- Oct 17, 2017
- 982
- 505
- Northwest UK
- C?ID=321059
Ok you'll need to go to the installations list in the CAN Gateway 19 to select those modules.
Wednesday,14,February,2018,22:25:59:35129
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4409.4
Data version: 20171130 DS276.6
VIN: WVWFM2AUXGW246170 License Plate:
Mileage: 26153km-16250mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
55 5F A9
VIN: WVWFM2AUXGW246170 Mileage: 26153km-16250miles
Address 01: Engine (J623-CJXE) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 K HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00122464050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
ROD: EV_ECM20TFS0205G0906259F_VW37.rod
VCID: 3620C89689CE44F67B-8062
Readiness: 1010 0001
Part No SW: 0D9 300 020 K HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4904
Revision: 06253104 Serial number: TFK01601191468
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 1D72373A0C38F7AE9A-8048
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60246000000551
Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AB81CA6FD566096DF-802E
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0420808478
Coding: 030F0F
Shop #: WSC 13765 790 12345
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B36D9A2B2EC999E84-806E
65826 - No Basic Setting
B2010 00 [009] - -
Mileage: 1048574 km
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020014200100001005000012101402
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A982CE68DF6D0162F-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061602803455
Coding: 00111A46C20122F34B644000000C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 095A736AA8B07B0EC6-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160118 043 0551
Serial number: 160202045705
Component: RLHS 037 0059
Serial number: S2Y16M02D08H10M34S06
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000RK8J200000
Coding: 181801
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 G HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0056
Revision: -------- Serial number: 39291603300852
Coding: 0001150011
VCID: 3D32D7BAACF897AEBA-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 02011604400195
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A38DCA6BDD6A0969F-806E
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 29121541350443
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 373EC5928EC4BDFE60-8062
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1CV8AR
VCID: 41CAAB4AD000F34EDE-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 902 16
Serial number: 35767000000E9650291V
Subsystem 2 - Part No SW: ----------- HW: 480 000 902 16
Serial number: 3586700000038644881S
Subsystem 3 - Part No SW: ----------- HW: 480 400 202 16
Serial number: 3516502B71EDD3E4637W
Subsystem 4 - Part No SW: ----------- HW: 480 400 202 16
Serial number: 3526502B71EDD3E591A
Subsystem 5 - Part No SW: ----------- HW: 480 400 502 16
Serial number: 3556502AD1EDD3E150D/
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160204500421
Coding: 0410
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 3FCEADB2A6F485BEA8-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G0 920 756 HW: 5G0 920 756
Component: KOMBI 302 6420
Coding: 47AD01183F98000801886A091400000000000000
VCID: 699A53EA88F0DB0E26-803C
16776980 - Databus
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:02:33
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 30011610802973
Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 79BA03AAF8506B8ED6-802C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000048900016026
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 6060799103
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000171068001
Coding: 5D00000000000000
Shop #: WSC 00066 790 07029
VCID: 3424F29E9FB256E645-8060
1048836 - Terminal S
B11A5 12 [009] - Short to Plus
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:02:34
ELV State: 02
Information Clamps: 66 20
CoCo State: A0 01
WFS State: 00 06
Vehicle speed: 0.00 km/h
Voltage: 68
AD-Value H-bridge: 32
Clamp15 flip flop: SSTx: button contacts: 09
CAN signals: 00
1048838 - Terminal 15
B1148 12 [137] - Short to Plus
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:02:34
ELV State: 02
CoCo State: A0 01
WFS State: 00 06
Voltage: 68
CAN signals: 00
1048840 - Terminal 15 Redundancy
B11D6 12 [137] - Short to Plus
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:02:34
ELV State: 02
CoCo State: A0 01
WFS State: 00 06
Voltage: 68
AD-Value H-bridge: 33
CAN signals: 00
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00023.11.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 47DEB552FE24CD7E10-8012
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0391756389
Coding: 01031103
ROD: EV_HREntryHella_VW32.rod
VCID: 3C34DABEB7E29EA68D-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 070116EA606676
Coding: 003F1320D000040100001000
VCID: 43C6A142CA1CE15ECC-8016
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 393AC3AAB8D0AB8E96-806C
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA01GG51
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
VCID: 6D9227FABC18C72E4A-8038
0512 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:03:39
Voltage terminal 30: 11.9 V
0517 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 49
Mileage: 26153 km
Date: 2018.02.14
Time: 22:03:39
Component: TSG BFS 020 0041
Serial number: 080116EA801099
Coding: 003F1120DC00040100801000
VCID: 42C8A446D506E856C7-8016
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029203000B010200
VCID: 40CCAE4EDB0AFA46D1-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3G0 035 045 B HW: 3G0 035 045
Component: MU-H-N-RW H50 0343
Serial number: A688A0GB002325
Coding: 0273000C0000000051110002001828001F0203F401200100DF
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU304VU1
Subsystem 2 - Part No SW: V03 959 801 ED HW: -----------
Component: ROW 2017/2018 --- 0065
Compact Disc Database:
Component: Gracenote2 --- 4008
Part No SW: 5G0 907 159 E HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0002
Serial number: 151216201255
VCID: 302CFE8E6BAA6AC621-8064
End----------(Elapsed Time: 01:51, VBatt start/end: 13.6V/13.6V)-----------
acc/auth module appears with name (J518) , it should J965 according to golf7 wiring diagram.
