Limp Mode CJAA wrenchers please help!
Dedman
New Member
WA, USA
Car is occasionally studdering. It gave me a camshaft position sensor code and a throttle body code with limp mode. Cleaned and lubed throttle body thought all is well. 2000 miles later the cam shift position sensor code went on without a check engine light up or any issues. The next day on my way to work the car started shuddering real bad while just driving normal, tried to accelerate and limp mode again with a bunch of other codes. Maybe bad camshaft sensor or a bad wiring harness? Ecu? What do you think?
Thursday,21,May,2020,13:38:12:38103
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VWPL7AJ1BM667128   License Plate:
Mileage: 146370km-90950mi   Repair Order:
                Address 01: Engine       Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 B    HW: 03L 906 019 DA
  Component and/or Version: R4 2.0l TDI G000AG  9983
           Software Coding: 0050078
            Work Shop Code: WSC 13327 002 1048576
                      VCID: 2D070B6891187313C8D-8078
7 Faults Found:
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 53
                    Mileage: 146258 km
                    Date: 2020.05.20
                    Time: 12:22:30
                    RPM: 3473 /min
                    Speed: 74.0 km/h
                    Voltage: 14.06 V
                    Temperature: 77.4C
                    Idle Stabilization: -2.7KW
                    RPM: 1721 /min
                    (no units): 48.0
001151 - Exhaust Pressure Control Valve
               P047F - 000 - Stuck Open - Intermittent
                    Mileage: 146310 km
                    Date: 2020.05.21
                    Time: 02:40:29
                    RPM: 2139 /min
                    Speed: 109.0 km/h
                    Load: 47.1 %
                    Load: 21.6 %
                    Lambda: 26.8 %
                    Temperature: 384.0C
                    Temperature: 79.2C
001162 - Exhaust Pressure Control Valve 1
               P048A - 000 - Stuck Closed - Intermittent
                    Mileage: 146310 km
                    Date: 2020.05.21
                    Time: 02:40:29
                    RPM: 2162 /min
                    Speed: 109.0 km/h
                    Load: 44.3 %
                    Load: 100.0 %
                    Lambda: 52.9 %
                    Temperature: 384.0C
                    Temperature: 79.2C
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - Intermittent
                    Mileage: 146316 km
                    Date: 2020.05.21
                    Time: 02:44:23
                    RPM: 2162 /min
                    Speed: 110.0 km/h
                    Load: 45.1 %
                    Load: 100.0 %
                    Lambda: 11.8 %
                    Mass Air / Rev.: 735.0 mg/str
                    Temperature: 81.0C
008198 - Intake Manifold Flap; Bank 1
               P2006 - 000 - Stuck Closed - Intermittent
                    Mileage: 146316 km
                    Date: 2020.05.21
                    Time: 02:44:23
                    RPM: 2162 /min
                    Speed: 110.0 km/h
                    Load: 45.1 %
                    Load: 100.0 %
                    Lambda: 42.6 %
                    Mass Air / Rev.: 740.0 mg/str
                    Temperature: 81.0C
001601 - Sensor Reference Voltage A
               P0641 - 000 - Open Circuit - Intermittent
                    Mileage: 146299 km
                    Date: 2020.05.21
                    Time: 02:31:26
                    RPM: 1978 /min
                    Speed: 100.0 km/h
                    Load: 38.0 %
                    Voltage: 13.60 V
                    Temperature: 81.9C
                    (no units): 0.0
                    Torque: 105.0 Nm
008504 - Accelerator Position Sensors (G79) / (G185)
               P2138 - 001 - Implausible Correlation - Intermittent
                    Fault Status: 00100001
                    Mileage: 146323 km
                    Date: 2020.05.21
                    Time: 02:48:54
                    RPM: 1495 /min
                    Speed: 75.0 km/h
                    Load: 39.2 %
                    Voltage: 13.68 V
                    Voltage: 0.836 V
                    Voltage: 0.988 V
                    Bin. Bits:  1 00  0
Dedman
New Member
WA, USA
Car drove great today without any issues.... i didn't do anything to it. Any idea why the hick up?
Clear the fault codes and see if any come back.
