Wednesday,20,May,2020,11:25:13:28697
VCDS Version: 20.4.1.0
VIN: WVWZZZ1KZBW044224 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 62 72
77
VIN: WVWZZZ1KZBW044224 Mileage: 259900km-161494miles
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BC HW: 03L 907 309 R
Component: R4 2.0l TDI H21 9979
Revision: 42H21--- Serial number: 00000000000000
Coding: 001D0012042400080000
Shop #: WSC 00165 211 00000
ASAM Dataset: EV_ECM20TDI01103L906018BC 003010
ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
VCID: 6CDCD40587FBEEE6C7-8038
4891 - EGR Valve (N18)
P0403 00 [039] - Malfunction
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:14
Engine speed: 781.00 /min
Normed load value: 28.2 %
Coolant temperature: 73 °C
Intake air temperature: 44 °C
Voltage terminal 30: 13.940 V
Air mass: actual value (mg/stroke): 422.5 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 105.03 %
EGR valve: offset closed: 4.97 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 7
Actuator for high pressure EGR: status-Bits 0-7: 51
High press EGR actuator: actual unconditioned volt val: 679.2 mV
4892 - EGR Valve (N18)
P0403 00 [167] - Malfunction
Mileage: 259901 km
Date: 2020.05.20
Time: 00:20:52
Engine speed: 783.00 /min
Normed load value: 34.9 %
Coolant temperature: 76 °C
Voltage terminal 30: 13.880 V
Air mass: actual value (mg/stroke): 338.4 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
EGR Solen.val.: actual value: 49.79 %
High press EGR actuator: actual unconditioned volt val: 2357.6 mV
Part No SW: 02E 300 052 H HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2256
Revision: 05151112 Serial number: 00001006171259
VCID: 1932DDD1D0E9AB4EEC-804C
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
VCID: 040C9CA5876B06A62F-8050
03306 - Coding Not Valid
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.19
Time: 23:02:37
Count: 3
Count: 14
Count: 12800
Count: 4161
Count: 50432
Count: 64768
00003 - Control Module
Fault Status: 01100101
Reset counter: 27
Mileage: 259901 km
Date: 2020.05.19
Time: 22:18:33
Count: 3
Count: 12
Count: 12800
Count: 143
Count: 50432
Count: 59904
Count: 65280
Reset counter: 27
Date: 2020.05.19
Time: 22:19:22
Count: 7
Count: 12
Count: 4608
Count: 195
Count: 50688
Count: 1536
Reset counter: 27
Date: 2020.05.19
Time: 22:19:22
Count: 7
Count: 12
Count: 4608
Count: 320
Count: 50688
Count: 1536
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
VCID: 7DFAE941EC81776E60-8028
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:14
B10AB F0 [009] - Too Low
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:14
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40180A3A88251AC0408800843400092443550088736D8160648000200040
VCID: 387438558B239246F3-806C
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 27061 21 0512
Coding: 009795
Component: RLS 260610 05 54 0403
Coding: 0330AD
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:14
Voltage: 13.80 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12991011138539
Coding: 100103
VCID: 3668366D81376436E1-8062
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA9SY8P
Coding: 00003132
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7E2759B215B95E1E-806E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME646C1455ZZZ-
Component: S.Sens.Beif.V U01 ----
Serial number: 3582MSME33272541ZZZL
Serial number: 3512QSME3E276451ZZZX
Serial number: 3522QSME30276451ZZZK
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JFG000VJ
Coding: 1892140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E8F66DC9B7243621-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0007729
Coding: 830000
Part No SW: 5K6 920 871 A HW: 5K6 920 871 A
Component: KOMBI H04 0406
Coding: 170D01
VCID: 32600A7D655F7816CD-8066
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 270610F2001136
Coding: EDA17F0640060200000002
VCID: 6DDAD90174E1E7EED0-8038
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:16
Component: IMMO H04 0406
VCID: 6AD0D21D8D0FF0D6B5-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H53 SZ01
Serial number: VWZAZ2M4686457
Coding: 000104110400000000021000
Shop #: WSC 00259 116 58746
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: 60C4B0357B33BA866B-8034
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:15
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:15
Correction for sound system: OK
CD changer: OK
Status of antenna 2 for radio: OK
Digital radio (DAB): OK
Antenna diagnostic: OK
Telephone baseplate diagnostic: OK
Speaker status: OK
Rearview camera: OK
Telephone Transceiver: ERROR
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2113
Coding: 0004278
VCID: 32600A7DAD5F7816CD-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 31620571A859430EB4-8064
Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
Component: Tuer-SG 008 2015
Coding: 0000052
VCID: 7AF0E25D35AF405645-802E
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Component: AFS-Steuergeraet 0142
Coding: 1442908
VCID: 346C0C65574B7626DF-8060
Subsystem 1 - Part No: 4F0 941 329 D Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0010
Coding: 00000031
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
02233 - Left Headlight Power Output Stage (J667)
014 - Defective - MIL ON
Fault Status: 11101110
Reset counter: 28
Mileage: 259901 km
Date: 2020.05.20
Time: 00:11:15
Voltage: 13.77 V
ABS 1
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 28
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 28
Invalid
Invalid
Invalid
Fault Status: 11100101
Reset counter: 28
Invalid
Invalid
Invalid
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 356A31615C316F2EE8-8060
Address 72: Door, Rear Right
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668233662
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 316205716059430EB4-8064
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
U1400 00 [000] - -
End-------------------------(Elapsed Time: 03:08)--------------------------
