MK7 Golf R DCC Delete- Ross Tech?
   #21
Akkipen
Norway
C?ID=327213
   #22
LOL -- No. Not quite that much. :rolleyes:
I was thinking more like 20-30 mm.
Mike@Gendan
Swansea, UK
C?ID=57030
How would that even turn a slight corner without ripping the front bumper off?
   #24
Biscycles
C?ID=237573
Does this DCC Delete work on NAR mk7?
Am I right to assume that your fix for DCC delete only works on ROW MK7? I tried it tonight on my NAR mk7 R and no luck. Still have warnings in the cluster and have no way to turn off ESP by the button or the MMI. Also I have no Sercuity Access code for ABS and can't uncheck bit 7 of byte 27. Bit 7 was marked as 0, should it be a 1? Anyone get this to work on NAR MK7?
Sunday,17,November,2019,20:34:25:32148
VIN: WVWLF7AU1GW261344   License Plate: BIS R
Mileage: 57385km-35657mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 75 A5 A9
VIN: WVWLF7AU1GW261344   Mileage: 57385km-35657miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122466000E3004
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001002
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 45C25C2CC4DC7267D4-8010
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:56:06
                    Coolant temperature: 38 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 12.089 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 36.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 159 min
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ECU_STATE: ENG_STOP
Readiness: 1110 0101
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 5045
   Revision: 06253104    Serial number: TFK01602040777
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53E672743A88DCD74A-8006
   Revision: 00000000    Serial number: 60436000001257
   Coding: 01FA6BA15426096D057A030441C76980D62A90A0C08296B7184050D8C288
   VCID: 7AB8FFD0FDA2CD9FE9-802E
0105 - ABS Hydraulic / Return Flow Pump
          C1077 01 [008] - Electrical Failure
                    Reset counter: 112
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:58
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 64
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:25
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 64
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:25
8388 - Databus
          [FCAN: GE_Fahrstufe_inv signal is invalid]
                    Reset counter: 114
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:25
32870 - Databus
          [IPB-BUS: Getriebe_11 / GE_Zielgang invalid]
                    Reset counter: 114
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:25
   Revision: 00021000    Serial number: 0395078222
   Coding: 030C0C
   VCID: 3A383FD0BD220D9FA9-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100000105000012111402
   VCID: 6A98CF908D027D1F19-803E
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061605000470
   Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 044481288F668B6F83-8050
   Component: WWS    150822  043 0551
   Serial number:         160215161927
   Component: RLHS  037 0059
   Serial number: S4Y16M02D26H20M42S07
   Coding: 90A8DD
558356 - Databus
                    Reset counter: 114
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:26
   Revision: --------    Serial number: 39391604905903
   Coding: 0071157011
   VCID: 43C64234CAE84C57FA-8016
13637426 - Databus
                    Reset counter: 112
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
13637632 - Databus
          [Getriebe - Getriebe_11.GE_Fahrstufe - Fehlerspeicher auslesen]
                    Reset counter: 114
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 19:44:25
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 112
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:36:10
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 19011641350094
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 373E26E48E3010F756-8062
835584 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [137] - -
                    Fault Frequency: 28
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:57
36363 - Valve for Damping Adjustment Front Left
          C1040 13 [137] - Open Circuit
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:57
36619 - Valve for Damping Adjustment Front Right
          C1041 13 [137] - Open Circuit
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:57
36875 - Valve for Damping Adjustment Rear Left
          C1042 13 [137] - Open Circuit
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:57
37131 - Valve for Damping Adjustment Rear Right
          C1043 13 [137] - Open Circuit
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:57
   Serial number: 003GCR04F7TR
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47DE5624FED0607726-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003O2593
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 002 502 16
   Serial number: 3570000000054A7C591P
   Subsystem 3 - Part No SW: -----------    HW: 480 002 002 16
   Serial number: 35800000000EB001491D
   Subsystem 4 - Part No SW: -----------    HW: 480 401 902 16
   Serial number: 3510002BB1F35382A374
   Subsystem 5 - Part No SW: -----------    HW: 480 401 902 16
   Serial number: 3520002C91F1FF31437C
   Subsystem 6 - Part No SW: -----------    HW: 480 402 202 16
   Serial number: 3550002C71F1FF30B23E
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 202 16
   Serial number: 3560002C71F1FF3111BD
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 13
                    Reset counter: 112
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:30:12
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 14011604400705
   Coding: 0C10
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 095A901CA844D607F0-805C
