GTI MK7 base model S 8 sensor PDC install
aljb320
Long Island
C?ID=174376
Hello everyone hope this msg find you all well and safe,
so here we go,
I was wondering if anyone can assist me with my problem on my PDC retrofit installed on my 2017 GTI MK7 6 speed manual. I purchases this kit new form amazon/china. Anyway the module is a 5QD 919 294J other number on it 5QA 919 294. I installed all wiring as per the instructions and confirmed all connections were correct prior to power on. I also have a registered VAGCOM cable with new update. I coded the modules as per instructions, however I still keep getting these faults, see scan,
Anyway if you can offer any assistance that would be great, thanks again.
Monday,26,April,2021,15:22:42:09643
VCDS Version: 21.3.0.0 (x64)
Dealer/Shop Name: Tony's VW_4_life
VIN: 3VW5T7AU5HM066511   License Plate: RED GTI PDC INST
Mileage: 9470km-5884mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW5T7AU5HM066511   Mileage: 9470km-5884miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900322424002F0000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 377DE3BD8E682F3332-8062
Readiness: 1110 1101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51147000001983
   Coding: 01FA6BA134260972407C020180C42980D62C90024001943400435050C009430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 000F48619B26A88BC3-8054
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   VCID: 4A9BAA49ED9AA2DB5D-801E
          B10CD 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:22:30
                    Voltage terminal 30: 11.3 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86420041701R6
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 071D537DBE089FB382-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170304  043 0551
   Serial number: 97022066170318005905
   Part No SW: 5QD 919 294 J    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000308418218348
   Coding: 0431251101
   Shop #: WSC 01369 210 40505
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 56A34E392922F63BC9-8002
12658704 - Databus
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:45:16
13632273 - Databus
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:45:16
   Serial number: 003GCR07PRJ7
   VCID: 479D937DFE885FB342-8012
   Serial number: IBH0000000000071T2ON
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 357000000003747D622G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35800000000B0A2C622I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3510001B7257C422E70/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3520001C7257C426D476
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3550002B924F384181FA
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3560002B924F3845C28D
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 31031704221018
   Coding: 0400
   VCID: 0D116155DC74F5E3B8-8058
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BBD09022180CF0502086A001000000000000000
   VCID: 2D51C1D57C3495E358-8078
          U1014 00 [009] - -
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 14:07:52
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5286
   Serial number: 30051700840073
   Coding: 0101000870085900FB000028080F00000001050000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_GatewNF_VW37.rod
   VCID: 2E53C6D97132EEFB61-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000129990067045
   Coding: 30FFFF
   Serial number: 160517A0080CLA
   Coding: 003F03205000020000000000
   Shop #: WSC 12345 123 61029
   VCID: 4385876DCAB073939E-8016
   Serial number: 00000000000006346821
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C176C51A76EFCEBAF-8058
   Serial number: 160517A00801Z8
   Coding: 003F03205E00020000000000
   VCID: 428B8269D5AA7A9B95-8016
   Serial number: 00000000000005234289
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMW0466181
          B201A 00 [009] - -
                    Reset counter: 189
                    Mileage: 9470 km
                    Date: 2021.04.25
                    Time: 20:14:30
                    Voltage terminal 30: 12.5 V
                    Status_Software_Version_Management-module_name: C
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:50
                    Voltage terminal 30: 11.5 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 229
                    Mileage: 9470 km
                    Date: 2021.04.26
                    Time: 13:37:53
                    BAP-BAP_Function_ID: 02
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 170318201005
   VCID: 6BD50FCD82A05BD306-803E
End-------------------------(Elapsed Time: 03:50)--------------------------
aljb320
Long Island
C?ID=174376
Also and not sure if this matters, but I forgot to add that I installed/retrofitted auto folding mirrors and an 8" radio display that was from an atlas, (so I was told). every thing works fine just the issues as stated above, thanks.
