Hi folks, this is my first post, and asking for some light on an issue I have with a customer's Jetta MK5 TDI Advance (Argentina spec).
He has messed around with a crappy chinese interface and, after he fried his BCM (5K0 937 086 F), he retrofitted an used Jetta MK6 Luxury BCM (5K0 937 086 J) as it seems compatible; and then he asked me to re-code his BCM to match the previous coding (which he saved with the chinese interface).
So, after I re-coded the new BCM, almost all the DTC were gone except for the two that the following scan reports. Also, I noticed this Jetta MK5 has the rear fog light only in the inner left tail light, and the reverse light in the inner tail light and the MK6 doesn't. Should I change the Byte 18?
Thank you!
Saturday,11,August,2018,13:47:46:43330
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
Dealer/Shop Name: TopHost Soluciones
VIN: 3VWHC61K0AM179780 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VWHC61K0AM179780 Mileage: 166390km-103389miles
Address 01: Engine Labels: None
Part No SW: 03G 906 056 AC HW: 03G 906 021 AN
Component: R4 1,9L EDC G000AG 6508
Revision: --H13--- Serial number:
Coding: 0000078
Shop #: WSC 00066 000 00000
VCID: 689C63395BDA99048F-803C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit - Intermittent
Fault Status: 00110000
Mileage: 165598 km
Date: 2012.12.24
Time: 10:53:47
RPM: 147 /min
Voltage: 9.88 V
Bin. Bits: 00001011
Temperature: 7.2°C
Bin. Bits: 01110000
Part No SW: 02E 300 054 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00001001140781
Shop #: WSC 02069 000 90108
VCID: 15621ACD3C28D4ECE4-8040
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 113B200D0A290003881204EC50190041310000
VCID: 0444578987B25D6403-8050
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 00066 000 00148
VCID: 7DB2226DEC582CAC4C-8028
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0045
Revision: BC011001
Coding: 08000A3E982DE3E0400800802000012403000088510081605C8000000000
Shop #: WSC 00066 123 12345
VCID: 3B36EC75BACCE29C32-806E
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 28081 21 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 222
Mileage: 166396 km
Date: 2013.01.01
Time: 13:26:03
Voltage: 12.95 V
02199 - Bulb for Tail Light 2; Right (M50)
Reset counter: 222
Mileage: 166396 km
Date: 2013.01.01
Time: 13:25:44
Voltage: 13.20 V
Component: 2N AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2N721+
Coding: 0012878
VCID: 3D32E26D64D8ECAC0C-8068
Subsystem 1 - Serial number: 6332MSME55124B368
Subsystem 2 - Serial number: 6342MSME55130C266
Subsystem 3 - Serial number: 6351HSME231F4B014
Subsystem 4 - Serial number: 6361HSME231F534CD
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001531
VCID: 76A03D41016E7FF40D-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
00457 - Control Module for Network (J519)
Part No SW: 5M0 920 870 E HW: 5M0 920 870 E
Component: KOMBI H05 0305
Coding: 171D00
Shop #: WSC 15846 002 104857
VCID: 312ACE5D608018CC98-8064
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 04091001210870
Coding: ED807F0600060200001002
VCID: 6D92122D7438BC2CFC-8038
Component: IMMO H05 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A9819318DD6AB1499-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001317999
Coding: 0000B4
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 271E20055E44567C46-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005197129
Coding: 000090
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 312ACE5DA88018CC98-8064
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001302436
Coding: 0000B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 281C2339535A59044F-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005200871
Coding: 000090
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3548402
Coding: 0000041004
VCID: 628871117DE6F35451-8036
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 96P HW: KTC 364 96P
Component: SWP:3.21.9 H24 0191
Shop #: WSC 21977 142 74100
VCID: 3E30E56169DEF7B415-806A
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.2V)-----------
