GTI clubsport (3 door) - Kessy retrofit (AU) chasis
   #61
myounus
Northwest UK
C?ID=321059
Ok you'll need to go to the installations list in the CAN Gateway 19 to select those modules.
Qassem
Kuwait
C?ID=325382
this autoscan after adding the modules to the installation list.
I noticed something:-(
acc/auth module appears with name (J518) , it should J965 according to golf7 wiring diagram.
the part # of the kessy module I have 5Q0 959 435 B
I searched the net , there is also 5Q0 959 435 , 5Q0 959 435 A for VW
so, are they different (I checked the wiring diagram for a Passat CC , the Acc/auth module is J518
is that mean that the module I have was installed on Passat ??
its different ? or can be changed with ODIS ?
this is the one I bought :
https://www.ebay.com/itm/AUDI-VW-SE...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Wednesday,14,February,2018,22:25:59:35129
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
VIN: WVWFM2AUXGW246170   License Plate:
Mileage: 26153km-16250mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 47 52
          55 5F A9
VIN: WVWFM2AUXGW246170   Mileage: 26153km-16250miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 K    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122464050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
   ROD: EV_ECM20TFS0205G0906259F_VW37.rod
   VCID: 3620C89689CE44F67B-8062
Readiness: 1010 0001
   Part No SW: 0D9 300 020 K    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4904
   Revision: 06253104    Serial number: TFK01601191468
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1D72373A0C38F7AE9A-8048
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
   Revision: 00000000    Serial number: 60246000000551
   Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
   VCID: 7AB81CA6FD566096DF-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420808478
   Coding: 030F0F
   Shop #: WSC 13765 790 12345
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B36D9A2B2EC999E84-806E
65826 - No Basic Setting
          B2010 00 [009] -  -
                    Mileage: 1048574 km
                    Time: 00:00:00
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020014200100001005000012101402
   VCID: 6A982CE68DF6D0162F-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061602803455
   Coding: 00111A46C20122F34B644000000C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 095A736AA8B07B0EC6-805C
   Component: WWS    160118  043 0551
   Serial number:         160202045705
   Component: RLHS  037 0059
   Serial number: S2Y16M02D08H10M34S06
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000RK8J200000
   Coding: 181801
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39291603300852
   Coding: 0001150011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3D32D7BAACF897AEBA-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 02011604400195
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A38DCA6BDD6A0969F-806E
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 29121541350443
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 373EC5928EC4BDFE60-8062
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1CV8AR
   VCID: 41CAAB4AD000F34EDE-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35767000000E9650291V
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 3586700000038644881S
   Subsystem 3 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3516502B71EDD3E4637W
   Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3526502B71EDD3E591A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3556502AD1EDD3E150D/
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160204500421
   Coding: 0410
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 3FCEADB2A6F485BEA8-806A
   Part No SW: 5G0 920 756     HW: 5G0 920 756
   Component: KOMBI         302 6420
   Coding: 47AD01183F98000801886A091400000000000000
   VCID: 699A53EA88F0DB0E26-803C
16776980 - Databus
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:02:33
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 30011610802973
   Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79BA03AAF8506B8ED6-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160000048900016026
   Coding: 2DFFFF
   Serial number: 6060799103
   Revision: 00000000    Serial number: 14000171068001
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3424F29E9FB256E645-8060
1048836 - Terminal S
          B11A5 12 [009] - Short to Plus
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:02:34
                    ELV State: 02
                    Information Clamps: 66 20
                    CoCo State: A0 01
                    WFS State: 00 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
                    AD-Value H-bridge: 32
                    Clamp15 flip flop: SSTx: button contacts: 09
                    CAN signals: 00
1048838 - Terminal 15
          B1148 12 [137] - Short to Plus
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:02:34
                    ELV State: 02
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 68
                    CAN signals: 00
1048840 - Terminal 15 Redundancy
          B11D6 12 [137] - Short to Plus
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:02:34
                    ELV State: 02
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 68
                    AD-Value H-bridge: 33
                    CAN signals: 00
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00023.11.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 47DEB552FE24CD7E10-8012
   Component: HRE_Master    H11 0071
   Serial number: 0391756389
   Coding: 01031103
   Shop #: WSC 12345 123 12345
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C34DABEB7E29EA68D-8068
   Serial number: 070116EA606676
   Coding: 003F1320D000040100001000
   VCID: 43C6A142CA1CE15ECC-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 393AC3AAB8D0AB8E96-806C
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01GG51
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 6D9227FABC18C72E4A-8038
0512 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:03:39
                    Voltage terminal 30: 11.9 V
0517 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 49
                    Mileage: 26153 km
                    Date: 2018.02.14
                    Time: 22:03:39
   Serial number: 080116EA801099
   Coding: 003F1120DC00040100801000
   VCID: 42C8A446D506E856C7-8016
   Coding: 029203000B010200
   VCID: 40CCAE4EDB0AFA46D1-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3G0 035 045 B    HW: 3G0 035 045
   Component: MU-H-N-RW     H50 0343
   Serial number: A688A0GB002325
   Coding: 0273000C0000000051110002001828001F0203F401200100DF
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304VU1
   Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Component: Gracenote2  --- 4008
   Part No SW: 5G0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 151216201255
   VCID: 302CFE8E6BAA6AC621-8064
End----------(Elapsed Time: 01:51, VBatt start/end: 13.6V/13.6V)-----------
Spacewalker
C?ID=159607
use ETKA to check what parts is recomend to which platform, because you mix passat CC (PQ) with golf 7 (MQB)
In etka you also have equipment code desctription
   #64
myounus
Northwest UK
C?ID=321059
Qassem the part number for a Golf on MQB is 5Q0 959 435B which is the control unit for access and start Auth. If the part begins with a 'J' that normally efers to a control module.