aljb320
Long Island
C?ID=174376
downtime noticed that my Instrument cluster, byte 13 bit 1. Is enabled? and that I don’t have PLA. but when I try to Uncheck it get this,
downtime
Finland
C?ID=280813
Sorry, my bad I counted the bytes incorrect. I'll check today your coding if no one else beats me to it :)
aljb320
Long Island
C?ID=174376
Hey no worries, I appreciate the the help, thanks
aljb320
Long Island
C?ID=174376
Hey morning to all, I have a question for the RossTech team. Do I need a newer cable (HEX-NET or HEX-V2) for my coding of this after market/Chinese PDC and also for future newer VW/audi car groups? My current cable is HEX+CAN.
downtime
Finland
C?ID=280813
to get the most out of your current car you would need hex-v2. You will get much better coding options with an upgraded cable.
downtime
Finland
C?ID=280813
Ok, your coding :
Module 10, change your coding to this : 0431051041
That should get rid of the missing message errors
For the module 17 instrument cluster coding, try this : 0BBD09022190CF0502086A001000000000000000
aljb320
Long Island
C?ID=174376
downtime, I coded the modules as you stated but no help. Controller 17 I have (contrl. Mod. incorrectly coded) and 10 same faults as before data bus missing msg. I purchased a used one on ebay and will wait to see if that will fix it the P/N 5QA919294B. I looked this up on VW parts catalog and its shows to fit 8 sensor PDC. thanks again.
downtime
Finland
C?ID=280813
There's nothing wrong with the PDC module. It is still just not coded correctly. With the chinese modules you never know for what car the module has been parameterized for.
Was the new module you bought from what car originally? If it's not from Golf, you need to start finding someone who can flash Golf dataset to it.
Do you have park menu visible in MIB -> Car menu?
aljb320
Long Island
C?ID=174376
oh did not know about that plus I dont know what car the old unit is from. as for the new module where do I see that info for what car its was programmed for?
I initially had a display in the MIB then like the idiot that I am I must have coded something wrong and lost it so every time I turn the car on it will immediately fault.
downtime
Finland
C?ID=280813
Can you post the adaptation map from 5F.
VCDS -> Applications -> controller channel map and choose csv as ouput and 5F as the module
Some hints could be gained by going to the module 10, advanced ID and look what it says after the dataset part.
aljb320
Long Island
C?ID=174376
downtime,
here you go I hope I did this rite, thanks.
    SW:3Q0-035-844-A   HW:3Q0-035-844-A ---  Information Electr. --- SA: 71679
    Component:MU-S-S-US     710 0753     Coding:02730000FF00000051220001001808009F0203D40120010002
    EV_MUStd4CDELP    1001    EV_MUStd4CDELP_VW26.rod
    Wednesday    28    April    2021    09:50:50:09643
    VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
IDE00001-Production mode    00 00 00     3
IDE00346-Summertime-automatic    manual     1
IDE00758-Base volume of telephone    50 %    1
IDE00759-Base volume of speech output    50 %    1
IDE00760-Microphone sensitivity    0 dB    1
IDE00769-Call number 1 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00770-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages    OFF     1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages    OFF     1
IDE02121-CD eject button    Enabled     1
IDE02122-Developer mode    activated     1
IDE02330-Call number 2 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02331-Number 2 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02332-Deactivate production mode    0    3
IDE02476-MAS03001-Electrical test of speakers-Mode    automatic     49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency    19000 Hz    49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume    27    49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency    19000 Hz    49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume    27    49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency    19000 Hz    49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume    27    49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency    19000 Hz    49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume    27    49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency    19000 Hz    49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume    27    49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency    19000 Hz    49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume    27    49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency    19000 Hz    49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume    27    49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency    19000 Hz    49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume    27    49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency    19000 Hz    49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume    27    49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency    19000 Hz    49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume    27    49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency    19000 Hz    49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume    27    49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency    19000 Hz    49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume    27    49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency    19000 Hz    49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume    27    49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency    19000 Hz    49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume    27    49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency    19000 Hz    49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume    27    49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency    19000 Hz    49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume    27    49
IDE02502-Confirmation of installation change    40 C1     2
IDE02699-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02701-Number 1 (roaming) for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display    OFF     30
IDE03471-ENG249824-Vehicle configuration-AliBox    OFF     30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing    OFF     30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO    On     30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless    OFF     30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life    OFF     30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios    OFF     30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless    OFF     30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless    OFF     30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb    locked     30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant    0    30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage    0    30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call    On     30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support    OFF     30
IDE03471-ENG185778-Vehicle configuration-FoD    SWaP     30
IDE03471-ENG130248-Vehicle configuration-Google_GAL    On     30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless    OFF     30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts    OFF     30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other    OFF     30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts    OFF     30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other    OFF     30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data    not activated     30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender    Deactivated     30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting    OFF     30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1    not installed     30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2    not installed     30
IDE03471-ENG127492-Vehicle configuration-LGI    OFF     30
IDE03471-ENG130246-Vehicle configuration-LTE_modul    activated     30
IDE03471-ENG142142-Vehicle configuration-map_email_support    OFF     30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support    OFF     30
IDE03471-ENG142141-Vehicle configuration-map_sms_support    OFF     30
IDE03471-ENG142152-Vehicle configuration-Map_Style    0    30
IDE03471-ENG152537-Vehicle configuration-media_control    not activated     30
IDE03471-ENG138662-Vehicle configuration-Mirror_link    On     30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code    MIB_EU     30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference    RGB565     30
IDE03471-ENG117843-Vehicle configuration-my_audi    OFF     30
IDE03471-ENG117845-Vehicle configuration-online_dictation    OFF     30
IDE03471-ENG127495-Vehicle configuration-online_media    OFF     30
IDE03471-ENG117840-Vehicle configuration-online_navigation    OFF     30
IDE03471-ENG117837-Vehicle configuration-online_POI    OFF     30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice    OFF     30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services    OFF     30
IDE03471-ENG152553-Vehicle configuration-online_radio    Deactivated     30
IDE03471-ENG117841-Vehicle configuration-online_street_view    OFF     30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit    OFF     30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold    0    30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis    0    30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy    0    30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode    Data & language service active     30
IDE03471-ENG117844-Vehicle configuration-picture_navi    OFF     30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking    not activated     30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use    not activated     30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest    0    30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi    OFF     30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo    OFF     30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version    PSD_1.5     30
