Retrofit Jetta MK6 BCM into Jetta MK5 TDI
0xff
Argentina
C?ID=316445
Hi folks, this is my first post, and asking for some light on an issue I have with a customer's Jetta MK5 TDI Advance (Argentina spec).
He has messed around with a crappy chinese interface and, after he fried his BCM (5K0 937 086 F), he retrofitted an used Jetta MK6 Luxury BCM (5K0 937 086 J) as it seems compatible; and then he asked me to re-code his BCM to match the previous coding (which he saved with the chinese interface).
So, after I re-coded the new BCM, almost all the DTC were gone except for the two that the following scan reports. Also, I noticed this Jetta MK5 has the rear fog light only in the inner left tail light, and the reverse light in the inner tail light and the MK6 doesn't. Should I change the Byte 18?
Saturday,11,August,2018,13:47:46:43330
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: TopHost Soluciones
VIN: 3VWHC61K0AM179780   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VWHC61K0AM179780   Mileage: 166390km-103389miles
   Part No SW: 03G 906 056 AC    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000AG  6508
   Revision: --H13---    Serial number:
   Coding: 0000078
   Shop #: WSC 00066 000 00000
   VCID: 689C63395BDA99048F-803C
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit - Intermittent
                    Fault Status: 00110000
                    Mileage: 165598 km
                    Date: 2012.12.24
                    Time: 10:53:47
                    RPM: 147 /min
                    Voltage: 9.88 V
                    Bin. Bits: 00001011
                    Temperature: 7.2°C
                    Bin. Bits: 01110000
   Part No SW: 02E 300 054 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2106
   Revision:    51112    Serial number: 00001001140781
   Shop #: WSC 02069 000 90108
   VCID: 15621ACD3C28D4ECE4-8040
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 113B200D0A290003881204EC50190041310000
   VCID: 0444578987B25D6403-8050
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00066 000 00148
   VCID: 7DB2226DEC582CAC4C-8028
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0045
   Revision: BC011001
   Coding: 08000A3E982DE3E0400800802000012403000088510081605C8000000000
   Shop #: WSC 00066 123 12345
   VCID: 3B36EC75BACCE29C32-806E
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 28081  21  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 222
                    Mileage: 166396 km
                    Date: 2013.01.01
                    Time: 13:26:03
                    Voltage: 12.95 V
02199 - Bulb for Tail Light 2; Right (M50)
                    Reset counter: 222
                    Mileage: 166396 km
                    Date: 2013.01.01
                    Time: 13:25:44
                    Voltage: 13.20 V
   Component: 2N AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2N721+
   Coding: 0012878
   VCID: 3D32E26D64D8ECAC0C-8068
   Subsystem 1 - Serial number: 6332MSME55124B368
   Subsystem 2 - Serial number: 6342MSME55130C266
   Subsystem 3 - Serial number: 6351HSME231F4B014
   Subsystem 4 - Serial number: 6361HSME231F534CD
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001531
   VCID: 76A03D41016E7FF40D-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
00457 - Control Module for Network (J519)
   Part No SW: 5M0 920 870 E    HW: 5M0 920 870 E
   Component: KOMBI         H05 0305
   Coding: 171D00
   Shop #: WSC 15846 002 104857
   VCID: 312ACE5D608018CC98-8064
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 04091001210870
   Coding: ED807F0600060200001002
   VCID: 6D92122D7438BC2CFC-8038
   Component: IMMO          H05 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9819318DD6AB1499-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001317999
   Coding: 0000B4
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 271E20055E44567C46-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005197129
   Coding: 000090
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 312ACE5DA88018CC98-8064
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001302436
   Coding: 0000B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 281C2339535A59044F-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005200871
   Coding: 000090
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3548402
   Coding: 0000041004
   VCID: 628871117DE6F35451-8036
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.21.9      H24 0191
   Shop #: WSC 21977 142 74100
   VCID: 3E30E56169DEF7B415-806A
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.2V)-----------
Thank you!
downtime
Finland
C?ID=280813
Yes, byte 18.
0xff
Argentina
C?ID=316445
Thank you @downtime!
Is it safe to change BCM byte 18? I saw some threads in other forums where they had big issues after changing byte 18 (not so sure if they did it with a genuine interface or not).
If someone did the same retrofit (or similar one), I’ll be glad to hear/read some experiences with that.
