2019 VW Golf TPMS Error
m3nt4l
C?ID=348982
had a 2019 Golf in with a Component Protection fault on the Distance regulation (item was replaced with a used one).
Car was involved in a minor accident causing front end damage. Headlights front bumper etc was replaced but nothing else.
The fault i am having is 16411 - Display For Tire Pressure Monitoring - C1146 02 - Signal failure
I believe because of this i am getting the other databus error faults.
The wheels have also been changed, but i have been assured that the new wheels have the TPMS sensors installed.
I have used GeKo to complete the CP removal and i have also recoded all modules back to factory but it hasn't changed anything.
I have the scan from ODIS also.
Any help is much appreciated!
Friday,08,May,2020,21:22:34:08713
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZKP557632   License Plate: CA19 OAX
Mileage: 8067km-5012mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 42 44 4B 52 5F
          75 A5 A9 D6 D7
VIN: WVWZZZAUZKP557632   Mileage: 8067km-5012miles
Address 01: Engine (J623-DNUE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 R    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 092540122466050B3000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
   ROD: EV_ECM20TFS0208V0906259R_VW37.rod
   VCID: 4FEE8D1B16FF25FECB-801A
23176 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [039] - Malfunction
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:35
                    Engine speed: 0.00 /min
                    Coolant temperature: 78 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 13.105 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 13590.0 kPa
16803 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [039] - -
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:36
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 84.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 8 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    T_AST_SAE: 0 s
Readiness: 1110 0001
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V08
   ROD: EV_TCMDQ381061.rod
   VCID: 240412B72FF9F6A646-8070
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60339000003335
   Coding: 04FA93A150252173477D070360C56920C90A84E2E006967738425078D2284B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79BA13C3F8FB5B4E45-802C
16411 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:24
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0506014156
   Coding: 132C0C0723
   Shop #: WSC 00028 028 00067
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C6B12BCAB7D19E5F-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0212000420011001110500000010102A
   VCID: 6D923793BCB3F7EED9-8038
   Air quality sensor:
459527 - Databus
          [Klima_Sensor_02 - empfangener Fehlerwert]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:41
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658010219006R
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0A585C0FAD1D40D65C-805E
   Component: WWS    190121  042 0551
   Serial number:         190129175439
   Component: RLHS  052 0107
   Serial number: SBY19M02D13H23M07S08
   Coding: 00A8DD
   Serial number: 000000000ZY190020SKZ
   Serial number: 00000000000046362052
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100110220190C100233
137217 - Outside temperature sensor
          B103F 1B [137] - Resistance Too High
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:42
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019037
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD49A17E7E91EE6AE-8018
13637888 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:46
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C159FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E30C0DFA155BC7630-806A
1395 - Databus
          [FAULT_TEMP_FAIL]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:41
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 12.9 V
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR519CS.
   Shop #: WSC 00028 028 00058
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1366416BFA57811EAF-8046
   Belt Pretensioner left:
   Serial number: 34169677E11021921241
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E11021920783
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 502 19
   Serial number: 35700000000FC964593Z
   Subsystem 4 - Part No SW: -----------    HW: 480 000 302 19
   Serial number: 3580000000029348C83M
   Subsystem 5 - Part No SW: -----------    HW: 480 401 102 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010C2BF8CC234EJ
   Subsystem 6 - Part No SW: -----------    HW: 480 401 102 19
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019F2DA6D71542C
   Subsystem 7 - Part No SW: -----------    HW: 480 400 102 19
   Serial number: 3550001162B70F5163B$
1054981 - Databus
          [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:44
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27AD60186F84060001886B031401000800000000
   VCID: 2B16F98B422739DE87-807E
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:41
   Serial number: 09011910802917
   Coding: 030100047F085900FB00827E1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90309FB1B50CF6E0-803A
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000347520039071
   Coding: 2DFFFF
   Serial number: 8708440405
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00014.01.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47DEA53BFE8FFDBE83-8012
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000020908015