IDE03471-ENG117846-Vehicle configuration-remote_HMI    OFF     30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component    activated     30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open    not activated     30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold    not activated     30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe    not activated     30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input    FBAS     30
IDE03471-ENG152556-Vehicle configuration-scon_telephony    not activated     30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation    no restriction     30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag    no_region     30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch    not activated     30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch    not installed     30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support    OFF     30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi    activated     30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode    0    30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold    OFF     30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling    On     30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone    On     30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location    OFF     30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability    OFF     30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving    locked     30
IDE03471-ENG137647-Vehicle configuration-UOTA    OFF     30
IDE03471-ENG167532-Vehicle configuration-UOTA_2    OFF     30
IDE03471-ENG117852-Vehicle configuration-UPnP    OFF     30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound    not activated     30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound    not activated     30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte    not activated     30
IDE03471-ENG117836-Vehicle configuration-VZAPro    OFF     30
IDE03471-ENG127494-Vehicle configuration-VZO    OFF     30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI    On     30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot    OFF     30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch    not activated     30
IDE03902-Automatic ring break diagnostic    No automatic start     1
IDE04295-Bluetooth: Preferred connection profile for phone book data    PBAP     1
IDE04331-Selection of release codes for a SWaP function    FF FF FF FF     4
IDE04521-Sporadic ring break detection    optical     1
IDE04522-Awakening ability on optical databus    OFF     1
IDE04550-Bluetooth: Sniff mode    OFF     1
IDE05113-Infotainment Recorder    activated     1
IDE06425-Dynamometer mode: functional    not activated     1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner    -128    40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio    5    40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)    -128    40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)    -128    40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)    -128    40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB    -128    40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP    -128    40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay    -128    40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter    -128    40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN    -128    40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray    -128    40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice    -128    40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA    -128    40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud    -128    40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD    -128    40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI    -128    40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP    -128    40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP    -128    40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink    -128    40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP    -128    40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB    -3    40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice    -128    40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM    -128    40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep    -128    40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging    -128    40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen    6    40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning    -128    40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav    -128    40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS    -128    40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online    -128    40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal    -128    40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI    -128    40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN    -128    40
IDE10480-MAS10741-Interface for external media: activation-Connection 1    activated     4
IDE10480-MAS10742-Interface for external media: activation-Connection 2    not activated     4
IDE10480-MAS10743-Interface for external media: activation-Connection 3    not activated     4
IDE10480-MAS10744-Interface for external media: activation-Connection 4    not activated     4
IDE10604-Menu entries for mobile online services    not activated     1
IDE11122-Country identification: country of sale HMI    US     2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0    blocked     21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1    non_blocked     21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10    non_blocked     21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11    blocked     21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12    blocked     21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13    non_blocked     21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14    non_blocked     21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15    non_blocked     21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16    non_blocked     21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17    non_blocked     21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18    non_blocked     21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19    non_blocked     21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2    blocked     21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20    non_blocked     21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21    non_blocked     21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22    non_blocked     21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23    non_blocked     21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3    blocked     21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4    non_blocked     21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5    non_blocked     21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6    non_blocked     21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7    blocked     21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8    non_blocked     21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9    non_blocked     21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0    non_blocked     21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1    blocked     21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10    blocked     21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11    blocked     21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12    blocked     21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13    blocked     21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14    non_blocked     21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15    blocked     21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16    non_blocked     21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17    non_blocked     21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18    non_blocked     21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19    non_blocked     21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2    non_blocked     21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20    non_blocked     21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21    non_blocked     21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22    non_blocked     21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23    non_blocked     21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3    blocked     21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4    blocked     21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5    blocked     21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6    non_blocked     21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7    non_blocked     21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8    blocked     21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9    blocked     21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0    blocked     21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1    non_blocked     21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10    blocked     21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11    blocked     21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12    blocked     21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13    blocked     21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14    blocked     21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15    non_blocked     21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16    non_blocked     21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17    non_blocked     21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18    blocked     21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19    blocked     21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2    blocked     21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20    