I've had the VCDS since last year and it's great. Thus far I haven't used it for much more than making some tweaks to my vehicle (adjusting the blinker lights and such).
In the meantime, I became tired of the slowness of the RNS-510 module and the fact that it didn't support Carplay so I ordered a RCD-330 along with a camera adapter from Lemon Shark on Aliexpress. The installation was fairly painless, mostly plug in play except for the adapter. I did unplug the Bluetooth module that's under the passenger seat (HT-6C PN: 561 035 285) as bluetooth is included in the new head unit.
In order for the radio to produce sound I needed to disconnect the battery for a few minutes then reconnect it. This caused a bunch of errors to be thrown, but the radio worked.
I was able to clear the majority of the faults using VCDS however I still have a couple of issues.
First, it seems like the TPMS isn't able to communicate with the central computer. This might just be that I need to drive the car around a bit, i haven't had a chance to do that yet.
Second, I'm unable to access the radio control module (56). I have a feeling it's the new part number that end's in an F vs the A-E models currently out there. I emailed in the channel mapping so hopefully that's easy to fix with an update. I plan to use this as a guide for the updates to make (disable navigation, etc).
There are a number of errors that still exist in the scan, things like motor for the rear window regulator is missing calibration, how do i fix that? Or Steering angle sensor for steering aid isn't working, I didn't think I had such a feature in my car. The signal for the mirror adjustment on the passenger side is "Implausible" which sounds kinda crazy.
Fourth, the backup camera isn't working even though I've wired it up with the adapter. I have more troubleshooting to do on this, make sure my wiring is correct, make sure box I received from Lemon Shark actually works, etc, but I'm thinking there might be a radio setting that needs to be adjusted?
Finally, is there some way to tell it to stop looking for a phone, or do i need to wait until the radio coding is completed?
Anyway, any help you can provide would be great! Here's my Autoscan:
Wednesday,08,July,2020,11:27:42:05588
VIN: 1VWCN7A3XEC008934 License Plate:
Mileage: 61120km-37978mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A3XEC008934 Mileage: 61120km-37978miles
75-Telematics -- Status: Cannot be reached 1100
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 09460 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B23370B73E4FD93469-806E
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9437
Revision: 05651213 Serial number: 00001304111271
Shop #: WSC 09003 957 00200
VCID: 1471BCB7327AD2EBE73-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F549220002A31403E7921D0042A71000
VCID: 7DA7F9132DF033A338D-8028
Reset counter: 23
Mileage: 61125 km
Date: 2020.07.08
Time: 11:24:42
Count: 3
Count: 14
Count: 12800
Count: 16390
Count: 49920
Count: 1
Count: 256
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0193377285
Coding: 130C0C
VCID: 34311C375EBA32EB873-8060
Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic H03 0505
Revision: 00001K01
Coding: 0030019012
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 57EB8BBBEF8C39F3421-8002
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E3B882B2AD4098802013600854802F1A086458015B064806000BC70
Shop #: WSC 05082 001 104857
VCID: 78A9E80702D2168B6BB-802C
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM0265CI
Coding: 00004D4A
Shop #: WSC 62905 003 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7E13315406BE370D-8020
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y130000VSMB0K
Coding: 303047
Serial number: 3572MSME0745117BZZZT
Serial number: 3582MSME4244117BZZZS
Serial number: 3516KSME7A180923ZZZT
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME5A493225ZZZU
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME2D4B6321ZZZ-
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME2D566A21ZZZ/
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130423100338
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7F9132D7033A338D-8028
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1E65DE9FC03688BB417-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 09071303000251
Coding: 461000
VCID: 7BA3F70B33E43D93069-802E
01302 - Control Module for Telematic (J499)
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:27:57
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:27:57
Component: IMMO H04 0811
Coding: 000007
VCID: 6A8DC24F4CFEB41BEDF-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000030486004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW01.rod
VCID: 30391027AAA20ECBE3B-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000063588966
Coding: 00581B0000000000000021010100202020202120202020
VCID: 221DEA6FF4CEAC5B65F-8076
Address 37: Navigation
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0006803347
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61D497D62A9AABAF3-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630130628125116
Coding: 800000
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:29:56
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 392F2D037558CF83545-806C
000 - - - MIL ON
Fault Status: 11100000
Mileage: 61125 km
Date: 2020.07.08
Time: 00:30:42
Battery Volts: 14.0 V
DU
Temperature: 35.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0041915
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 2615F67F9866507B097-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FBBD35B779C5133BA1-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011305101476
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0006872045
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67D993CD3093A358D-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631130708131811
Coding: 800000
66821 - Position Sensor for Mirror Adjustment
B11FA 29 [009] - Signal Implausible
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:31:35
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:31:35
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 F HW: 6RD 035 187 B
Component: Radio 566 Y520
Revision: -------- Serial number: VWZZZ4K6216369
Coding: 0E000440040005
Shop #: WSC 00078 790 00167
VCID: 4CC164D726CA4A2BFF3-8018
Address 75: Telematics
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664882816
Coding: 0A10030081010110
ROD: EV_UHVUMI.rod
VCID: 2E050E5FB096183BF17-807A
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:33:40
9457170 - Right audio channel for speech/telephone
B104E 12 [009] - Short to GND
Reset counter: 22
Mileage: 61125 km
Date: 2020.07.08
Time: 00:33:39
End----------(Elapsed Time: 01:14, VBatt start/end: 14.0V/14.0V)-----------