Thanks!
downtime
Finland
C?ID=280813
I never had any issues with byte 18. I've read that someone had managed to destroy the BCM by changing it but well, internet is full of sh*t.
Search for the byte 18 here and you'll find a list of values you could try out. I think you'll find the correct one quite quickly.
0xff
Argentina
C?ID=316445
Thank you, I’ll do that.
golfi_vend
Tartu, Estonia
C?ID=195131
It's not only Internet. It's really possible do make BCM brick when playing with byte18. I know a such happening with Caddy 2010.
downtime
Finland
C?ID=280813
^ 99% of the cases a hacked Chinese VCDS copy was involved :D
But you're right, there's a slight chance to brick it. That said, unfortunately only route to make your lights work.
downtime
Finland
C?ID=280813
Ok but for some practical stuff. You can find a comprehensive list of byte 18 values below.
But you could go with Jetta codes first and as the car does not have Xenon then try 05 or 06 depending on the market area. Or 1E might be ok as well.
Value   Car      Light   Region      Note
01   BCM (default)
02   VW Golf (VW360)      Halogen   Rest of World      TFL_0
03   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0
04   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0_LED+LED_SBBR
05   VW Jetta (VW351)   Halogen   Rest of World      TFL_0
06   VW Jetta (VW351)   Halogen   NORTH AMERICA   TFL_0
07   VW Jetta (VW351C)   Halogen   China      TFL_0
08   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World      TFL_0
09   VW Golf/Jetta Variant (VW362)   Halogen   NORTH AMERICA   TFL_0
0A   VW Scirocco (VW364) LHD   Halogen   Rest of World       LHD TFL_0
0B   VW Scirocco (VW364) RL   Halogen   Rest of World      RHD TFL_0
0C   VW Caddy Van (VW367)    Halogen   Rest of World      TFL_0
0D   VW Caddy Van (VW367)    Halogen   Rest of World/Ska      TFL_0_Ska
0E   VW Golf Plus (VW369)   Halogen   Rest of World      TFL_0
0F   SEAT Leon (SE350)    Xenon   NORTH AMERICA   TFL_0
0F   SEAT Altea XL II (SE352)   Xenon   NORTH AMERICA   TFL_0   2/7
10   SEAT Toledo (SE351)   Xenon   NORTH AMERICA   TFL_0   9/9
11   SEAT Leon (SE350)    Halogen   NORTH AMERICA   TFL_S
11   SEAT Altea XL II (SE352)   Halogen   NORTH AMERICA   TFL_S   2/7
12   SEAT Toledo (SE351)   Halogen   NORTH AMERICA   TFL_0   9/9
13   VW Sharan (VW428)   Halogen   Rest of World      TFL_1
14   VW Sharan (VW428)   Xenon   Rest of World      TFL_1
15   VW Golf GTI (VW360)   Halogen   Rest of World      TFL_0+ LED SBBR
16   SEAT Leon (SE350   Xenon   Rest of World      TFL_0
16   SEAT Altea XL II (SE352)   Xenon   Rest of World      TFL_0    2/7
17   SEAT Toledo (SE351)   Xenon   Rest of World      TFL_0   9/9
18   SEAT Leon (SE350)    Halogen   Rest of World      TFL_S
18   SEAT Altea XL II (SE352)   Halogen   Rest of World      TFL_S   2/7
19   SEAT Toledo (SE351)   Halogen   Rest of World      TFL_S   9
1A   Skoda Superb Combi (SK462)   Halogen       without TFL, DRL-Low Beams
1B   Skoda Superb (SK461)   Halogen       without TFL, DRL-Low Beams
1C   Skoda Superb (SK461)   Halogen   Rest of World      separate TFL_1
1D   Skoda Superb (SK461)    Xenon   ASUV      TFL_Separate
1D   Skoda Yeti (SK356)   Xenon   ASUV      TFL_Separate
1E   VW Golf (VW360)    Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
1E   VW Jetta (VW351)   Halogen   NORTH AMERICA                           TFL_0 + SMR on SL-back
1F   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0 + LED SBBR
20   VW Golf (VW360)      Halogen   NORTH AMERICA   TFL_0_LED
21   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
22   VW Golf (VW360)      Halogen   Rest of World/Japan   Japan + LED_SBBR
23   Audi A3 (AU350PA)    Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