blocked     21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21    non_blocked     21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22    non_blocked     21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23    non_blocked     21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24    non_blocked     21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25    non_blocked     21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26    non_blocked     21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27    non_blocked     21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28    non_blocked     21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29    non_blocked     21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3    non_blocked     21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30    non_blocked     21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31    non_blocked     21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32    non_blocked     21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33    non_blocked     21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34    non_blocked     21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35    non_blocked     21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36    non_blocked     21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37    non_blocked     21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38    non_blocked     21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39    non_blocked     21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4    non_blocked     21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40    non_blocked     21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41    non_blocked     21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42    non_blocked     21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43    non_blocked     21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44    blocked     21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45    blocked     21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46    blocked     21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47    blocked     21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5    blocked     21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6    non_blocked     21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7    non_blocked     21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8    non_blocked     21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9    blocked     21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0    blocked     21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1    non_blocked     21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10    non_blocked     21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11    non_blocked     21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12    non_blocked     21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13    non_blocked     21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14    non_blocked     21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15    non_blocked     21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16    non_blocked     21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17    non_blocked     21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18    non_blocked     21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19    non_blocked     21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2    non_blocked     21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20    non_blocked     21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21    blocked     21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22    non_blocked     21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23    non_blocked     21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24    non_blocked     21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25    non_blocked     21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26    non_blocked     21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27    non_blocked     21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28    non_blocked     21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29    non_blocked     21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3    non_blocked     21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30    non_blocked     21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31    non_blocked     21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32    non_blocked     21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33    non_blocked     21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34    non_blocked     21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35    non_blocked     21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36    non_blocked     21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37    non_blocked     21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38    non_blocked     21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39    non_blocked     21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4    blocked     21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5    non_blocked     21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6    blocked     21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7    non_blocked     21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8    non_blocked     21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9    blocked     21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0    blocked     21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1    non_blocked     21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10    non_blocked     21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11    non_blocked     21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12    non_blocked     21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13    non_blocked     21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14    non_blocked     21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15    non_blocked     21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2    non_blocked     21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3    non_blocked     21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4    blocked     21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5    blocked     21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6    blocked     21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7    blocked     21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8    non_blocked     21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9    non_blocked     21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0    non_blocked     21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1    non_blocked     21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10    non_blocked     21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11    non_blocked     21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12    non_blocked     21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13    non_blocked     21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14    non_blocked     21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15    non_blocked     21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2    non_blocked     21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3    blocked     21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4    blocked     21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5    blocked     21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6    blocked     21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7    blocked     21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8    non_blocked     21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9    non_blocked     21
IDE11503-Satellite radio tuner: pre-activated subscription    5    1
MAS00951-Bluetooth    On     1
MAS01968-Fan    normal     1
MAS02809-MAS02870-Check tone frequency-High note frequency range    4000 Hz    6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range    1000 Hz    6
MAS02809-MAS02872-Check tone frequency-Low note frequency range    100 Hz    6
MAS03782-WLAN    On     1
ENG117917-BAP_Debug_Mode_Release    not_released     1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization    not activated     60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer    not activated     60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off    not activated     60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high    not activated     60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill    not activated     60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation    not activated     60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer    not activated     60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off    not activated     60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high    not activated     60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill    not activated     60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent    not activated     60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer    not activated     60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off    not activated     60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high    not activated     60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill    not activated     60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC    not activated     60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer    not activated     60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off    not activated     60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high    not activated     60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill    not activated     60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key    