Park Assist 2.0 from Park Pilot - Tutorial PLA 2.0
XaGiCo
Ponferrada of Spain
C?ID=243154
Brico Park Assist 2.0 from Park Pilot
https://vimeo.com/154322053
https://vimeo.com/168360956
- > LINK PDF BRIKO PARK ASSIST 2.0 A PARTIR DE PARK PILOT EN VW GOLF MKVII
Last Revised: 27-05-2016
Size 32MB
Ingredients and utensils:
Coding:
Part of the work:
New page LINKS:
VERY VERY PERFECT!!!!
But two members of ClubVWGOLF.com, has problems.
One is him and this Golf!
@Experimentos
http://forums.ross-tech.com/showthread.php?6589-Park-Assist-Pla-2-0
Regards
XaGiCo
aljb320
Long Island
C?ID=174376
Hello Xagico,
First sorry for the English but Im located in NYC USA.
I was wondering if you can assist me with my problem on my PDC retrofit installed on my 2017 GTI MK7 6 speed manual. I purchases new form amazon. Anyway the module is a 5QD 919 294J other number on it 5QA 919 294. I installed all wiring as per the instructions and confirmed all connections were correct prior to power on. I also have a registered VAGCOM cable with new update. I coded the modules as per instructions, however I still keep getting the faults bellow:
   Part No SW: 5QD 919 294 J    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000308418218348
   Coding: 0431251101
   Shop #: WSC 01369 210 40505
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 56A34E392922F63BC9-8002
12658704 - Databus
13632273 - Databus
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BBD09022180CF0502086A001000000000000000
   Shop #: WSC 00066 790 00149
   VCID: 2D51C1D57C3495E358-8078
          U1014 00 [009] - -
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   Shop #: WSC 00066 790 00215
   ROD: EV_MUStd4CDELP_VW26.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMW0466181
          B201A 00 [009] - -
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.25
                    Time: 20:14:30
                    Voltage terminal 30: 12.5 V
                    Status_Software_Version_Management-module_name: C
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:50
                    Voltage terminal 30: 11.5 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:53
                    BAP-BAP_Function_ID: 02
Anyway if you can offer any assistance that would be great, thanks again
downtime
C?ID=280813
Xagicos post is from 2016 so very slim change he will reply :)
if you post a full autoscan though, some other people here might be able to help.
Also I would throw the chinese pdc module away and get a proper one. Or flash it with euro software.
edit : ok saw your initial post on this one with autoscan. Instrument cluster, byte 13 bit 1. Is it enabled? Uncheck it. You don’t have PLA.
aljb320
Long Island
C?ID=174376
Ok great thanks I will do that and get back.
Monday,26,April,2021,15:22:42:09643
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
Dealer/Shop Name: Tony's VW_4_life
VIN: 3VW5T7AU5HM066511   License Plate: RED GTI PDC INST
Mileage: 9470km-5884mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW5T7AU5HM066511   Mileage: 9470km-5884miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900322424002F0000
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 377DE3BD8E682F3332-8062
Readiness: 1110 1101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51147000001983
   Coding: 01FA6BA134260972407C020180C42980D62C90024001943400435050C009430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 000F48619B26A88BC3-8054
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 4A9BAA49ED9AA2DB5D-801E
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
          B10CD 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:22:30
                    Voltage terminal 30: 11.3 V
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86420041701R6
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 071D537DBE089FB382-8052
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170304  043 0551
   Serial number: 97022066170318005905
   Coding: 0431251101
12658704 - Databus
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:45:16
13632273 - Databus
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:45:16
   Serial number: 003GCR07PRJ7
   VCID: 479D937DFE885FB342-8012
   Seat occupied recognition passenger side:
   Serial number: IBH0000000000071T2ON
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 357000000003747D622G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35800000000B0A2C622I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3510001B7257C422E70/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3520001C7257C426D476
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3550002B924F384181FA
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3560002B924F3845C28D
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 31031704221018
   Coding: 0400
   VCID: 0D116155DC74F5E3B8-8058
          U1014 00 [009] - -
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:07:52
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5286
   Serial number: 30051700840073
   Coding: 0101000870085900FB000028080F00000001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2E53C6D97132EEFB61-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000129990067045
   Coding: 30FFFF
   Serial number: 160517A0080CLA
   Coding: 003F03205000020000000000
   Shop #: WSC 12345 123 61029
   VCID: 4385876DCAB073939E-8016
   Rear Driver Side Door Control Module:
   Serial number: 00000000000006346821
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C176C51A76EFCEBAF-8058
   Serial number: 160517A00801Z8
   Coding: 003F03205E00020000000000
   VCID: 428B8269D5AA7A9B95-8016
   Rear Passenger Door Control Module:
   Serial number: 00000000000005234289
   Coding: 091000
          B201A 00 [009] - -
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.25
                    Time: 20:14:30
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:50
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:53
   Component: OCULowMQBUS   007 0570
   ROD: EV_OCULowMQB.rod
   Serial number: 170318201005
   VCID: 6BD50FCD82A05BD306-803E
End-------------------------(Elapsed Time: 03:50)--------------------------
aljb320
Long Island
C?ID=174376
Hey sorry for my ignorance but not sure how to code as it shows all zeros in byte 13, im trying to upload a pic so i can show you but dont know how sorry.
aljb320
Long Island
C?ID=174376
aljb320
Long Island
C?ID=174376
sorry for the double post please reply to my other post
@aljb320 's other post is here:
We'll close this thread.