23   VW Golf (VW360)      Halogen   NORTH AMERICA                           TFL_0_LED+ LED_SBBR
24   Audi A3 (AU350PA)    Halogen   Rest of World      TFL_1
24   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World      TFL_1
25   Audi A3 (AU350PA)    Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
25   VW Scirocco (VW364)   Halogen   Rest of World/Ska LDH   TFL_0 LL_Ska
26   Audi A3 (AU350PA)    Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
26   VW Scirocco (VW364)   Xenon   Rest of World/Ska RHD   TFL_0 RL_Ska
27   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
27   VW Tiguan (VW316)   Xenon   Rest of World/Ska      TFL_1_Ska
28   Audi A3 (AU350PA)    Xenon   Rest of World/Ska      TFL_1_Ska
28   VW EOS (VW465)   Xenon   Rest of World/Ska      TFL_1_Ska
29   Audi A3 (AU350PA)    Halogen   Rest of World/Ska      TFL_0_Ska
29   VW Golf/Jetta Variant (VW362)   Halogen   Rest of World/Ska      TFL_0_Ska
2A   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
2B   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL without tail, AB2 PA 5door
2C   Audi A3 SportBack (AU353PA)   Xenon / ECE   Rest of World   LED DRL with tail, AB2 PA 5door
2D   Audi A6 (AU356PA)   Halogen   Rest of World   TFL_0
2E   Audi A6 (AU356PA)   Xenon   Rest of World   TFL_0
2F   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_0
30   VW Tiguan (VW316)   Halogen / Xenon   Rest of World   TFL_S
31   Skoda Superb Combi(SK462)   Halogen       separate TFL_1
32   Skoda Octavia (SK350)    Halogen   RHD   TFL_LED ROM from TFL
32   Skoda Octavia RS (SK35x-RS)   Halogen   RHD   TFL_LED ROM from TFL
33   Skoda Octavia (SK350)    Halogen   LHD   TFL_LED ROM from TFL
33   Skoda Octavia RS (SK35x-RS)   Halogen   LHD   TFL_LED ROM from TFL
34   Skoda Octavia (SK350)    Halogen   RL   RL from TFL ROM 52 ROM from TFL
34   Skoda Octavia (SK351)   Halogen   RL   RL from TFL ROM 52 ROM from TFL
35   Skoda Octavia (SK350)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
35   Skoda Octavia (SK351)   Halogen   LHD   TFL_1.separat LL halogen -ROM from TFL
36   Skoda Octavia (SK350)   Halogen   RL   DRL-Low Beams (S) (P)
36   Skoda Octavia (SK351)   Halogen   RL   DRL-Low Beams (S) (P)
37   Skoda Octavia (SK350)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
37   Skoda Octavia (SK351)   Halogen   LHD   DRL LHD-Low Beams (S) (P)
38   Skoda Octavia (SK350)   Halogen   RL   TFL_SH
38   Skoda Octavia (SK351)   Halogen   RL   TFL_SH
39   Skoda Octavia (SK350)   Halogen   LHD      TFL_SH
39   Skoda Octavia (SK351)   Halogen   LHD      TFL_SH
3A   Audi A1 (AU210)      Halogen   Rest of World       LHD TFL_S
3A   VW Scirocco (VW364)   Halogen   Rest of World       LHD TFL_S
3B   VW Scirocco (VW364)   Xenon   Rest of World       RHD TFL_S
3C   VW Golf (VW360)      Xenon   Rest of World      TFL_S
3D   VW Golf (VW360)      Xenon   NORTH AMERICA   TFL_S
3E   VW Golf (VW360)      Halogen   NORTH AMERICA
3F   VW Golf (VW360)      Xenon   Ska      TFL_S LED_SBBR
40   VW Golf (VW360)      Halogen   Rest of World
41   VW Golf (VW360)      Xenon   Rest of World      PO_LED
42   VW Golf (VW360)      Xenon   Ska      TFL_S_LED
43   VW Golf (VW360)      Halogen   Ska      TFL_S LED_SBBR
44   VW Golf (VW360)      Xenon   Rest of World      LED_SBBR
45   VW Golf (VW360)      Halogen   Ska      TFL_0_S
46   VW Golf Plus (VW369)   Halogen   Ska      TFL_0_S
47   VW Golf Plus (VW369)   Xenon   Rest of World      PO_LED
48   VW Golf Plus (VW369)   Xenon   Rest of World      TFL_LED
49   VW Golf Plus (VW369)   Halogen   Ska      TFL_S
4A   VW Jetta (VW351)   Xenon   Rest of World      PO_LED
4B   VW Jetta (VW351)   Xenon   Rest of World      TFL_LED
4C   VW Jetta (VW351)   Xenon   NORTH AMERICA   TFL_LED
4D   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      PO_LED
