2014 VW Passat TDI SEL RCD330 Installation
ProZach
C?ID=381303
I've had the VCDS since last year and it's great. Thus far I haven't used it for much more than making some tweaks to my vehicle (adjusting the blinker lights and such).
In the meantime, I became tired of the slowness of the RNS-510 module and the fact that it didn't support Carplay so I ordered a RCD-330 along with a camera adapter from Lemon Shark on Aliexpress. The installation was fairly painless, mostly plug in play except for the adapter. I did unplug the Bluetooth module that's under the passenger seat (HT-6C PN: 561 035 285) as bluetooth is included in the new head unit.
In order for the radio to produce sound I needed to disconnect the battery for a few minutes then reconnect it. This caused a bunch of errors to be thrown, but the radio worked.
I was able to clear the majority of the faults using VCDS however I still have a couple of issues.
First, it seems like the TPMS isn't able to communicate with the central computer. This might just be that I need to drive the car around a bit, i haven't had a chance to do that yet.
Second, I'm unable to access the radio control module (56). I have a feeling it's the new part number that end's in an F vs the A-E models currently out there. I emailed in the channel mapping so hopefully that's easy to fix with an update. I plan to use this as a guide for the updates to make (disable navigation, etc).
There are a number of errors that still exist in the scan, things like motor for the rear window regulator is missing calibration, how do i fix that? Or Steering angle sensor for steering aid isn't working, I didn't think I had such a feature in my car. The signal for the mirror adjustment on the passenger side is "Implausible" which sounds kinda crazy.
Fourth, the backup camera isn't working even though I've wired it up with the adapter. I have more troubleshooting to do on this, make sure my wiring is correct, make sure box I received from Lemon Shark actually works, etc, but I'm thinking there might be a radio setting that needs to be adjusted?
Finally, is there some way to tell it to stop looking for a phone, or do i need to wait until the radio coding is completed?
Anyway, any help you can provide would be great! Here's my Autoscan:
Wednesday,08,July,2020,11:27:42:05588
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 1VWCN7A3XEC008934   License Plate:
Mileage: 61120km-37978mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCN7A3XEC008934   Mileage: 61120km-37978miles
37-Navigation -- Status: Cannot be reached 1100
75-Telematics -- Status: Cannot be reached 1100
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 09460 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B23370B73E4FD93469-806E
   Component: GSG DSG AG6     512 9437
   Revision: 05651213    Serial number: 00001304111271
   Shop #: WSC 09003 957 00200
   VCID: 1471BCB7327AD2EBE73-8040
   Revision: 00H31001
   Coding: C54BC0F549220002A31403E7921D0042A71000
   VCID: 7DA7F9132DF033A338D-8028
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 11:24:42
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 49920
                    Count: 1
                    Count: 256
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193377285
   Coding: 130C0C
   VCID: 34311C375EBA32EB873-8060
   Part No SW: 561 907 044 AB    HW: 561 907 044 AB
   Component: Climatronic   H03 0505
   Revision: 00001K01
   Coding: 0030019012
   VCID: 57EB8BBBEF8C39F3421-8002
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0173
   Revision: BL122001
   Coding: EF200E3B882B2AD4098802013600854802F1A086458015B064806000BC70
   Shop #: WSC 05082 001 104857
   VCID: 78A9E80702D2168B6BB-802C
   Serial number: 003MWM0265CI
   Coding: 00004D4A
   Shop #: WSC 62905 003 1048576
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7E13315406BE370D-8020
   Serial number: 6940000Y130000VSMB0K
   Coding: 303047
   Serial number: 3572MSME0745117BZZZT
   Serial number: 3582MSME4244117BZZZS
   Serial number: 3516KSME7A180923ZZZT
   Serial number: 3526KSME5A493225ZZZU
   Serial number: 3556LSME2D4B6321ZZZ-
   Serial number: 3566LSME2D566A21ZZZ/
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130423100338
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7F9132D7033A338D-8028
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1E65DE9FC03688BB417-804A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 09071303000251
   Coding: 461000
   VCID: 7BA3F70B33E43D93069-802E
01302 - Control Module for Telematic (J499)
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:27:57
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:27:57
   Coding: 000007
   VCID: 6A8DC24F4CFEB41BEDF-803E
   Revision: 00000000    Serial number: 13000030486004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 30391027AAA20ECBE3B-8064
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000063588966
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 221DEA6FF4CEAC5B65F-8076
Address 37: Navigation
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0006803347
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61D497D62A9AABAF3-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630130628125116
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:29:56
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F2D037558CF83545-806C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:30:42
                    Battery Volts: 14.0 V
                        DU
                    Temperature: 35.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0041915
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   VCID: 2615F67F9866507B097-8072
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBD35B779C5133BA1-803A
   Serial number: 53388786011305101476
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0006872045
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67D993CD3093A358D-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631130708131811
   Coding: 800000
66821 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:31:35
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:31:35
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 F    HW: 6RD 035 187 B
   Component: Radio         566 Y520
   Revision: --------    Serial number: VWZZZ4K6216369
   Coding: 0E000440040005
   Shop #: WSC 00078 790 00167
   VCID: 4CC164D726CA4A2BFF3-8018
Address 75: Telematics
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664882816
   Coding: 0A10030081010110
   ROD: EV_UHVUMI.rod
   VCID: 2E050E5FB096183BF17-807A
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:33:40
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:33:39
End----------(Elapsed Time: 01:14, VBatt start/end: 14.0V/14.0V)-----------
Hmm.. It appears to be coded for "Back-Up Camera installed", so I'm not sure what's up with that.
