A3 8V Door Entry / Puddle Lights Retrofit
DJAlix
London, United Kingdom
C?ID=238277
Am in the process of working out whats needed for retrofitting these lights and from doing some reading around the internet it would seem that installing lights in to the front door is not an issue, however us A3 8V people cannot seem to access our rear door modules to be able to code them.
I don't have an up to date AutoScan on my at the moment, can post one later today, but would anyone know why VCDS cannot see the modules?
Many thanks!
golfi_vend
Tartu, Estonia
C?ID=195131
Aren't rear modules coded via front module and as subsystem?
DJAlix
C?ID=238277
Thats what I thought but the drop down is greyed out / unavailable.
Zenerdiode
Newcastle, England
C?ID=24330
I thought they were a LIN slave to the fronts - but we won't know until... :)
asmetana
C?ID=266775
Would appreciate anyone's updates on this. I scoured the 09 section just in case and front door modules don't let me do the drop-down from the menu either. Model Year 2015 A3 8V 2.0 TFSI Quattro Premium Plus, US-spec, non ILP.
AIB Wolfgang
Hello
Tricky way to do this:)
You have to register the back doors in Installation list "19". >> Add "BB + BC" .Than you are able to access this modules. After coding
remove the modules out of the list and delete fault codes.:thumbs:
asmetana
C?ID=266775
Thanks for the quick input, Wolfgang! I just did that, added the BB&BC modules to the Installation List, exited VCDS, and cycled the ignition. After restarting VCDS the modules were present. However when I went to go into them there weren't any obvious options. I also checked the front doors to see if the drop-down menus had become available but they were not. Here's a document with my screen captures as I went there: http://gofile.me/6oxMo/AviCeIjl
Thanks for any & all input! Aron
Dana
Western PA, USA
Please post the Auto-Scans before and after the BB/BC GVL tweak.
asmetana
C?ID=266775
Hi Dana,
Here are the relevant portions of the 'after'. I don't have a 'before' scan. I can disable the modules and re-scan again and post.
Thanks,
Aron
Thursday,11,February,2016,06:54:56:59136
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
                Address BB: Door Rear Drv Side
Control Module Part Number:
  Component and/or Version: 020 0025
           Software Coding: 0041172040000480000000022076654D494E4B4C4F004F000000000000000000202122232425262728292A2B2C2D2E2F303132333435363738393A3B3C3D3E3F404142434445464748494A4B4C4D4E4F50515253
            Work Shop Code: WSC 06385
                      VCID: 55A1E72B34E6569672-8000
Advanced Identification/FAZIT
     Identification: 1708140
     Date: 6070026
Flash Status
     Programming Attempts(application): 0/0/1
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Date: 0001.01.00
Software
     Theft prot.: 00.86.2C
Misc.
     Hardware number: 5Q0 959 395 B
     Workshop System Name: J388
VCDS Info:
       Labels: None
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F BB BC
VIN: WAUEFGFF9F1061257   Mileage: 12095km-7515miles
BB-Door Rear Drv Side -- Status: Cannot be reached 0100
BC-Door Rear Pass Side -- Status: Cannot be reached 0100
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 01091410800168
   Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
   Shop #: WSC 06385 790 00016
   ROD: EV_GatewConti.rod
   VCID: 428B2C77D568D12E27-8016
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 15 08 2014  F0044677
131646 - Door Control Module - Rear Left
          U0201 00 [009] - No Communications
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 06:43:54
131647 - Door Control Module - Rear Right
          U0202 00 [009] - No Communications
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 06:43:54
   Serial number: 22081403111473
   Coding: 00571F204000048000000002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 408F267FDB64C33E31-8014
   Serial number: 29081406071113
   Coding: 005717204C00048000000002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 3F8D2583A69ABCC648-806A
Address BB: Door Rear Drv Side (J388)       Labels: None
   Part No HW: 5Q0 959 395 B
   Coding: 0041172040000480000000022076654D494E4B4C4F004600000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
No ASAM data for: "Unknown" (AU37)
Address BC: Door Rear Pass Side (J389)       Labels: None
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Coding: 0041172040000480000000022073654D494E4B4C4F000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
End
## EOF ##
Interesting.....
asmetana
C?ID=266775
And I snapped a picture of the driver's side rear door controller when I had the panel/card off to install the lamps, it's the 5Q0959395B
Dana
Western PA, USA
First of all I'm not entirely sure what's going on but that crazy long coding showing up under BB and BC doesn't appear to be normal.
