- Nov 30, 2021
- 83
- 12
- Tripoli , Lebanon
- C?ID=319462
it worked , thank you allIn the Autoscan you posted, you have not changed Byte 27 Bit 7
91 > 11
91 > 11
Rejoyce everyone, for the collective thinking has once again broken the mould.
Recipe for coding out DCC on a MK7 Golf R (ROW) is as follows
Step Uno: Unplug Fuse 13 in fuse holder C located behind the flip-down compartment to the left of the steering wheel (LHD).
Step Dos: Uncheck Susp.Electronics from the CAN-Gateway.
Step Tres: Uncheck Bit 7 in Byte 27 of the ABS-module to allow the ESP to function.
Step wish you had quattro: Go scrape on the nearest speed-bump after lowering your golf too much.
Sidenote: Adaptive light is still throwing an error, but this is not really an issue, so i'll look into it at a later date.
Thanks to Somnus, Uwe and darkchina811.
Thread solved bois![]()
Saturday,31,August,2024,16:17:33:52565
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VW6T7BU2KM147072 License Plate: HMFIC2 083124
Mileage: 117835km-73219mi Repair Order:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 17 19 2B 32 3C 42 44 52 5F A9
VIN: 3VW6T7BU2KM147072 Mileage: 117835km-73219miles
Address 01: Engine (J623-DKFA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 9C0 BB0 2 HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0003
Revision: --H13--- CVN: 37BD0D56
Coding: 092500124424012F3000
Shop #: WSC 00066 790 00391
ASAM Dataset: EV_ECM20TFS0205G09C0BB02 001003
ROD: EV_ECM20TFS0205G09C0BB02.rod
VCID: 3E253D7E40FB60AA6DF-806A
VINID: 0E69C69074A509B7411070070831080CB9
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [00100111] - Malfunction / Open Circuit
Mileage: 117835 km
Date: 2024.08.31
Time: 16:13:55
Engine RPM: 0.00 /min
Coolant temperature: 61 °C
Intake air temperature: 45 °C
Ambient air pressure: 850 mbar
Voltage terminal 30: 12.304 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 85 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 640.0 kPa
Readiness: 1110 1101
Part No SW: 0GC 300 020 G HW: 0GC 927 711 H
Component: GSG DQ381 H06 2403
Revision: 00H06V07 CVN: BB564CFC
ROD: EV_TCMDQ381061.rod
VCID: 2615F51EB86BD86A05F-8072
No subsystems:
Part No SW: 5Q0 614 517 EB HW: 5Q0 614 517 BR
Component: ESC H82 0108
Revision: 00000000 Serial number: 53168000001068
Coding: 70FB6BA1502421738577020760C5A90ED60A84A1400695761041F0D9D2894B0B0000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 75B7E252354DE3F27C5-8020
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0500403098 Dataset Number: V03935272JE 0001
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D34C8A2B190D42021-8016
Part No SW: 5GM 907 044 P HW: 5GM 907 044 P
Component: Climatronic H04 2009
Revision: 00001K04
Coding: 0102000420011800100400001211100C
ASAM Dataset: EV_ACClimaBHBVW37X 006148
VCID: 51FF76C2E165EFD280D-8004
Part No SW: 5Q0 937 087 BB HW: 5Q0 937 087 BB
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C864281118052U Dataset Number: V03935281MQ 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F7761667B2BA03B-8028
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S6Y18M10D10H19M50S14
Coding: 0038DD
Humidity sensor: interior:
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300181220180C202871
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Dataset Number: V03935284GG 0205
Coding: 3300008111FFC428949C810500301600000000000000000004
VCID: 44D14F962E170A7A3BB-8010
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 197
Mileage: 117835 km
Date: 2024.08.31
Time: 16:14:23
Control Module temperature: 44 °C
Voltage terminal 15: 12.3 V
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 22091841350725 Dataset Number: V03935285SE 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292B6662DF5E9AA73-806C
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 005 0403
Serial number: 003FGM000KA0 Dataset Number: V03935295BA 0001
Coding: 8CCCFC00000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 0C41A7B646C7823A33B-8058
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000APNURW