not activated     60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer    not activated     60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off    not activated     60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high    not activated     60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill    not activated     60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue    not activated     60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer    not activated     60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off    not activated     60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high    not activated     60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill    not activated     60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper    not activated     60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer    not activated     60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off    not activated     60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high    not activated     60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill    not activated     60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination    activated     60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer    not activated     60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off    not activated     60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high    activated     60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill    not activated     60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope    not activated     60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer    not activated     60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off    not activated     60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high    not activated     60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill    not activated     60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification    not activated     60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer    not activated     60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off    not activated     60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high    not activated     60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill    not activated     60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating    not activated     60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer    not activated     60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off    not activated     60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high    not activated     60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill    not activated     60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv    not activated     60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer    not activated     60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off    not activated     60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high    not activated     60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill    not activated     60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management    not activated     60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer    not activated     60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off    not activated     60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high    not activated     60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill    not activated     60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE    activated     60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer    not activated     60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off    not activated     60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high    activated     60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill    not activated     60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer    activated     60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer    not activated     60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off    not activated     60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high    activated     60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill    not activated     60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function    activated     60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer    not activated     60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off    not activated     60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high    activated     60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill    not activated     60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror    activated     60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer    not activated     60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off    not activated     60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high    activated     60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill    not activated     60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking    activated     60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer    not activated     60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off    not activated     60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high    activated     60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill    not activated     60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master    activated     60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer    not activated     60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off    not activated     60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high    activated     60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill    not activated     60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma    activated     60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer    not activated     60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off    not activated     60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high    activated     60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill    not activated     60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration    not activated     60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer    not activated     60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off    not activated     60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high    not activated     60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill    not activated     60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock    activated     60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer    not activated     60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off    not activated     60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high    activated     60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill    not activated     60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass    not activated     60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer    not activated     60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off    not activated     60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high    not activated     60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill    not activated     60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist    not activated     60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer    not activated     60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off    not activated     60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high    not activated     60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill    not activated     60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration    not activated     60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer    not activated     60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off    not activated     60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high    not activated     60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill    not activated     60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school    not activated     60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer    not activated     60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off    not activated     60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high    not activated     60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill    not activated     60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall    activated     60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer    not activated     60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off    not activated     60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high    activated     60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill    not activated     60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist    not activated     60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer    not activated     60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off    not activated     60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high    not activated     60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill    not activated     60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI    activated     60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer    not activated     60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off    not activated     60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high    activated     60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill    not activated     60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination    activated     60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer    not activated     60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off    not activated     