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312AEBE3600B530EBD-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000363808157
   Coding: 003F1220D001048000001000
   VCID: 48DCA607F391F2C68A-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000011344068
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C34CAD7B749AE661E-8068
   Component: FCM MQB Low   002 0345
   Serial number: 01021910520649
   Coding: 00000005090019D601204F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522DFF394637F2EE1-8060
13706008 - Databus
          [KBI_Aussen_Temp_gef received error value]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:41
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000364767969
   Coding: 003F1020DE01048000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000011351992
   Coding: 050000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Coding: 02731201FF00000041110101008808001F0507F6012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3228E4EF650D6816C4-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0454504
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02730201EA42180D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D32C7D3AC53A76E29-8068
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 23101815K22480
   Coding: 0003070200000401000213448150A90094000E300040
1123175 - Databus
          [Gateway_72_BCM1_Aussen_Temp_ungef]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:42
                    Control Module temperature: 42 °C
                    Outside air temperature: 77.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 510.1 s
                    Voltage terminal 15: 13.1 V
                    mid: 02 8D
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123184 - Databus
          [Kombi_02_KBI_Aussen_Temp_gef]
                    Reset counter: 216
                    Mileage: 8067 km
                    Date: 2020.05.08
                    Time: 21:13:45
                    System run time: 513.3 s
                    mid: 02 E2
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190111202070
   VCID: 2F2EED9B763F45FEAB-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393AD3C3B87B9B4E05-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:53, VBatt start/end: 13.1V/14.4V)-----------
^^^ hmm......... MQB vehicles with "real" TPMS (meaning not "indirect" TPMS) usually have a Tyre Pressure Monitoring System control unit which the manufacturer calls J502. The module usually lives @ address hex 65 on the CAN network and a typical response from a VCDS auto-scan looks like this:
   Serial number: 40000000018297
   ROD: EV_RDKBERU30_005.rod
   VCID: B42497EF1F6EF9EA89-80E0
Alas, your auto-scan doesn't report a J502 module -with no offense intended, why do you believe that the car doesn't have indirect TPMS (i.e, the TPMS system without pressure transducers on the tire stem caps on the wheels)?
m3nt4l
C?ID=348982
Thank you. I will do some more digging and see what i can find! At the moment its lit up with numerous functions not being available.
+1, Direct TPMS does not exist on Golf unless retrofitted.
That's not quite universally true. In the NAR market, there were definitely Golfs sold for a period 10-12 years ago that had direct TPMS.
That was because TPMS was a required safety feature here and the indirect systems were not yet sufficiently developed to meet the performance requirement. I expect the problem was the ability to detect equal under-inflation of all four tires. I still don't fully understand how they manage to do that with an indirect system, but somehow, at around MY 2011, they did.
m3nt4l
C?ID=348982
I cannot for the life of me see what may be the issue.
I can see the coding states it has INDIRECT TPMS and I’ve tried to reset the tire pressure through basic settings - the factory reset of tire pressure finished correctly but the other warning display basic setting said out of range.
Anyone have any thoughts of what to check next?
NEtech
Denmark
C?ID=56995
I would fix the problem with Ambient Air Temperature sensor (G17).
And then do a tire pressure reset as described in the car manual.
What basic setting?
darkchina811
ITALY
C?ID=333184
I meant MK7 only...
m3nt4l
C?ID=348982
Thank you i will do this and report back!
Rollux
New Zealand
C?ID=380572
I agree with Don, I think you have indirect TPMS as the ABS module is reporting the error. Check the coding and set to indirect and your error should go away.
dnoermann
C?ID=358118
Like the others already said in your Car probably there is only the "Indirect TMPS" installed, you dont need wheels with the Sensor.
Thanks to @Somnus you can find here the exel sheet which helps you decode the ABS Coding. (https://forums.ross-tech.com/showthread.php?17417-MK100-ABS-Coding&p=178255&viewfull=1#post178255)
Probably you have a wrong coding regarding TPMS in ABS.
Looking into your Byte 27
0x78 ==> 01111000 ==> Bit 4, 5 & 6 checked Direct TPMS w/ Radio (PR. 7K1+I8A/I8B/I8D/I8E/I8H)
That is wrong, the ABS Thinks that a Active TPMS is there but it is missing.
So now you have to find out the Error:
1. You really don’t have Direct TPMS than correct the ABS coding
one of this will be the right
Bit 4 & 5 checked Indirect TPMS w/ Radio (PR. 7K9+I8A/I8B/I8D/I8E/I8H)
Bit 4 & 6 checked Indirect TPMS w/ Radio (PR. 7K6+I8A/I8B/I8D/I8E/I8F/I8H)
2. If you have Direct TPMS than the Address 65: Tire Pressure (J502) Module is broken or lost connection to Power or Can, but still the Gateway Config is than wrong, too
Just let someone do a PR Code Lookup with your vin, than you know what was in the Car when it was produced.