Coding: 30344A
Subsystem 2 - Part No SW: ----------- HW: 480 003 110 18
Serial number: 35700000000133095531
Subsystem 3 - Part No SW: ----------- HW: 480 003 110 18
Serial number: 35800000000C2309553C
Subsystem 4 - Part No SW: ----------- HW: 480 403 108 18
Component: SideSensor_Dr 003 6149
Serial number: 35100019B2BB7D438249
Subsystem 5 - Part No SW: ----------- HW: 480 403 108 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001BB2A3241384F%
Subsystem 6 - Part No SW: ----------- HW: 480 400 511 18
Component: FrontSensor_D 004 6149
Serial number: 35500011C2B7C81310E0
Subsystem 7 - Part No SW: ----------- HW: 480 400 511 18
Component: FrontSensor_P 004 6149
Serial number: 35600010A2BF5A73659C
Part No SW: 17A 920 840 A HW: 17A 920 840 A
Component: KOMBI 252 2500
Coding: 01A4011A3388CF05028823095000000020000000
Shop #: WSC 00066 790 00013
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
VCID: 211FE602D1453F5270D-8074
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 03121800842800 Dataset Number: V03935291WX 0001
Coding: 030100047F085900FB0002E99C0F00010001070000000000000000000000
Shop #: WSC 00066 790 00162
GVL: 01403C5000000600404C80000000CC0000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CD3E501BD02ABDF-803A
Generator:
Component: 0-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AD HW: 5G0 959 442 AD Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002518890098434
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7009136200
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000345145003
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F164281A58FD2E0D-8064
Address 32: Differential Locks (J492) Labels:| 0CQ-907-554-V2.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H52 8043
Serial number: HA1-00014.08.18 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52FD79CEE46394CAB97-8006
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V1.clb
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H03 0052
Serial number: 00000496451945 Dataset Number: V03935286DX 0001
Coding: 5000C500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
Subsystem 1 - Part No SW: 2Q0 907 685 A HW: 2Q0 907 685 A
Component: HRE3_Kl15_Slv H03 0052
Serial number: 00000495786182
Part No SW: 5Q4 959 393 M HW: 5Q4 959 393 F
Component: TSG FS 006 0247
Serial number: 50038834200692 Dataset Number: V03935288VK 0001
Coding: 003C1B200000028000000000
VCID: 4DC76AB2FD5DCB32E45-8018
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000001346863
Coding: 011000
Part No SW: 5QN 909 144 A HW: 5QN 909 144 A
Component: EPS_MQB_ZFLS 507 5081
Dataset Number: V03935283PS 0001
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F973C6EA6FE6DA8F3-8004
Part No SW: 5Q4 959 392 M HW: 5Q4 959 392 F
Component: TSG BFS 006 0247
Serial number: 54038831401112 Dataset Number: V03935288VL 0001
Coding: 003C13200000028000000000
VCID: 4CC167B60647C23AF3B-8018
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000001336138
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 17A 035 868 HW: 17A 035 868
Component: MU-E--ER 695 8742
Serial number: 15101800011277 Dataset Number: V03935281LR 0001
Coding: 02730100BE00000041220001001000009F0000D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 678BB81A7FE10162FE9-8032
Part No SW: 5G0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0004
Serial number: 181005203594
End----------(Elapsed Time: 01:28, VBatt start/end: 12.4V/12.3V)-----------
Well yes, a GLI is FWD and a Golf-R is AWD. In addition, I think the GLI is Hecho en Mexico rather than Europe..? Cars made in North America have historically had some differences from their European counterparts.I have a 2019 GLI it is different then the golf..
Eh? It's right there in your Gateway Installation List:Step Dos: Uncheck Susp.Electronics from the CAN-Gateway.
Cant locate in can-gateway its all German
14-Susp. Elect.
Language -> Expert Mode.Step Tres: Uncheck Bit 7 in Byte 27 of the ABS-module to allow the ESP to function.