60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high    activated     60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill    not activated     60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display    not activated     60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer    not activated     60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off    not activated     60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high    not activated     60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill    not activated     60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid    not activated     60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer    not activated     60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off    not activated     60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high    not activated     60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill    not activated     60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant    not activated     60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer    not activated     60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off    not activated     60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high    not activated     60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill    not activated     60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning    not activated     60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer    not activated     60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off    not activated     60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high    not activated     60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill    not activated     60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker    not activated     60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer    not activated     60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off    not activated     60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high    not activated     60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill    not activated     60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision    not activated     60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer    not activated     60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off    not activated     60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high    not activated     60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill    not activated     60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level    not activated     60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer    not activated     60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off    not activated     60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high    not activated     60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill    not activated     60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc    activated     60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer    not activated     60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off    not activated     60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high    activated     60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill    not activated     60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist    not activated     60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer    not activated     60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off    not activated     60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high    activated     60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill    not activated     60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk    activated     60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer    not activated     60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off    not activated     60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high    activated     60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill    not activated     60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment    not activated     60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer    not activated     60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off    not activated     60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high    not activated     60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill    not activated     60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load    not activated     60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer    not activated     60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off    not activated     60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high    not activated     60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill    not activated     60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification    not activated     60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer    not activated     60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off    not activated     60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high    not activated     60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill    not activated     60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration    not activated     60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer    not activated     60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off    not activated     60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high    not activated     60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill    not activated     60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic    not activated     60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer    not activated     60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off    not activated     60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high    not activated     60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill    not activated     60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia    activated     60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer    not activated     60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off    not activated     60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high    activated     60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill    not activated     60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view    not activated     60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer    not activated     60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off    not activated     60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high    not activated     60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill    not activated     60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions    not activated     60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer    not activated     60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off    not activated     60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high    not activated     60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill    not activated     60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler    not activated     60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer    not activated     60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off    not activated     60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high    not activated     60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill    not activated     60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI    not activated     60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer    not activated     60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off    not activated     60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high    not activated     60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill    not activated     60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons    not activated     60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer    not activated     60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off    not activated     60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high    not activated     60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill    not activated     60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant    not activated     60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer    not activated     60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off    not activated     60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high    not activated     60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill    not activated     60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner    not activated     60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer    not activated     60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off    not activated     60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high    not activated     60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill    not activated     60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo    not activated     60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer    not activated     60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off    not activated     60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high    not activated     60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill    not activated     60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating    activated     60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer    not activated     60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off    not activated     60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high    activated     60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill    not activated     60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin    