #: WSC 11200 205 99205
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_SE36.rod
   VCID: 2241838635C3AF0EAD3-8077
I don't want to give you any false hope but I think I narrowed the coding down to 6 or 7 possible bits. If I come up with something safe to try I'll update this thread with the suggestions.
-Dana
Heikki J.
Finland
C?ID=14516
Thanks Dana. That's pretty much what I've come up with. I just don't understand why I'm getting the error while I'm trying to recode.
I took a fresh look at this today but I do not have anything conclusive to offer in the coding area.
I will note that VW/Audi use coding bridges in factory wiring (either jumpers or open circuits) that are specific to driveline configurations. It is entirely possible that you already found the correct coding along the way but did you consider the possibility that the wiring harness may need a jumper or open to indicate AWD versus FWD? I could be all wrong here but MK60EC1 controllers are fussy enough to either zero coding when something isn't adding up or outright refuse perfectly valid coding when the controller (or car/wiring) aren't compatible.
-Dana
Heikki J.
Finland
C?ID=14516
Thanks Dana for letting me know. I wasn't aware of jumpers or open circuits in wiring loom. Would you expect to find these kind of tweaks by looking at wiring circuit diagrams... or could they be built inside the modules on the cars? So are they most likely built on the wiring loom or on the control units? I guess I'll need to start compare the circuit diagrams of my Scirocco and Golf... they both share the same ABS/ESB unit so I assume internally they are the same.
Still I'm not sure if the coding I tried is valid... I just tried brute-force with couple of bits (marked red on my earlier post).
But you're sure it's possible to change MK60EC1 coding with VCDS if you just have a valid code on the right vehicle? Like for example if I buy a brand new ABS unit I could recode with the original coding?
Hello Heikki,
These ABS modules vary based on each and every part number (suffix) so it is possible that hardware or software in the controller may vary ... but if coding bridges exist on this car they should be in the factory level wiring diagrams.
VCDS does not have issues configuring MK60EC1 ABS modules when the direct replacement controller is installed as a replacement on a vehicle under normal circumstances. In those straight forward repair situations the incorrect ABS module will either refuse coding -or- the coding will zero it after an ignition cycle when the incorrect module is installed but that is usually in conjunction with an Incompatible Interface or Control module does not match vehicle type of fault code.
Because you are retrofitting it is entirely possible that perfectly valid coding will be refused but the same should occur with the dealer level scan tool. If you encounter an error message other than 31: Request out of range please note it.
-Dana
Heikki J.
Finland
C?ID=14516
According to VCDS the ABS unit seems to be exactly the same in my both cars, Scirocco and Golf:
Revision: 00H31001
So I assume I now need to double check if I can find some differencies on the wiring looms...
Not sure if I have ever tried, but if I try to recode with the original code (write the same code that it already has), how should it respond?
That module should accept the original coding but let us know if it doesn't! If that's the case we can test a few Security Access codes - but those alone won't force the module to accept coding it doesn't want.
Heikki J.
Finland
C?ID=14516
Hi! Finally had time to try. Did not accept coding with the existing code, same error (Coding out of range).
Heikki J.
Finland
C?ID=14516
Today I compared the circuit diagrams of Golf and Scirocco and they seem to be equal. Same amount of wires connected exactly the same way. Perhaps it could still be the problem on coding of some other ECU than ABS... all the other ECUs just won't throw me any fault codes.