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
   Coding: 0BAD081A7F88CF0502886A0B5400000000000000
   VCID: 2E100380716AD13F05-807A
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:59
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004549318
   Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79BAE0DCF8A4C687E0-802C
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160000124450036034
   Coding: 35FFFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
131695 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
                    Terminal 15: On
   Serial number: HA1-00014.01.16
   Coding: 0001
   VCID: 4AD86F10EDC29D1F39-801E
   Revision: 00000000    Serial number: 16000031917005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 342411E89F46FBEF73-8060
   Component: HRE_Master    H12 0071
   Serial number: 0395617623
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C3439C8B71633AFBB-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0394245453
   Coding: 020111
338048 - Databus
          [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
                    Reset counter: 112
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:36:09
   Serial number: 200116EAJ00851
   Coding: 003E13208000040000000000
   Serial number: 00000000000009088017
   Coding: 111000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9102
   Shop #: WSC 19460 666 12345
   VCID: 393A20DCB8240687A0-806C
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01GZET
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D92C48CBCEC6A277C-8038
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [009] - Open Circuit
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:58
                    Voltage terminal 30: 12.1 V
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [009] - Open Circuit
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:58
   Serial number: 220116EAL07312
   Coding: 003E13208000040000800000
   VCID: 42C84730D5F2455FF1-8016
   Serial number: 00000000000009104043
   Coding: 091000
   Coding: 022202010B000400
   VCID: 40CC4D38DBFE574FE7-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0245
   Serial number: VWZAZ2R0375263
   Coding: 027300020000000051220002001808001F0207F401200105C6
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 71AAD8FCA0D48EC758-8024
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX003HK
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:59
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 64
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:59
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 114
                    Mileage: 57385 km
                    Date: 2019.11.17
                    Time: 17:47:53
                    Voltage terminal 30: 12.2 V
                    Interface for external media: status-Status: Open circuit
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000515382
   Coding: 0100000000020306000400010100000100
   ROD: EV_MFKBoschAU370.rod
393216 - Databus
          [ACC_10_TO_FAILURE]
                    Fault Frequency: 28
                    Reset counter: 74
                    Mileage: 57119 km
                    Date: 2019.11.10
                    Time: 21:29:56
                    Control Module temperature: 29 °C
                    Outside air temperature: 19.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.0 V
                    Terminal 15 on: 5.4 s
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 160115202839
   VCID: 2F2E1E847660D8370E-807A
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.1V)-----------
   #25
Somnus
SLC, USA
C?ID=215931
Biscycles,
As far as I know, yes. the following should work to disable DCC on a NAR vehicle
1) Disconnect Module/Pull Fuse for Suspension Regulation module
2) Remove Susp. Elec. from Gateway installation list
3) Make Sure ABS Byte 27 Bit 7 is unchecked (if it is a 1 make it 0)
3) Recode other modules that are expecting the DCC module (Deselect DCC bit)
4) You may have to rewire the headlight level sensor as well, but I am unsure about that
I am a bit worried about the other faults you have as well, especially the fact that your front radar isn't communicating.
Biscycles
C?ID=237573
I bought this car at an auto auction after a front end crash. The Front Radar was destroyed and I have no plans on replacing it. This car will soon be stripped and turned into a rally car only so many systems are going to have to be deleted, bypassed or otherwise. Thanks for the info I will try all of that. Which other modules should I expect to find DCC coding in? Cluster? ABS? Obviously Adaptive headlights, which I can re-wire. Thanks Sommus.
   #27
Biscycles
C?ID=237573
After your above procedure all DCC is gone and coded out. No errors for that system come up, but everything works as expected except for AFS. This is causing another error in the cluster and not allowing me to turn off ESP via button or MMI. Is there a written procedure for rear suspension level sensor wiring to the J745 Cornering Lamp and Headlamp Range Control Module? I don't really care about the AFS working or the warning but would love to get the select traction control back. Any thoughts?
   #28
Somnus
SLC, USA
C?ID=215931
could you post an updated auto-scan?
as far as the level sensor wiring goes
Pin 1 on the level sensor goes to Pin 7 on the AFS module
Pin 3 on the level sensor goes to Pin 10 on the AFS module
Pin 4 on the level sensor goes to Pin 11 on the AFS module
you also might have to code out the front radar to re-enable ESC OFF as it is part of the ABS coding
vag-retrofits
Barcelona
C?ID=330860
Rejoyce everyone, for the collective thinking has once again broken the mould.