It's not unknown for the ECU software to 'get out of bed the wrong side' :rolleyes:
Dedman
New Member
WA, USA
car is having some serious issues. Updated faults. I inspected the throttle body again. All the gears on the inside look good. Did an output test of the throttle body and visual watched the butterfly flap open and close. Figured might as well clean the egr since I got the throttle boddy off. Put it all back together still having issues. The car will go through spurts of full power no issues then just start to stutter. Not sure whats going on.
Sunday,31,May,2020,10:25:46:38103
                      VCID: 2D070B6891087313C8D-5184
10 Faults Found:
001592 - Throttle Body Actuator Bank 1 (J338)
               P0638 - 000 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 147425 km
                    Date: 2020.06.01
                    Time: 09:56:00
                    Voltage: 12.39 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
                    Fault Frequency: 142
                    Mileage: 147393 km
                    Date: 2020.06.01
                    Time: 02:34:34
                    RPM: 2185 /min
                    Speed: 111.0 km/h
                    Voltage: 13.53 V
                    Temperature: 82.8C
                    Idle Stabilization: -5.0KW
                    RPM: 2177 /min
                    (no units): 48.0
               P2004 - 000 - Stuck Open - Intermittent - MIL ON
                    Fault Frequency: 7
                    Mileage: 147395 km
                    Date: 2020.06.01
                    Time: 02:35:32
                    RPM: 2116 /min
                    Speed: 107.0 km/h
                    Load: 54.1 %
                    Load: 94.9 %
                    Lambda: 100.2 %
                    Mass Air / Rev.: 665.0 mg/str
                    Temperature: 82.8C
               P2006 - 000 - Stuck Closed - Intermittent - MIL ON
                    Fault Frequency: 7
                    Mileage: 147395 km
                    Date: 2020.06.01
                    Time: 02:35:32
                    RPM: 2116 /min
                    Speed: 107.0 km/h
                    Load: 54.1 %
                    Load: 94.9 %
                    Lambda: 38.7 %
                    Mass Air / Rev.: 700.0 mg/str
                    Temperature: 82.8C
                    Mileage: 147396 km
                    Date: 2020.06.01
                    Time: 02:36:28
                    RPM: 2116 /min
                    Speed: 107.0 km/h
                    Load: 34.5 %
                    Load: 40.8 %
                    Lambda: 45.8 %
                    Temperature: 594.0C
                    Temperature: 83.7C
                    Mileage: 147396 km
                    Date: 2020.06.01
                    Time: 02:36:28
                    RPM: 2116 /min
                    Speed: 107.0 km/h
                    Load: 24.7 %
                    Load: 41.2 %
                    Lambda: 71.8 %
                    Temperature: 594.0C
                    Temperature: 83.7C
005000 - Control Module Malfunction - DBW Throttle Monitoring
               P1388 - 004 -  - Intermittent - MIL ON
                    Fault Status: 10100100
                    Mileage: 147449 km
                    Date: 2020.06.01
                    Time: 10:16:02
                    RPM: 1518 /min
                    Speed: 77.0 km/h
                    Voltage: 13.83 V
                    Voltage: 2.736 V
                    Voltage: 1.368 V
                    Torque: -70.0 Nm
                    Bin. Bits:  0000000
               P1388 - 000 -  - Intermittent
                    Fault Frequency: 21
                    Mileage: 147449 km
                    Date: 2020.06.01
                    Time: 10:16:02
                    RPM: 1518 /min
                    Speed: 77.0 km/h
                    Load: 0.0 %
                    Bin. Bits:  0000000
                    Inj. Quantity: 6.3 mg/str
                    Hex Value: 0xFF6C
                    Hex Value: 0xFF01
009305 - Diesel Particulate Filter
               P2459 - 000 - Regeneration Frequency
                    Mileage: 147409 km
                    Date: 2020.06.01
                    Time: 02:44:32
                    RPM: 1863 /min
                    Speed: 58.0 km/h
                        21.3
                        4.2
                    Pressure: 0 mbar
                    milliliters: 108 ml
008482 - Accelerator Position Sensor (G79)
               P2122 - 000 - Signal too Low - Intermittent
                    Mileage: 147458 km
                    Date: 2020.06.01
                    Time: 10:22:41
                    RPM: 1587 /min
                    Speed: 67.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Voltage: 0.684 V
                    Voltage: 0.380 V
                    Bin. Bits:  0 01  0
Readiness: 1 6 0 0 1
Address 01: DTCs clearedMonday,01,June,2020,17:56:36:38103
7 Faults Found:
                    Fault Frequency: 7