activated     60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer    not activated     60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off    not activated     60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high    activated     60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill    not activated     60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition    not activated     60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer    not activated     60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off    not activated     60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high    not activated     60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill    not activated     60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows    activated     60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer    not activated     60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off    not activated     60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high    activated     60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill    not activated     60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper    activated     60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer    not activated     60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off    not activated     60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high    activated     60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill    not activated     60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol    not activated     60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer    not activated     60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off    not activated     60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high    not activated     60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill    not activated     60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05    not activated     64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus    Extended data bus     64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06    not activated     64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus    Suspension data bus     64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D    not activated     64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus    Infotainment data bus     64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24    not activated     64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus    not activated     64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03    not activated     64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus    Comfort data bus     64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B    not activated     64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus    Terminal 15     64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25    not activated     64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus    Powertrain data bus     64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23    activated     64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus    Infotainment data bus     64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26    activated     64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus    Suspension data bus     64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D    activated     64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus    Comfort data bus     64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17    activated     64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus    Infotainment data bus     64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16    not activated     64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus    Comfort data bus     64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01    not activated     64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus    Comfort data bus     64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02    not activated     64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus    Comfort data bus     64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11    activated     64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus    Comfort data bus     64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15    not activated     64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus    not activated     64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10    not activated     64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus    Comfort data bus     64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33    activated     64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus    Comfort data bus     64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C    Comfort data bus     64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C    not activated     64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37    activated     64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus    Comfort data bus     64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38    not activated     64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus    Comfort data bus     64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09    activated     64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus    Comfort data bus     64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04    not activated     64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus    Comfort data bus     64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D    not activated     64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus    Powertrain data bus     64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08    activated     64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus    Comfort data bus     64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19    not activated     64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus    Extended data bus     64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F    activated     64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus    Comfort data bus     64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34    not activated     64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34    Infotainment data bus     64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E    activated     64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus    Comfort data bus     64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18    not activated     64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus    Comfort data bus     64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A    activated     64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus    Infotainment data bus     64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20    not activated     64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus    Comfort data bus     64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A    not activated     64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A    Extended data bus     64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39    not activated     64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39    Infotainment data bus     64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E    not activated     64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus    Comfort data bus     64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F    not activated     64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus    Powertrain data bus     64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B    not activated     64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B    Comfort data bus     64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F    not activated     64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F    Comfort data bus     64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E    not activated     64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E    Comfort data bus     64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12    activated     64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus    Comfort data bus     64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E    not activated     64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus    not activated     64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35    not activated     64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35    Comfort data bus     64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27    not activated     64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus    Infotainment data bus     64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A    not activated     64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus    Extended data bus     64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07    activated     64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus    Suspension data bus     64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21    not activated     64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus    Extended data bus     64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36    not activated     64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36    Comfort data bus     64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C    not activated     64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus    Comfort data bus     64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14    not activated     64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus    Terminal 15     64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13    activated     64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus    Comfort data bus     64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B    not activated     64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus    Infotainment data bus     64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22    not activated     64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus    Infotainment data bus     64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C    activated     64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus    Comfort data bus     64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key    Not available     8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus    Comfort data bus     8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school    Not available     8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus    Infotainment data bus     8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL    available.     