4E   VW Golf/Jetta Variant (VW362)   Xenon   Rest of World      TFL_LED
4F   VW Golf/Jetta Variant (VW362)   Xenon   NORTH AMERICA   TFL_LED
50   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_1
51   VW Tiguan (VW316)   Halogen / Xenon   NORTH AMERICA   TFL_S
52   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_1
53   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_1
54   VW EOS (VW465)   Halogen / Xenon   Rest of World      TFL_S
55   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S
56   Audi TT Coupe (AU354)   Halogen   Rest of World      TFL_S 2 R
56   VW EOS (VW465)   Halogen   Rest of World      TFL_S 2 R
57   Audi TT Coupe (AU354)   Halogen   NORTH AMERICA   TFL_S_II
57   VW EOS (VW465)   Halogen   NORTH AMERICA   TFL_S_II
58   Audi TT Coupe (AU354)   Xenon       LED DRL Choming+ H SL
59   Audi TT Coupe (AU354)   Xenon       LED DRL POL + SL + KZL Choming H SL
5A   Skoda Octavia (SK35x)   Halogen / Xenon   RL   LED, TFL from Shutter
5A   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   RL   LED, TFL from Shutter
5B   Skoda Octavia (SK35x)   Halogen / Xenon   LHD   LED, TFL from Shutter
5B   Skoda Octavia RS (SK35x-RS)   Halogen / Xenon   LHD   LED, TFL from Shutter
5C   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1_LED 8TA
5D   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TA
5E   VW EOS (VW465FL)   Halogen   Rest of World   TFL_1 8TC_8TD
5F   VW EOS (VW465FL)   Xenon   Rest of World   TFL_1_LED 8TC_8TD
60   VW EOS (VW465FL)   Halogen   NORTH AMERICA   TFL_1 8TA
61   VW EOS (VW465FL)   Xenon   NORTH AMERICA   TFL_1_Ska 8TA
62   VW EOS (VW465FL)   Halogen   Rest of World/Ska   TFL_1_Ska 8TC_8TD
63   VW EOS (VW465FL)   Xenon   Rest of World/Ska   LED_DRLs TFL_1 8TC_8TD
64   Audi R8   Xenon / ECE   Rest of World   LED DRL without tail
65   Audi R8   Xenon / ECE   Rest of World   LED DRL with tail
66   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL without tail
67   Audi R8   Halogen / Xenon   USA (SM  0W)   LED DRL with tail
68   Audi R8   Xenon / ECE   Rest of World   Complete LED LED DRL without tail
69   Audi R8   Xenon / ECE   Rest of World   Complete LED, LED DRL with tail
6A   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL without tail (LED tail without TFL)
6B   Audi R8   Halogen / Xenon   USA (SM  0W)   Complete LED, LED DRL with tail (LED rear TFL)
6C   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/Bulb 8.08.08
6D   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ Bulb 8.08.08
6E   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED 8.08.08
6F   Audi A1 (AU210)   Halogen / Xenon       TFL with tail, Halogen/ LED 8.08.08
70   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ Bulb 8.08.08
71   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ Bulb 8.08.08
72   Audi A1 (AU210)   Halogen / Xenon       LED TFL without tail, LED TFL/ LED 8.08.08
73   Audi A1 (AU210)   Halogen / Xenon       LED TFL with tail, LED TFL/ LED 8.08.08
74   Skoda Superb (SK461)   Halogen / Xenon   China      China without DRL SL with BL-function LED SBBR
75   Skoda Superb (SK461)   Halogen / Xenon   China       China without DRL / TFL-ABL SL without BL function LED SBBR
76   Audi TT Coupe (NF) (AU354)   Halogen   NORTH AMERICA              separate TFL without SL in CHO
77   Audi TT Coupe (NF) (AU354)   Xenon   NORTH AMERICA   LED DRL + CHO SL
78   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      LHD TFL_S
79   VW Scirocco (VW364)   Halogen / Xenon   Rest of World      RHD TFL_S
7A   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   separate DRL with tail
7B   Audi TT Coupe (NF) (AU354)   Halogen / Xenon   NORTH AMERICA   LED DRL with tail
7C   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ Bulb (dimmed DRL as taillight)