                    Mileage: 147459 km
                    Date: 2037.14.24
                    Time: 10:27:05
                    RPM: 2093 /min
                    Speed: 64.0 km/h
                    Voltage: 13.91 V
                    Temperature: 75.6C
                    RPM: 1026 /min
                    (no units): 48.0
                    Mileage: 147462 km
                    Date: 2037.14.24
                    Time: 10:29:08
                    RPM: 2093 /min
                    Speed: 105.0 km/h
                    Load: 45.5 %
                    Load: 94.9 %
                    Lambda: 78.9 %
                    Mass Air / Rev.: 525.0 mg/str
                    Temperature: 81.9C
                    Mileage: 147462 km
                    Date: 2037.14.24
                    Time: 10:29:08
                    RPM: 2093 /min
                    Speed: 105.0 km/h
                    Load: 39.6 %
                    Load: 46.3 %
                    Lambda: 71.8 %
                    Temperature: 456.0C
                    Temperature: 81.9C
                    Mileage: 147462 km
                    Date: 2037.14.24
                    Time: 10:29:08
                    RPM: 2093 /min
                    Speed: 105.0 km/h
                    Load: 37.6 %
                    Load: 94.9 %
                    Lambda: 97.1 %
                    Mass Air / Rev.: 515.0 mg/str
                    Temperature: 81.9C
                    Mileage: 147462 km
                    Date: 2037.14.24
                    Time: 10:29:08
                    RPM: 2070 /min
                    Speed: 105.0 km/h
                    Load: 34.9 %
                    Load: 45.9 %
                    Lambda: 86.0 %
                    Temperature: 456.0C
                    Temperature: 81.9C
               P0641 - 000 - Open Circuit - MIL ON
                    Fault Status: 11100000
                    Mileage: 147463 km
                    Date: 2037.14.24
                    Time: 10:29:39
                    RPM: 2001 /min
                    Speed: 102.0 km/h
                    Load: 47.1 %
                    Voltage: 13.68 V
                    Temperature: 82.8C
                    (no units): 0.0
                    Torque: 198.0 Nm
000618 - Charge Air Cooler
               P026A - 000 - Efficiency Below Threshold
                    Mileage: 147466 km
                    Date: 2037.14.24
                    Time: 10:31:29
                    RPM: 1817 /min
                    Speed: 92.0 km/h
                    Temperature: 15.3C
                    Temperature: 12.6C
                    (no units): 132.6
                    Temperature: 78.0C
                    (no units): 0.0
                Address 01: Engine       Labels: 03L-906-022-CBE.CLB
                    Mileage: 147470 km
                    Date: 2037.14.25
                    Time: 17:57:26
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Temperature: 13.5C
                    (no units): 0.0
                    Torque: -150.0 Nm
Readiness: 0 0 0 1 1
                    Mileage: 147470 km
                    Date: 2037.14.25
                    Time: 18:00:46
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Temperature: 13.5C
                    (no units): 0.0
                    Torque: -150.0 Nm
               P2122 - 000 - Signal too Low - MIL ON
                    Mileage: 147470 km
                    Date: 2037.14.25
                    Time: 20:03:26
                    RPM: 138 /min
                    Load: 0.0 %
                    Voltage: 9.20 V
                    Voltage: 0.684 V
                    Voltage: 0.380 V
                    Bin. Bits:  1 00  0
                      VCID: 2D070B6891087313C8D-5160
                    Mileage: 147470 km
                    Date: 2037.14.25
                    Time: 20:08:22
                    RPM: 1380 /min
                    Voltage: 13.91 V
                    Temperature: 32.4C
                    Idle Stabilization: -1.4KW
                    RPM: 1037 /min
                    (no units): 48.0
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:07
                    RPM: 1265 /min
                    Speed: 36.0 km/h
                    Load: 55.3 %
                    Load: 94.9 %
                    Lambda: 85.2 %
                    Mass Air / Rev.: 565.0 mg/str
                    Temperature: 63.9C
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:07
                    RPM: 1265 /min
                    Speed: 36.0 km/h
                    Load: 55.3 %
                    Load: 94.9 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 555.0 mg/str
                    Temperature: 63.9C
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:19
                    RPM: 966 /min
                    Speed: 34.0 km/h
                    Load: 4.3 %
                    Voltage: 13.76 V
                    Temperature: 65.7C
                    (no units): 0.0
                    Torque: 111.0 Nm