Recipe for coding out DCC on a MK7 Golf R (ROW) is as follows
Step Uno: Unplug Fuse 13 in fuse holder C located behind the flip-down compartment to the left of the steering wheel (LHD).
Step Dos: Uncheck Susp.Electronics from the CAN-Gateway.
Step Tres: Uncheck Bit 7 in Byte 27 of the ABS-module to allow the ESP to function.
Step wish you had quattro: Go scrape on the nearest speed-bump after lowering your golf too much.
Sidenote: Adaptive light is still throwing an error, but this is not really an issue, so i'll look into it at a later date.
Thanks to Somnus, Uwe and darkchina811.
Thread solved bois :cool:
When you have DCC, there're 2 lever sensors for AFS. Both are connected to DCC control unit, that's the reason why you can not calibrate AFS. You only need to disconect rear left sensor and attach it to BCM, after that code Lever sensor in FCM and BCM. That's all.
   #30
darkchina811
ITALY
C?ID=333184
when you have DCC, there are THREE level sensors, two front and one rear.
the rear only is used for AFS.
   #31
Danilo78
Italy
C?ID=216246
Hi to all dears....
I changed BCM with one used on my friend golf 7
Installed 084CP (no long coding) from 084Q (with long coding)
I have dcc and dla error on aid, on bcm "incorrect coding" only.... I finded parameters inside adaptations but not found....
Someone knows dcc or dla parameters for change?
084CP was instelled to car with pxc led and dcc
   #32
DV52
C?ID=194404
@Daniilo:Hi
Please tell me that you made an adaptation channel map of the old BCM before the change? If so, also make an admap of the new BCM and post-up both. Also include an auto-scan- please
Danilo78
Italy
C?ID=216246
Thank you so much Don
I solved... problem was on AiD coding....
All bcm parameters was ok
   #34
Tariq Mustafa
Tripoli , Lebanon
C?ID=319462
hello,
i have MK7 GTI US Model , i deleted the DCC but i'm struggling with the ESP Button
Wednesday,15,February,2023,15:18:17:21894
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
Data version: 20221026 DS344.0
VIN: 3VW447AU1GM047333   License Plate:
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 5F 75 A9
VIN: 3VW447AU1GM047333   Mileage: 171209km-106384miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---    CVN: 5E75E924
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F307A0597981413428-807A
   VINID: 0E69C41074650577401070C30C12B52114
20251 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [096] - -
                    Mileage: 171205 km
                    Date: 2023.02.15
                    Time: 00:00:33
                    Engine RPM: 3300.00 /min
                    Coolant temperature: 37 ∞C
                    Intake air temperature: 31 ∞C
                    Voltage terminal 30: 12.773 V
                    Engine: operating status: PU
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 27 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 17.187500 %
                    FUP_H_SAE: 7260.0 kPa
Readiness: 0010 0001
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01510080757 CVN: 0000EE8B
   VCID: 1C6ABDC9F62E9F8B17A-8048
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 50026000000594
   Coding: 01FA6BA154240973007A020341C66880D62A9000408216B600430091C009
   Shop #: WSC 01383 790 50316
   VCID: 4BC80E95034048334E0-801E
8216 - Databus
          [FCAN: Fahrwerk_01 message is not received]
                    Reset counter: 241
                    Mileage: 171190 km
                    Date: 2023.02.01
                    Time: 04:19:12
   Revision: 00021000    Serial number: 0382560798
   Coding: 030C0C
   VCID: 3A265B515CDAC1BBE56-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000002
   VCID: 46DE3FA11822B55B91E-8012
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580512152109
   Coding: 001118464041826969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00156
   VCID: 7AA69B511C5A01BBA56-802E
   Wiper motor control module:
   Component: WWS    150812  043 0581
   Serial number:         160126070313
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M12D15H07M33S24
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691609332208150306
   Coding: 181803
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 222
                    Mileage: 171076 km
                    Date: 2023.01.26
                    Time: 23:23:02
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: g¸ltiges Funktelegramm
                    Voltage: 14.2 V
                    Outside temperature: 16.0 ∞C
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 222
                    Mileage: 171076 km
                    Date: 2023.01.26
                    Time: 23:23:02
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 14.2 V
722437 - Control Module for Power Sunroof
          B13C6 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 249