   #65
Qassem
Kuwait
C?ID=325382
I checked the ETKA before I buy even , and since my car came from germany wolfsburg April 2016 , this part number 5Q0959435B was the latest part number used for MQB Golf.
I took a picture for the control module (it’s written MQB):
https://imgur.com/a/WHiiD
What makes me suspicious is the wiring diagram refers to KESSY module as J965 , and my autoscan shows J518 , I don’t have experience with VCDS , but this may because the module is not coded (no basic settings) !!
   #66
Qassem
Kuwait
C?ID=325382
Hi Maysoun is,
I agree with you totally, it’s the correct part number , but why J518 , not J965 as appears in the wiring diagram.
Is this because the module is not coded yet ?!
   #67
I doubt that coding it is going to change the 'J' number it claims to be. I wouldn't obsess over this discrepancy. Sometimes VW changes these numbers. It has never really made sense to me why they do so, but I suppose the Herr. Dr. Dipl. Ing types in their white lab coats in Germany probably have their reasons, ja?
Qassem
Kuwait
C?ID=325382
Thank you Uwe ,
Today I will try to find a shop having ODIS and Geko access, I found one yesterday and he asked me to come next Monday so he can take alook , he was clear with me , he said that he did a lot of retrofitting for VW, Audi, Porsche, but he never did a Kessy retrofit,
So giving that I don’t have that much info to at least guid him using both systems to correctly code it , I decided to look for locksmith specialist so he can confirm to me if he can do it or not.
As I heard if someone miss with immobilizer , it may cost a lot to gain back the identity of the car (I am not sure of that correct).
Qassem
Kuwait
C?ID=325382
I booked an appointment next Sunday with a specialist Audi & VW shop , who have access to both ODIS and GEKO.
He will check the connections first then he will code the modules with ODIS then program the new keys.
It sound good for me , but can you guys confirm that this is the way to do it , I need those guys who did it before or at least help other doing it.
Is there any other tweaks should be done to the ELV and Kessy especially that they are used (I mean already have data from the old vehicles)??!
   #70
Qassem
Kuwait
C?ID=325382
Dear Friends,
Regarding the last autoscan.
Can you help me with the steering lock faults.
Terminal s and terminal 15 short to plus.
What this means , and how I can fix it.
Any ideas please.
Maybe this because I am connecting the mechanical ignition switch also ?!!
Best regards,
Qassem
Kuwait
C?ID=325382
Dear Friends,
kessy module successfully adapted using ODIS online (MY VIN is inside now)
Steer col lock coding process using ODIS Online lead to this message (ERP0617E : software configuration not computed)
no faults inside the ELV but my VIN is not there yet (another VIN is there)
this is the auto scan (using brake pedal pressed ,flash indicator and high beam) I did this because if I used the mechanical switch there will be a short in terminal 15.
I need your help with the ELV.