Greats
Dennis
Good idea. Full PR-code list:
Vehicle Identification No.WVWZZZAUZKP557632
ModelGolf Variant 2.0 GOLF
Date of production26.02.2019
Model year2019
Sales typeBV5RXH
Engine CodeDNUE
Transmission CodeUAQ
Axle drive7A
EquipmentTW
Roof color0Q
Carpet color code
Exterior color / Paint Code0Q / C9A
Seat combination no.
Number of Z-Orders
Special editionsE0ANo special edition
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation powertrains/platform parts7LGVehicle class differentiation -5G0-
Tailpipes0P4Exhaust tailpipe, double-flow
Emission standard7CSEmission standard EU6 BG
Trailer hitch1D0Without trailer hitch
airbag4UPAirbag on driver and front passenger side, knee airbag on driver/front pass. side, with front pass. airbag deactivat.
Activated carbon canister/gasoline particulate filter1E5Activated carbon canister (Evaporative Emission Control System (EVAP))
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror adjustment6XQExterior mirrors with memory feature, power-folding/adjustable, separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Electronic engine sound measuresGM1Standard electronic engine sound
Right exterior mirror5RVRight exterior mirror, aspherical
Alternative drive system0K0Without alternative drive system
Drive type1X1Four-wheel drive
Multimedia/video/DVD/notebook connection9WXMirror Link and wireless RSE "App"
Equipment linesA9RTop sports
Stopping distance reduction system6K4Forward collision warning incl. autonomous emergency braking, for adaptive cruise control "high"
Rear brakes1KYDisc brakes in rear
batteriesJ0TBattery 360 A (69 Ah)
Front brakes1LMDisc brakes in front
Components with special surface6FHExterior mirror housings painted
Battery/alternator capacitiesNY0Standard battery/alternator capacity
Component sets for country-specific prescriptive standardsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ASElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD-ROM/DVD/SD card7RESD card (Europe)
Driving mode selection2H5Driving profile selection and conventional shock absorber
Chrome packageQJ3Chrome package (type 2)
General operating license additionsC35Operating permit, alteration
Roof rails/roof rack3S1Bright roof rails
Roof insert/convertible top3FAWithout roof insert (standard roof)
Shock absorption in rearUA1Rear shock absorption
Shock absorption in frontG28Shock absorption in front
Differential lock1Y3Electronic differential lock XDS, dynamic traction support
Eco feature for driver profile and driving mode selectionEF1ECO function
Installation differentiation for vehicle parts0IJInstallation differentiation for transmission DQ381 -- vehicle components --
Theft protection system7ASAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5TDDecorative aluminum inserts
Scuff plates7M7Scuff plates in door apertures
Park distance control7X2Park distance control in front and rear
Extended safety system7W1With extended safety system (proactive passenger protection system)
Electric interface for external use UI5External, USB type A, 1x USB socket
Differentiation for manufacturing process0FGMosel manufacturing sequence
Adhesive film51AWithout adhesive film
window regulator4R4Power windows with comfort operation and circuit breaker
Fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL3Extended and proactive pedestrian protection
Pedal clusterVF1pedal cluster
Headlight activation8K3Separate daytime running light with automatic headlight control and manual Coming and Leaving Home feature
Fresh air intake for vehicle interior (with particle filter)2V5Fresh air intake system with combination filter
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category for rear axle0YBWeight range 2 installation control only, no requirement forecast
Weight category for front axleL34Suspension range 34 installation control only, no requirement forecast
Base engineTT64-cylinder SI engine 2.0 l unit 06K.C
cruise control system8T8Adaptive cruise control (with "follow-to-stop") and speed limiter
Transmission specificationG1D7-speed automatic transmission for four-wheel drive
Speed alert system/speed limiter6Y8Speed limiter
Rear spoiler5J0Without rear spoiler
Wiper and washer system for rear windows8M1Rear window wiper and washer system with intermittent control
Rear axle0N44-link rear suspension
Molded headliner6NWUnsplit molded headliner
Rear seats3NUUnsplit rear seat bench, split folding backrest, with center armrest
Heating system/air conditioning system9AKClimatronic with impact pressure control, CFC-free
Main headlamps8IULED headlamps with variable light distribution