You might want to remove the modules that "Cannot Be Reached" (37-Navigation and 75-Telematics) from the Gateway Installation List on general principle, but I don't think that's going to fix the back-up camera issue.
ProZach
C?ID=381303
Cool, will do. Mind if I ask where do I go to remove modules?
I have more troubleshooting to do with the camera. Make sure my fuse is delivering power, the line I ran wasn't somehow cut after I ran it (it was somewhat challenging to get the cable a short distance due to various metal panels), make sure the adapter actually works.
[Select]
[19-CAN Gateway]
[Installation List]
- Scroll down to the relevant modules and remove the check-marks next to them.
[Save Coding]
ProZach
C?ID=381303
Excellent, thank you!
ProZach
C?ID=381303
I'm reading through the forum and it looks like I need to do a few things to correct some of these faults. Adding this for my own notes and also for anyone else that has similar issues.
First for the 03803 - Steering Angle Sensor for Steering Aid error I should do this calibration routine.
For the TPMS error I need to hit the tire pressure rest button and drive for a while so the ABS system can sense how my tires are spinning and know that they aren't flat.
For the 131584 - Motor for Rear Window Regulator faults I need to do this.
For the 66821 - Position Sensor for Mirror Adjustment I'm not sure what to do but I'll play with adjusting the mirror around a bit to see if that helps.
ProZach
C?ID=381303
I was able to clear the errors. One issue I still have is the mirror fault and my side mirrors don't allow me to adjust them anymore. I'm done for this evening but i'll take a look at it tomorrow.
siLc
Tallinn, Estonia
C?ID=330192
This is the telematics module. BT is still there, at least in the first scan. Mind posting a fresh autoscan?
ProZach
C?ID=381303
Ahh, then yes, it was the telematics module. Here is a picture of it.
I'm guessing I should reinstall that, maybe that's the source of not being able to adjust my mirrors?
Here is a scan from this morning.
Thursday,09,July,2020,08:52:34:05588
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 42 44 46 47 4F 52
          56 62 72 77
77-Telephone -- Status: Not registered 0011
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001K01
   Coding: 0030019012
   Revision: BL122001
   Coding: 00004D4A
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
                    Fault Status: 01110100
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:27:57
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:27:57
                    Fault Frequency: 13
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:00:18
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 24
                    Mileage: 61126 km
                    Date: 2020.07.08
                    Time: 16:38:18
                    Fault Status: 00111011
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:02:47
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:02:47
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:02:47
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:02:47
                    Fault Status: 00110100
                    Reset counter: 23
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 15:03:12
   ROD: EV_UHVUMI.rod
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:33:40
                    Reset counter: 22
                    Mileage: 61125 km
                    Date: 2020.07.08
                    Time: 00:33:39
End----------(Elapsed Time: 01:11, VBatt start/end: 14.1V/14.0V)-----------
ProZach
C?ID=381303
Ok, went for a drive (to drop my RNS510 off at the post office) and my side mirrors adjustment works, although it looks like the blinker light is out in the driver side. Everything else works well except the backup camera. Love the Carplay.
I found the bluetooth module in my 2014 Passat TDI SEL it's in the center armrest where the multimedia connector is. That hinges forward from the top (two clips behind it) and it comes out. The cable is long enough to be able to pull it out and work with it. I disconnected it but left it in there. Now I don't have the odd errors about the hardware being missconfigured and I don't have any prompts to connect to bluetooth via the MFI display.
I plan to work on the rearview camera this weekend. I might end up just getting a new one with RCA out rather than messing with the adapter.
Thursday,09,July,2020,14:30:43:05588
Mileage: 61130km-37984mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 36 42 44 46 47 4F 52 56
          62 72
VIN: 1VWCN7A3XEC008934   Mileage: 61130km-37984miles
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001K01
   Coding: 0030019012
   Revision: BL122001
   Coding: 00004D4A
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 24
                    Mileage: 61126 km
                    Date: 2020.07.09
                    Time: 12:52:41
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 25
                    Mileage: 61136 km
                    Date: 2020.07.09
                    Time: 14:27:55
   Coding: 06000440010005
                    Reset counter: 24
                    Mileage: 61126 km
                    Date: 2020.07.09
                    Time: 12:51:16
End----------(Elapsed Time: 01:06, VBatt start/end: 13.8V/13.8V)-----------
