Hello all,
I am a long time time user; first time poster.
I have a 3.6L BLV that lost a timing chain at 113k miles. I found 2 bent intake valves and 4 bent exhaust valves.
I decided to purchase a used engine for replacement.
I now have 5,000 miles on engine since installing, but the lifters are sometimes noisy at idle.
In general, there is no noise upon starting, but once the engine is warm the lifters are ticking.
It also seems that the noise is more pronounced when the ambient temperature is cold, but I am not confident about this as it is still winter in Northern Maine and thus still waiting for warmer weather to test that theory.
Just barely pressing the gas pedal and lifting the idle speed, the ticking will go away. I have done multiple oil changes, but the ticking is still there.
So I decided to see if bumping up the idle speed would help keep the ticking at bay.
Unfortunately, I need a security access code for the engine module.
Is there anyone that can provide this? Or is this not an option with the BLV engine?
Many thanks in advance for any help and/or advice,
Corey
Corey
Sunday,08,March,2020,13:59:25:22024
VCDS Version: 19.6.2.2 (x64)
VIN: WVWVU73C77E002026 License Plate:
Mileage: 189620km-117824mi Repair Order: 2020.03.08
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
62 65 6D 72
VIN: WVWVU73C77E002026 Mileage: 189620km-117824miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 M HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2370
Revision: --H08--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 08193
VCID: 37773B75461B8CF754-8062
Part No SW: 09G 927 750 HK HW: 09G 927 750 AJ
Component: AQ 250 6F 1271
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 05050 444 89168
VCID: 010395AD585F0247AA-8054
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658498744
Coding: 0046544
Shop #: WSC 05311 000 00000
VCID: 30650069A3755BCF15-8064
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62C1BA21BD19B95FD3-8036
00710 - Defroster Flap Positioning Motor (V107)
Fault Frequency: 120
Reset counter: 226
Mileage: 184422 km
Date: 2019.11.24
Time: 11:18:18
00229 - Refrigerant Pressure
Fault Status: 00100001
Reset counter: 218
Mileage: 188834 km
Date: 2020.02.24
Time: 13:01:54
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002289050
Coding: F58C8F0340041A00400A00000F00000000285D435C0000
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 201006 003 0205
Coding: 00046997
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E0037794
VCID: 2B5F17058A53381720-807E
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0P AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PR12ERQ
Coding: 0012368
VCID: 2E591E11B9414D3F07-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000031SU9
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D2D625EQÿ†63
Subsystem 5 - Serial number: D625EQÿ†6342MSME0D2D671FTÿ†63
Subsystem 6 - Serial number: D671FTÿ†6351HTS63IK60AJ21ÿ†63
Subsystem 7 - Serial number: 60AJ21ÿ†6361HTS6I2I6B243Vÿ†63
Subsystem 8 - Serial number: 6B243Vÿ†63727TS6I2IIMNJ2 ÿ†63
Subsystem 9 - Serial number: IMNJ2 ÿ†63827TS61IKULHI21ÿ
Subsystem 10 - Serial number: ULHI21ÿ
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507P
Coding: 0002112
Component: E0221 006 0080
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
VCID: 336F0F65526360D768-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C0507C2
Coding: BFFD0F0CD32002
VCID: 2143F52DF89FE2478A-8074
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TPYVY02
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 E
Component: HALDEX 4Motion 0110
VCID: 2F670315BE4B44370C-807A
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 22607 444 05200
VCID: 2A51120185A9211FDB-807E
Component: ELV 029 0380
3C0905861J ELV 029 0380
02811 - Control Module for Electronic Steering Column Lock (J764)
Fault Status: 00101110
Reset counter: 212
Mileage: 188704 km
Date: 2020.02.20
Time: 19:40:52
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C5D14198F5D3F2F29-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0001463
Part No: 3C1 909 144 B
Component: EPS_ZFLS Kl.5 D04 1607
VCID: 244DFC39E78DF76FE1-8070
Component: KSG PQ46 RDK 041 0213
Coding: 13900E88D103067F1C04141FF00A8F0E081800
Shop #: WSC 05311 123 12345
00896 - Trunk Lock Unit (F256)
Reset counter: 81
Mileage: 185627 km
Date: 2019.12.18
Time: 09:59:35
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0001462
VCID: 387538494B05838F5D-806C
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
01487 - System Function Test
Reset counter: 230
Voltage: 11.90 V
Count: 100
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0018
Revision: 00016000 Serial number: VWZ5Z7E2029631
Coding: 0000010
Shop #: WSC 00028 028 00001
VCID: 2045F029F395EB4F85-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2505
Coding: 0000144
VCID: 3163056DA87F52C71A-8064
Component: RDK 0391
Coding: 0100101
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 H
Component: J605 HECKDECKEL 0405
Revision: 00H21001
Shop #: WSC 23250 384 715754
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0800H21001001A0095ÿ
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
VCID: 32610A61AD7969DF63-8066
End-------------------------(Elapsed Time: 02:19)--------------------------
