Wednesday,30,December,2015,10:39:50:59136
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUEFGFF9F1061257 License Plate:
Mileage: 9892km-6146mi Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F
VIN: WAUEFGFF9F1061257 Mileage: 9892km-6146miles
Address 01: Engine (J623-CNTC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 0A1D00124426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A_AU37.rod
VCID: 2C5762CF47EC375EFD-8078
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4515
Revision: 03253104 Serial number: TFK01408211140
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1E33B8070150D5CE63-804A
P1734 00 [002] - -
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62484000002581
Coding: 13FF6A9234260A6D0179030581CA29C8562C5080C08194B4024100588608
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 4581376BC446E61602-8010
Revision: 00021000 Serial number: 0345639559
Coding: 030C0C
VCID: 3A7B5497BDB899EE7F-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000426525
VCID: 336579B39AD268A6BC-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0134
Serial number: 01011423000403
Coding: 04151A46C04122F541C04004511007A00800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 79F98B9BF83E52F636-802C
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140817 042 0585
Serial number: 140908210725
Coding: 0A47F7
Slave 2:
Component: G397_RLFS H06 0002
Serial number: 23133808
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Serial number: 01 07 2014 00000953
Serial number: 00000000000060447583
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO32355710
Coding: 101F00
204546 - Remote key 2
Reset counter: 64
Mileage: 9892 km
Date: 2015.12.29
Time: 18:30:38
Component: AirbagVW20 009 0825
Serial number: 003GCR00P5KM
VCID: 479D3D63FE4AF406F0-8012
Seat belt tensioner; left:
Component: BeltPretRevFL H35 0341
Serial number: 34178311B12091440009
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H35 0341
Serial number: 34178312B09091471053
Coding: 333135
Seat occupant detection; front passenger side:
Serial number: 6940000Y1400017JUE00
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 000 309 14
Serial number: 357000000008B6450118
Subsystem 5 - Part No SW: ----------- HW: 480 000 309 14
Serial number: 35800000000FB645011G
Subsystem 6 - Part No SW: ----------- HW: 480 400 209 14
Serial number: 3510002BB175A8E3C22B
Subsystem 7 - Part No SW: ----------- HW: 480 400 209 14
Serial number: 3520002B1175A8D4003W
Subsystem 8 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3550002B71656B84E125
Subsystem 9 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3560002A11656B8470D2
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 27081404220272
Coding: A018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0A1BC457ADD8496E2F-805E
Part No SW: 8V0 920 971 D HW: 8V0 920 971 D
Component: KOMBI H02 4291
Coding: 03ED18192B80D7050200EA001800000000000000
VCID: 3E735887A190B5CE43-806A
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 01091410800168
Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti.rod
VCID: 428B2C77D568D12E27-8016
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 15 08 2014 F0044677
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Serial number: HA1-00016.06.14
Coding: 0001
Shop #: WSC 06314 790 00021
VCID: 46833067F940ED0E0B-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000237048005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 34677AAF9FDC6F9EA5-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 22081403111473
Coding: 00511F204000048000000002
VCID: 408F267FDB64C33E31-8014
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 4189237BD06ECA363E-8014
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 29081406071113
Coding: 005117204C00048000000002
VCID: 3F8D2583A69ABCC648-806A
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Component: LWR-ECU 005 0080
Coding: 012A000101000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E187ABD426369652-8020
Part No SW: 8V0 035 038 A HW: 8V0 035 038
Component: MU-H-LNS-US H42 0289
Serial number: A302I0EB003449
Coding: 017301020000000021220002041A00102F000125010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 326B7CB765C861AEB7-8066
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 T HW: -----------
Component: NAR 2016 --- 0048
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201H4B
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000024071400040320
Door Electronics Rear Left:
Component: Gracenote --- 3005
11 Faults Found:
1584 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1585 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1586 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1587 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1588 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1589 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1590 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:50
1592 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:51
1595 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:51
1591 - invalid data record
B2005 00 [008] - -
Reset counter: 104
Mileage: 9710 km
Date: 2015.12.24
Time: 17:39:51
0009 - Antenna for Satelite Radio
B10F4 13 [008] - Open Circuit
Reset counter: 104
Mileage: 8874 km
Date: 2015.12.04
Time: 13:11:00
End-------------------------(Elapsed Time: 03:54)--------------------------