Monday,26,February,2018,14:32:38:35129
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 52 55
          5F A9
VIN: WVWFM2AUXGW246170   Mileage: 26705km-16593miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
14-Susp. Elect. -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
32-Differential Locks -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine
   Coding: 030C0C
   Revision: 00001K08
   Coding: 90A8DD
   Sun Roof:
   Coding: 181801
Address 15: Airbags
   Coding: 0410
   Coding: 47AD01183F88000801886A095400000000000000
   Shop #: WSC 01001 796 12345
End----(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.4V. VIgn 0.0V)------
Qassem
Kuwait
C?ID=325382
This Autoscan by using the old switch (bypassing the immo):
Monday,26,February,2018,16:36:12:35129
          55 5F A9
VIN: WVWFM2AUXGW246170   Mileage: 26724km-16605miles
   Revision: --H13---
          P1734 00 [002] - -
   Coding: 030C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 90A8DD
   Sun Roof:
   Coding: 181801
   Coding: 0001150011
   Coding: 0410
   Coding: 2DFFFF
                    Reset counter: 70
                    Mileage: 26724 km
                    Date: 2018.02.26
                    Time: 16:26:13
                    ELV State: 42
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 77
                    AD-Value H-bridge: 3A
                    CAN signals: 00
                    Reset counter: 70
                    Mileage: 26724 km
                    Date: 2018.02.26
                    Time: 16:26:13
                    ELV State: 42
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 77
                    CAN signals: 00
                    Reset counter: 70
                    Mileage: 26724 km
                    Date: 2018.02.26
                    Time: 16:26:13
                    ELV State: 42
                    CoCo State: A0 01
                    WFS State: 00 06
                    Voltage: 77
                    CAN signals: 00
   Coding: 0001
   Coding: 01031103
   Coding: 8103
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 01:50, VBatt start/end: 13.9V/13.7V)-----------
Qassem
Kuwait
C?ID=325382
So this is maybe the post #5 in sequence from my side , but no comments.
Is this because there is no information about MQB Kessy retrofit or no one is willing to help??!
I know it’s rarely being done, but at least no one can tell me if i am going in the right direction?!
Immo 5 and MQB platform is a tough combination, but what I am seeing that not all what have been said about it are true facts.
1-online kessy module adaptation with my non kessy factory car is done easily (the module is used and had a vin inside it different than mine, and now it’s adapted and my vin is there without any fault using VW servers (the guys said the servers will not adapt used kessy module to a non factory kessy car).
2- ELV is used also, there is no faults there despite that the VIN inside it is different than mine, and we relearn my 2
factory keys 2 times during IMMo service using Fazit while the ELV connected (I am having two other solutions if this one doesn’t work), note: during adaptation process, ELV opened and closed several times.
3- key programming is the same procedure for kessy and non kessy , so people who said that kessy keys can’t be programmed online for a non factory kessy car(this is not true).
After adaptation of both KESSY and ELV, I will learn my 2 virgin new kessy keys and the shop confirmed it will work, and if not he will program it using VVDi2 , so again , MQB platform keys (both kessy and non kessy can be programmed using VW online servers and VVDI2 ).
Finally , thank you guys , even if there is no responses from your side , I will keep updating the thread so other can knows what can and can’t be done on MQB cars
Note: my believe, nothing can’t be done, you can do what ever you want with your MK7 golf , at least this is what l learned till now with my clubsport.
Golf7s are great cars.
I would speculate that it's the former.
D-Dub
C?ID=272151
I expect that everyone who has already tried to help as much as they have, do not anything else to suggest.
You are truly blazing the trail.
Going where no man has gone before!
Perhaps you open the doors for others to follow and become more commonplace retrofit.
   #76
Qassem
Kuwait
C?ID=325382
Update:
Today I took the car for a spin around the shop, and I noticed something, see the video.
https://youtu.be/PHOnVQmoKDg
Since the Kessy keys not yet programmed, and I turned on the car using the old switch, the kessy module keeps looking for the keys.
Also the start stop feature not turning the car off once reach to full stop , I guess because it’s think that it will not be able to switch on again because there is no keys :-) , its funny
Or maybe the car battery need to recharge that’s why the start stop fearture working.
iichel
Netherlands, eastern part
C?ID=284912
no those two things I also experienced with half-working kessy.
   #78
Qassem
Kuwait
C?ID=325382
Hi iichel,
what do you mean by "half-working kessy"
what you did after this ?
adapting the ELV and keys ? or something Extra you did ?
   #79
darkchina811
ITALY
C?ID=333184
how did this story finish? did it, actually?
   #80
marimsa
C?ID=361751
Hi iichel,
Hi Qassem,
I am doing the same retrofit but have the same issues.
Did you manage to adapte the ELV with your VIN?
If yes, how did you do it?