7D   Audi A1 (AU210)   Halogen / Xenon       TFL without tail, Halogen/ LED (dimmed DRL as taillight)
7E   Audi Q3 (AU316)      Halogen / Xenon      TFL_0 (from 05)
7E   VW Jetta (VW351)   Halogen / Xenon      TFL_0 (from 05)
7F   Audi Q3 (AU316)      Halogen / Xenon      TFL_S (from 35)
7F   VW Jetta (VW351)   Halogen / Xenon      TFL_S (from 35)
80   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_0 without NSL
80   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_0 without NSL
81   Audi Q3 (AU316)      Halogen / Xenon   Rest of World   TFL_S without NSL
81   VW Scirocco (VW364)   Halogen / Xenon   Rest of World   TFL_S without NSL
82   Audi Q3 (AU316)      Halogen / Xenon   LHD   TFL_1 8TC
82   VW Scirocco R-SCI (VW364)   Halogen / Xenon   LHD   TFL_1 8TC
83   Audi Q3 (AU316)      Halogen / Xenon   RHD   TFL_1 8TA/8TD
83   VW Scirocco R-SCI (VW364)   Halogen / Xenon   RHD   TFL_1 8TA/8TD
84   Audi Q3 (AU316)      Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
84   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska LHD   TFL_1 LHD_Ska 8TC
85   Audi Q3 (AU316)      Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
85   VW Scirocco R-SCI (VW364)   Halogen / Xenon   Ska RHD   TFL_1 RL_Ska 8TA/8TD
86   VW Jetta (VW351)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
87   VW Golf/Jetta Variant (VW352)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
87   VW Golf/Jetta Variant (VW362)   Halogen / Xenon   Rest of World/Ska      TFL_0_Ska
88   VW Scirocco (VW364) LHD   Halogen / Xenon   Rest of World/Ska LDH   TFL_1 LL_Ska
89   VW Scirocco (VW364) RL   Halogen / Xenon   Rest of World/Ska RHD   TFL_1 RL_Ska
8A   VW Tiguan (VW416)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8A   VW Tiguan (VW316)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8B   VW EOS (VW465)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8C   VW Jetta (VW361)   Halogen / Xenon   Rest of World      TFL_1
8D   VW Jetta (VW361)   Halogen / Xenon   NORTH AMERICA   TFL_1
8E   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1
8E   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1
8F   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
8F   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_Ska
90   VW EOS (VW465FL)   Halogen / Xenon   Rest of World      TFL_1_LED
90   VW Touran (VW368)   Halogen / Xenon   Rest of World      TFL_1_LED
91   VW EOS (VW465FL)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
91   VW Touran (VW368)   Halogen / Xenon   Rest of World/Ska      TFL_1_LED_Ska
92   SEAT Alhambra (SE428)   Halogen   Rest of World      TFL_1
93   SEAT Alhambra (SE428)   Xenon   Rest of World      TFL_1
94   VW EOS (VW465)   Halogen / Xenon   NORTH AMERICA   TFL_S, 2 Reverse Lights
95   VW Caddy Van (VN337)   Halogen / Xenon   Rest of World      TFL_S
96   VW Passat (VW411)   Halogen / Xenon   NORTH AMERICA   TFL_1
97   VW Passat (VW411)   Halogen   NORTH AMERICA   TFL_S
98   VW Passat (VW411)   Halogen / Xenon   China      TFL_1
99   VW Passat (VW411)   Halogen / Xenon   China      TFL_S
9A   SEAT Leon (SE350)   Xenon   NORTH AMERICA   TFL_0
9B   SEAT Leon (SE350)   Halogen   NORTH AMERICA   TFL_S
9C   SEAT Leon (SE350)   Xenon   Rest of World      TFL_0
9D   SEAT Leon (SE350)   Halogen   Rest of World
TFL_0   daytime running lights and rear fog light, reversing
light
TFL_1   daytime running lights with daytime running light
outputs
TFL_S   daytime running lights via Scandinavia low beam
lights
TFL_SH   daytime running lights via shutter
TFL_LED   LED module with dual function parking lights
TFL_O_S   special Scandinavia derivative solution
PO_LED   LED module
0xff
Argentina
C?ID=316445
Thank you, I’ll try 05 because the car doesn’t have DRLs lamps.