                    Mileage: 147470 km
                    Date: 2037.14.25
                    Time: 20:08:22
                    RPM: 1380 /min
                    Voltage: 13.91 V
                    Temperature: 32.4C
                    RPM: 1037 /min
                    (no units): 48.0
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:07
                    RPM: 1265 /min
                    Speed: 36.0 km/h
                    Load: 55.3 %
                    Load: 94.9 %
                    Lambda: 85.2 %
                    Temperature: 63.9C
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:07
                    RPM: 1265 /min
                    Speed: 36.0 km/h
                    Load: 55.3 %
                    Load: 94.9 %
                    Lambda: 99.4 %
                    Temperature: 63.9C
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:15:19
                    RPM: 966 /min
                    Speed: 34.0 km/h
                    Load: 4.3 %
                    Voltage: 13.76 V
                    Temperature: 65.7C
                    (no units): 0.0
                    Torque: 111.0 Nm
                    Fault Frequency: 12
                    Mileage: 147472 km
                    Date: 2037.14.25
                    Time: 20:18:41
                    RPM: 3726 /min
                    Speed: 48.0 km/h
                    Voltage: 13.76 V
                    Temperature: 65.7C
                    Idle Stabilization: -4.5KW
                    RPM: 1938 /min
                    (no units): 48.0
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:21:20
                    RPM: 1679 /min
                    Speed: 13.0 km/h
                    Load: 31.8 %
                    Load: 94.9 %
                    Lambda: 96.3 %
                    Mass Air / Rev.: 215.0 mg/str
                    Temperature: 76.5C
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:21:20
                    RPM: 1679 /min
                    Speed: 13.0 km/h
                    Load: 23.1 %
                    Load: 94.9 %
                    Lambda: 37.1 %
                    Mass Air / Rev.: 275.0 mg/str
                    Temperature: 76.5C
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:21:48
                    RPM: 1288 /min
                    Speed: 29.0 km/h
                    Load: 0.0 %
                    Voltage: 13.53 V
                    Voltage: 0.684 V
                    Voltage: 0.380 V
                    Bin. Bits:  1 01  0
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:22:11
                    RPM: 966 /min
                    Speed: 18.0 km/h
                    Load: 0.0 %
                    Voltage: 13.76 V
                    Temperature: 76.5C
                    (no units): 0.0
                    Torque: 0.0 Nm
Fault Codes have been Erased
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:24:00
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 500.0 mg/str
                    Temperature: 75.6C
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:24:25
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 10.6 %
                    Lambda: 100.2 %
                    Mass Air / Rev.: 265.0 mg/str
                    Temperature: 74.7C
Address 01: DTCs clearedMonday,01,June,2020,20:36:06:38103
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:32:49
                    RPM: 2185 /min
                    Speed: 28.0 km/h
                    Voltage: 13.68 V
                    Temperature: 77.4C
                    RPM: 2063 /min
                    (no units): 48.0
                    Mileage: 147474 km
                    Date: 2037.14.25
                    Time: 20:33:36
                    RPM: 966 /min
                    Speed: 6.0 km/h
                    Load: 0.0 %
                    Voltage: 13.45 V
                    Temperature: 78.3C
                    (no units): 0.0
                    Torque: 60.0 Nm
               P0638 - 000 - Implausible Signal - MIL ON
                    Mileage: 147475 km
                    Date: 2037.14.25
                    Time: 20:35:45
                    Voltage: 12.62 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
                    Mileage: 147475 km
                    Date: 2037.14.25
                    Time: 20:37:22
                    Voltage: 12.01 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
The fact that you have an "Accelerator Position Sensor" fault pretty consistently makes me suspect you have a flaky ECU and the rest of those faults may be due to the flaky ECU rather than anything real with that stuff. Check wiring diagrams to be sure, but I think the accelerator position sensors go directly back to the ECU; they have no connection to anything else.
Now verifying the wiring between the ECU and swapping out that sensor assembly if the wiring checks out is much cheaper/easier than swapping out the ECU, so I'd suggest doing that first, but I doubt it will yield any joy.