                    Mileage: 171205 km
                    Date: 2023.02.14
                    Time: 23:53:18
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Low beam: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 11.1 V
                    Outside temperature: 13.5 ∞C
   Serial number: 003GCR03V7MZ
   VCID: 47C032A51F28AC536A8-8012
   Seat occupied recognition passenger side:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH00000000000444KZR
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 3570000000015449F71I
   Subsystem 3 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 358000000004D948A71T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3510002C51CF1D242080
   Subsystem 5 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3520002A31E34432021G
   Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3550002AB1D3F985822G
   Subsystem 7 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3560002AB1D3F985E2AV
   Revision: FF033033    Serial number: 20151102501043
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045AE5A96E9E474BCFA-8050
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AA180CF0502086A001000000000000000
   VCID: 2C0A6D09A68E6F0B67A-8078
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 241
                    Mileage: 171190 km
                    Date: 2023.02.01
                    Time: 04:19:06
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2246
   Revision: --------    Serial number: 12111510801099
   Coding: 0101000830085900FB0000299C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   GVL: 01503C5000000600400C00008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 77A082652F481CD3DA8-8022
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001874890025403
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000230428005
   VCID: 343A75697EBE37CB3FA-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00029.09.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 06011606050058
   Coding: 003E13200000020000000000
   VCID: 43D826B52B108073B60-8016
   Rear Driver Side Door Control Module:
   Serial number: 00000000000011187774
   Coding: 011000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Fault Frequency: 7
                    Reset counter: 248
                    Mileage: 171076 km
                    Date: 2023.01.26
                    Time: 23:22:22
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 34
   Coding: 8102
   VCID: 3924445D59DCCAA3ECC-806C
   Revision: 00000001    Serial number: VWZ8Z1FBA01897V
   VCID: 6D8CA00D5D14A603304-8038
0560 - Front Right Treble Speaker
          B1064 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 7: Unterbrechung (AC-Diagnose)]
                    Reset counter: 36
                    Mileage: 171198 km
                    Date: 2023.02.06
                    Time: 23:14:33
                    Voltage terminal 30: 11.7 V
0585 - Front Left Treble Speaker
          B1061 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 12: Unterbrechung (AC-Diagnose)]
                    Reset counter: 36
                    Mileage: 171198 km
                    Date: 2023.02.06
                    Time: 23:14:33
   Serial number: 02121506050E0A
   VCID: 42D623B1340A897BBD6-8016
   Rear Passenger Door Control Module:
   Serial number: 00000000000002512265
   Coding: 091000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 34
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027300000000000051220002001808001F0203F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C8AAD09660EAF0B27A-8038
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9RJW00403
6919 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 241
                    Mileage: 171190 km
                    Date: 2023.02.01
                    Time: 04:19:27
                    Voltage terminal 30: 14.1 V
7175 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 241
                    Mileage: 171190 km
                    Date: 2023.02.01
                    Time: 04:19:30
   Coding: 02730002C2823A017F1E06000000
9455635 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 33
                    Mileage: 171195 km
                    Date: 2023.02.02
                    Time: 03:26:22
9458195 - Control Module for Cellular Telephone
          B1052 13 [008] - Open Circuit
          [roofline module open load]
                    Reset counter: 33
                    Mileage: 171195 km
                    Date: 2023.02.02
                    Time: 03:26:22
   Serial number: 151113200529
   VCID: 6B88AE156300A8332E0-803E
End----(Elapsed Time: 01:36, VBatt start/end: 12.1V/11.8V. VIgn 11.9V)-----
   #35
According to the spreadsheet linked in this thread
DCC installed should be Bit 7 in Byte 27 of the ABS coding.