Hybrid drive20AWithout electric motor (hybrid)
Customized installationFC1Customized installation
Interior lighting in footwell6T1Interior lighting in footwell
Dashboard insertsU5BInstrument cluster, mph speedometer -Great Britain-
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body formsK8DWagon/Avant
Camera/distance sensorQK1With multifunction camera
Cool box1W2Glove compartment cooling system
Folding table1U8W/o folding table on front seat backrest
Climate zones0Y1Standard climatic zones
Compass/road sign displayQR9Mit Verkehrszeichenerkennung
Head restraints in rear3T2Three rear head restraints
Head restraints5ZFFront head restraints
Fuel filling volume1Z2Increase in initial standard fuel filling
Categorization for tiresA60Category 0
Fuel systems1A7Fuel system for fuel-injected SI engine (tropicalized)
Body measures5C0Without special body measures
Camera systems/surround sensorsKA1With rear view camera system (type 1)
Radiator grille6KQRadiator grille
refrigerantKK3Kältemittel R1234yf
License plate lightingKL1LED license plate lighting
License plate carrier31FFront license plate carrier (large)
Paint preservation/transport protection5K7Transport protection film (minimum protection) with additional transport protection measures
Paint finishFB0standard paint coating
Lighting package (lighting)QQ3Interior ambient lighting and surround lighting
Vehicle inletsES0Without vehicle inlet
Steering system setupL0RRight-hand drive
Reading lamp8S62 reading lights in front
Steering system1N7Dynamic steering
Backrest release3H0Without backrest release for front seats
Curb weight rangeIG9Without curb weight range
Light assist systems8G3Maskiertes Dauerfernlicht
Charging cableEV0Without charging cable
Lumbar support in backrests7P4Manually adjustable lumbar support in front seats
steering wheels2FWLeather-wrapped multi-function sports steering wheel with tiptronic
Driving on the left/right sideAV0Driving on the left
Loudspeaker installation8RM8 speakers (passive)
Headlight range control8Q5Dynamic headlight range control, with cornering light (AFS 1)
Center armrest6E3Center armrest in front
VariantsFM0Basic equipment variant
Multi-function display/trip computer9S8Multi-function display/on-trip computer - active info display
Center console3D3Center console
Driver alert systemEM1Driver alert system
Engine cooling8Z5Not hot country
Engine specificationDS44-cylinder SI engine 2.0 l/221 kW TFSI, homogeneous base engine is TT6/T3W
Navigation system7UFNavigation system - Standard
rear fog lamp8TBrear fog lamp
Front fog lamps/additional headlamps8WGCornering lamp
Online servicesEL5Online service, with OCU, with head unit coding, without engine immobilizer interconnection
Model upgrade measuresGP1Vehicles with special upgrade measures
Rear floor panel platform module4P3Rear floor panel module, type 4
Wheel trims1NLTrims for alloy wheels
WheelsC2KAlloy wheels 7.5J x 18
RadiosI8FStandard radio (Gen2 GP)
Smoker's/non-smoker's version9JANon smoker version
Regional codes for radioER1Regional code " ECE " for radio
Tire pressure monitoring system7K1Tire pressure monitoring system
tireH7DTires 225/40 R18 92Y xl
Tire suppliersV1PTire suppliers for EU countries
Spare wheel/breakdown kit1G9Space-saving spare wheel for temporary use, radial tire (5-hole)
Wheelbases0B1Wheelbase
Restraint systems in front3QT3-point seat belts in front, with pretensioner and height adjustment
Call featureNZ4Private emergency call system
P23VE: Lane Assist/Dynamic Light Assist with Dynamic Road Sign Display
PF3Adaptive Cruise Control ACC stop & go up to 210 km/h, incl. Front Assist with Pedestrian Monitoring
PLALights & Vision package
PNDNavigation feature "Discover Media" (for "Composition Media")
PXCLED headlamps incl. dynamic cornering light for advanced high-beam control Dynamic Light Assist
W8QAustria: Golf wagon R Edition
WW1Winter package
Y9XProcess S
YOZGuide & Inform and Security & Service Plus, contract duration: 3 years, incl. Security & Service Basic
ZEDRadio "Composition Media" incl. 8ZH
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/gearshift handle6Q6Gearshift knob/handle in aluminum
Special labels0SCLabels in English
Tail lamp assemblies8SPLED rear combination lamp
Service indicatorQI6Service indicator 30 000 km or 2 years ( variable )
Seat belt reminder9P3Seat belt reminder, electric contact in buckle
Outer seat belts in rear3ZB3-point seat belts, outer rear with ECE label
Center seat belts in rear3C73-point seat belt for center rear seat
seat coversN0LSeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3Seat heater for front seats separately controlled
