VCDS Version: Beta 14.7.1
Data version: 20140601
Saturday,12,July,2014,10:13:25:14392
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
VIN: 3VW4T7AU5FM000582 Mileage: 1588km-986miles
Address 01: Engine (J623-CNTA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 091D00124424000F1000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM20TFS0205G0906259A 001005
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C79CA3147330F5AF9-8079
Part No SW: 0D9 300 040 S HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4310
Revision: 05852204 Serial number: TFK01312100993
Shop #: WSC 00066 790 07031
ROD: EV_TCMDQ250021_AU37.rod
VCID: 2773351D5ED52C0214-8072
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 53093000000155
Coding: 01FA6BA13420096C007C020881C52980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 44A98291CFA3E71A11-8011
Address 05: Acc/Start Auth. (J518) Labels: None
Revision: 00021000 Serial number: 0325945203
Coding: 030C0C
VCID: 3A55FC69BD67A1EA7B-806F
Part No SW: 5G0 907 044 AD HW: 5G0 907 044 AD
Component: Climatronic H02 0805
Revision: 00001K07
Coding: 00020014100100000005004012111800
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 69F773258841DA72C2-803C
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86583001140534
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_SE37.rod
VCID: 43AB818DCAADE02228-8016
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119
Component: WWS 131130 042 0581
Serial number: 140103013950
Component: RLFS 024 0042
Serial number: Y13M12D24H03M17S22S6
Coding: 00A8DD
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO26017662
Coding: 181801
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00146W
VCID: 5187BBC500D102B2AA-8004
Seat occupant detection; passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140000904906
Coding: 303136
Subsystem 2 - Part No SW: ----------- HW: 480 002 709 13
Serial number: 3570000000033C69DD0V
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: ----------- HW: 480 002 711 13
Serial number: 35800000000094605E0B
Crash sensor for side airbag; rear driver side:
Subsystem 4 - Part No SW: ----------- HW: 480 402 311 13
Serial number: 3510002C11230BC131AP
Crash sensor for side airbag; rear passenger side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 605 13
Serial number: 3520002C31050651315B
Subsystem 6 - Part No SW: ----------- HW: 480 403 011 13
Serial number: 3550002AF1220563A36Z
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 403 011 13
Serial number: 3560002AF1220563F04-
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 26011404400712
Coding: 0410
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 79D72365F8E16AF232-802C
Part No SW: 5G6 920 970 C HW: 5G6 920 970 C
Component: KOMBI 316 2210
Coding: 0BAD091A2980CF0502086A00000000
VCID: 3041DE416B1B6BBAC5-8065
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 31121310000535
Coding: 0101000820085900EF00022A180F00000001000000000000000000000000
Shop #: WSC 00066 790 00219
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_AU37.rod
VCID: 3FA38D7DA64584C24C-806A
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001883880063503
Coding: 29FFFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 13000293735003
Coding: 5D00000000000000
Shop #: WSC 00066 790 00061
ROD: EV_ELVMarquMQB.rod
VCID: 3449D2519F03579AA1-8061
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 041213060502LX
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 40A18E81DBBBFB3A35-8015
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000000291080
Coding: 011000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 354FEF5594794E9296-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 100114060501E7
ROD: EV_DCUPasseSideEWMAXKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000000912628
Coding: 191000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 021A01010B000400
VCID: 3D5FF775AC4996D25E-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 013 0645
Serial number: V7B00202140021
Coding: 027300020000000021220002001800001F0203340100010046
Shop #: WSC 00066 790 00208
ROD: EV_MUStd4CPASE_SE37.rod
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NK10007L
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 B HW: -----------
Component: NAR 2014 --- 0015
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
Reset counter: 82
Mileage: 892 km
Date: 2014.06.19
Time: 11:22:24
Address 75: Telematics (J949) Labels: None
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB_VW37.rod
VCID: 022544899537292A63-8057
2103041 - Unknown Error Code
B1788 F0 [009] - Unknown Error Elaboration
Fault Priority: 8
Reset counter: 57
Mileage: 1588 km
Date: 2014.07.12
Time: 09:51:17
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 131121200072
VCID: 6BFB092D82BDC862B0-803E
End---------------------(Elapsed Time: 03:23, Deb=2)-----------------------