Andy went out to his car (2015 NAR GTI) and attempted to duplicate this but he wasn't successful. That doesn't mean that we gave up.. but we don't have an answer either.
Please check the Scans folder (C:\Ross-Tech\VCDS\Scans) on that PC to see if you have a complete unedited pre-retrofit scan in addition to an unedited complete scan in the current condition. That may add some clarity to the sub-system slaves in this vehicle.
asmetana
C?ID=266775
Here's the first one I took:
Wednesday,30,December,2015,10:39:50:59136
VIN: WAUEFGFF9F1061257   License Plate:
Mileage: 9892km-6146mi   Repair Order:
VIN: WAUEFGFF9F1061257   Mileage: 9892km-6146miles
Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1D00124426000F3000
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A_AU37.rod
   VCID: 2C5762CF47EC375EFD-8078
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4515
   Revision: 03253104    Serial number: TFK01408211140
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1E33B8070150D5CE63-804A
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 62484000002581
   Coding: 13FF6A9234260A6D0179030581CA29C8562C5080C08194B4024100588608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 4581376BC446E61602-8010
   Revision: 00021000    Serial number: 0345639559
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7B5497BDB899EE7F-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Revision: 20026000    Serial number: 00000000426525
   Coding: 03000014010000000000000000001400
   VCID: 336579B39AD268A6BC-8066
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0134
   Serial number: 01011423000403
   Coding: 04151A46C04122F541C04004511007A00800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 79F98B9BF83E52F636-802C
   Slave 1:
   Component: WWS371 140817  042 0585
   Serial number:         140908210725
   Coding: 0A47F7
   Slave 2:
   Serial number: 23133808
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 01 07 2014  00000953
   Serial number: 00000000000060447583
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO32355710
   Coding: 101F00
204546 - Remote key 2
                    Reset counter: 64
                    Mileage: 9892 km
                    Date: 2015.12.29
                    Time: 18:30:38
   Serial number: 003GCR00P5KM
   Coding: 9DCCFCC0000000005000001AC24800000065
   VCID: 479D3D63FE4AF406F0-8012
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34178311B12091440009
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34178312B09091471053
   Coding: 333135
   Seat occupant detection; front passenger side:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 6940000Y1400017JUE00
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 000 309 14
   Serial number: 357000000008B6450118
   Subsystem 5 - Part No SW: -----------    HW: 480 000 309 14
   Serial number: 35800000000FB645011G
   Subsystem 6 - Part No SW: -----------    HW: 480 400 209 14
   Serial number: 3510002BB175A8E3C22B
   Subsystem 7 - Part No SW: -----------    HW: 480 400 209 14
   Serial number: 3520002B1175A8D4003W
   Subsystem 8 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3550002B71656B84E125
   Subsystem 9 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3560002A11656B8470D2
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 27081404220272
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0A1BC457ADD8496E2F-805E
   Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
   Component: KOMBI         H02 4291
   Coding: 03ED18192B80D7050200EA001800000000000000
   VCID: 3E735887A190B5CE43-806A
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00016.06.14
   Coding: 0001
   Shop #: WSC 06314 790 00021
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 46833067F940ED0E0B-8012
   Revision: 00000000    Serial number: 14000237048005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 34677AAF9FDC6F9EA5-8060
   Coding: 00511F204000048000000002
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8102
   ROD: EV_SteerAssisMQB.rod
   VCID: 4189237BD06ECA363E-8014
   Coding: 005117204C00048000000002
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E187ABD426369652-8020
   Part No SW: 8V0 035 038 A    HW: 8V0 035 038
   Component: MU-H-LNS-US   H42 0289
   Serial number: A302I0EB003449
   Coding: 017301020000000021220002041A00102F000125010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 326B7CB765C861AEB7-8066
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 T    HW: -----------
   Component: NAR 2016  --- 0048
   Seat Adjustment Driver Side:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201H4B
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000024071400040320
   Door Electronics Rear Left:
   Component: Gracenote  --- 3005
11 Faults Found:
1584 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1585 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1586 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1587 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1588 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1589 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1590 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:50
