Car is occasionally studdering. It gave me a camshaft position sensor code and a throttle body code with limp mode. Cleaned and lubed throttle body thought all is well. 2000 miles later the cam shift position sensor code went on without a check engine light up or any issues. The next day on my way to work the car started shuddering real bad while just driving normal, tried to accelerate and limp mode again with a bunch of other codes. Maybe bad camshaft sensor or a bad wiring harness? Ecu? What do you think?
Thursday,21,May,2020,13:38:12:38103
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWPL7AJ1BM667128 License Plate:
Mileage: 146370km-90950mi Repair Order:
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 B HW: 03L 906 019 DA
Component and/or Version: R4 2.0l TDI G000AG 9983
Software Coding: 0050078
Work Shop Code: WSC 13327 002 1048576
VCID: 2D070B6891187313C8D-8078
7 Faults Found:
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Fault Frequency: 53
Mileage: 146258 km
Date: 2020.05.20
Time: 12:22:30
RPM: 3473 /min
Speed: 74.0 km/h
Voltage: 14.06 V
Temperature: 77.4C
Idle Stabilization: -2.7KW
RPM: 1721 /min
(no units): 48.0
001151 - Exhaust Pressure Control Valve
P047F - 000 - Stuck Open - Intermittent
Mileage: 146310 km
Date: 2020.05.21
Time: 02:40:29
RPM: 2139 /min
Speed: 109.0 km/h
Load: 47.1 %
Load: 21.6 %
Lambda: 26.8 %
Temperature: 384.0C
Temperature: 79.2C
001162 - Exhaust Pressure Control Valve 1
P048A - 000 - Stuck Closed - Intermittent
Mileage: 146310 km
Date: 2020.05.21
Time: 02:40:29
RPM: 2162 /min
Speed: 109.0 km/h
Load: 44.3 %
Load: 100.0 %
Lambda: 52.9 %
Temperature: 384.0C
Temperature: 79.2C
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - Intermittent
Mileage: 146316 km
Date: 2020.05.21
Time: 02:44:23
RPM: 2162 /min
Speed: 110.0 km/h
Load: 45.1 %
Load: 100.0 %
Lambda: 11.8 %
Mass Air / Rev.: 735.0 mg/str
Temperature: 81.0C
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed - Intermittent
Mileage: 146316 km
Date: 2020.05.21
Time: 02:44:23
RPM: 2162 /min
Speed: 110.0 km/h
Load: 45.1 %
Load: 100.0 %
Lambda: 42.6 %
Mass Air / Rev.: 740.0 mg/str
Temperature: 81.0C
001601 - Sensor Reference Voltage A
P0641 - 000 - Open Circuit - Intermittent
Mileage: 146299 km
Date: 2020.05.21
Time: 02:31:26
RPM: 1978 /min
Speed: 100.0 km/h
Load: 38.0 %
Voltage: 13.60 V
Temperature: 81.9C
(no units): 0.0
Torque: 105.0 Nm
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 001 - Implausible Correlation - Intermittent
Fault Status: 00100001
Mileage: 146323 km
Date: 2020.05.21
Time: 02:48:54
RPM: 1495 /min
Speed: 75.0 km/h
Load: 39.2 %
Voltage: 13.68 V
Voltage: 0.836 V
Voltage: 0.988 V
Bin. Bits: 1 00 0