Dedman
New Member
WA, USA
Updated fault code from today's drive.
Tuesday,02,June,2020,09:19:01:38103
                    Mileage: 147475 km
                    Date: 2037.14.26
                    Time: 09:18:59
                    RPM: 299 /min
                    Load: 0.0 %
                    Voltage: 10.41 V
                    Temperature: 12.6C
                    (no units): 0.0
                    Torque: 171.0 Nm
Address 01: DTCs clearedTuesday,02,June,2020,09:42:51:38103
8 Faults Found:
                    Fault Frequency: 22
                    Mileage: 147475 km
                    Date: 2037.14.26
                    Time: 09:26:17
                    RPM: 3519 /min
                    Speed: 46.0 km/h
                    Voltage: 14.06 V
                    Temperature: 40.5C
                    RPM: 2907 /min
                    (no units): 48.0
                    Mileage: 147482 km
                    Date: 2037.14.26
                    Time: 09:32:21
                    RPM: 1794 /min
                    Speed: 91.0 km/h
                    Load: 40.8 %
                    Load: 38.0 %
                    Lambda: 100.2 %
                    Temperature: 546.0C
                    Temperature: 80.1C
                    Mileage: 147482 km
                    Date: 2037.14.26
                    Time: 09:32:21
                    RPM: 1794 /min
                    Speed: 91.0 km/h
                    Load: 40.4 %
                    Load: 38.4 %
                    Lambda: 60.0 %
                    Temperature: 546.0C
                    Temperature: 80.1C
                    Mileage: 147482 km
                    Date: 2037.14.26
                    Time: 09:32:21
                    RPM: 1794 /min
                    Speed: 91.0 km/h
                    Load: 41.2 %
                    Load: 94.9 %
                    Lambda: 7.9 %
                    Mass Air / Rev.: 460.0 mg/str
                    Temperature: 80.1C
                    Mileage: 147482 km
                    Date: 2037.14.26
                    Time: 09:32:21
                    RPM: 1794 /min
                    Speed: 91.0 km/h
                    Load: 41.2 %
                    Load: 94.9 %
                    Lambda: 100.2 %
                    Temperature: 80.1C
001166 - Sensor for Exhaust Flap
               P048E - 000 - Short to Plus
                    Mileage: 147483 km
                    Date: 2037.14.26
                    Time: 09:33:59
                    RPM: 3381 /min
                    Speed: 106.0 km/h
                    Voltage: 13.91 V
                    Lambda: 100.2 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
                    Mileage: 147489 km
                    Date: 2037.14.26
                    Time: 09:37:22
                    RPM: 3082 /min
                    Speed: 98.0 km/h
                    Load: 0.0 %
                    Voltage: 13.91 V
                    Voltage: 0.684 V
                    Voltage: 0.304 V
                    Bin. Bits:  1 01  0
                    Mileage: 147489 km
                    Date: 2037.14.26
                    Time: 09:37:22
                    RPM: 2944 /min
                    Speed: 97.0 km/h
                    Load: 0.0 %
                    Voltage: 13.83 V
                    Temperature: 80.1C
                    (no units): 0.0
                    Torque: 0.0 Nm
                    Mileage: 147492 km
                    Date: 2037.14.26
                    Time: 09:44:18
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 495.0 mg/str
                    Temperature: 78.3C
                    Mileage: 147492 km
                    Date: 2037.14.26
                    Time: 09:44:18
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 100.2 %
                    Temperature: 186.0C
                    Temperature: 78.3C
I don't know another way to share log besides convert to pdf and upload to Google drive.
Since .CSV is just text, you can open it with Notepad and paste the contents here.
But the best thing for large logs like that one might be to put it in a Google Spreadsheet, share it, and link it here.
VAG_Tech
Verified VCDS-User
Canada
C?ID=73044
Reviving thread, Any updates on a fix for this? Did an engine control unit repair the problem? Thanks.
JMR
Romania
C?ID=432218
001601 - Sensor Reference Voltage A P0641 - 000 - Open Circuit - MIL ON
oooo....the lovely reference voltage. :) Read through , look for it on the forums, we have had errors on sensor A , B , C , D ..all of which have been resolved. You need to do a bit of work though :)
