A3 8v steering angle set up problems
auditech12
Unverified
HC743489 (Clone!)
Hi all,
Really having problems getting the steering set up on my a3 8v. No matter what I try it will not accept a new calibration. The fault code it is giving is 15873
auditech12
Unverified
HC743489 (Clone!)
thanks Drennie, Who can I message to verify me?
auto scan as follows
Sunday,17,June,2018,18:18:41:40315
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4422.4
Dealer/Shop Name: w h enterprise
VIN: WAUZZZ8V7EA051852   License Plate: BF63YNW
Mileage: 61329km-38108mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V7EA051852   Mileage: 61329km-38108miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5518
   Revision: 84H22---
   Coding: 02250032032501092000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM16TDI01104L906021N 002009
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 3039EC84DAAA8437C17-8064
          U0428 00 [039] - -
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:53
                    Engine speed: 769.50 /min
                    Normed load value: 35.3 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 76 °C
                    Voltage terminal 30: 13.440 V
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:53
                    Engine speed: 771.50 /min
                    Normed load value: 34.9 %
                    Voltage terminal 30: 13.460 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 0CW 300 045 L    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4506
   Revision: 00043014    Serial number: CU501308056901
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 42DDB64C640606A7273-8016
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 62193000000AB8
   Coding: 12F18AA224250A6D017F060541C52548512450806082A4F20241F0788508
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BA30BA8436CB76F245-802E
0143 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
          [valve calibrating data missing]
                    Reset counter: 26
                    Date: 2018.04.06
                    Time: 01:51:52
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 26
                    Date: 2018.04.06
                    Time: 01:51:52
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 26
                    Date: 2018.04.06
                    Time: 01:51:52
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Reset counter: 26
                    Date: 2018.04.06
                    Time: 01:51:52
          C1146 02 [137] - Signal Failure
                    Reset counter: 26
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:52:01
   Part No SW: 8V0 820 043 A    HW: 8V0 820 043 A
   Component: AC Automat    H13 0031
   Revision: 20023000    Serial number: 00000000132240
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   Serial number: 9778CFB6000000000001
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 26
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:51
                    Outside air temperature: 41.5 °C
                    Engine speed: 771.00 /min
                    Temperature after evaporator: 31.9 °C
                    Refrigerant pressure: 1.2 bar
                    System run time-Terminal 15 on: 79 s
   Part No SW: 5Q0 937 084 T    HW: 5Q0 937 084 T
   Component: BCM MQBAB M+  H14 0112
   Serial number: 00011321002628
   Coding: 07001846C24102FD03844004B31407A80000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 49CFA1605930D5FFE69-801C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130715  041 0580
   Serial number:         130802135812
   Coding: 0A47F7
   Serial number: 21583462
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 31 05 2013  00001168
   Serial number: 000000000ZY1317700D4
   Serial number: 00000000000057082965
   Part No SW: 5Q0 919 298 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0033
   Revision: --------    Serial number: 61131322101806
   Coding: 0110060051
   ASAM Dataset: EV_EPHVA2CAU3700000 003015
   ROD: EV_EPHVA2CAU3700000_003_AU37.rod
   VCID: 3E25C2BC10FE624743B-806A
13637426 - Databus
                    Reset counter: 26
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:51
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
                    Reset counter: 26
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:51
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R02SGY5
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4BC39B68534CC7EFD45-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 208 13
   Serial number: 357670000006B23DCC01
   Subsystem 2 - Part No SW: -----------    HW: 480 000 208 13
   Serial number: 358670000000D23DCC0+
   Subsystem 3 - Part No SW: -----------    HW: 480 400 908 13
   Serial number: 35165029B1074480D2A5
   Subsystem 4 - Part No SW: -----------    HW: 480 400 908 13
   Serial number: 35265029B107448552B4
   Subsystem 5 - Part No SW: -----------    HW: 480 401 107 13
   Serial number: 3556502B5106FA4062CC
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 307 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502BD107DB54808K
   Subsystem 7 - Part No SW: -----------    HW: 480 401 106 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502AF1B5A883B2AY
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 106 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502B11B5A8808241
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1A [137] - Resistance Too Low
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:52
          B1006 1B [137] - Resistance Too High
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:52
9451547 - Igniter 1 for pedestrian protection
          B1038 1B [136] - Resistance Too High
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:53
   Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 12081308490249
   Coding: A418
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 392FD1A009D0457F769-806C
   Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
   Component: KOMBI         H03 2211
   Coding: 27A40A08239046000100E800000000
   VCID: 47CBA7584F24238FF0D-8012
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000899518
   Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
   ROD: EV_GatewLear_009_VW37.rod
   VCID: 3A2DCEAC0CD64E677F3-806E
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 01 08 2013  D0282700
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051820217
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 16071306070407
   Coding: 00108E205C01040000001002
   VCID: 3FDBBFB817F46B4F48D-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 80
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D27C5B01DF8795F5A1-8068
15873 - Steering angle sensor
                    Reset counter: 26
                    Mileage: 61329 km
                    Date: 2018.04.06
                    Time: 01:51:51
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 40.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uAdSensI_U5VFiltered_xdu16: 5.07331 V
                    uioUdNotFilt_xdu16: 13.22 V
                    uAdSensI_SwitchedKl30_xdu16: 13.21 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 14
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 27071303110009
   Coding: 001086205E01040000001002
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    040 0420
   Serial number: A7F02507131486
   Coding: 01730301FF00000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3B23CBA803EC776F645-806E
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG6021HL
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000022061300010928
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 25071302090039
   Coding: 000086204001040000001002
   VCID: 41DFB94061001DBF3E9-8014
   Component: TSG HBFS      010 0006
   Serial number: 25071304080038
End----------(Elapsed Time: 01:28, VBatt start/end: 12.8V/12.8V)-----------
Sunday,17,June,2018,18:25:26:40315
                Address 44: Steering Assist  (5Q0 909 144 L)
18:25:18
  IDE02216-IDE06673   Steering angle sensor: basic setting-Initialization status not initialized
  IDE02216-MAS01632   Steering angle sensor: basic setting-Status not calibrated
  IDE02216-MAS03161   Steering angle sensor: basic setting-Start Not permitted
  IDE04448-IDE00924   Steering angle sensor: angle-Steering angle 3276.7 °
auditech12
Unverified
HC743489 (Clone!)
Thanks for that Golfivend
Yeah, gen setup I promise!
when I try to "initialise" it it faults with security key required despite having logged in with 19142 or whatever it is. when I select the calibrate steering angle with wheel scale it wants me to enter a number between 1 to 3 digits.
also When I view my steering angle in measuring blocks its something like 3760 degrees. does not alter when I steer. Can someone look through my autoscan and see what they think?!
From autoscan seems like He's using V2.
Agreed, the scan was done with a legitimate HEX-V2. Unfortunately, I can't correlate that interface to him, and the serial number he provided when he joined the forum a few days ago earned him the "Unverified" status. ;)
auditech12
Unverified
HC743489 (Clone!)
Indeed you are correct! I started off with a non genuine set up and joined this forum looking for help, realised my problems were due to my non genuine set up. have since switched to a genuine set up and have only tonight learnt how to register it, unfortunately I am back at work for 4 days so cant get to my unit to do the registration!!
thanks for your help so far, only got 9 uses left before I must register it so am glad ive sussed it
thanks!