the part # of the kessy module I have 5Q0 959 435 B
I searched the net , there is also 5Q0 959 435 , 5Q0 959 435 A for VW
so, are they different (I checked the wiring diagram for a Passat CC , the Acc/auth module is J518
is that mean that the module I have was installed on Passat ??
its different ? or can be changed with ODIS ?
use ETKA to check what parts is recomend to which platform, because you mix passat CC (PQ) with golf 7 (MQB)
In etka you also have equipment code desctription
Qassem the part number for a Golf on MQB is 5Q0 959 435B which is the control unit for access and start Auth. If the part begins with a 'J' that normally efers to a control module.
I doubt that coding it is going to change the 'J' number it claims to be. I wouldn't obsess over this discrepancy. Sometimes VW changes these numbers. It has never really made sense to me why they do so, but I suppose the Herr. Dr. Dipl. Ing types in their white lab coats in Germany probably have their reasons, ja?Is this because the module is not coded yet ?!
Monday,26,February,2018,14:32:38:35129
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 52 55
5F A9
VIN: WVWFM2AUXGW246170 Mileage: 26705km-16593miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
14-Susp. Elect. -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
32-Differential Locks -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine
Coding: 030C0C
Revision: 00001K08
Coding: 90A8DD
Sun Roof:
Coding: 181801
Address 15: Airbags
Coding: 0410
Coding: 47AD01183F88000801886A095400000000000000
Shop #: WSC 01001 796 12345
End----(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.4V. VIgn 0.0V)------
Monday,26,February,2018,16:36:12:35129
55 5F A9
VIN: WVWFM2AUXGW246170 Mileage: 26724km-16605miles
Revision: --H13---
P1734 00 [002] - -
Coding: 030C0C
Revision: 00001K08
Air quality sensor:
Coding: 90A8DD
Sun Roof:
Coding: 181801
Coding: 0001150011
Coding: 0410
Coding: 2DFFFF
Reset counter: 70
Mileage: 26724 km
Date: 2018.02.26
Time: 16:26:13
ELV State: 42
CoCo State: A0 01
WFS State: 00 06
Voltage: 77
AD-Value H-bridge: 3A
CAN signals: 00
Reset counter: 70
Mileage: 26724 km
Date: 2018.02.26
Time: 16:26:13
ELV State: 42
CoCo State: A0 01
WFS State: 00 06
Voltage: 77
CAN signals: 00
Reset counter: 70
Mileage: 26724 km
Date: 2018.02.26
Time: 16:26:13
ELV State: 42
CoCo State: A0 01
WFS State: 00 06
Voltage: 77
CAN signals: 00
Coding: 0001
Coding: 01031103
Coding: 8103
Coding: 2E0000
Coding: 2E0000
End----------(Elapsed Time: 01:50, VBatt start/end: 13.9V/13.7V)-----------
I would speculate that it's the former.Is this because there is no information about MQB Kessy retrofit or no one is willing to help??!
no those two things I also experienced with half-working kessy.
Hi Qassem,Hi iichel,
what do you mean by "half-working kessy"
what you did after this ?
adapting the ELV and keys ? or something Extra you did ?