1592 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:51
1595 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:51
1591 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 104
                    Mileage: 9710 km
                    Date: 2015.12.24
                    Time: 17:39:51
0009 - Antenna for Satelite Radio
          B10F4 13 [008] - Open Circuit
                    Reset counter: 104
                    Mileage: 8874 km
                    Date: 2015.12.04
                    Time: 13:11:00
End-------------------------(Elapsed Time: 03:54)--------------------------
asmetana
C?ID=266775
And here's the complete one with the most recent post-coding for installed rear door modules
   Revision: --H13---
Readiness: 1110 1101
   Coding: 030C1C
   Coding: 04151A46C0C322F541C04004511007A00814000000000000000000000000
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 101F00
565764 - LED Light Bar
          B1664 31 [009] - No Signal
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 333135
   Coding: 333135
   Coding: 303230
   Coding: A018
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 0001
   Coding: 8102
   Sound System:
   Coding: 0041172040000480000000022076654D494E4B4C4F000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
End-------------------------(Elapsed Time: 04:14)--------------------------
DJAlix
C?ID=238277
Scans from MY14 Saloon without factory Door Lights
Pre CAN Installation List additions
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7E1010072   Mileage: 12244km-7608miles
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---
   Coding: 0A2500322404010B2000
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B_AU37.rod
   VCID: 3B72BBC1B230EBE664-806E
Readiness: 0010 0001
   Part No SW: 0CW 300 045 P    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4530
   Revision: 00043014    Serial number: CU501309107614
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4684DA35F9F2A60E0B-8012
   Revision: 00000000    Serial number: 62683000000594
   Coding: 13F18AA234212A6C0177060741C529C8512C5480608294F4004100388508
   VCID: 7BF27BC1F2B02BE624-802E
   Revision: 20025000    Serial number: 00000000161197
   Coding: 03100014100000011000000000001100
   VCID: 336293E19A6023A6BC-8066
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011326901276
   Coding: 07101A46C24122FD03804004B11807A80000000000000000000000000000
   VCID: 77FA67F1CE980F8640-8022
   Slave 1:
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130825  041 0585
   Serial number:         130911003409
   Coding: 0A47F7
   Slave 2:
   Serial number: 20449421
   Coding: 07006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 04 02 2014  00000218
   Serial number: 000000000ZY1323145BH
   Serial number: 00000000000027931362
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO23970296
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831326300552
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3878A4CD8306C0FE89-806C
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR009MN%
   VCID: 00080C2D9B56483E71-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 000 409 13
   Serial number: 35767000000BA3FCBD0H
   Subsystem 2 - Part No SW: -----------    HW: 480 000 409 13
   Serial number: 358670000004C20DBD0+
   Subsystem 3 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3516502A31118A52F25%
   Subsystem 4 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3526502A311FBEB2B24M
   Subsystem 5 - Part No SW: -----------    HW: 480 401 109 13
   Serial number: 3556502A91118A526283
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 109 13
   Serial number: 2286502B11118A53838%
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 109 13
   Serial number: 2296502AD1118A546313
   Subsystem 8 - Part No SW: -----------    HW: 480 002 108 13
   Serial number: I0M80000000694249D09
   Subsystem 9 - Part No SW: -----------    HW: 480 002 108 13
   Serial number: I0N80000000C44249D0B
   Part No SW: 8V0 953 521 F    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 26091304220118
   Coding: 8018
   VCID: 3D76B5D9AC24E5D65A-8068
   Part No SW: 8V0 920 970 M    HW: 8V0 920 970 M
   Component: KOMBI         H03 2212
   Coding: 238D19082B8026000101EA00000000
   Shop #: WSC 04698 001 104857
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 20091310801689
   Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   Serial number: 17 09 2013  C0342910
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051110240
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 07081304081240
   Coding: 00108E205C01040000001002
   VCID: 3F8ACFD1A628F7C648-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 81
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 13091303111490
   Coding: 001086205E01040000001002
   VCID: 3E74B2D5A122FECE43-806A
   Coding: 019E000001000000
   VCID: 75E66DF9D4947D9652-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    040 0420
   Serial number: A7F01809130964
   Coding: 01730101FF00000021111101000A00002F0205460100010006
   ASAM Dataset: EV_MUStd6C3PASE 002010