Start-stop system/regenerative braking7L6Start-stop system with regenerative braking
Horns8Y1Two-tone horn
sun visors5XJSun visors with mirror, illuminated, with airbag label on sun visor and B-pillar
Voice control system/voice controlQH0without voice control
Lane change system/lane keeping system7Y4Lane keeping system
Side and rear windows4KFSide windows in heat-insulating glass, from B-pillar and rear window dark tinted
Outlet7B212 volt socket in luggage compartment
Bumper2JFPainted bumpers
Rear stabilizer bar0BFRear stabilizer bar
Front stabilizer bar0AFFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Headlamp washer system8X1Headlamp washer system
Intermittent windshield wiper control/ light/rain sensor8N6Windshield wiper intermittent control with light/rain sensor
Nameplate set0PJNameplate set "R"
Counterweights for steering wheels1Q2Mass damper for steering wheel, 36 Hz
Door and tailgate/trunk lid locking mechanism4F2Central locking system "Keyless Entry"
Type-approval testing countries/ countries with specific requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Trägerfrequenz 433,92 bis 434,42 MHz
Partition3CAWithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQV3Digitaler Radioempfang
Front-end underbody cladding1SAWithout additional front underbody guard
Identification labels1EXSpecial identification label for EC for M1 passenger vehicles
Delivery equipment2A0Without delivery equipment
First aid kit/warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Front seatsQ4PSports front seats
Rear seat catchUK3Mechanical rear seat release
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone/telematics9ZXMobile phone interface
Additional warning lamps9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Thermal energy storage system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAOhne zusätzliche Bereifung
floor mats0TDFloor mats in front and rear
Additional child seat anchorage3B4Child seat anchors for child seat system ISOFIX
Auxiliary heater9M0Without auxiliary heater/parking heater
7K1 is Indirect (ABS/WSS based) TPMS
P.S. I ran a search of that exact ECM# and got one Golf hit in our files. Luckily that user posted his (VCDS-Mobile) scan here in the past:
https://forums.ross-tech.com/showth...em-VCDS-Mobile&p=166517&viewfull=1#post166517
Similar Golf Variant, same ABS# as well with 7K1-Tire pressure monitoring system -and- PF3-Adaptive Cruise Control ACC stop & go up to 210 km/h, incl. Front Assist with Pedestrian Monitoring. For that reason his baseline ABS coding may be of assistance if something is goofed up on this Golf.
Somnus
SLC, USA
C?ID=215931
It definitely seems that 7K1 is indeed indirect based on the data seen so far. I'll have to update the language on my spreadsheet to hopefully remove any confusion
Somnus
SLC, USA
C?ID=215931
Looking at the auto-scan, it seems like the entire car is singularly unhappy with the ambient temp sensor. i'm not sure if that has a correlation with the TPMS, but fixing that fault could remove a rather large variable
dnoermann
C?ID=358118
Hehe ok the Data Basis was wrong here.
Than ABS is correctly coded, and your car only does have the Passive TPMS System.
Anyhow i think the Error in ABS is just meaning that ABS can talk to it's Display, in your case i would think the Display for TPMS is the Radio. Probably something wrong with it than.
m3nt4l
C?ID=348982
What basic setting?
This solved the issue.
Was a bad G17 sensor. As soon as it was replaced all lights are off!!
Just proves that one sensor can cause all those issues.
Somnus
SLC, USA
C?ID=215931
I'm glad you fixed the issue!
I wonder if the TPMS display error was in relation to a fault being stored in the Instrument Cluster, since the instrument cluster can display TPMS messages (Tire Pressure Low, Etc.).
I don't recall the source (SSP, repair manual, etc) but I have a fuzzy recollection that indirect TPMS requires a valid ambient air sensor reading prior to calibration. I believe it is also taken into consideration when WSS based discrepancies are detected in order to warn for low pressure properly .... but I would need to dig to locate the facts.
Either way, problems with Ambient air sensor readings can cause all kinds of issues such as AC compressor activation to stop, convertible roof system problems (For instance, the Eos won't even try to open the roof) and in this instance it prevented the indirect TPMS from resetting/calibrating.
I'm glad this one had a relatively good outcome and the fact that the thread helped clarify those TPMS versions for the coding spreadsheet is excellent! :thumbs:
