had a 2019 Golf in with a Component Protection fault on the Distance regulation (item was replaced with a used one).
Car was involved in a minor accident causing front end damage. Headlights front bumper etc was replaced but nothing else.
The fault i am having is 16411 - Display For Tire Pressure Monitoring - C1146 02 - Signal failure
I believe because of this i am getting the other databus error faults.
The wheels have also been changed, but i have been assured that the new wheels have the TPMS sensors installed.
I have used GeKo to complete the CP removal and i have also recoded all modules back to factory but it hasn't changed anything.
I have the scan from ODIS also.
Any help is much appreciated!
Friday,08,May,2020,21:22:34:08713
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZKP557632 License Plate: CA19 OAX
Mileage: 8067km-5012mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 42 44 4B 52 5F
75 A5 A9 D6 D7
VIN: WVWZZZAUZKP557632 Mileage: 8067km-5012miles
4B-Multifunc. Module -- Status: Malfunction 0010
Address 01: Engine (J623-DNUE) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 R HW: 06K 907 425 J
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 092540122466050B3000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
ROD: EV_ECM20TFS0208V0906259R_VW37.rod
VCID: 4FEE8D1B16FF25FECB-801A
23176 - Sensor for Ambient Air Temperature (G17)
P0070 00 [039] - Malfunction
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:35
Coolant temperature: 78 °C
Intake air temperature: 44 °C
Voltage terminal 30: 13.105 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
FAC_TPS_1_SAE: 15.625000 %
FUP_H_SAE: 13590.0 kPa
16803 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [039] - -
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:36
ECU_STATE: ENG_STOP
Engine oil temperature: 84.0 °C
Time since engine start: 0.0 s
T_ES: 8 min
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Main switch CAN: not activated
T_AST_SAE: 0 s
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2403
Revision: 00H06V08
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061.rod
VCID: 240412B72FF9F6A646-8070
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 60339000003335
Coding: 04FA93A150252173477D070360C56920C90A84E2E006967738425078D2284B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 79BA13C3F8FB5B4E45-802C
16411 - Display for Tire Pressure Monitoring
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:24
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0506014156
Coding: 132C0C0723
Shop #: WSC 00028 028 00067
ROD: EV_KessyHellaMQBAB.rod
VCID: 43C6B12BCAB7D19E5F-8016
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0212000420011001110500000010102A
VCID: 6D923793BCB3F7EED9-8038
459527 - Databus
[Klima_Sensor_02 - empfangener Fehlerwert]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:41
Part No SW: 5Q0 937 086 BQ HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: 8658010219006R
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 0A585C0FAD1D40D65C-805E
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 190121 042 0551
Serial number: 190129175439
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY19M02D13H23M07S08
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY190020SKZ
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000046362052
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100110220190C100233
137217 - Outside temperature sensor
B103F 1B [137] - Resistance Too High
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:42
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Serial number: 000308418019037
Coding: 0471151811
VCID: 4CD49A17E7E91EE6AE-8018
13637888 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:46
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 330067C159FFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E30C0DFA155BC7630-806A
1395 - Databus
[FAULT_TEMP_FAIL]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:41
Control Module temperature: 44 °C
Voltage terminal 15: 12.9 V
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 007 0403
Serial number: 003FNR519CS.
Shop #: WSC 00028 028 00058
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 1366416BFA57811EAF-8046
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E11021921241
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E11021920783
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 502 19
Serial number: 35700000000FC964593Z
Subsystem 4 - Part No SW: ----------- HW: 480 000 302 19
Serial number: 3580000000029348C83M
Subsystem 5 - Part No SW: ----------- HW: 480 401 102 19
Component: SideSensor_Dr 004 6149
Serial number: 35100010C2BF8CC234EJ
Subsystem 6 - Part No SW: ----------- HW: 480 401 102 19
Component: SideSensor_Pr 003 6149
Serial number: 35200019F2DA6D71542C
Subsystem 7 - Part No SW: ----------- HW: 480 400 102 19
Component: FrontSensor_D 004 6149
Serial number: 3550001162B70F5163B$
1054981 - Databus
[NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:44
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 27AD60186F84060001886B031401000800000000
VCID: 2B16F98B422739DE87-807E
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:41
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 09011910802917
Coding: 030100047F085900FB00827E1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E90309FB1B50CF6E0-803A
Component: 1-01-13-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29190000347520039071
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8708440405
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00014.01.19
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47DEA53BFE8FFDBE83-8012
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000020908015
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 312AEBE3600B530EBD-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000363808157
Coding: 003F1220D001048000001000
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 48DCA607F391F2C68A-801C
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000011344068
Coding: 0D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C34CAD7B749AE661E-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 01021910520649
Coding: 00000005090019D601204F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3522DFF394637F2EE1-8060
13706008 - Databus
[KBI_Aussen_Temp_gef received error value]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:41
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000364767969
Coding: 003F1020DE01048000001000
ROD: EV_DCU2PasseSideMAXHKLO.rod
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000011351992
Coding: 050000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Coding: 02731201FF00000041110101008808001F0507F6012000008E
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 3228E4EF650D6816C4-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHW0454504
Subsystem 2 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 02730201EA42180D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3D32C7D3AC53A76E29-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 23101815K22480
Coding: 0003070200000401000213448150A90094000E300040
1123175 - Databus
[Gateway_72_BCM1_Aussen_Temp_ungef]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:42
Control Module temperature: 42 °C
Outside air temperature: 77.5 °C
Vehicle speed: 0.00 km/h
System run time: 510.1 s
Voltage terminal 15: 13.1 V
mid: 02 8D
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1123184 - Databus
[Kombi_02_KBI_Aussen_Temp_gef]
Reset counter: 216
Mileage: 8067 km
Date: 2020.05.08
Time: 21:13:45
System run time: 513.3 s
mid: 02 E2
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 190111202070
VCID: 2F2EED9B763F45FEAB-807A
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 393AD3C3B87B9B4E05-806C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:53, VBatt start/end: 13.1V/14.4V)-----------