Tariq Mustafa
Tripoli , Lebanon
C?ID=319462
Tuesday,23,April,2024,16:05:28:21894
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20240205 DS351.0
VIN: 3VW447AU0GM025405   License Plate:
VIN: 3VW447AU0GM025405   Mileage: 123307km-76619miles
   Revision: --H13---    CVN: CAA5B114
   VCID: 2F307A0597981412869-807A
   VINID: 0E69C410746501774008510014753D16B5
Readiness: 1110 1101
   Revision: 06253104    Serial number: TFK01507301083 CVN: 0000EE8B
   VCID: 1C6ABDC9F62E9F8AD3B-8048
   Revision: 00000000    Serial number: 52345000001493
   Coding: 01FA6BA154220971007B020041C86880D62A9000408216B600430091C007
   VCID: 4BC80E95034048328A1-801E
8216 - Databus
          U1121 00 [00001001] - Missing Message
                    Reset counter: 220
                    Date: 2024.04.23
                    Time: 05:56:29
   Revision: 00021000    Serial number: 0375867857 Dataset Number: V03935226DW 0001
   Coding: 030C0C
   VCID: 3A265B515CDAC1BA217-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000005000012111402
   VCID: 42D623B1340A897A797-8016
   Revision: --------    Serial number: 86583007151872 Dataset Number: 5GM063v____ 0061
   Coding: 00111A464041A2E969E44000081407201800000000000000000000000000
   VCID: 7AA69B511C5A01BA617-802E
   Component: WWS    150714  043 0581
   Serial number:         151007030616
   Serial number: S2Y15M08D03H14M21S52
   Coding: 90A8DD
   Serial number: 03694804012402150445
   Coding: 181803
   Humidity sensor: interior:
540693 - Databus
                    Reset counter: 220
                    Mileage: 123307 km
                    Date: 2024.04.23
                    Time: 05:56:27
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
                    Outside temperature: 24.0 ∞C
133643 - Voltage Supply; Terminal 30 for Anti-Theft Alarm System
          B1410 13 [00001001] - Open Circuit
                    Reset counter: 220
                    Mileage: 123307 km
                    Date: 2024.04.23
                    Time: 05:56:29
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
   Serial number: 003GCR035DMF Dataset Number: 5GM003V____ 0046
   VCID: 47C032A51F28AC52AE9-8012
   Serial number: IBH000000000003DK1PM
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 357000000003379DC51P
   Subsystem 3 - Part No SW: -----------    HW: 480 000 708 15
   Serial number: 35800000000CA11DE51U
   Subsystem 4 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 3510002A31C52F25F30+
   Subsystem 5 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 35200029B1B7E8E30105
   Subsystem 6 - Part No SW: -----------    HW: 480 402 007 15
   Serial number: 35500029D1B7E8E1E20N
   Subsystem 7 - Part No SW: -----------    HW: 480 402 007 15
   Serial number: 35600029D1B7E8E321DQ
   Revision: FF032032    Serial number: 20150804400712
   Coding: 0410
   VCID: 045AE5A96E9E474A0BB-8050
   Coding: 0BAD091A2180CF0502087A001000000000000000
   VCID: 2C0A6D09A68E6F0AA3B-8078
16776973 - Databus
                    Reset counter: 220
                    Mileage: 123307 km
                    Date: 2024.04.23
                    Time: 05:56:27
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 04081510800004 Dataset Number: 5G0067V____ 2214
   Coding: 0101000830085900FB00022B9C0F00000001050000000000000000000000
   VCID: 75BC886D35446EC20C5-8020
   Generator:
   Serial number: 29150001422000025301
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000180111002
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 343A75697EBE37CAFBB-8060
   Serial number: HA1-00007.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   Serial number: 270615060505D5 Dataset Number: V03935214VB 0007
   Coding: 003E13200000040000000000
   VCID: 43D826B52B108072721-8016
   Serial number: 00000000000001909015
   Coding: 011000
          B1775 01 [00001001] - Electrical Failure
                    Reset counter: 220
                    Mileage: 123307 km
                    Date: 2024.04.23
                    Time: 05:56:27
   Dataset Number: 5GM074V____ 0418
   Coding: 8102
   VCID: 3924445D59DCCAA228D-806C
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00RGHN Dataset Number: 5GM050v____ 0212
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D8CA00D5D14A602F45-8038
   Serial number: 24061506050CR2 Dataset Number: V03935214VC 0007
   Coding: 003E13200C00040000000000
   Serial number: 00000000000001872953
   Coding: 091000
   Serial number: VWZAZ2R0416138 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300020000000051220002001808001F0203F401200105C6
   VCID: 71B4BC7D412C42E2D0D-8024
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC006BM
   Data carrier:
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
          U1111 00 [00001001] - -
                    Reset counter: 220
                    Mileage: 123307 km
                    Date: 2024.04.23
                    Time: 05:56:31
   Component: OCULowMQBUS   007 0566
   Dataset Number: 561098V____ 0409
   Serial number: 150804200798
   VCID: 6B88AE156300A832EA1-803E
End----(Elapsed Time: 01:39, VBatt start/end: 11.7V/11.8V. VIgn 0.0V)------
   #38
Tariq Mustafa
Tripoli , Lebanon
C?ID=319462
i deleted DCC Module and Headlight range Module , the only thing left is blinking TPMS and ESP Button not working
   #39
Yeah...
Missing Message
Fahrwerk = Suspension.
However, I don't know where in the MK100 ABS coding that might be.
