Skoda Superb 3T Sedan (2011 model) byte 18 issue -- HELP PLEASE
mikeholroyd
C?ID=98585
Please help on an issue I have with a 2011 model Skoda Superb 2.0 CR TDI Sedan Twindoor.
The car has been retrofitted with LED rear lights, and has an issue with these that the lower line of LEDs glows much brighter than the rest whilst the tail lights are lit. Also, the full C shape of the brake lights does not light up as the bottom section does not change when the brake light function is selected.
The central electronics module 09 does not show any option to code for LED rear lights -- I believe this function only appears in model year 2012 cars.
In an attempt to code these LED clusters, the 00 mask of the byte 18 was changed to 1C for Skoda Superb Sedan with separate daytime running lights. The option to code did not appear in the central electronics as I was led to believe, and so the code for the byte 18 was returned to its original 00.
Now, the separate DRLs do not work at all, even though they are still selected within 09 Central Electronics and they are still also shown as active within the MFD maxidot display on the dash panel. All other lighting functions are normal, and no bulb failure light is showing on the dash.
Can anyone please offer some advice how to get the DRL function working again.
I also have full access to VCP Vag Can Pro.
Thank you in anticipation.
Mike
The car has been retrofitted with LED rear lights, and has an issue with these [...]
Then this belongs in the Retrofits section, not the Car Repair section. Moving it now.
mikeholroyd
C?ID=98585
As requested, here is the full scan for the car, which was factory delivered with HALOGEN not xenon headlights.
Note that 09 Central Electronics, byte 3 bit 4 has been coded for an aftermarket HID headlight kit. This has not been an issue and still is not, the issue here is restoring the front DRL function after changing byte 18 from 00 to 1C and back to 00.
Saturday,25,July,2015,12:40:54:42237
VCDS Version: 14.10.2.0
Data version: 20150311
Dealer/Shop Name:
Workshop Code:
VIN: TMBBE73T1B*******   License Plate: Superb 2.0CR TDI SE Twindoor Sedan Manual, Factory halogen headlights
Mileage: 122330km-76012mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBE73T1B*******   Mileage: 122330km-76012miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JB    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H22 7128
   Revision: 42H22---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM20TDI01103L906018JB 003001
   ROD: EV_ECM20TDI01103L906018JB.rod
   VCID: 73EEDB3CDA11D5B963D-8026
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 863D6016092500FB611206E7901D0082300000
   Shop #: WSC 33361 790 00079
   VCID: 75EAE524DC65CB894D9-8020
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 02008EF895ABEC3178B-8057
   Part No SW: 1K0 937 087 K    HW: 1K0 937 087 K
   Component: BCM PQ35  H+  103 0615
   Revision: 00103 AD
   Coding: 48990AB8E05BF1C040080080110081E4467400AE532081605C0040000040
   Shop #: WSC 24666 010 24666
   VCID: 39722914B0FD6FE9691-806C
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 19101  26  0602
   Coding: 00D7B7
   Component: RLS 211010 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66601030000092
   Coding: 100004
   VCID: 408444F0D3273E212EF-8015
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAU VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PMG7A6P
   Coding: 0016725
   VCID: 418241F4182D3729211-8014
   Subsystem 1 - Serial number: 6332MTS662862920
   Subsystem 2 - Serial number: 6342MTS662712920
   Subsystem 3 - Serial number: 6351HTS67IDGF9KJ
   Subsystem 4 - Serial number: 6361HTS6UE3EF9KR
   Subsystem 5 - Serial number: 63727TS6OA7EF9KR
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101026200525
   Coding: 0082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E8E228C963C091443-8023
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 3T2 920 941 H    HW: 3T2 920 941 H
   Component: KOMBI         H20 0420
   Coding: 410B00
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 3A703618BDFB64F160B-806F
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 251010F2002524
   Coding: E9A07F0600020200003303
   VCID: 6DDACD4474350349B59-8038
   Component: IMMO          H20 0420
   VCID: 6AD0C6588DDB1471D0B-803F
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 C    HW: 8X0 959 793 C
   Component: TSG FA        H09 0409
   Coding: 011D0220D001001000
   VCID: 4D9A6DC41475E349D59-8018
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 31621134A88DA7A9D11-8064
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 C    HW: 8X0 959 792 C
   Component: TSG BF        H09 0409
   VCID: 4C9C60C0EF6FEA41C27-8019
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 G    HW: 3T0 035 156 G
   Component: BOLERO        003 0013
   Revision: -----13S    Serial number: SKZ4Z3P1105120
   Coding: 1D0004000004
   Shop #: WSC 59233 001 1048576
   VCID: 32601E386D8B9CB1A8B-8067
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
   VCID: 4E986AC81973D851AC3-801B
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 02:30)--------------------------
LasseTheDude
Norway
C?ID=247880
Try 84 of 85 in byte 18 :)
mikeholroyd
C?ID=98585
Tried 84 and 85, neither allow front DRLs to be lit.
Back to square 1 !
mikeholroyd
C?ID=98585
So far, the best option we have found is 39, which gives us the front DRLs back, but only one (right hand side) rear fog. This seems close to the original, as the LED rear lights are still behaving as described in post 1 above. I say close, as the original had both left and right rear fogs on.
Back to square 1 !
LasseTheDude
Norway
C?ID=247880
Check out this list man
http://www.pjruane.com/jm/Byte18.pdf
39 is 57 39 SK350 Halogen SK351 TFL_SH LL ROM 57 SK350 SK351 halogen TFL_SH LL ROM 57
U have to look at the hex value.. That is what u use in byte 18. :) Then U have to try everything that contains SK350 ;)
This is how I fix my byte 18 issue on 2014 Superb. Tried every code in this list.