Cant access any coding in ABS Lcoding hlper
Thanks Uwe and everybody who has contributed I get an error in the instrument area now I can't figure out along with a suspension fault. My guess is a misalignment of front radarWell yes, a GLI is FWD and a Golf-R is AWD. In addition, I think the GLI is Hecho en Mexico rather than Europe..? Cars made in North America have historically had some differences from their European counterparts.
Thursday,05,September,2024,14:51:17:52565
VIN: 3VW6T7BU2KM147072 License Plate: HMFIC2 090524
Mileage: 118245km-73474mi Repair Order:
Scan: 01 02 03 05 08 09 13 15 17 19 2B 32 3C 42 44 52 5F A9
VIN: 3VW6T7BU2KM147072 Mileage: 118245km-73474miles
P0036 00 [10101111] - Malfunction / Open Circuit
Mileage: 118240 km
Date: 2024.09.05
Time: 12:06:35
Coolant temperature: 49 °C
Intake air temperature: 43 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 12.070 V
T_AST_SAE: 0 s
MAP_MES_SAE: 85 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.958 V
FUP_H_SAE: 15470.0 kPa
15255 - Secondary Air Injection System Valve (N112)
P0413 00 [11101101] - Open Circuit
Mileage: 118240 km
Date: 2024.09.05
Time: 12:10:24
Engine RPM: 891.00 /min
Normed load value: 11.0 %
Coolant temperature: 47 °C
Intake air temperature: 41 °C
Voltage terminal 30: 11.816 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 30 kPa
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 9660.0 kPa
Readiness: 0010 1101
No subsystems:
Coding: 70FB6BA1502421738577020760C5A90ED60A84A1400695761041F059D2894B0B0000000012121212B835351919323200
Coding: 132C0C0723
Revision: 00001K04
Coding: 0038DD
Reset counter: 212
Mileage: 118240 km
Date: 2024.09.05
Time: 12:06:31
Control Module temperature: 64 °C
Voltage terminal 15: 12.0 V
Coding: 30344A
16776966 - Databus
[Daempfer_01 keine Kommunikation]
Reset counter: 212
Mileage: 118240 km
Date: 2024.09.05
Time: 12:06:30
GVL: 01403C5000000600404C80000000C80000000000000000000000000000000000
Generator:
Coding: 29FFFF
Coding: 0001
Coding: 5000C500
Coding: 011000
Coding: 811F0000
Coding: 091000
End----------(Elapsed Time: 01:27, VBatt start/end: 12.8V/12.7V)-----------
Thursday,05,September,2024,14:51:57:52565
Address 17: Instruments Labels: 5G0-920-XXX-17.clb-SRI3
Control Module Part Number: 17A 920 840 A HW: 17A 920 840 A
Component and/or Version: KOMBI 252 2500
Software Coding: 01A4011A3388CF05028823095000000020000000
Work Shop Code: WSC 00066 790 00013
ASAM Dataset: EV_DashBoardVDDMQBAB 009065 (VW37)
16776966 - Databus
Reset counter: 212
Mileage: 118240 km
Date: 2024.09.05
Time: 12:06:30
Yup. [FAULT_MISALIGNMENT_VERTICAL] My guess is your car now has a different attitude in the pitch axis that it did with the stock suspension, which is enough to annoy the ACC sensor.My guess is a misalignment of front radar
Thanks that worked perfect. now to research where my Engine Bay Fuse box diagram is o locate the secondary air fuse is to fixt it and its wire harness routes. i use to have all this for several VW but my laptop was stolen and I wasn't smart enough to have backupsYup. [FAULT_MISALIGNMENT_VERTICAL] My guess is your car now has a different attitude in the pitch axis that it did with the stock suspension, which is enough to annoy the ACC sensor.
Instrument Cluster: Try turning off Byte 4, Bit 4. Use either 'Experimental' coding or Expert Mode.
yeah i did that once... and the laptop was stolen.. unfortunately i am living on disability and food stamps so no $$$ to subscribeSubscribe to Erwin for a day and download all the manuals you need/want. And make backups this time.