8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus    Infotainment data bus     8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level    Not available     8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus    Powertrain data bus     8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering    Not available     8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus    Suspension data bus     8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved    Not available     8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1    Comfort data bus     8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2    Comfort data bus     8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3    Not available     8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN    available.     8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus    Comfort data bus     8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps    OFF     10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture    OFF     10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart    OFF     10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode    RLE     10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution    resolution_1     10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode    OFF     10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon    0    10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most    OFF     10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode    RLE     10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution    resolution_1     10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode    OFF     10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart    OFF     10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1    0    6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2    50    6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3    100    6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1    0    6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2    50    6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3    100    6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1    0    6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2    50    6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3    100    6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1    0    6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2    50    6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3    100    6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1    0    12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2    10    12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3    50    12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4    100    12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5    150    12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6    253    12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1    1 %    12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2    1 %    12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3    3 %    12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4    6 %    12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5    44 %    12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6    100 %    12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07    0    32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F    0    32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17    0    32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F    0    32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27    0    32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F    0    32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37    0    32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F    0    32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47    0    32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F    0    32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57    0    32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F    0    32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67    0    32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F    0    32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77    0    32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F    0    32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87    0    32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F    0    32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97    0    32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F    0    32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7    0    32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF    0    32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7    0    32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF    0    32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7    0    32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF    0    32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7    0    32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF    0    32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7    0    32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF    0    32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7    0    32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF    0    32
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation    01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C     40
ENG117809-p_damping_Display    5 ms    1
ENG117808-p_HMI_Display    13 %    1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset    0    2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset    0    2
ENG117919-Startup_Screen_Sticker_HMI    00 00     2
Elapsed Time: 00:40
aljb320
Long Island
C?ID=174376
Also here is controller 10
;SW:5QD-919-294-J   HW:5QA-919-294 ---  Park/Steer Assist --- SA: 71679
;Component:PDC 8 KanalH07 0443     Coding:0431041001
;EV_EPHVA18AU3700000    9035    EV_EPHVA18AU3700000.rod
;Wednesday    28    April    2021    12:00:53:09643
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 56A34E392922F63BC9-8002
IDE00001-Production mode    Deactivating     3
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble    not activated     1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble    not activated     1
IDE00845-Wheel circumference    1970 mm    2
IDE01165-Park assist activation tone    On     1
IDE01167-Convertible offset for volume level 1    255    1
IDE01168-Increment for convertible volume levels    255    1
IDE01169-Audio lowering request    On     1
IDE02328-Distance to curb    15 cm    1
IDE02332-Deactivate production mode    0    3
IDE03782-Switch-off speed for parking assist    15 km/h    1
IDE05274-Acoustic warning for rear lid assistant    not active     1
IDE06425-Dynamometer mode: functional    not activated     1
MAS01426-Rear parking aid buzzer: volume    Stage 6     1
MAS01427-Speaker frequency for rear park assist    Stage 4     1
MAS01428-Front parking aid buzzer: volume    Stage 4     1
MAS01429-Speaker frequency for front park assist    Stage 6     1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners    0.189 1/m    6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners    1.308 1/m    6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang    1.090 m    6
MAS12129-Customer-oriented off-road trip    not activated     1
MAS12843-Maneuvering brake function    activated     1
Elapsed Time: 00:11
aljb320
Long Island
C?ID=174376
here is module 10, advanced ID.
Wednesday,28,April,2021,10:32:17:09643
VCDS Version: 21.3.0.0 (x64)
Dealer/Shop Name: Tony's VW_4_life
VIN: 3VW5T7AU5HM066511   License Plate: GTI MODULE 10
                Address 10: Park/Steer Assist
Control Module Part Number: 5QD 919 294 J
  Component and/or Version: PDC 8 KanalH07 0443
           Software Coding: 0401101041
            Work Shop Code: WSC 12345
Advanced Identification/FAZIT
     Serial number: 000308418218348
     Identification: 4HK-001
     Date: 19.12.18
     Manufacturer number: P101
     Test stand number: 0597
Flash Status
     Programming Attempts(application): 1/0
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Date: 00.01.01
     Flash Tool Code(data): 00000 000 00046
Misc.
     Hardware number: 5QA 919 294
     Workshop System Name: J446
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFE
     Dataset Number: V03935282CH
     Dataset Version: 0001
     ASAM Dataset: EV_EPHVA18AU3700000
     ASAM Dataset Revision: 009035
VCDS Info:
       Labels: 5Q0-919-294.clb
       ROD: EV_EPHVA18AU3700000.rod
downtime
Finland
C?ID=280813
This is the dataset : V03935282CH. Can't really tell anything else than it's for China.
Then for 5F
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering Not available 8 => Change this to Available
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Infotainment data bus 64 => Change this to Terminal 15
aljb320
Long Island
C?ID=174376
ok done no help, the other thing i i get a park pilot error with key on, but I don't have park pilot or is this part of the PDC?
downtime
Finland
C?ID=280813
Yes, park pilot is pdc
aljb320
Long Island
C?ID=174376
ok thank and thank you for everything i really appreciate you help.
aljb320
Long Island
C?ID=174376
Ok I'm all out of options, can anyone tell me what if I reset the box will this erase everything and would it require to be parameterized?