   ROD: EV_MUStd6C3PASE_AU37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30DPYV
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000027071300020767
          B201A 00 [009] -  -
                    Reset counter: 123
                    Mileage: 12241 km
                    Date: 2016.02.05
                    Time: 13:49:18
End-------------------------(Elapsed Time: 03:43)--------------------------
Post CAN Installation List additions
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V7E1010072   Mileage: 12307km-7647miles
   Revision: --H09---
Readiness: 1110 0001
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 07006C
   Slave 3:
   Coding: 901E00
   Coding: 0000050011
   Coding: 8018
   Coding: 81
   Coding: 01730101FF00000021111101000A00002F0205C60100010006
   Sound System:
          B201A 00 [009] -  -
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 04101302091078
   Coding: 000086204001040000001002
   VCID: 418EC929D0DC81363E-8014
   Component: TSG HBFS      010 0006
   Serial number: 04101303111083
End-------------------------(Elapsed Time: 04:10)--------------------------
Ignore the 5F DTC, believe it's related to having left VIM activated while Audi had my car in for a service :)
asmetana
C?ID=266775
Pre-Scan (I reverted my CAN door modules to NOT installed)
Thursday,11,February,2016,20:34:17:59136
VIN: WAUEFGFF9F1061257   License Plate: 7HWC852
Mileage: 12095km-7515mi   Repair Order: 20160211-04
   Revision: --H13---
   Coding: 030C1C
   Coding: 04151A46C0C322F541C04004511007A00810000000000000000000000000
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 101F00
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:20:16
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 333135
   Coding: 333135
   Coding: 303230
   Coding: A018
          U0201 00 [008] - No Communications
                    Reset counter: 186
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
          U0202 00 [008] - No Communications
                    Reset counter: 186
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 0001
   Coding: 8102
Scan with rear door modules enabled
Thursday,11,February,2016,19:41:03:59136
Mileage: 12095km-7515mi   Repair Order: 20160211-03
   Revision: --H13---
   Coding: 030C1C
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 101F00
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:20:16
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 333135
   Coding: 333135
   Coding: 303230
   Coding: A018
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
                    Reset counter: 146
                    Mileage: 12095 km
                    Date: 2016.02.11
                    Time: 07:12:42
   Coding: 0001
   Coding: 8102
   Sound System:
   Coding: 0041172040000480000000022073654D4900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
End-------------------------(Elapsed Time: 04:16)--------------------------
Just in case, with the door modules enabled, I checked the long coding, had the below:
Driver (left) Rear
0041172040000480000000022076654D494E4B4C4F0000000000000000000000202122232425262728292A2B2C2D2E2F303132333435363738393A3B3C3D3E3F404142434445464748494A4B4C4D4E4F50515253
Passenger (right) Rear
0041172040000480000000022073654D494E4B4C4F0000000000000000000000202122232425262728292A2B2C2D2E2F303132333435363738393A3B3C3D3E3F404142434445464748494A4B4C4D4E4F50515253
Andy
Sector 7G
HC424490
So I found this post:
http://www.golfmk7.com/forums/showpost.php?p=184369&postcount=3
It seems to confirm that unfortunately neither my 2015 GTI 4 door nor Helen's 2015 A3 convertible have actual rear door controllers:
Sure enough we both have slaves shown under our 42 and 52. I wonder if this is due to the rear door module only really being needed if you have KESSY for the rear door handles? My GTI has touch sensors only on the front handles, not the rears. So a simple motor like this is able to control anything that needs to be controlled:
Anyway for real 4 door A3's, it looks like VCDS should be displaying the BB and BC so we will look into that.
asmetana
C?ID=266775
With VCDS 15.7.4 having been released, I thought I'd give it a whirl and re-enable my rear doors and see if there were any options in there but it didn't look like it. However I see that the rear door codes appear to be different now. Here's what I found when I checked the long-coding helper:
default drivers door rear (US, LHD)
default passenger door rear (US, LHD)
Which appears to be considerably shortened from the previous scans. It was also a different Windows laptop this time, if that would make any difference.
DV52
C?ID=194404
Sorry for hi-jacking this thread , but a question for the good folk at Ross Tech: I've seen examples of changes in the existence (or non existence) of adaptation channels with various versions of VCDS, but I've not before seen a situation where the coding sting on a control module has actually been reported differently (i.e. changed)! To quote a famous physics professor from your country (Julius Sumner Miller) "Why is it so"?
Because control modules sometimes LIE. :banghead:
