2007 VW Passat, [01]-Engine, security code needed
Corey
C?ID=2457
Hello all,
I am a long time time user; first time poster.
I have a 3.6L BLV that lost a timing chain at 113k miles. I found 2 bent intake valves and 4 bent exhaust valves.
I decided to purchase a used engine for replacement.
I now have 5,000 miles on engine since installing, but the lifters are sometimes noisy at idle.
In general, there is no noise upon starting, but once the engine is warm the lifters are ticking.
It also seems that the noise is more pronounced when the ambient temperature is cold, but I am not confident about this as it is still winter in Northern Maine and thus still waiting for warmer weather to test that theory.
Just barely pressing the gas pedal and lifting the idle speed, the ticking will go away. I have done multiple oil changes, but the ticking is still there.
So I decided to see if bumping up the idle speed would help keep the ticking at bay.
Unfortunately, I need a security access code for the engine module.
Is there anyone that can provide this? Or is this not an option with the BLV engine?
Many thanks in advance for any help and/or advice,
Corey
Sunday,08,March,2020,13:59:25:22024
VCDS Version: 19.6.2.2 (x64)
VIN: WVWVU73C77E002026   License Plate:
Mileage: 189620km-117824mi   Repair Order: 2020.03.08
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
          62 65 6D 72
VIN: WVWVU73C77E002026   Mileage: 189620km-117824miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 M    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 2370
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 08193
   VCID: 37773B75461B8CF754-8062
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
   Component: AQ 250 6F           1271
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 05050 444 89168
   VCID: 010395AD585F0247AA-8054
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0658498744
   Coding: 0046544
   Shop #: WSC 05311 000 00000
   VCID: 30650069A3755BCF15-8064
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 62C1BA21BD19B95FD3-8036
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Frequency: 120
                    Reset counter: 226
                    Mileage: 184422 km
                    Date: 2019.11.24
                    Time: 11:18:18
00229 - Refrigerant Pressure
                    Fault Status: 00100001
                    Reset counter: 218
                    Mileage: 188834 km
                    Date: 2020.02.24
                    Time: 13:01:54
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000002289050
   Coding: F58C8F0340041A00400A00000F00000000285D435C0000
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 201006 003  0205
   Coding: 00046997
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E0037794
   VCID: 2B5F17058A53381720-807E
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0P AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3PR12ERQ
   Coding: 0012368
   VCID: 2E591E11B9414D3F07-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000031SU9
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0D2D625EQÿ†63
   Subsystem 5 - Serial number: D625EQÿ†6342MSME0D2D671FTÿ†63
   Subsystem 6 - Serial number: D671FTÿ†6351HTS63IK60AJ21ÿ†63
   Subsystem 7 - Serial number: 60AJ21ÿ†6361HTS6I2I6B243Vÿ†63
   Subsystem 8 - Serial number: 6B243Vÿ†63727TS6I2IIMNJ2 ÿ†63
   Subsystem 9 - Serial number: IMNJ2 ÿ†63827TS61IKULHI21ÿ
   Subsystem 10 - Serial number: ULHI21ÿ
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507P
   Coding: 0002112
   Component: E0221           006 0080
01426 - Controls in Steering Wheel (E221)
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 336F0F65526360D768-8066
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C05C0507C2
   Coding: BFFD0F0CD32002
   VCID: 2143F52DF89FE2478A-8074
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TPYVY02
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 E
   Component: HALDEX 4Motion      0110
   Coding: 0000001
   VCID: 2F670315BE4B44370C-807A
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 22607 444 05200
   VCID: 2A51120185A9211FDB-807E
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 00101110
                    Reset counter: 212
                    Mileage: 188704 km
                    Date: 2020.02.20
                    Time: 19:40:52
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   VCID: 2C5D14198F5D3F2F29-8078
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2461
   Coding: 0001463
   Part No: 3C1 909 144 B
   Component: EPS_ZFLS Kl.5   D04 1607
   VCID: 244DFC39E78DF76FE1-8070
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D103067F1C04141FF00A8F0E081800
   Shop #: WSC 05311 123 12345
00896 - Trunk Lock Unit (F256)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 81
                    Mileage: 185627 km
                    Date: 2019.12.18
                    Time: 09:59:35
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0001462
   VCID: 387538494B05838F5D-806C
   Revision:   013
   Coding: 0000013
01487 - System Function Test
                    Reset counter: 230
                    Voltage: 11.90 V
                    Count: 100
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio PM6       016 0018
   Revision: 00016000    Serial number: VWZ5Z7E2029631
   Coding: 0000010
   Shop #: WSC 00028 028 00001
   VCID: 2045F029F395EB4F85-8074
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: 3163056DA87F52C71A-8064
   Component:    RDK              0391
   Coding: 0100101
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 H
   Component: J605  HECKDECKEL    0405
   Revision: 00H21001
   Shop #: WSC 23250 384 715754
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0800H21001001A0095ÿ
   Part No: 3C9 959 704 A
   Coding: 0000144
   VCID: 32610A61AD7969DF63-8066
End-------------------------(Elapsed Time: 02:19)--------------------------
TBAx
C?ID=287144
What action exactly requires you to enter a security code?
Corey
C?ID=2457
I am trying to adjust the idle speed.
Using adaptation channel 1
TBAx
C?ID=287144
Maybe the value you want to set is out of bounds?
There is however a widely accepted login code 12233, that often works in Engine modules and you could try.
12233 is pretty much a 4-cylinder TDI thing. I don't recall it ever working on any gasoline engine.
PS: There's another 3.6 guy asking more-or less the same question here.
TBAx
C?ID=287144
Thanks for the heads-up Uwe
Corey
C?ID=2457
Yes, i can confirm that code does not work; I have tried twice.
I will look in the other thread.
Thank you!
pokorneo
Czech Republic
C?ID=93296
Hey Corey,
i have the same problem with idle speed adjustment , you can try other code :
27971
79153
26281
45678
the code not help to me .
TOP priority , when you try enter code and not accepted , you must wait a 10 minits with open drivers door and ignition on , when you meny times wrong tries the time it will be extended to max 4 hours :(
when you find another security acces code, pls send me .
Thank you and good luck
Dietrich
South Africa
C?ID=311443
Hi
I saw another thread where they used code 26262. Maybe try this code and I hope you are lucky. I have the same issue with my 2007 VW Touareg 3.0 V6 TDi. All codes that I have tried does not work.
Let me know if this code works.
Good luck
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Why not try with ATF fluid and see what happens.
When engine hot put 100ml of regular ATF fluid , after that start car , get up to 1800prm and hold like that for 20 min(I usually stuck someting in gas pedal because your leg will be numb after 5 min).
After that drive car around the block and see do you have any lifter noise.
